Author Topic: [IC] BIOI G60BLE PCB Rev2 + Cora 60% Case (GB Live Now)  (Read 28176 times)
Offline Kuj0
Re: [IC] BIOI G60BLE PCB Rev2 + Cora 60% Case
« Reply #50 on: Thu, 11 February 2021, 23:50:58 »
Been waiting a year for this next drop. Best believe I will be buying a few for all my 60% boards.
Offline PlayKeyboardTW
    • Shop
« Reply #51 on: Fri, 12 February 2021, 01:23:32 »
my main source of keeb news is geekhack, so I hope to be updated once the GB starts. I'm gunning for that turquoise.
 :) We'll keep updating everything in this thread.
Thanks. ^-^
Offline sybase
« Reply #52 on: Fri, 12 February 2021, 19:30:49 »
GB period: Around February 11st depends on our process. Lasts for a month.
I can't access your store https://play-keyboard.store/ something to do NET::ERR_CERT_COMMON_NAME_INVALID
Is website not ready yet? If it is ready, can you fix it or is this issue on my end?
Offline KingOfMemes
« Reply #53 on: Fri, 12 February 2021, 19:34:44 »
From the 1st post:
PS.
We've just moved to a new platform, so the site is still under construction. It will be ready before GB starts.
Offline sybase
« Reply #54 on: Fri, 12 February 2021, 19:49:58 »
From the 1st post:
PS.
Ok thanks! I just wanted to make sure I wasn't missing something.
    • Shop
« Reply #55 on: Sat, 13 February 2021, 23:36:18 »
From the 1st post:
PS.
Thanks for the clarification! :thumb:
    • Shop
« Reply #56 on: Sat, 13 February 2021, 23:45:43 »
Guys we've edited the GB time due to our site is still not ready for GB.
We are still waiting for platform official to set us up. So new date will be after Lunar New Year. :)
Offline Domantas
« Reply #57 on: Mon, 15 February 2021, 08:18:14 »
why 3 rd switch on top is north facing on hotswap :-X ? It is usually only first two
    • Shop
« Reply #58 on: Tue, 16 February 2021, 02:59:48 »
There's a FPC connector on the back took the top position. So another key position needs to be install inverted as well. :)
Offline f1ngers_
« Reply #59 on: Tue, 16 February 2021, 04:55:01 »
Do you have a plan to upgrade the BT module to BT 5.0?
Offline lush_bunny
« Reply #60 on: Tue, 16 February 2021, 06:26:17 »
Are you still aiming to start the GB in February?
    • Shop
« Reply #61 on: Tue, 16 February 2021, 11:05:53 »
Yap. We hope to start the GB around end of Feb. :)
    • Shop
« Reply #62 on: Tue, 16 February 2021, 11:07:17 »
It will take a period to develop. ^-^
Offline CDKing
« Reply #63 on: Tue, 16 February 2021, 21:25:09 »
How much space would be needed inside a case to fit the PCB + battery module?
    • Shop
« Reply #64 on: Tue, 16 February 2021, 22:46:20 »
We set 90mm x 44mm x 8.75mm for Cora's battery compartment.
8.75mm is measured from back of PCB to top of battery. :)
Offline yui
« Reply #65 on: Wed, 17 February 2021, 03:13:06 »
i am stubborn as possible :), but how does the battery module connects to the pcb? i still want to try with my own batteries :) although i will likely still buy a module just i case i fail, as a backup, or for future use in an other project, an holder like that can be used in so many projects i would guess (depending on how it connects).
Thanks
    • Shop
« Reply #66 on: Wed, 17 February 2021, 04:19:27 »
Thanks
There's a connector on back of PCB to connect the module. ;)
    • Shop
« Reply #67 on: Wed, 17 February 2021, 22:55:29 »
Guys. New site is ready.
We'll start the GB on Fed 22nd to March 24th CST. :)
« Last Edit: Wed, 17 February 2021, 22:57:16 by PlayKeyboardTW »
Offline lush_bunny
Re: [IC] BIOI G60BLE PCB Rev2 + Cora 60% Case (GB time edited)
« Reply #68 on: Thu, 18 February 2021, 22:03:56 »
aww yis
Offline LONGZILLA
  • ヽ(`Д´)ノ rawr
« Reply #69 on: Thu, 18 February 2021, 23:58:37 »
What’s the rough/expected delivery timeline for the PCB?
    • Shop
« Reply #70 on: Fri, 19 February 2021, 04:24:38 »
It depends on how many orders we get. If we won't be short in BT module then delivery time will be 2 month approximately. :)
    • Shop
« Reply #71 on: Sat, 20 February 2021, 23:29:10 »
Hi guys!
GB page is ready: https://www.play-keyboard.store/collections/bioi-g60ble-rev2-pcb-cora-60-case-groupbuy
GB post is still waiting for approval. We'll update the link once it's been approved. :thumb:
Offline lush_bunny
« Reply #72 on: Sat, 20 February 2021, 23:47:30 »
Hi guys!
So excited!
Offline IBMweMissU
« Reply #73 on: Sun, 21 February 2021, 10:46:39 »
Awesome, been waiting for this.
    • Shop
Re: [IC] BIOI G60BLE PCB Rev2 + Cora 60% Case (GB Live Now)
« Reply #74 on: Sun, 21 February 2021, 23:06:00 »
GB is live now. We've updated the link in main post.
GB post will be updated later when it's been approved. ;)
Offline KingOfMemes
« Reply #75 on: Sun, 21 February 2021, 23:28:16 »
Nice, copped mine with the little battery compartment :thumb: :thumb: Any recommendation of BL-5J vs BL-5C?
Offline sybase
« Reply #76 on: Sun, 21 February 2021, 23:48:10 »
Just wondering if the Taiwan Post shipping option comes with any tracking or shipping insurance? If not, is there is any way to add it? I'm in the US btw. Excited for this group buy!
Edit: also need to ask what kind of JST battery do you recommend we use if we don't use the battery module (i.e. 3.7V Li-Po battery should be ok?), and is DHL Express the recommended shipping option? how reliable is Taiwan Post?
« Last Edit: Sun, 21 February 2021, 23:53:54 by sybase »
Offline IBMweMissU
« Reply #77 on: Mon, 22 February 2021, 00:43:57 »
Order placed, for one of each PCB - thrilled!
    • Shop
« Reply #78 on: Mon, 22 February 2021, 01:47:39 »
5C is a bit smaller in power comparing to 5J. I use 5J personally. ;)
Yes Taiwan Post comes with a tracking code as well. Just not as detailed as DHL Express.
You can check it from our shipping policy here: https://www.play-keyboard.store/legal/shipping
We are now using this site to track our Taiwan Post packages: https://track.aftership.com/
It's more detailed than the previous one we used.
It's unfortunately that our latest code is not available to show details in tracking site, or I'll upload a screenshot for you to check.
And of course it's recommended to use DHL Express instead if you have enough budget.
3.7v Li-Po batteries were what we used for previous version PCBs. So they are okay for sure. :thumb:
Thanks for the support! :D
    • Shop
« Reply #79 on: Mon, 22 February 2021, 01:48:10 »
Offline Shmeagle
  • Formerly dawowie
    • GMK Keycap Colors
« Reply #80 on: Sun, 28 February 2021, 20:07:46 »
Any chance the mounting points could be removable. If not, I'll be cutting mine off with a rotary tool
Are you trying to mod the case into a top/sandwich mount?
