Author Topic: [IC-2] Coarse60 - GROUPBUY LIVE - Affordable Leaf-Spring Alice 60%  (Read 34241 times)
Offline seh0nk
    • tech advantage blog
Coarse 60% IC-2
275888-0
Introduction and Updates
The Coarse60 is an aluminum alice 60% with premium features at $210.
GROUPBUY IS LIVE 10/3/2021
Kit:
https://keebsforall.com/collections/group-buys-and-pre-orders/products/coarse60
Extras:
https://keebsforall.com/collections/group-buys-and-pre-orders/products/coarse60-pcb
This post will be locked soon for a gb post tomorrow but I would like to thank everyone for this amazing opportunity. I hope you will support this gb, and have a good day!
-sehonky
UPDATE 9/26/2021 Andy's Stream of the Coarse60 is in and it was great! https://www.twitch.tv/videos/1158988347?t=01h45m10s for type test.
"This board is a banger"
-Andy V Nguyen
UPDATE 9/8/2021 After one factory botching of the PCB prototype, we switched factories, finally got all the pieces together and built the prototype. The price is now an even $210 to account for the new, more expensive (but more reliable) PCB factory as well as other accessory costs such as o-rings and standoffs. We still think this is a great price and hope you will too.
I have taken some prototype pictures so you guys can see what it looks like IRL and we are sending it to Andy V Nguyen soon for a build stream and video.
Lastly, we are anticipating a groupbuy start on October 3rd. Stay tuned for a groupbuy post with more information.
Update 4/26 Due to popular opinion, e-white has been added to the color selection. Available colors are now black, navy, and e-white. Also, the streamlined version has been chosen.
Update 4/13 Streamlined version has won with a large majority. We have ordered a prototype for it.
Keebsforall Discord for updates: https://discord.gg/dRjsAh5jMX
Table of Contents
Intro and Updates
Photos and Renders
Specifications
Vendors
Frequently Asked Questions
Closing Remarks
Prototype Photos and Renders
266242-2
Note: plate has holes for standoffs attaching to PCB.
275876-3
275878-4
275880-5
275882-6
275884-7
275886-8
275888-9
275890-10
Specifications
If you require any more information feel free to join the Keebsforall discord server, leave a comment, or refer back to IC-1: https://geekhack.org/index.php?topic=111192.0;topicseen
Front Height: ~20.5mm
Additional keys supported: split backspace, 2u spacebar, split rshift, stepped capslock. All supported with hotswap except split backspace which is soldered.
Typing Angle: 6.9 degrees
Plate materials: aluminum, POM
Case colors: Navy, Black, and White. All e-coated.
Kit Price: $210
Vendors
US: KeebsForAll
CA: Ashkeebs
UK: Keebcats
EU: Keygem
SEA: ZionStudiosPH
OCE: DailyClack
FAQ
So all positions mentioned in the specifications are supported with hotswap?
Yes, thanks to creative hotswap socket positioning by our PCB guy taylor.
Iso Support?
No, by nature of alice layout.
Won't the sound be hollow?
After experience with the prototype, the board will not sound hollow when using the o-rings and acrylic bottom at normal typing distance. Using the POM plate will further mitigate this issue.
Can you further explain the mounting?
Of course - If you look at the photo of the plate, there are four holes, one in each corner. Those will be used to screw the plate into the case, and will be the only points of pressure on the plate. The plate will flex when the strips of metal connecting the hole to the main plate bend.
Closing Remarks
I have been working very hard on this keyboard and hope you enjoy it.
Please consider joining the Keebsforall Discord server to receive updates! https://discord.gg/dRjsAh5jMX
Special Thanks:
Candice at Keebsforall - groupbuy and logistics
Jerry at Keebsforall - keyboard strategy
Patrick from Neokeys - file review
Rhuk.tech - USB port help
Taylor - PCB man
Thank You for reading.
-seh0nky
« Last Edit: Mon, 04 October 2021, 03:28:04 by seh0nk »
Offline hayt
Re: [IC-2] Coarse60 - PROTOTYPE RECEIVED - Affordable Leaf-Spring Alice 60%
« Reply #1 on: Fri, 09 April 2021, 18:19:25 »
P cool
Offline Chippy
  • sus chef
« Reply #2 on: Fri, 09 April 2021, 18:25:21 »
damn that is a lot of keyboard, looks nice. That usb port is a pretty good compromise if you don't want to use a db.
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline hayt
« Reply #3 on: Fri, 09 April 2021, 18:27:30 »
Can we see a slim one with virtually no chamfer? I think that would be extremely clean.
Offline adularescence
« Reply #4 on: Fri, 09 April 2021, 19:34:39 »
 :thumb: :thumb: :thumb:
i am determined to shell out money for this regardless of the design chosen
Offline seh0nk
« Reply #5 on: Fri, 09 April 2021, 19:51:40 »
uh... it seems I forgot to reserve a post. Anyway reserved
Offline seh0nk
« Reply #6 on: Fri, 09 April 2021, 19:55:29 »
P cool
:thumb:
I will look into this. Good idea!
Thanks for the support  :thumb:
Offline Ustinj
« Reply #7 on: Sat, 10 April 2021, 01:00:18 »
Looks good so far - I saw a few comments on the other thread about how it was bad that it was a rectangle, but I'm all for it. Tons of keyboards are plain rectangles, and an Alice layout as a rectangle is pretty unique actually. Kind of like the Lubrigante, where I preferred the rectangular version over the chinned version. Though the little bit of rounding where the acrylic bottom piece meets the case looks a bit strange. How come this needed a new thread?
Offline MisterWaffle
« Reply #8 on: Sat, 10 April 2021, 01:07:39 »
yuge keyboard. like the angle
Offline seh0nk
« Reply #9 on: Sat, 10 April 2021, 10:26:05 »
Thanks for the feedback. Could you elaborate on which edge is rounded? As for your last question, I thought this warranted a new thread because the design decision we had to make was very significant, and the prototype had been received.
Offline hizkia
« Reply #10 on: Sun, 11 April 2021, 13:12:53 »
Nice Boar, Nice Design alreadyd submit the IC Form.
really want hear your opinion about the typing feel on this keyboard and the sound test.
Thank you.
Offline Yumelon
I just like how I can use a normal wrist wrest for this lol
Offline seh0nk
That's the idea!
Offline i luv chuletas
Damn, love the blocky version. Might need to pick this up!
Offline seh0nk
Update 5-19-2021
Hey everyone. Thanks for the support so far. This is the current state of the project:
  • The streamlined version has been chosen by popular opinion.
  • The colors chosen are e-white, black, and navy.
  • We have ordered a prototype in the e-white colorway.
  • The groupbuy is going to start in the next few months, barring problems with the prototype.
  • We are waiting for the PCB prototype.
Thanks for your patience! For the most current updates join the discord: https://discord.gg/dRjsAh5jMX
Offline jabe8i
THAT PRICE POINT THOO!!!
Offline seh0nk
Offline Rumblethumps
Aww, I really liked the blocky one lol. Still in for the slim version though, that price is incredible!
Offline seh0nk
Thanks! Hopefully the GB will come in the next 2-3 months!
Offline knobbers
Have you ordered a pcb prototype yet?
Offline seh0nk
Yep, it's coming!
Offline seh0nk
Re: [IC-2] Coarse60 - BIG UPDATES - Affordable Leaf-Spring Alice 60%
« Reply #21 on: Thu, 09 September 2021, 01:11:36 »
Hey guys, thanks for all your patience.
There are some big updates; firstly I received all components of the prototype, and secondly, we are aiming for an October GB date! See all the news at the top of the post and check out the prototype photos!
Have a great day.
-seh0nky
Offline darthcapn
« Reply #22 on: Thu, 09 September 2021, 03:12:24 »
love what you folks are doing for the community. Totally love that e-white got added to the color choice! Looking forward to the gb!
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline WejB
« Reply #23 on: Thu, 09 September 2021, 04:55:23 »
How come there wont be a eu vendor. I would love if you added a eu vendor
Offline unusuaL_
« Reply #24 on: Thu, 09 September 2021, 09:48:56 »
please consider eu/uk vendor
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline seh0nk
« Reply #25 on: Thu, 09 September 2021, 10:17:39 »
UPDATE: EU vendor is KeyGem!
For those of you wondering, there probably will be an EU/UK vendor, we just haven't decided on it yet
« Last Edit: Sun, 03 October 2021, 16:34:10 by seh0nk »
Offline seh0nk
« Reply #26 on: Thu, 09 September 2021, 10:18:00 »
 :thumb:
Offline seh0nk
« Reply #27 on: Fri, 10 September 2021, 20:59:37 »
Update 9/10/2021
Wanted to let you guys know the prototype is now in the process of getting shipped to Andy V. Nguyen!
Offline seh0nk
Re: [IC-2] Coarse60 - Big Updates - Affordable Leaf-Spring Alice 60%
« Reply #28 on: Wed, 15 September 2021, 18:01:27 »
Update 9/15/2021
Super excited to say that we have confirmed vendors! They are in the main body of the post but in case you missed them:
US: KeebsForAll
CA: Ashkeebs
UK: Keebcats
EU: Keygem
SEA: ZionStudiosPH
OCE: DailyClack
Have a good day,
-seh0nky
Offline kameron
« Reply #29 on: Wed, 15 September 2021, 19:43:45 »
this board is very interesting and has a great price definitely interested
Offline dantambok
« Reply #30 on: Wed, 15 September 2021, 21:09:26 »
very nice
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline seh0nk
« Reply #31 on: Thu, 16 September 2021, 02:32:54 »
very nice
Glad to hear!
Offline Sh1zaru
    • Keeb Studio
« Reply #32 on: Thu, 16 September 2021, 02:53:16 »
Price point is great and as there is a EU vendor I might join
Offline CookieFlow
« Reply #33 on: Tue, 21 September 2021, 20:02:36 »
First time I see an Alice board in a pure rectangle without the alice shape, I'm still not 100% sure how I feel about it.
But the price point makes this very attractive.
-Is there a reason we cannot get split backspace on the hotswap PCB?
-Are the colors final? I have nothing against them per say, but black/white/navy are probably the most common colors for boards. It's always nice when boards have at least one original/unusual color.
Offline Ustinj
« Reply #34 on: Wed, 22 September 2021, 01:25:49 »
The Wonderland + Lubrigante was a rectangular Alice layout - I kind of liked it being different.
Offline seh0nk
« Reply #35 on: Wed, 22 September 2021, 11:52:46 »
Hi!
1. The reason for no split backspace is that the sockets would block the full backspace position.
2. The colors are final, sorry. The way we decided the colors was taking a survey and picking the three most popular.
Thanks for you interest and the questions!
Offline Tulesto
« Reply #36 on: Thu, 23 September 2021, 13:37:40 »
Oh yeah this is an easy buy for me. Great price point and great options with the PCB.  :thumb:
Sangeo/Suit/Spring/Angle/CW88/Kohaku/Unikorn/Navi/Corsa
Offline kukkurovaca
« Reply #37 on: Thu, 23 September 2021, 13:56:34 »
It's too bad about the split backspace. TKC Candybar is able to do hotswap split and full backspace, but I can imagine it would be harder on an Alice type plate.
Offline seh0nk
« Reply #38 on: Fri, 24 September 2021, 15:36:32 »
Yep. We will look into creative solutions for R2 or future iterations.
:D
Offline Gvalch_ca
« Reply #39 on: Fri, 24 September 2021, 18:16:54 »
Pretty nice looking keyboard. And I like the concept of flat non-CNC bottom piece.
But please consider adding an aluminum/brass bottom option.
Lead Keyboard Cringeneer.
Alps and Space Invaders enthusiast.
Offline seh0nk
« Reply #40 on: Sun, 26 September 2021, 11:59:37 »
Thinking about adding a metal accent option as a "max" kit. But that is still up in the air.
Offline seh0nk
« Reply #41 on: Sun, 26 September 2021, 12:03:47 »
Hi All,
I am super excited to announce that the stream with Andy V. Nguyen has been completed and it went very well!
-Andy V. Nguyen
That is the link to the sound-test portion.
Groupbuy starts October 3rd! For the newest updates join the KeebsForAll discord: https://discord.gg/dRjsAh5jMX
Offline baka jiken
Re: [IC-2] Coarse60 - Andy's Stream In - Affordable Leaf-Spring Alice 60%
« Reply #42 on: Mon, 27 September 2021, 21:25:11 »
It sounds amazing. Not going to lie. Looking forward to GB :eek:
Offline seh0nk
« Reply #43 on: Sun, 03 October 2021, 16:30:51 »
GROUPBUY IS LIVE!
Kit (you can also find your regional vendor here, or in the main post):
Extras:
This post will be locked soon for a gb post tomorrow but I would like to thank everyone for this amazing opportunity. I hope you will support this gb, and have a good day.
-sehonky
« Last Edit: Sun, 03 October 2021, 16:34:33 by seh0nk »
