Author Topic: [IC] Roses/バラ V1  (Read 20075 times)
Offline Reason6
    • Roses V1 Discord
[IC] Roses/バラ V1
« on: Tue, 10 November 2020, 06:13:01 »
Welcome to the first interest check post for the Roses/バラ V1 Board!
The Roses/バラ V1 is an Alice Style Layout with arrow keys and 3 additional right-side macro keys or 2 keys and a rotary encoder!
The Roses/バラ V1 comes with a completely customizable OLED Display (pre-baked functions below).
Access the Render Gallery: https://imgur.com/a/6OO00Nd
IC Form: https://forms.gle/7vfwRMn5cw4BwWvt5
The complete info!
Typing Angle: 5°
Layout: Alice Style + Arrow Keys & 3 Added Keys
PCB: Custom Black with QMK & VIA Support
Screen: SSD1306 OLED 128x64 (Rotated Vertical)
Mount: Top Mount with optional o-ring add-on
Stabilizer Support: PCB Mount
Layout Options: Split Backspace, one encoder or no encoder
Material: 6061 Full aluminum
Full Pates: (Not confirmed) Aluminum, FR4, POM, Carbon Fiber.
Case Colors: (Not confirmed) EWhite, Matte Black, Gun Metal Grey, Red
Weight Colors: (Not confirmed) Stainless/Chrome, Full Crimson, Stainless Rose on Crimson, Crimson Rose on Stainless.
Weight Designs: Full design with large rose and name or minimal with just a small rose!!
OLED Screen Custom Features (Will be confirmed Before GB):
- Onboard Storage for up to 3 full layouts selectable via onboard Screen
- 'On the fly' Key remapping via onboard Screen
- Custom Screen Animation
- WPM Graph
- Caps lock, Num lock, etc indicators
- Completely Opensource access to the screen features
UPDATE 1.1: Adding split r shift for right hand 'b' + base plate designs now are "full" and "minimal" Check the imgur link to see them or join the discord!
Join my discord to get live updates as we progress further into the IC: https://discord.gg/KgVFwzR5t9
Thank you!
« Last Edit: Wed, 11 November 2020, 19:25:45 by Reason6 »
Offline yoot
    • none
Re: [IC] Roses/バラ V1
« Reply #1 on: Tue, 10 November 2020, 06:17:34 »
Color me interested! GLWIC
Offline Reason6
    • Roses V1 Discord
« Reply #2 on: Tue, 10 November 2020, 06:21:13 »
Thank you!!!
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #3 on: Tue, 10 November 2020, 06:21:28 »
on the fly key remapping sounds very very interesting
Offline Kajoler
« Reply #4 on: Tue, 10 November 2020, 06:23:36 »
that looks pretty dope glwic!
>:0
Offline Reason6
    • Roses V1 Discord
« Reply #5 on: Tue, 10 November 2020, 06:23:46 »
Something i've been playing around with for a while. Perfect useage of the OLED so you can easily navigate it!
Offline Reason6
    • Roses V1 Discord
« Reply #6 on: Tue, 10 November 2020, 06:24:20 »
Thank you!
Offline klexoslethal
« Reply #7 on: Tue, 10 November 2020, 08:04:35 »
I'm very interested in this, looks nice!
Offline Retne
« Reply #8 on: Tue, 10 November 2020, 09:34:14 »
I'm curious why you skipped on the right hand B.  Was it because you built off the Arisu and didn't want to tweak the layout?
Offline FamilyJoule924
« Reply #9 on: Tue, 10 November 2020, 09:41:47 »
i'd like to see this with brass options and a function row ... otherwise it looks awesome
Offline mirubere
« Reply #10 on: Tue, 10 November 2020, 09:51:08 »
Looking good, glwic~!
Filled in the IC form as well~
Offline YoRHannya
« Reply #11 on: Tue, 10 November 2020, 10:54:11 »
Very interested! -keeping an eye on this for sure.
Glwic!
Offline huey
« Reply #12 on: Tue, 10 November 2020, 11:21:09 »
That plate looks suspiciously similar to open source acrylic files. I suggest you put some more refined design into stabs cut-out.
Offline treeleaf64
    • treeleaf64
« Reply #13 on: Tue, 10 November 2020, 11:22:54 »
Hello, how is that back going to be done? I don't see mentions of it in your post
Everyone must pay the cat tax
Offline Shinigamii
« Reply #14 on: Tue, 10 November 2020, 13:13:09 »
Are you going to have any prototypes?  I would love to see some protos, and like tree mentioned, it would be nice to know how the back is going to be done.
Offline njrobb
« Reply #15 on: Tue, 10 November 2020, 13:44:44 »
Yo, this looks nice! The key remapping feature sounds pretty neat.
I'd like to suggest a dark or forest green case colour. I think it would look nice, and would go with well the theme of the design.
Also the only thing I'm not too fond of is the japanese characters on the bottom of the case. I think it would look a bit cleaner with just the rose imo, especially with them already present on the top of the case.
Nice work so far either way, definitely will be following. Good Luck.  :thumb:
Offline steezkeez
« Reply #16 on: Tue, 10 November 2020, 13:47:31 »
really appreciate the 3 extra macro keys
will be following intently
looking forward to the prototype
Offline grabmienutz
« Reply #17 on: Tue, 10 November 2020, 13:54:07 »
This looks so dope, been waiting for a board like this  :thumb: .  Can't wait to see protos
« Reply #18 on: Tue, 10 November 2020, 13:58:25 »
This looks very interesting and I am interested.
My questions are:
- Can we get a render with Crimson/Blue colors? They were mentioned in Form and it could really sway my decision.
- From right B user: please consider adding second B.
- From both post and form it is not exactly clear whether encoder is optional. IMO most of the time, encoder doesn't fit and ruins the whole visual aesthetic. Is this optional?
Thanks.
Offline Reason6
    • Roses V1 Discord
« Reply #19 on: Tue, 10 November 2020, 16:33:51 »
Thanks everyone for your feedback so far!!
An Initial over the IC Form shows that there is a good amount of people requesting a right-hand B key, so we are looking at splitting the right shift to allow that option!
I am also going to make a more minimal option for the base plate and see where it goes from there!
I still have some reading to do so if ive missed your comment I promise I will get to it soon!!
Offline audax989
  • NOM NOM NOM
    • Guam Mechanical Keyboards
« Reply #20 on: Tue, 10 November 2020, 19:59:43 »
I'm really digging that top engraving!
Offline Reason6
    • Roses V1 Discord
« Reply #21 on: Wed, 11 November 2020, 02:57:55 »
Yes there will be prototypes! I have announced on discord a minimal base version, however the big one is a 2 piece design with the weight slotting into the base plate :)
Offline Arithmetics
« Reply #22 on: Wed, 11 November 2020, 12:09:00 »
the minimal weight is really nice. second removing the top engraving given how busy the top already is
Offline stein3
« Reply #23 on: Wed, 11 November 2020, 13:34:20 »
Am I crazy, or aren't all the pictures of the full-design bottom? Would love to see the minimal weight.
Offline Reason6
    • Roses V1 Discord
« Reply #24 on: Wed, 11 November 2020, 19:25:31 »
There was an issue uploading more images into that gallery, They were posted to discord and I have updated the link in the post: https://imgur.com/a/6OO00Nd
Offline hectellian
« Reply #25 on: Thu, 12 November 2020, 06:56:54 »
Big love, super nice
Offline Dissitesuxba11s
« Reply #26 on: Thu, 12 November 2020, 11:46:15 »
Ooh definitely interested. Going to keep an eye out on the progress.
Offline zoo
    • zoo
« Reply #27 on: Thu, 12 November 2020, 15:45:24 »
I’m always interested in keyboards with OLEDs :) looking forward to seeing this develop
Offline Hanabi
  • Falling into a black hole.
« Reply #28 on: Thu, 12 November 2020, 21:20:33 »
Looks pretty cool. Will see how it goes!
Offline Damage
« Reply #29 on: Thu, 12 November 2020, 23:00:06 »
Extremely interested!
Offline Diamagisk
« Reply #30 on: Sat, 14 November 2020, 01:22:47 »
Really like this design! Interested to see how things develop.
Offline yuutsu
  • Consumer of Brioche Loaf
    • Desktop Designs
« Reply #31 on: Sat, 14 November 2020, 12:18:54 »
That design on the back is to die for, just hope the larger one of the two is what we are getting!
Offline Boxes
« Reply #32 on: Sat, 14 November 2020, 22:50:05 »
Been wanting an alice layout board since I started this hobby a year ago. Definitely an instabuy for me. Looking forward to future updates!
Offline baccaan
« Reply #33 on: Sun, 15 November 2020, 19:01:28 »
Dropping in here with my support for a right "B" key. Otherwise the board looks fantastic!
Offline Thighs
  • Thighs#0100
« Reply #34 on: Tue, 17 November 2020, 19:18:53 »
sexy. hoping for ewhite!
Offline UberPlatypus
« Reply #35 on: Wed, 18 November 2020, 22:46:09 »
Please, please please, give the back some sort of angle of flare. Otherwise it just looks like a brick. This needs more than just a bottom to stand out from others and features. A keyboard is art too.
Personally I would prefer a 6° angle however this is preference.
The large rose design is awesome. HOWEVER it it is terribly off balance in its design. One side remains too heavy. By rotating the design and removing the stem without removing the stem leaves you should be able to obtain a better balance.
Sent from my HD1925 using Tapatalk
Offline xanserkx
« Reply #36 on: Thu, 19 November 2020, 18:50:03 »
Filled out the form. Good luck with the IC  :thumb:
Oblotzky AIS65 - Rama Zenith - RME Studio Emery65 - TGR Tomo - Hex 4B - Cablecar Design Angel - Cablecar Design Phoenix - Cablecar Design Cypher - Hand Engineering Haus - TX HJ75 - Parallel Limited Portal -  SingaKBD Kohaku -  and bunch of prototypes that I made :(
Sold: Merisi Ottantaquatro
Offline Pach
« Reply #37 on: Thu, 19 November 2020, 20:25:56 »
I've said this before, but I love everything about the board except the font choice. I feel like a more classic font would be nice, but if that's solidified then I completely understand.
Offline moe_en
« Reply #38 on: Mon, 30 November 2020, 07:32:35 »
filled form.
Best of luck
Offline LeblancCafe
« Reply #39 on: Thu, 03 December 2020, 23:45:50 »
Looks really nice!
Offline super_tu
« Reply #40 on: Thu, 04 February 2021, 14:25:47 »
I am excited for this board! Hoping for an unlimited GB eventually. GL!
Offline Zidnex
« Reply #41 on: Thu, 04 February 2021, 14:59:19 »
OLEDs and encoders are always great, and that weight in a crimson rose on stainless would be sweet! Can't wait!
Offline croatoanlp
« Reply #42 on: Thu, 04 February 2021, 15:28:00 »
This is beautiful.
Offline mawli
« Reply #43 on: Thu, 04 February 2021, 23:01:55 »
Very nice bottom design! GLWIC
Offline Bantalope
« Reply #44 on: Fri, 05 February 2021, 00:37:08 »
Not normally one for alice boards but this ones definitely gotten my interest.
Offline Thunderbird
« Reply #45 on: Fri, 05 February 2021, 00:47:21 »
Very interesting, I'll be keeping my eyes on this one!
