Author Topic: [GB] KAT Comet (ENDED)  (Read 23068 times)
Offline Chuttau
  • Formerly botallu
« on: Mon, 02 November 2020, 13:40:18 »
彗星の如く現れたスターの原石
Introducing - KAT Comet
GB will run through 2nd November to 2nd December!
Estimated Shipping:Q3-4 2021
Discord Channel
Vendors:
Pricing:
Kits:
TKLs-
TKL
ALT TKL
Alphas-
Alphas
ALT Alphas
Hiragana
ALT Hiragana
French
North
Colevark+
Mods-
Text mods
Icon mods
40s/Ortho
Ergo
Others-
Spacebars
Numpad
ALT Numpad
Novelties-
Colours:
PANTONE 533c and 290c (291C is just for reference)
real life pantone chip shoots with samples
ALL keys with Navy Base with Light Blue Legends Will have GiD blue legends,
 I will keep everyone updated on the GiD samples in the discord server
Renders(by kingk22)
Join the discord for faster update and responses![/size]
Special Thanks:
OneCreativeMind for allowing me to use his Hiragana alphas files!
Peeps from Thicthock for supporting the project
Kig for being my render slave
mcnos for guiding me to make the kits
Ulliam for the beautiful novelties
NOTICE: This is NOT an offical Hololive merch
« Last Edit: Thu, 03 December 2020, 05:36:11 by botallu »
Re: [GB] KAT Comet
« Reply #1 on: Mon, 02 November 2020, 13:42:49 »
Approved. :thumb: Can you please add an estimated ship date as well? Also, just a note, adding some links to the product pages for the vendors might be helpful. :)
Offline Chuttau
  • Formerly botallu
Re: [GB] KAT Comet
« Reply #2 on: Mon, 02 November 2020, 13:49:24 »
Edited! Thank you for the fast approval  :D
Offline dvorcol
  • Discord: dvorcol_5071
Re: [GB] KAT Comet
« Reply #3 on: Mon, 02 November 2020, 13:50:03 »
GLWGB!
Re: [GB] KAT Comet
« Reply #4 on: Mon, 02 November 2020, 13:50:38 »
Thanks!! GLWB!
Offline BapoDonu
Re: [GB] KAT Comet
« Reply #5 on: Mon, 02 November 2020, 19:02:19 »
can i simp
Offline Chuttau
  • Formerly botallu
Re: [GB] KAT Comet
« Reply #6 on: Tue, 03 November 2020, 00:04:28 »
Offline paulgali
    • SKME
Re: [GB] KAT Comet
« Reply #7 on: Tue, 03 November 2020, 00:34:06 »
It's like Mizu, but you stuck with blue on the mod text. I like this tbh. GLWGB :thumb:
Offline AnAsianPanda
Re: [GB] KAT Comet
« Reply #8 on: Tue, 03 November 2020, 02:28:16 »
It's finally out yay! Been waiting months for this
Offline nasp
Re: [GB] KAT Comet
« Reply #9 on: Tue, 03 November 2020, 13:19:47 »
Is there a 3u bar in both the spacebar and the 40's/ortho kits? It's hard to tell without descriptors by the keys.
Offline Chuttau
  • Formerly botallu
Re: [GB] KAT Comet
« Reply #10 on: Tue, 03 November 2020, 13:53:10 »
3u bar is only in the spacebars kit
Offline nasp
Re: [GB] KAT Comet
« Reply #11 on: Tue, 03 November 2020, 15:57:43 »
Another question. Is there a 3u bar in both the light blue and the dark blue?
Offline scowl
Re: [GB] KAT Comet
« Reply #12 on: Tue, 03 November 2020, 17:51:35 »
I'm interested in this set. Would the TKL option be all I need if I had a KBD75v2?
Figured it out. I'm in. :)
« Last Edit: Tue, 03 November 2020, 18:05:49 by scowl »
Offline kokugatsu
Re: [GB] KAT Comet
« Reply #13 on: Wed, 04 November 2020, 07:04:38 »
You should get Alphas + Mods
TKL is missing the smaller shift and different profiles of keys on the right side (page up, down, delete etc)
Offline dvorcol
Re: [GB] KAT Comet
« Reply #14 on: Wed, 04 November 2020, 15:30:14 »
Unless there is an error in the kit image, the only 3u spacebar is dark.
Edit: clarified 6u stem compatibility question, added convex question.
« Last Edit: Thu, 05 November 2020, 17:52:14 by dvorcol »
Offline dvorcol
Re: [GB] KAT Comet
« Reply #15 on: Wed, 04 November 2020, 18:57:26 »
Offline nasp
Re: [GB] KAT Comet
« Reply #16 on: Thu, 05 November 2020, 11:43:09 »
Thanks for the help as always, Dvorcol!
Offline azzipa
Re: [GB] KAT Comet
« Reply #17 on: Fri, 06 November 2020, 18:50:28 »
Very nice set, GLWGB
Offline Maszaia
Re: [GB] KAT Comet
« Reply #18 on: Mon, 09 November 2020, 05:41:17 »
This is a beautiful set. I am definitely getting the TKL, might even go for those novs
Offline dvorcol
Re: [GB] KAT Comet
« Reply #19 on: Tue, 10 November 2020, 07:40:14 »
Offline dvorcol
Re: [GB] KAT Comet
« Reply #20 on: Thu, 26 November 2020, 19:52:15 »
Offline Chuttau
  • Formerly botallu
Re: [GB] KAT Comet (ended)
« Reply #21 on: Thu, 03 December 2020, 05:35:09 »
GB ENDED!
thank you for the support, final numbers will be updated soon
Offline NoPunIn10Did
    • NoPunIn10Key
« Reply #22 on: Mon, 25 January 2021, 10:11:03 »
GB ENDED!
Out of curiosity, do you have final numbers with extras that you can share?
Offline Arilleria
Re: [GB] KAT Comet (ENDED)
« Reply #23 on: Wed, 27 January 2021, 19:55:33 »
unfortunate that I missed out on this GB. any chance there will be a re-run of this?
Offline dvorcol
« Reply #24 on: Fri, 06 August 2021, 09:20:45 »
Offline dvorcol
« Reply #25 on: Thu, 06 January 2022, 14:01:47 »
Keyreative shared their estimated KAT/KAM production schedule - https://en.zfrontier.com/blogs/project-updates/keyreative-keyset-progress-report
