Author Topic: [IC] Orca 60 OG | Magnet Mounted Premium 60 | 12/1/20 Updates  (Read 31035 times)
Offline Orca Builds
    • Orca Builds
« on: Mon, 19 October 2020, 20:07:07 »
Orca 60 OG
-Inspiration-
Mounting: The mounting of this board is inspired by the Lodestone designed by Jae/Flex.
Although I've always thought that the idea of a magnet mounted board would be cool, I never thought it was possible until I saw their design.
However, being an FPS guy, I wanted to create a magnet mounted board in a 60 format with slim bezels to allow additional room for my mouse.
Additionally, I've implemented my own unique solution for the magnets, plate alignment, and isolation.
Sound: Like many other 60 enthusiasts, my favorite sound signature of all time from a 60 has got to be the OTD 356 mini.
Though it would be impossible to recreate the sound profile without directly copying their design,
this was definitely the benchmark I was aiming for and I am quite pleased with the results.
Aesthetics: I am clearly influenced by the aesthetics of many great designs/designers from this community.
Some of the main influences include OTD, TGR, Keycult, Lin, ai03, RAMA, Quantrik, and LSJ just to name a few.
-Motivation-
The motivation behind the creation of this board is quite simple,
I wanted to create the ultimate typing experience in a premium yet minimal 60.
As my daily driver, this board has brought me an immeasurable amount of joy during these strange times and
now I'd like to share my creation with the rest of the community in hopes that it might bring you joy as well.
-Explanation-
4 N35 strip magnets are installed on the bottom case and 4 N35 strip magnets are installed on the protruding fins of the plate.
The magnets are oriented so that the like poles will be facing each other creating repulsion.
The fins of the plate fit into slots in the top case which are lined with Poron gasket.
The gaskets surrounding the perimeter of the plate fins are also lined with PTFE strips over the Poron gaskets
creating a plate guide that keeps the plate aligned, absorbs vibration, and provides isolation.
This allows for smooth and silent vertical movement while preventing any horizontal movement.
The result is a mounting solution that achieves a clean sound profile with 100% plate isolation and a forgiving typing experience.
-Specifications-
-  6061-T6 Aluminum case with a hand-sanded, glass bead-blasted, and anodized finish
-  316 Stainless steel weight raw with a hand-sanded and glass bead-blasted finish
-  5052 Aluminum full or half plate with a hand-sanded, glass bead-blasted, and anodized finish
-  N35 Neodymium magnet mounting solution with 2mm of plate travel/flex
-  WT60-C PCB in black
-  Genuine Poron polyurethane gaskets
-  Poron/PTFE plate guides
-  M2 Socket head black-oxide alloy steel screws
-  Genuine translucent 3M bumpons
- 7-degree typing angle
-  Low front height just under 18mm (under 20mm with 3M bumpons installed)
-  WKL only, split right shift only, full or split backspace, stepped or regular caps lock (can have full right shift if WT60-D is used)
-  Available in Obsidian Black, Anthracite Gray, or Palladium Silver
- ~3.4 Pounds or ~1540 grams fully built
- 25 unit limit to be raffled and this variant will never be offered again
- 1 unit per person
- $650
- CONUS only
-Contents-
-  1 x 6061-T6 Aluminum Top case
-  1 x 6061-T6 Bottom Case
-  1 x 316 Stainless Steel Weight
-  1 x 5052 Aluminum Plate (Full or Half)
-  1 x WT60-C PCB in black
-  8 x N35 Neodymium Magnets
-  4 x Slim Poron Gaskets
-  4 x Wide Poron Gaskets (to be used with PTFE strips as plate guides)
-  4 x PTFE plate guide strips
-  4 x 3M SJ5382 Bumpons
-  6 x M2 x 8mm Black Oxide Alloy Steel Socket Head Screws
-  6 x M2 x 3mm Black Oxide Alloy Steel Socket Head Screws
-  1 x Wera 3950 PKL Stainless Long Arm Ballpoint 1.5mm Hex Key
-Prototype-
After 3 iterations of prototypes, this is the final product. Over the course of prototyping, there have been various changes which include:
materials, surface finishing, magnets, size of screws, tolerances, fillets, chamfers, bumpons, size of weight, engraving, USB cutout, etc
Obsidian Black Prototype
-Other Colors-
Anthracite Gray
Palladium Silver
Note that these samples have gone through a different surface finishing procedure than the keyboard so it's likely that the board will come out in a much nicer color.
Also, these pictures were sent from our manufacturer hence the poor image quality.
-Typing Sounds / Flex Demonstration-
-Build Specs-
Plate: 5052 Aluminum Half Plate
Switches: Cherry MX Black (Krytox 205g0/Deskey Films)
Springs: Sprit 63.5 S (Krytox 106)
Stabilizers: Zeal (Krytox 205g0/206g2)
Keycaps: GMK Olivia++
-Notes-
- Magnets and Gaskets will be preinstalled
- Replacement Poron gasket strips, PTFE strips, and Magnets will be made available
- Option for zinc plated screws will be made available as well
- Plates will be anodized to match the choice of case color
- If you like crispy clacks I recommend a half plate
- If you like creamy thocks I recommend a full plate
- Half plate alphas have a more singular isolated feel and sound with a crisp bottom out
- Full plate alphas have great rebounding pop with softer typing feel and sound
- NGL this board feels amazing you need to try it
-Links-
Interest Check Form: https://docs.google.com/forms/d/e/1FAIpQLScqi6ksCldnsTxmhP2w6XM01QypcmV7hjJziN53xEwaO-LipA/viewform?usp=sf_link
Website: orcabuilds.com
Instagram: instagram.com/orcabuilds
Discord: discord.gg/JYumTqS
-Thank you-
- Thank you Jae/Flex for innovating and inspiring me
- Thanks Taeha for getting me into this hobby
- Thanks Quantrik for making a case design tutorial on youtube
- Thanks to all my friends/family who have encouraged me to share my project
-10/20/20 Updates-
- This release will be renamed to Orca 60 OG as a limited variant
- WKL only
- We will take measures to reduce the cost of the regular Orca 60 to be released on a later date (different materials, surface finishing, and possibly manufacturer)
- Tsangan layout will be offered with the release of the normal variant
- WT60-C PCB in black confirmed
- Magnets and gaskets will come preinstalled at the same price
-12/1/20 Updates-
- Over the past month and a half we've been assessing manufacturers to reduce the price of the Orca 60 while maintaining a similar level of quality. Of the seven manufacturers we've assessed, one has met our criteria. We are currently in negotiation and will have them produce a prototype for us. We will have updates in pricing shortly.
- We will be hiring a quality control agent overseas for third party inspection of the boards before they get shipped to the US. There will effectively be three rounds of quality control; one from the manufacturer, one from our agent before shipping to US, and one from myself before they are shipped to the customer.
- Custom packaging has been received and rejected because quality did not meet expectations. I have decided to provide a custom TX style carrying case with every order instead. Custom carrying case design has been completed and prototype has been ordered.
- We will be testing other plate materials to achieve even more consistency in flex and sound. Aluminum full plate is very consistent but could be a little less stiff so FR4 and PC full plates will be tested. The aluminum half plate is very consistent as well but could be a little more stiff so titanium and stainless steel half plates will be tested.
« Last Edit: Wed, 02 December 2020, 15:36:20 by Orca Builds »
Offline Orca Builds
    • Orca Builds
Re: Orca 60 | Magnet Mounted Premium 60
« Reply #1 on: Mon, 19 October 2020, 20:07:34 »
reserved
Offline androo
« Reply #2 on: Mon, 19 October 2020, 20:11:04 »
niiiiiiice
adk64 | s7 elephant | m65-b | kei r2 | gskt-00 (waiting) | angel (waiting)
Offline austinliu
« Reply #3 on: Mon, 19 October 2020, 20:12:54 »
looks really interesting
Offline productkun
« Reply #4 on: Mon, 19 October 2020, 20:17:01 »
Any reason you went with 6061 instead of 6063?
Offline Orca Builds
    • Orca Builds
« Reply #5 on: Mon, 19 October 2020, 20:19:44 »
6061 is higher strength while still having wonderful surface finishing qualities
Offline Tyler
  • hhkb >
« Reply #6 on: Mon, 19 October 2020, 20:22:26 »
Color me intrigued
Offline yoot
    • none
« Reply #7 on: Mon, 19 October 2020, 20:26:05 »
Very interested in this. It looks great
Offline scoopbb
« Reply #8 on: Mon, 19 October 2020, 20:27:49 »
will this work with standard 60% pcb and will plate file be released?
Offline Orca Builds
    • Orca Builds
« Reply #9 on: Mon, 19 October 2020, 20:32:02 »
Only if the USB C connecter is perfectly centered between ESC and 1 key. Currently, it has only been tested with WT60-C and WT60-D from Wilba.
Offline Orca Builds
    • Orca Builds
« Reply #10 on: Mon, 19 October 2020, 20:32:31 »
Plate files will most likely be released later on
Offline firewrath9
« Reply #11 on: Mon, 19 October 2020, 20:33:06 »
 this is amazing. I absolutely love the finish on the proto.  :thumb:
Offline Orca Builds
    • Orca Builds
« Reply #12 on: Mon, 19 October 2020, 20:34:49 »
thank you so much
Offline Diggidy
« Reply #13 on: Mon, 19 October 2020, 20:35:15 »
It sounds really nice, and I like the overall look of the board. Are the magnets just beneath the PCB/Plate, and it's regular gasket mount above the plate?
Offline Fredington
    • Instagram
« Reply #14 on: Mon, 19 October 2020, 20:45:06 »
HHKB?
Offline webstersx
« Reply #15 on: Mon, 19 October 2020, 20:50:37 »
Really cool!
Offline yoniwolf1202
« Reply #16 on: Mon, 19 October 2020, 20:55:33 »
I like the idea on this because I especially love the lodestone. I was wondering if you could make a video showing the flex towards the edges that would show off the benefits of the magnet mounting system.
Sent from my Pixel 3 using Tapatalk
Offline Rebral
« Reply #17 on: Mon, 19 October 2020, 20:58:27 »
Another magnet keeb to keep an eye on? Perfect.
Is my wallet ready for either one? Nope.
Following!
Offline Ustinj
« Reply #18 on: Mon, 19 October 2020, 21:00:35 »
amazing.
Offline Arcitan
  • pain peko
« Reply #19 on: Mon, 19 October 2020, 21:01:29 »
What an interesting design! Even when it seems almost every variation of "isolation mount" has been done, the community continues to raise the bar. Will be following very closely! :)
TGR Jane V2 CE | TGR Jane V2 | TGR x TM Jane v1.5 | Kepler | PC TGR 910 RE | Bauer | Iron165 | 2x Volcano660 (White + Black) | TGR x Singa Unikorn | LZ Physix | Rukia | Geonworks F1-8X | Polaris
Offline Orca Builds
    • Orca Builds
« Reply #20 on: Mon, 19 October 2020, 21:07:03 »
Please refer to the Typing Sounds / Flex Demonstration video where I show flex towards the edges ty
« Reply #21 on: Mon, 19 October 2020, 21:07:44 »
Ope, ty
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #22 on: Mon, 19 October 2020, 21:22:59 »
How do Magnet works
(credits to Kokaloo)
Offline Orca Builds
    • Orca Builds
« Reply #23 on: Mon, 19 October 2020, 21:31:39 »
How do Magnet works
gimme kei and i tell u
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #24 on: Mon, 19 October 2020, 21:32:32 »
Offline o3okevin
« Reply #25 on: Mon, 19 October 2020, 21:42:26 »
damn this is cool
Offline Tribeq
« Reply #26 on: Mon, 19 October 2020, 21:58:21 »
I love how cool this board is. It also looks great and sounds incredible. Hope I get lucky on this one!
Offline treeleaf64
    • treeleaf64
Everyone must pay the cat tax
Offline jimboytacos
« Reply #28 on: Mon, 19 October 2020, 22:20:27 »
What if you designed a daughterboard on the lower half of the case? That way, when the PCB physically shifts up/down (cuz, magnets and levitation) it will not affect the position of the USB-C position. Get it? I think it'll look cleaner than a PCB with an integrated USB-c since the cutout won't have to be so large to accommodate movement.
Offline Orca Builds
    • Orca Builds
« Reply #29 on: Mon, 19 October 2020, 22:28:34 »
A daughterboard was taken into consideration during the design process. However, because of the strength of the magnets, during the assembly process the bottom case must be a good distance away from the top case/ plate until the magnets are aligned because the strength of the magnets will pull the plate out of the top case. This means an extremely long daughterboard cable would be required and would complicate the assembly process even further. It is possible but I opted for a slightly larger usb cutout which makes assembly much easier.
Offline finalarcadia
« Reply #30 on: Mon, 19 October 2020, 22:39:21 »
Cool stuff  :thumb:
Offline pixelpusher
« Reply #31 on: Mon, 19 October 2020, 22:50:39 »
Have you run any previous group buys?  Do you have a team, or is it just you?  I like the design and mounting system, just hard to give $650 to someone who i've never heard of with only 15 posts.
Offline Orca Builds
    • Orca Builds
« Reply #32 on: Mon, 19 October 2020, 22:57:56 »
Nope, I have not run a previous group buy and it's just me. Which is why there are limited units and I may reduce units even further until I can build trust. Unfortunately, I have to start somewhere and this is my attempt.
Offline pixelpusher
Re: [IC] Orca 60 | Magnet Mounted Premium 60
« Reply #33 on: Mon, 19 October 2020, 23:01:34 »
I get that.  Everyone has to start somewhere.  I do hope that it is a success.
100 seems like too many.  50 seems like a lot, honestly.  Any other first time runners wanna chime in here?
Offline Orca Builds
    • Orca Builds
« Reply #34 on: Mon, 19 October 2020, 23:19:22 »
Keep in mind that as unit quantity goes down cost of manufacturing goes up. But I'm willing to do what it takes to build trust.
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #35 on: Mon, 19 October 2020, 23:26:31 »
Do you need PCBs? Because I make PCBs that are compatible with WT60-C and WT60-D.
Offline Orca Builds
    • Orca Builds
« Reply #36 on: Mon, 19 October 2020, 23:39:09 »
Yes please Wilba
Offline Wilba
    • wilba.tech
« Reply #37 on: Mon, 19 October 2020, 23:45:06 »
Yes please Wilba
Slide into my DMs bby  :-*
Offline fishbiscuit13
  • do you realize ???
« Reply #38 on: Tue, 20 October 2020, 00:04:28 »
This looks really cool. The sound test was disappointingly metallic and high pitched though; reading the build I was very surprised it was blacks on aluminum. It sounds like the extreme lack of contact between the plate assembly and the case leaves you with just the sound of the pcb, without the mass of the case contributing to the sound. This could be just from your recording setup or some other factor I'm not expecting, but I've gotten deeper sounds from brass plates and clacky linears.
Offline Ustinj
« Reply #39 on: Tue, 20 October 2020, 00:08:15 »
That is a good point. I thought it was the microphone, but it is true that a lot of the deeper tones of a case would come from the vibrations dissipating into the case.
This is true isolation mount - isolated mostly by air  ;D
Offline Romutulus
« Reply #40 on: Tue, 20 October 2020, 00:12:14 »
Looks good. 650 is a bit steep for me, but just maybe...
Offline bthezebra
« Reply #41 on: Tue, 20 October 2020, 01:39:28 »
Looks clean, love the insides
Offline NoxNoxNox
« Reply #42 on: Tue, 20 October 2020, 01:43:03 »
I'm 100% on board with this one.  What a great design.
Offline whitemamba
« Reply #43 on: Tue, 20 October 2020, 01:45:49 »
The idea is very nice, Daughterboard PCB would be nice but I understand why it is not the final option. The USB port is not snugly fit into the hole and there is room for movement. But still needs very careful assembling, I guess.   Would love to see it as a success, $650 price tag is a bit high imo,  GLWIC.
Offline Solotov
« Reply #44 on: Tue, 20 October 2020, 04:55:11 »
Wow looks great  :thumb:
Flex is love, flex is life.
Offline Rayndalf
« Reply #45 on: Tue, 20 October 2020, 05:15:52 »
How do Magnet works
smaller magnets inside?
Offline firewrath9
« Reply #46 on: Tue, 20 October 2020, 09:56:04 »
How do Magnet works
but how do smaller magnet works
Offline Baka Bot
« Reply #47 on: Tue, 20 October 2020, 09:57:57 »
gimme gimme gimme gimme
Offline zoo
    • zoo
« Reply #48 on: Tue, 20 October 2020, 11:16:58 »
In the flex test, the front bottomed out on a hard press. Is there space in the bottom case for some padding to soften this?
Offline Yeoh
« Reply #49 on: Tue, 20 October 2020, 12:12:21 »
I like a lot about that design, and that ano looks nice.
First time designer, correct? Price is steep for an initial offering.
Logo on the back could use revision, it looked like a strange blob to me until I saw your pfp. Then it looked like a strange fish-like blob. If you like it, that's all that really matters though I guess.
GL with the GB!
« Last Edit: Tue, 20 October 2020, 13:13:35 by Yeoh »
