Author Topic: MX browns are expensive  (Read 1818 times)
Offline Phaedrus2129
« on: Wed, 11 August 2010, 14:50:24 »
When I asked Das why the Silent version costs more than the regular, they said that MX brown switches cost more than MX blues. When XArmor mentioned to me that they were probably going to roll out an MX brown version of the U9BL the rep briefly griped about how MX browns are the most expensive MX switches and said, "I can see why Das charges more for their Silent version".
Why are MX browns so expensive? Is the demand for them huge and the factory has low yields? I'd think MX blues would be more expensive as a two-part stem must be more complicated to manufacture. But no, it's the browns, which must be close to the same cost to manufacture as blacks or clears.
What gives?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline MissileMike
« Reply #1 on: Wed, 11 August 2010, 14:58:41 »
The i-rocks isn't so expensive at 70$ on ebay, I think it's more the companies that use browns than the browns themselves.
BS: 5 Space Savers  ||  9 42H  ||  10 1391401 or similar  ||  1x 1390131  || AT&T 305b  ||  Dell Model M
Cherry: Leopold FC200RC/AB  ||  3 Ducky 1087  ||  PLU ML87 ||  Cherry G80-8113LUVEU-2  browns
Alps: Filco Zero Tenkeyless (fukka)  ||  ABS M1  ||  3x Dell AT101w  ||  Ancer KF-191  ||  6 Vivanco Compact
Misc: NMB RT6855T+  ||  NMB RT101 Space Invader  ||  Dell Quietkey  ||  Ge Fanuc Industrial Metal
« Reply #2 on: Wed, 11 August 2010, 15:01:19 »
I mean the switches themselves, not the boards.
Offline ch_123
« Reply #3 on: Wed, 11 August 2010, 15:03:11 »
For any supplier I have seen, they're about the same price.
Unless there's a shortage of them relative to the demand, they shouldn't be more expensive than the Blues given that they are a simpler switch internally.
« Reply #4 on: Wed, 11 August 2010, 15:11:08 »
Doh, I remember. Gah, my memory is terrible. Where'd I put my keys again? Who are you?
But still now XArmor/iOne is saying the same thing. They presumably have direct access to Cherry price lists.
