Author Topic: [Pre-IC] Screw Trays (Circle or Square)  (Read 9106 times)
Offline kk73715
  • Why are you even reading
« on: Fri, 23 October 2020, 09:06:32 »
[deleted]
« Last Edit: Tue, 27 July 2021, 09:56:03 by kk73715 »
Offline kk73715
Re: [IC] *affordable* Screw Trays (Circle or Square) - Accessorise your desk!
« Reply #1 on: Fri, 23 October 2020, 09:08:36 »
[deleted]
« Last Edit: Tue, 27 July 2021, 09:56:11 by kk73715 »
Offline of_sam
« Reply #2 on: Fri, 23 October 2020, 09:12:08 »
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #3 on: Fri, 23 October 2020, 09:19:54 »
I don’t think the elephant in the room is that it looks like a RAMA tray, it’s that you’re advertising it as affordable and the price already increased!!
(credits to Kokaloo)
Offline Visionaire
Offline kk73715
« Reply #5 on: Fri, 23 October 2020, 09:34:50 »
Sound concerns. I got a quote from the manu before the results of the interest check form on r/mm (rookie mistake). I was optimistic for the MOQ numbers but realised that its not a good idea to set expectations so high (or low price) so early on. After I receive the prototypes, I will be getting an updated quote and share MOQ.
On a side note, I meant affordable as compared to what is currently available in the market. My apologies if it was misleading.
Offline kk73715
« Reply #6 on: Fri, 23 October 2020, 09:39:39 »
See ya on Simon's stream! ;)
Expecting newspaper bonk or **** face. This is definitely an early IC with no proper renders or a prototype.
See you there!
Offline xv
« Reply #7 on: Fri, 23 October 2020, 09:39:59 »
definitely interested if the price stays close to $30
 QFR MX Blue      QFRI MX Red
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #8 on: Fri, 23 October 2020, 10:13:14 »
where are other popular shapes such as diamond, or triangle, or even the rhombicosidodecahedron?
« Last Edit: Fri, 23 October 2020, 14:35:17 by Kokaloo »
Offline Ustinj
« Reply #9 on: Fri, 23 October 2020, 11:42:47 »
Ha, I wanted a RAMA tray but couldn't justify the $50 tag on it - ended up getting some metal bowls that looked decent enough, with snail mail shipping from CN for $3 each 😳!!
Offline HoodrowThrillson
« Last Edit: Fri, 23 October 2020, 11:52:22 by HoodrowThrillson »
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline meowscanttype
  • 65 is bad
« Reply #11 on: Fri, 23 October 2020, 13:27:46 »
gg
Offline dandruff
« Reply #12 on: Fri, 23 October 2020, 13:53:52 »
Offline Janoma
  • certified nerd
« Reply #13 on: Fri, 23 October 2020, 14:13:41 »
Not trying to be a downer, but this seems kinda pointless.
I get you have an idea and you want to produce it, but at the moment there are many trays very very similar to this on the market. I could order a 10$ tray off of amazon and get it two days from now instead of waiting weeks and even months for the same product in a GB. I like trays and am interested, but I suggest giving something that sets it apart from other designs.
EDIT: maybe some unique colors would be nice
GL :thumb:
« Last Edit: Fri, 23 October 2020, 14:15:19 by Janoma »
Offline Ustinj
« Reply #14 on: Fri, 23 October 2020, 14:47:11 »
The difference between this / RAMA tray and a simple metal tray or bowl from Amazon or Aliexpress is the weight, density, and shape.
I got these good looking metal bowls, but they're usually either made of thin aluminum or they are hollow double-walled aluminum. I could see the appeal for a solid aluminum block CNC'd to a tray, as it would be more dense feeling. The difference between a CNC'd metal tray like this and a typical metal tray from Amazon would be comparable to the difference of between a Drop Alt and a $500+ custom. Not really useful, but cool to have. Also, something i was looking for while picking was that I wanted something that didn't look like a bowl - the RAMA tray looks more like a tray, and not a bowl. A lot of the alternatives look like dog food bowls.
btw idk if you'll really be able to get 'mirror polished stainless steel' CNC'd for that cheap
« Last Edit: Fri, 23 October 2020, 15:01:46 by Ustinj »
Offline Rebral
« Reply #15 on: Fri, 23 October 2020, 16:45:01 »
I don't know how to say that rhinobionicleduducacamegalodon shape, but I heckin want one.
Offline Artemie
  • Don't Let Your Memes Be Dreams
« Reply #16 on: Fri, 23 October 2020, 17:22:37 »
 :p
254345-0
« Last Edit: Fri, 23 October 2020, 23:41:16 by Artemie »
| 420CL | Fanoe | Porpoise | KFE R1 Silver| MxSS |  is0 Pink & Silver | HBCP Polycarbonate | Matrix 2.0 Additional Purple | TGR Police | Singa Jaguar Green | KFE R2 Blue | RS so lit | Dolch CR Black | Jelly 60 Blue | Belle en Rose | Kei R2 Olive | Dalco 959 Mini | Aripeko
Boards in GB: | IU board |
Previous Boards: QXP | Singa  | UTD | Taichi | Jane v2 Red | Jane v2 CE
Offline pool
« Reply #17 on: Sat, 24 October 2020, 00:41:38 »
Gonna need to see prototypes of these
Offline kk73715
« Reply #18 on: Sat, 24 October 2020, 03:48:09 »
:p
did you just make that?? or was this something you already made?
Offline kk73715
« Reply #19 on: Sat, 24 October 2020, 04:06:43 »
To address a few comments about why would someone want this compared to cheaper alternatives, the main reason would be for aesthetic and quality. In terms of function, there are many other household items that can serve the same purpose as these trays. I think the analogy mentioned in the quote was very well said and is a perfect response to the function vs form argument.
Offline jjoejimmy
« Reply #20 on: Sat, 24 October 2020, 13:11:07 »
The difference between this and the keyboard analogy is that I wouldn't put a tray of screws on my desk 24/7.....
If you plan to treat it as a decoration rather than a practical thing, then the designs in the renders are way too simple to warrant the 20$ price. Maybe add some patterned engravings or something that makes it look high quality. But then it might look like a pretty ashtray...glwic
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #21 on: Sat, 24 October 2020, 22:20:27 »
Buy an ash tray, jesus
Offline Artemie
« Reply #22 on: Sat, 24 October 2020, 23:43:34 »
Needs the Puddsy seal of approval.
Offline fropsie
Offline Nonnegaard
« Reply #24 on: Mon, 26 October 2020, 03:16:33 »
Ye thats a yikes
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline Nonnegaard
« Reply #25 on: Mon, 26 October 2020, 03:20:21 »
SO MANY PEOPLE are saying you should just buy a $3 screw tray from Amazon but they out here spending hundreds or even thousands on keyboards when you can literally just buy this.254586-0
Offline EdgeOfInfinity
« Reply #26 on: Sun, 01 November 2020, 00:55:39 »
awesome, i've been waiting for more magnetic screw trays!
« Last Edit: Sun, 01 November 2020, 01:09:32 by EdgeOfInfinity »
