Author Topic: [IC] GMK Infernal | GB ENDING IN 3 DAYS!!!!  (Read 132843 times)
Offline Blamby
Re: [IC] GMK Infernal | GB month announced
« Reply #50 on: Wed, 28 July 2021, 00:54:28 »
Updates:
26.07: announced GB date
           novelties revamped
           new render on tgr alice
I think you should turn on design of ansi novelties to left shift key, this way it won't be left out on neither iso or ansi. You have 4 ansi enter novelties right now and it's not only excessive but also expensive for the kit. This change can reduce from 4 ansi enters to 2 with a left shift.
I planned the cerberus to be on shifts and the wings on enters, but thank you I discovered that I need to change their postion a bit ro be how I planned
Offline balance
« Reply #51 on: Sat, 31 July 2021, 16:32:02 »
The iso enter noveltie is just fire
Offline Blamby
« Reply #52 on: Wed, 11 August 2021, 03:31:44 »
Worldwide vendor collaboration
Offline udller
« Reply #53 on: Wed, 11 August 2021, 04:02:47 »
i thought there would at least be one pentagram :(
Offline Blamby
« Reply #54 on: Tue, 31 August 2021, 14:55:18 »
Update: New Kitting renders
            Small changes in kitting
            New noveltie
Offline Blamby
Re: [IC] GMK Infernal | New Kitting renders
« Reply #55 on: Fri, 17 September 2021, 14:46:33 »
Update: New renders
Offline ctrl+shift+n
« Reply #56 on: Fri, 17 September 2021, 15:51:22 »
Nice renders
Offline Dinerenblanc
« Reply #57 on: Sun, 19 September 2021, 21:31:04 »
 Check out MW Heresy. No actual pentagram, but gets pretty close.
https://geekhack.org/index.php?topic=114631.0
Offline konstantin
  • Formerly constexpr
« Reply #58 on: Sun, 19 September 2021, 21:41:53 »
You sure about that?
Offline konstantin
« Reply #59 on: Sun, 19 September 2021, 21:54:52 »
BASE KIT:
ALT MODS:
The 1.75u Shift in both of these is mislabeled as 1.50u.
I don't think it's worth including the numpad mods in the Alt Mods kit. That's gonna be one hell of an expensive kit even without them.
BASE KIT:
You might want to include a second 3c space in this kit, that way it will be possible to cover standard split 7u space (3–1–3).
NORDEUK KIT:
The R4 1u <> key should be changed to \|. Angle brackets are already included in the base kit, and the pipe is necessary for ISO-UK.
The R4 1u ;: key has an incorrect legend, it should be changed to ,;.
« Reply #60 on: Sun, 19 September 2021, 22:06:44 »
Yes, a pentagram in the traditional sense is simply a 5 pointed star. The modern idea of a pentagram has the star encased in a circle, yes, but it's not necessary.
edit*
Oops, just figured out what ya meant with your reply.
« Last Edit: Sun, 19 September 2021, 22:20:04 by Dinerenblanc »
Offline Blamby
« Reply #61 on: Mon, 20 September 2021, 01:51:33 »
BASE KIT:
ALT MODS:
BASE KIT:
NORDEUK KIT:
Thank you for help, I'll try to change it asap
Offline hagiwaraDaisuke
« Reply #62 on: Mon, 20 September 2021, 03:36:53 »
Does the 6 1u R1 novelties right? I thought that there would be at least one R2,R3 1u novelties for something like a 65% or 75%
Offline Blamby
« Reply #63 on: Tue, 21 September 2021, 06:31:28 »
Offline Blamby
« Reply #64 on: Wed, 22 September 2021, 14:04:01 »
Update: Small changes in kitting
Offline Blamby
« Reply #65 on: Fri, 24 September 2021, 13:50:55 »
We got a UK Vendor
Offline Djengiss
« Reply #66 on: Sun, 26 September 2021, 03:25:24 »
Has the raffles for the Artisans for this set run yet, or are they running with the GB?
Offline wgsunrise
« Reply #67 on: Wed, 29 September 2021, 00:13:56 »
Totally agree with this. Please take this change into consideration.
Offline Blamby
Re: [IC] GMK Infernal | Small Changes in Kitting
« Reply #68 on: Thu, 30 September 2021, 12:35:19 »
Update: fixed some mistakes in latin kit and added r2 r3 noveltie
Offline STUDIOBLB
« Reply #69 on: Thu, 30 September 2021, 16:52:39 »
Love the colours on this set! GLWGB!
Offline Blamby
« Reply #70 on: Fri, 01 October 2021, 14:44:43 »
Thank you!
Offline Bubblegum
« Reply #71 on: Sat, 02 October 2021, 04:59:42 »
Suggestion for the novelty kit to have different 1u novelties for r1-r4 so the right side rows of a 65%/75% is more varied. Just avoiding having the one and same icon across the column. Example: R1 you can use the hand, r2 can be the ribcage, r3 the skull and bones, while r4 stays the same. Or any other setup with the same goal in mind :)
Offline hark
« Reply #72 on: Sat, 02 October 2021, 06:36:09 »
I'm not sure if my thinking is wrong but I feel like it might be beneficial to make the sublegends UV printed given that they're all custom and will require new moulds.
I do really like the look of the subs though.
Offline Blamby
Re: [IC] GMK Infernal | Group Buy starting on 16 October
« Reply #73 on: Sun, 03 October 2021, 05:45:39 »
Update: Groupbuy starts on 16 october
Offline Blamby
« Reply #74 on: Mon, 04 October 2021, 13:40:24 »
thank you, the sublegends will be UV printed, I planned it from the beggining
Offline Blamby
Update: revealed some collaborations
Offline Bubblegum
Any news on pricing for this?
Offline Blamby
Re: [IC] GMK Infernal | Group Buy delayed to 22 october | More collabs!!
« Reply #77 on: Fri, 15 October 2021, 13:36:59 »
Update: GB Delayed to 22 october
 small changes in novelties design; Took out ISO noveltie
Offline Blamby
Re: [IC] GMK Infernal | Pricing Revealed | GB tomorrow
« Reply #78 on: Thu, 21 October 2021, 00:16:09 »
PRicing revealed
Offline Finite
  • peer pressured into mk hobby, pls send help
« Reply #79 on: Fri, 22 October 2021, 14:22:05 »
I can understand not wanting to do a 40s kit since it can be a little hard to hit MOQ, but why not do 3key in base kit? Also, why do a NordeUK kit when that's even harder to hit MOQ? I'm not trying to be a ****, but it just doesn't make sense to skip out on 40s like this.
Offline Blamby
Re: [IC] GMK Infernal | GROUP BUY LIVE
« Reply #80 on: Mon, 25 October 2021, 03:01:40 »
GB IS LIVE NOW!!!!
Offline Blamby
Re: [IC] GMK Infernal | GB ENDING IN 3 DAYS!!!!
« Reply #81 on: Fri, 19 November 2021, 13:37:55 »
Group Buy ending in 3 days!!!!!!!!!!!
Offline BerserkeR
« Reply #82 on: Tue, 27 June 2023, 15:38:50 »
Is there an update? A couple vendors had Q1 2023 as shipping date.
Offline Neely_12
« Reply #83 on: Tue, 27 June 2023, 21:22:38 »
If color matching is done, prob August or September
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #84 on: Wed, 28 June 2023, 23:55:19 »
There is slightly more discussion in the GB thread - https://geekhack.org/index.php?topic=115050
