Author Topic: [IC] GMK HANOK 한옥 - Group Buy Live!  (Read 121437 times)
Offline JKKEEBS
« on: Fri, 22 January 2021, 15:51:07 »
Interest Check Form/Discord
Please consider filling out the IC form!  Join the Discord for updates and announcements!
Follow me on Instagram! For future updates on possible giveaway.
Iron 180
M60
F1-8X
Kibou's 'Harbour'
Vanquish 65
*note* Colors are not 100% accurate on renders. I found that higher resolution or color accurate monitors show darker browns and grays that show a drastically different feel of the set.
Base
Gray Mods
Novelty
Spacebar
Old Kits
N9 Deskmat and L9 Deskmat
Vendors:
Pricing:
TBD
GB Date:
Estimated April
Q. Where's the f13 key?
A. Top right of the base kit.
Q. Replace base kit mods with N9?
A. Originally I wanted to make the set with N9/black mods. This idea got some criticism for copying other sets, thus swapping the colors. I've seen the set with N9 mods and it doesn't feel like the Hanok I designed anymore nor the vision I have for this set. I will not be swapping the colors at this point in the IC nor adding a 2nd base kit with N9 mods.
Q. Mono Hangul alpha?
A. Will not be adding due to sales from other sets.
Q. What is the estimated price for the sets and deskmat?
A. I still have no idea but it'll be in the price range of other kits of the same size. Pricing was summitted on the date listed on the change log. Hopefully pricing will be announced soon.
Q. Dark deskmat?
A. Yes
Q. Rama cap?
A. I need the GB date to be announced in order to work with rama. Hoping for rama cap tho... Thinking of a black roof tile design for the rama currently.
Q. Separate Hangul from Latin and make an additional kit?
A. No
Q. Ral 1015?
A. After looking at RAL color ring, 1015 was a little too red and went with 2028, after looking at colors for a long time.
Q. Why the change of vendors?
A. Unfortunately GMK stopped shipping to new vendors and most of my vendors need to pay double shipping. Thus the change of vendors sadly.
To Do List:
  • Wait for pricing.
  • Rama/Salvun?
  • Announce GB date
Colors
Beige: L9
Gray: N9
Brown: Ral 8028
Keycap specs
Profile: Cherry
Sculpt: 1 - 1 - 2 - 3 - 4 - 4
Legends: Doubleshot
Modifier Style: Icon+Text
Material: ABS Plastic
Thank you to Fredington! Designed deskmat and novelties! Thank you for helping me with everything and anything I needed help with. This set would not have been possible without Fredington thanks!
Thank you to KingK22 for the amazing renders!
Thank you to Manzel for the amazing renders on the Iron 180!
Thank you to everyone that supported the set!
Thank you to Taeha Types for using the deskmat on stream.
Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=110801.0][img]https://i.imgur.com/tiYQ6pN.png[/img][/url]
« Last Edit: Mon, 06 September 2021, 21:57:37 by JKKEEBS »
Offline JKKEEBS
Re: [IC] GMK HANOK 한옥 Renewed
« Reply #1 on: Fri, 22 January 2021, 15:52:04 »
ChangeLog:
1.22.21
IC Launch
1.23.21
Fixed double F8 in F Row
Still looking for ways to implement alice support and accent keys into the kits without making them too big.
1.25.21
Changes to the base/bar kit. Added new N9 mod kit.
1. Moved white alice bars from bar kit to the base kit. Black alice bars added to bar kit.
2. Second B added in base kit for alice users.
3. Accent arrows added in base kit.
4. Added N9 mod kit.
5. Removed accent kit and merged with mod kit.
1.26.21
Reddit MechMarket IC launch.
1.28.21
Vendors and dark deskmat announced.
1.30.21
Dark Deskmat render/design added.
1.31.21
Kits summitted to gmk for pricing.
2.9.21
Minor changes made to IC.
2.11.21
Signature added.
Sizing for keys in kits are added.
RN Cable Collab announced.
Render from Kibou's keyboard 'Harbour' added
2.15.21
Render attachments changed to imgur links.
Changed 1st render to Harbour from Vanquish 65
2.25.21
Changed, EU vendor.
Added UK and CN vendor.
3.1.21
Major Aesthetic Changes made to IC
3.5.21
N9 mod render added.
New renders on the Iron 180.
Added specification tab.
3.15.21
Instagram account added/made.
3.29.21
Casper Keys collaboration announced.
3.29.21
Monokei artisan and MarbleK wrist rest collaboration added.
5.26.21
Base: added 2u removed R3 PgUp and R4 PgDn
Novelties: Removed numpad and new R2 novelty changed ISO novelty into numpad  design
Spacebar: Removed off center 6u and added 3u
Gray Mods: Removed numpad support
« Last Edit: Wed, 26 May 2021, 13:44:28 by JKKEEBS »
Offline yoot
    • none
« Reply #2 on: Fri, 22 January 2021, 16:02:12 »
Why second IC? Just post an update to your first. I don't want to have to figure out which is the new and old IC when searching up the set
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #3 on: Fri, 22 January 2021, 16:05:07 »
ne ral 1015 alphas avail?
Offline Baka Bot
« Reply #4 on: Fri, 22 January 2021, 16:10:16 »
Oh so it wasnt just me then
Offline nvh2092
« Reply #5 on: Fri, 22 January 2021, 16:20:48 »
Nice colorway, I think you should lock the 1st thread. Also, please consider adding F13, second B and moving accent arrows from the child kit to the base kit. This way will make the base more in line with the current ICs.
Offline tngpq
« Reply #6 on: Fri, 22 January 2021, 20:59:43 »
Nice update. Just curious, what is the novelty on numpad enter?
Offline Pluto19
  • All who break the taboo will be eliminated.
« Reply #7 on: Fri, 22 January 2021, 21:05:42 »
Could've just updated your OP from your first GMK Hanok IC.
That being said, I'm interested to see this set progress.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #8 on: Fri, 22 January 2021, 23:48:39 »
Neat.
Offline BapoDonu
« Reply #9 on: Sat, 23 January 2021, 00:22:47 »
I remember the first IC glad you took your time to improve the set its so much better now. On the deskmat I dislike the orange/blue charm personally I would go with some other color like red but gj
Offline HungHingDaiLo
  • 無間道
« Reply #10 on: Sat, 23 January 2021, 00:27:47 »
I think the Accent kits (L9/N9) is not needed, I personally feel the colorway in base kit looks good as is.
Great progress, keep it up!
IG: @rayhhdailo
Offline sup3r170va
« Reply #11 on: Sat, 23 January 2021, 08:12:32 »
I like the core and the novelty kits, but I think the core can just be upgraded with black (well N9) arrow keys and brown F13, and can do away with the black kit. Also, good if we can have a Rama :)
Offline nvh2092
« Reply #12 on: Sat, 23 January 2021, 10:16:28 »
I think there's a problem with the function row in base kit, there are 2 F8 and no F12
Offline sup3r170va
« Reply #13 on: Sat, 23 January 2021, 10:42:01 »
Sorry, I just realised some of the Control and Alt have Korean sublegends. Is it possible for all of it to have the Korean sublegends, so that it is more balanced? Thanks.
Offline tngpq
« Reply #14 on: Sat, 23 January 2021, 13:02:36 »
That doesn't make sense from a practical standpoint. The right Alt sublegend is switching between Korean/English and right Ctrl is for Chinese character input. The left side does not support such functions.
Offline powwu
    • Discord
« Reply #15 on: Sat, 23 January 2021, 22:47:59 »
knowing the issues the first set had, since I'm not affected by them, I'm gonna keep my mouth shut. Color wise, looks clean. GLWIC
Offline sup3r170va
« Reply #16 on: Sun, 24 January 2021, 00:54:37 »
Ah ok thanks for clarifying.
Offline JKKEEBS
« Reply #17 on: Mon, 25 January 2021, 17:02:02 »
The numpad enter novelty is a traditional lantern
Offline JKKEEBS
« Reply #18 on: Mon, 25 January 2021, 19:03:47 »
Fixed all three of these problems. N9 arrow keys added into the base kit and brown F13 was always in the top right of the base kit. Still need more feedback and IC responses to get a vendor and then start on the Rama cap. Check the Changelog for more details thanks!
Offline manaorme
Re: [IC] GMK HANOK 한옥 - New kits!
« Reply #19 on: Mon, 25 January 2021, 19:20:33 »
Yes! Grey mod. Glad to hear that.
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
« Reply #20 on: Mon, 25 January 2021, 19:33:17 »
This is nice!
Offline nvh2092
« Reply #21 on: Tue, 26 January 2021, 00:43:03 »
Nice and fast change. Now I wait for gb  :D . Very nice and subtle set.
Offline Rocket
« Reply #22 on: Tue, 26 January 2021, 13:10:37 »
Would you consider making this into an r3 enter key please? 260565-0
« Last Edit: Tue, 26 January 2021, 13:13:07 by Rocket »
Offline mr_fro2000
« Reply #23 on: Thu, 28 January 2021, 04:45:34 »
One of the few sets where the keycaps actually evoke the actual inspiration.  Very interested!
Offline JKKEEBS
Re: [IC] GMK HANOK 한옥 - VENDORS ANOUNCED!
« Reply #24 on: Thu, 28 January 2021, 19:58:34 »
Vendors announced for 6 proxies. GB date estimated to be April.
US: Dang Keebs
EU: Keygem
CA: Desk Hero
SK: Swag Keys
SEA: Kibou
OCE: Daily Clack
« Last Edit: Thu, 28 January 2021, 20:29:17 by JKKEEBS »
Offline diamondogs
« Reply #25 on: Fri, 29 January 2021, 09:12:40 »
Normally don't like brown keycaps but I like it in this set. Nice!
Offline JKKEEBS
Re: [IC] GMK HANOK 한옥 - DARK DESKMAT!
« Reply #26 on: Sun, 31 January 2021, 01:44:51 »
Dark deskmat design out!
« Last Edit: Sun, 31 January 2021, 14:36:03 by JKKEEBS »
Offline hkiri
« Reply #27 on: Tue, 02 February 2021, 06:43:04 »
Really clean set.
Offline Niphix
« Reply #28 on: Thu, 04 February 2021, 17:19:26 »
looks super slick , would love a EU / German version but will absolutely buy either way :) love the novelties especially !!
  • Formerly 'esclab'
    • esc lab
« Reply #29 on: Thu, 04 February 2021, 17:22:42 »
Very high quality IC. Good work. Love the deskmats and homage to authenticity.
Offline Weaselpc
« Reply #30 on: Fri, 05 February 2021, 08:06:21 »
The dark deskmat is pretty fire. If anything I'll definitely pick it up.
Offline cecioclock
« Reply #31 on: Tue, 09 February 2021, 09:40:15 »
No question I’m in,, such an amazing set. Thank you for bringing this theme to life
Offline Que7797
« Reply #32 on: Tue, 09 February 2021, 14:22:49 »
I like the theme.
Offline JKKEEBS
« Reply #33 on: Thu, 11 February 2021, 12:53:45 »
Signature added.
Code: [Select]
RnCable collab announced
« Last Edit: Mon, 15 February 2021, 03:51:42 by JKKEEBS »
Offline raykcy
    • RnCables
Re: [IC] GMK HANOK 한옥 - New render, Cable and Signature!!
« Reply #34 on: Fri, 12 February 2021, 01:35:30 »
very unique and amazing keycaps set!!
Offline JPKr
« Reply #35 on: Sun, 14 February 2021, 01:18:39 »
Is there a chance for a black r4 novelty (onngi)?? Also really like the set, hope to buy this soon
Offline Izeri
« Reply #36 on: Sun, 14 February 2021, 07:07:28 »
You have ~120MB of images which takes forever to load, could you consider compressing them?
Offline JKKEEBS
« Reply #37 on: Sun, 14 February 2021, 18:08:38 »
Considering this thanks!
Noted will fix.
Offline bayfunXiao
« Reply #38 on: Fri, 26 February 2021, 02:02:13 »
Renders on a black/gray case look amazing.
Offline Rx003
« Reply #39 on: Sat, 27 February 2021, 02:18:42 »
Any chance for a render with the gray mods? Also any chance to show the box art as well?
Offline mayorpeepo
Re: [IC] GMK HANOK 한옥 - Revamped IC!
« Reply #40 on: Tue, 02 March 2021, 00:59:44 »
love the natural tones on this set!!  :D Any chance of adding a 2u left shift? would look amazing on the wood case gk64!
Offline SJHL
« Reply #41 on: Tue, 02 March 2021, 01:04:34 »
I think my wife and I found our next deskmat. Looks great!
Offline JKKEEBS
Re: [IC] GMK HANOK 한옥 - N9 Mod Renders!
« Reply #42 on: Fri, 05 March 2021, 02:39:36 »
New renders done by Manzel on the Iron 180 including the highly demanded N9 mod render!
Offline JKKEEBS
« Reply #43 on: Fri, 05 March 2021, 15:28:36 »
Yes gray mod renders!
Most likely box art will not be shown off in the IC but in the GB thread.
Glad to hear that!
Still waiting for pricing from GMK, will adjust kits after I see prices.
Offline Nuts
« Reply #44 on: Fri, 05 March 2021, 22:49:56 »
Yes!  :-* :p They match with my discrete brown wooding of my table and floor.
Offline tofulo
« Reply #45 on: Fri, 05 March 2021, 23:52:13 »
Really big fan of the mats. Not big on the rainbow color, but still great
Offline tngpq
« Reply #46 on: Sat, 06 March 2021, 00:14:14 »
N9 Mods on TKL looks so nice
Offline JKKEEBS
« Reply #47 on: Sun, 07 March 2021, 14:44:26 »
Thanks! Still thinking about EU kit but I'm not sure yet... A few people have been asking about this but not sure if this will reach MOQ.
Offline vibaSept
« Reply #48 on: Sun, 07 March 2021, 17:12:14 »
I'm also in if it comes with a German or Nord Kit! Please make it happen, if the demand is high enough  ;D
Offline chung
« Reply #49 on: Wed, 10 March 2021, 20:29:29 »
<3
