Author Topic: GMMK PRO  (Read 7340 times)
Offline phinix
GMMK PRO
« on: Wed, 24 March 2021, 10:01:24 »
Anyone here getting it?
GMMK PRO
Offline diazel
Re: GMMK PRO
« Reply #1 on: Wed, 24 March 2021, 10:14:27 »
Been in my cart more than once in the last day...
I DON'T NEED IT!
but precious....
NO! I HAVE ENOUGH KEYBOARDS
silly hobbitses never have enough keebs
Kind of looking at this as a beater high end. Something that gives me the feel and aesthetic but I don't have to worry about scratches and blemishes if I decide to throw it in my backpack and take it away from the desk.
Yeah, I think that's about all the convincing I needed.
Offline phinix
Re: GMMK PRO
« Reply #2 on: Wed, 24 March 2021, 10:29:23 »
I DON'T NEED IT!
but precious....
How about all those issues reviewers are addressing?
Would those bother you?
I ordered it, would be second wave, now kinda want to cancel...
Offline diazel
Re: GMMK PRO
« Reply #3 on: Wed, 24 March 2021, 10:42:21 »
Besides stabilizers that need a little work, what else is anyone complaining about? I only watched TaehaTypes full review of it so I'm unaware.
Offline phinix
Re: GMMK PRO
« Reply #4 on: Wed, 24 March 2021, 10:48:41 »
I've seen some issues, like bricking the board after necessary firmware update on arrival, some keys not responding, some imperfections of the chassis finish.
Those stabs will be a pain, reviewers had problems with swapping them with Durock for example, saying you would need to shave off a bit to push in.
I want a high end TKL board, dont really need this, but still weird urge told me to order it ;)
Offline diazel
Re: GMMK PRO
« Reply #5 on: Wed, 24 March 2021, 11:57:12 »
::slowly slides credit card back into wallet::
I'll need to take a closer look at some other reviews then. Definitely haven't heard about them bricking. That's a dealbreaker. Playing with plates/stabilizers is not a big deal to me. It might be annoying but then I've purchased plates from KBD that doesn't accept any MX style switch because the dimensions were too tight. I'd rather trim a little off a few stab holes than 60 individual switch sockets.
Either way, thanks for the heads up and I'm going to go watch some more reviews.
I still anticipate me buying it though  :rolleyes:
Offline phinix
Re: GMMK PRO
« Reply #6 on: Wed, 24 March 2021, 16:16:30 »
Don't remember which one was it, but the guy got two keyboards and bricked one after initial update.
It could be just one incident, not saying that all will be DOA.
Offline diazel
Re: GMMK PRO
« Reply #7 on: Wed, 24 March 2021, 18:36:39 »
Well for better or for worse, I reserved one. Seems like only Brandon had that situation happen to him regarding the bricking. Even though Nathan has a very particular style he seems to go for that isn't always for me, I trust his opinion on the rest. Badseedtech suggested he didn't have as much of the fitting issues for the stabilizers too.
As I sit here now, I'm pondering why I was so quick to pick up that board and I think it's the volume knob. Right now I tend to reach for the volume knob on my headset instead of the volume control on the computer and for some non-reason that bugs me. I'm hoping through QMK/VIA I'll be able to change it's use or even put layers on it so I could do other fun things with it.
Offline phinix
Re: GMMK PRO
« Reply #8 on: Wed, 24 March 2021, 20:41:31 »
One of the reviewers confirmed that knob will only be for volume - you can change its setting for pressing it, but not for turning.
Offline diazel
Re: GMMK PRO
« Reply #9 on: Wed, 24 March 2021, 21:24:05 »
I know they mentioned that but was thinking maybe that could be subject to change in the future with the right firmware?
Offline andred
Re: GMMK PRO
« Reply #10 on: Wed, 24 March 2021, 21:32:49 »
I assume that reviewer was referring specifically to the Glorious Core software. In QMK, you should be able to program the press like a regular switch and the turn like any rotary encoder. Here you can see the default GMMK Pro keymap.c file where they configure the volume up/down keycodes when turning it. And here's an example (different keyboard) of someone coding rotary turns depending on the layer.
Offline MrBIGEURO
Re: GMMK PRO
« Reply #11 on: Wed, 24 March 2021, 22:41:37 »
- GOAT stabs are bad - horrible, don't use stock stabs
- Durock stabs need mod to Brass plate - Just stick with aluminum or polycarb plate
- Over compressed gasket mount design - This is a design flaw, but still better than an integrated mount
- Firmware flash - Non-issue will be addressed or warrantied
With all that said, I'm planning to get one and decide after I get it if I will keep it. It still looks like a decent board. If you are on fence because you think over $125 is too much for a board, then this board is for you. If you currently have keyboards (not Logitech/Razer/Corsair) that's over $200, then you should skip this board. This board are for those that consider $100-200 for a 'custom' board appropriately priced.
If you experienced with custom keyboards over $250-500 range, then skip. If you are using a Corsair/Logitech/Razer keyboard right now, you should consider this board. The other boards that I consider competes with GMMK Pro are the Idabao ID80v2, Ikki68 Aurora, Rama Kara, Bauer Lite, KDB67, Portico. At which point, the GMMK Pro still a fair buy against those. Although I'd say the Aurora is my favorite of those.
Offline Leslieann
Re: GMMK PRO
« Reply #12 on: Wed, 24 March 2021, 22:57:50 »
The Glorious software may be limited but with it using QMK you shouldn't be limited to just their software and even if they try that, someone will bypass that limitation.
That's one of the nice things about open source.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline phinix
Re: GMMK PRO
« Reply #13 on: Thu, 25 March 2021, 04:28:35 »
I guess you cannot order Aurora anymore?
Offline yui
Re: GMMK PRO
« Reply #14 on: Thu, 25 March 2021, 05:58:27 »
in the original GB they said there would be multiples runs, and hopefully now that the tooling is paid maybe even cheaper
Offline phinix
Re: GMMK PRO
« Reply #15 on: Thu, 25 March 2021, 07:52:34 »
Oooh, nice:)
