Author Topic: [IC] Vast60- 60% keyboard  (Read 28375 times)
Offline made in China
« on: Tue, 02 February 2021, 21:40:00 »
As a classic PCB for many years, GH60 usually be used by Tray Mount. Our team made a small change to the case by changing the top case so that the case could be support more layout. The popular Gasket Mount was used to improve the type of feeling.
In order to meet the needs of some people for bluetooth, we add the position of battery compartment inside the bottom case and add a layer of poron to optimize the abnormal sound.
Layout: HHKB, WKL, WK,Can support 60% series  most of layout
Typing Angle: 6°
Construction: Gasket mount or bottom mount.
Because this case is compatible with general 60% PCB,so the basic kit not include pcb,If necessary, you can buy it separately. The PCB will support QMK&VIA.
In addition, in order to be compatible with Bluetooth, we will offer PC and FR4 plate for the material option of plate.
The price
Target  price: $145;
The price of PCB is $25.
Kit includes: bottom case*1, top case *1, plate *1, 3.5mm Porpon sandwich pad *1, Porpon gasket tape, sandwich pad *1, EVA portable packing *1, bottom silencer pad, and other accessories
Schedule:
The first batch protype has finished.The second batch of protype will be started soon, and the case color and surface treatment process will be decided by the following IC vote.
The follow-up plan
In order to improve our product series, we will continue to launch the following series of kits in the future. If you have any suggestions, please join us for discussion.
https://discord.gg/D6tzYKgv67
« Last Edit: Wed, 03 February 2021, 05:48:01 by made in China »
Offline powwu
    • Discord
Re: [IC] Vast60- 60% keyboard
« Reply #1 on: Tue, 02 February 2021, 21:43:08 »
Pretty cool! Looks nice, pricing is reasonable. I like the compatibility with standard 60% pcbs, gives them a good use. Another board that comes to mind that does this is the Brutal60, for example. Thank you for taking the time to get a prototype done. GLWIC!
Offline Chippy
  • sus chef
« Reply #2 on: Tue, 02 February 2021, 22:14:08 »
Some of your images are very small, not sure if that was intentional or an accident.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
« Reply #3 on: Tue, 02 February 2021, 22:33:00 »
sorry,I'll replace them later
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #4 on: Tue, 02 February 2021, 23:27:13 »
I don't really understand how this would mount, do you have a diagram or exploded view or something? Looks promising otherwise : )
Offline reticent
« Reply #5 on: Wed, 03 February 2021, 01:08:01 »
Very fair price and good job with having a prototype! Not a fan of the aesthetic you're going for but this is definitely something I can easily recommend to friends trying to get into the hobby/can't justify $300+ on a case. GLWIC!
« Reply #6 on: Wed, 03 February 2021, 01:53:33 »
Offline elongatedmusk
« Reply #7 on: Wed, 03 February 2021, 02:12:38 »
Gasket mount with <200$ price point. That's a go for me.
Oh, and please consider a (dark) purple color  :D
Offline wencan008
« Reply #8 on: Wed, 03 February 2021, 02:26:14 »
I have no need for any cheap 60% boards but this is interesting. Will be keeping an eye out for this
Offline darthcapn
« Reply #9 on: Wed, 03 February 2021, 03:36:34 »
Defo one of the finer 60% cases out there! I am interested in this especially because if the price
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline atlanticise
« Reply #10 on: Wed, 03 February 2021, 03:52:16 »
This is a cool idea and I like that this case is supposed to support a lot of different kinds of layouts! A little bit confused by the final image you shared with the 4 different keyboards - I'm not sure how those layouts can be supported by the same 60% kayboard. Unless those are just sneak previews of completely different boards?
Offline Genericusername56
« Reply #11 on: Wed, 03 February 2021, 03:58:10 »
Looks great, I'd definitely get this at the price you're estimating.
« Reply #12 on: Wed, 03 February 2021, 05:21:09 »
In fact, it supports more 60% series layouts because the top case is very simple
« Reply #13 on: Wed, 03 February 2021, 05:53:32 »
The Discord link seems to be having a problem and needs to be rejoined
Offline Flexmaster
« Reply #14 on: Wed, 03 February 2021, 06:20:55 »
Looks interesting and at a very good price. Gj!
Offline Sileohaeyo
« Reply #15 on: Wed, 03 February 2021, 07:20:08 »
looks really good imo,  do you already have set case colors  in my mindestens like the 3 in the first picture?
really lovin that pink.
Will u have an IC Form up soon?
Gesendet von meinem SM-T595 mit Tapatalk
« Reply #16 on: Wed, 03 February 2021, 08:10:05 »
Could you join us on Discord? We can set up a poll there
Offline clonetropboi
« Reply #17 on: Wed, 03 February 2021, 08:31:26 »
nice
Offline treeleaf64
    • treeleaf64
« Reply #18 on: Wed, 03 February 2021, 11:38:48 »
Love to see cheap options like this pop up. Hit or miss. Hopefully it will turn out good and people will buy it.
Everyone must pay the cat tax
Offline catamscott
« Reply #19 on: Wed, 03 February 2021, 12:54:16 »
can't say no to an inexpensive bottom mount 60%. great price and i like the accent top piece/blocker :thumb:
Offline Buburoo
« Reply #20 on: Wed, 03 February 2021, 14:07:07 »
No ISO - Cucked as usual.
Offline erich8to
« Reply #21 on: Wed, 03 February 2021, 14:16:15 »
I missed out on the Square.X 60, won't miss this one. Hope there will be Navy Blue bottom and e-White top to mix and match. GLWIC
Offline nick779
« Reply #22 on: Wed, 03 February 2021, 19:36:15 »
Looks great, especially for the cost.
Please consider an Aluminum plate option too.
« Reply #23 on: Wed, 03 February 2021, 20:47:05 »
« Last Edit: Wed, 03 February 2021, 21:30:24 by made in China »
Offline Lysol_
« Reply #24 on: Wed, 03 February 2021, 22:36:24 »
definitely gonna keep an eye out for this
Offline le_bauser
  • quack?
« Reply #25 on: Thu, 04 February 2021, 10:23:30 »
this is a nice concept and a very reasonable price for gasket. I will be keeping an eye out
Offline Lenux
« Reply #26 on: Thu, 04 February 2021, 11:25:06 »
This is definitely a 60 to buy, the eye reminds me of something but i can't remember.
Anyways GLWIC
Offline Alien
« Reply #27 on: Fri, 05 February 2021, 21:17:51 »
Looks great
Offline Joaquox
« Reply #28 on: Sat, 06 February 2021, 14:18:08 »
Would love to see xd75/idobo support on plate!
« Reply #29 on: Sat, 06 February 2021, 15:53:17 »
I am more than interested in it!
Would it be possible to add split-spacebar support on the plates?
Offline MajorKoos
  • 1 life please. Extra large.
« Reply #30 on: Sun, 07 February 2021, 07:53:05 »
Great looking design.  I’d love to get one.
Offline ddnomad
« Reply #31 on: Sun, 07 February 2021, 17:26:58 »
Dark / deep purple would be nice indeed. Also having polypropylene / nylon plate options would be very sweet.
Offline LeoZ
« Reply #32 on: Sun, 07 February 2021, 18:00:50 »
been wanting to get in on the gasket mount meme for a long time, perfect price point to try it :)
Offline zoo
    • zoo
« Reply #33 on: Mon, 08 February 2021, 01:07:39 »
target price seems low for sufficient QC and also seems low as an incentive for project follow-through.
Offline Bantalope
« Reply #34 on: Mon, 08 February 2021, 01:49:28 »
Good price, Clean look, Time taken for an IC.
Lookin good to me, GLWIC!
Offline Alugo95
« Reply #35 on: Mon, 08 February 2021, 02:59:00 »
Will this be FCCS ?
Offline nick779
« Reply #36 on: Mon, 08 February 2021, 08:08:14 »
Super excited, I'm in for 3-4 of these if its unlimited.
Offline BlueBalou
« Reply #37 on: Wed, 10 February 2021, 00:43:53 »
Extremely interested ! I am happy with any color but black. Would love some additional thick foam/Silicone layers... otherwise I will fill up up the thing with playdough ;)
Offline MIGHTY CHICKEN
« Reply #38 on: Wed, 10 February 2021, 13:30:09 »
The bottom looks pretty hot
Offline Twist
« Reply #39 on: Fri, 12 February 2021, 22:09:18 »
Simple, unique... with a decent price! I'm all in!
Offline Rx003
« Reply #40 on: Fri, 19 February 2021, 05:23:57 »
Hey this looks nice interesting design! Glwic wish you all the best with this project!  :thumb: :thumb: :thumb:
« Reply #41 on: Fri, 26 February 2021, 20:46:25 »
For those of you who are not interested, please join us on Discord. GB is due to start in 10 days
« Last Edit: Fri, 26 February 2021, 22:48:29 by made in China »
« Reply #42 on: Tue, 23 March 2021, 05:51:34 »
https://forms.gle/sWqaY1MGcsAL9Mqr5,pls vote for PCB,and the prototype already finshed, GB will released soon
Offline DaaDaa
« Reply #43 on: Sat, 27 March 2021, 08:12:52 »
I went in on this big time. mekanisk and fjel will get no love from me this year lol
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline NightRye_
  • keebs n' fluff
« Reply #44 on: Sun, 28 March 2021, 01:01:43 »
This looks like an awesome budget aluminum gasket kit, any chance for a R2?
