Author Topic: [IC] MW STONE Age (GB IS LIVE | QK65 collab late April)  (Read 82766 times)
Offline garald
Re: [IC] ePBT STONE Age
« Reply #50 on: Sun, 18 April 2021, 10:56:56 »
just curious, will the wording on the deskmats be changed now that the set has been renamed?
Offline Jr.Mars
« Reply #51 on: Sun, 18 April 2021, 19:25:19 »
Of course,the wording on the deskmats will be changed.I will release more details this week.
Offline //gainsborough
  • MATRIXの日常
« Reply #52 on: Sun, 18 April 2021, 20:35:04 »
ストーンワールド ?
Offline Jr.Mars
« Reply #53 on: Sun, 18 April 2021, 22:45:15 »
PBT
Offline Fraaaan
« Reply #54 on: Mon, 19 April 2021, 13:00:04 »
 Please fix ISO support in base kit. You need more than just the Enter to support an ISO layout.
Offline bowljob
« Reply #55 on: Mon, 19 April 2021, 15:54:06 »
PBT!
I  like this.
Offline mr_foggy
  • neue = nope
« Reply #56 on: Mon, 19 April 2021, 20:14:46 »
@OP, for minimum ISO compat you might want to add:
  • \|む in R3 base
  • <>ろ or \|む in R4 base
  • \| in R3 latin
  • <> or \| in R4 latin
other than that, it looks nice. having missed Dandy I might get a base kit.
Offline mechajosh
« Reply #57 on: Mon, 19 April 2021, 22:08:17 »
I like the theme behind this set, i do think taht you should find a way to incorporate the red that is found in senku's eyes.
Offline Jr.Mars
« Reply #58 on: Tue, 20 April 2021, 05:12:27 »
Thanks for your advice.I tried red but i'm not very satisfied.
Offline Bonsa
« Reply #59 on: Tue, 20 April 2021, 05:55:23 »
"stone age"
what I think: apes/men, caves, saber tooth tigers, mammoths, animal skins, a fire
what the internet thinks: ANIME
Offline GraffitiDecos
« Reply #60 on: Tue, 20 April 2021, 08:25:38 »
I like the colors for sure.
I would suggest adding the mod color enter and numpad return to base kits and put the light color in the light mod kit.
Also, personal preference, but I dislike the numpad sublegends preferring a more clean look. Do many people still use those keys?
Offline Jr.Mars
« Reply #61 on: Mon, 26 April 2021, 21:50:38 »
  • \|む in R3 base
  • \| in R3 latin
I update"ISO_UK",thanks for your advice.
Offline treeleaf64
    • treeleaf64
Re: [IC] ePBT STONE Age(Kits updates)
« Reply #62 on: Mon, 26 April 2021, 22:40:09 »
When you say "Stone age"
I'm not seeing the stone tools or the cavemen or anything
So where did they go
or is it supposed to be based off some Anime series?
Everyone must pay the cat tax
Offline Arcoril
« Reply #63 on: Tue, 27 April 2021, 01:59:03 »
The escape and both enters on the light modifiers set should be light since the dark versions are already included in the base set. With the current kitting you'd end up with duplicates of those keys if you purchased the light modifiers.
Offline lakeboredom
« Reply #64 on: Tue, 27 April 2021, 02:36:43 »
The colors here are really underwhelming.
Offline Neracles(Norway)
« Reply #65 on: Tue, 27 April 2021, 04:09:31 »
Any chance of a Nordic set being added?
Offline Jr.Mars
« Reply #66 on: Tue, 27 April 2021, 07:00:15 »
Thanks for your advice.If you buy dark and light base both,you will get 3 esc and enters in different color,not the same color.
Offline Arcoril
« Reply #67 on: Tue, 27 April 2021, 17:01:23 »
Gotcha, thank you! I was just going by the kit pictures on the main post where it looked like the base kit was bundled with the dark modifiers. If they're separated out then that makes sense.
Offline Antivity
  • Keycap Designer
« Reply #68 on: Sat, 01 May 2021, 22:13:56 »
This set is very well made :thumb:. The novelties look very nice. Hopefully, this set doesn't face IP issues. GLWIC
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #69 on: Sat, 01 May 2021, 23:55:19 »
Oh yup I thought Dr. Stone before getting into the thread. I have some ideas but I'm not sure how far into the manga you're going.
Offline Krigen
« Reply #70 on: Sun, 02 May 2021, 11:42:30 »
When I saw the thread I thought it would be either a stone themed set or Dr. Stone, I was right. Overall the colours are really good, if it were up to me the light mods are not really needed.
Offline CookieFlow
« Reply #71 on: Sun, 02 May 2021, 14:16:44 »
Preferences.
Personally I much prefer the light mods than the ones in the base kit.
Offline ab042896
« Reply #72 on: Mon, 03 May 2021, 08:23:49 »
Preferences.
Agreed, and getting Light Mods along with the Latin Alphas allows for a distinct set and other combination with the Base Kit. Without these I would personally pass on the set altogether because of hiragana.
Different strokes for different folks  :thumb:
Offline Jese
  • Newbie mechanical keyboard boi
« Reply #73 on: Mon, 03 May 2021, 23:33:43 »
Are there any plans on NordeUK kit?
Offline Arkells
« Reply #74 on: Tue, 04 May 2021, 23:47:03 »
Would you be able to add Deskhero as a Canadian vendor? Love the set!
Offline Jr.Mars
« Reply #75 on: Fri, 14 May 2021, 03:45:30 »
Just name it Dr Stone or Doctor Stone, some variation, doesn't have to be a complete rename. Either way I like the colours and I'm in once the GB is out
Sent from my LYA-L09 using Tapatalk
Thanks for your advice,and i've renamed the set to "STONE Age".
Your set is cool as well, good luck to you bro.
Offline Izeri
« Reply #76 on: Fri, 14 May 2021, 04:56:28 »
Offline robsta
Re: [IC] ePBT STONE Age (more renders updates&Kits updates)
« Reply #77 on: Mon, 17 May 2021, 01:19:40 »
sadly no NorDE / International Kit - SENKU!!!!
[img width=198 height=78]
Offline NitPik
« Reply #78 on: Wed, 26 May 2021, 10:33:39 »
Discord link seems to be broken
Offline Jr.Mars
Offline Jr.Mars
Offline Jr.Mars
DELETED
« Last Edit: Wed, 26 January 2022, 03:33:15 by ElvisXSS »
Offline KID
I like the way the colors are chosen for this theme
Offline Jr.Mars
Re: [IC] MW STONE Age (Manu changed | Everything is redesigned)
« Reply #83 on: Wed, 26 January 2022, 07:19:55 »
※ ChangeLog
1. Changed the manu from ePBT to Milkyway.
>>> Milkyway has high dye-sub quality, shoter lead time and lower price <<<
2. Everything of this set was redesigned.
>>> new novelties | new kittings | new renders | new deskmats | new collab <<<
>>> If you want to see the previous kitting layout, you can click here <<<
3. GB will be happened in early April.
Re: [IC] MW STONE Age (Manufacturer changed | Whole set redesigned)
« Reply #84 on: Wed, 26 January 2022, 08:25:48 »
oh man i'm so excited for this set!
Offline sorathiel
« Reply #85 on: Wed, 26 January 2022, 08:44:52 »
something weird is happening in that international kit. you don't have the regularly offending [; :] error that has haunted norde kits for months but instead there's a [' ;] ? Or that's the weirdest comma I've ever seen. Please double-check the proper symbols are used. Too many sets go into GB with an error in that specific key  :)
Offline CLAP_STUDIO
« Reply #86 on: Thu, 27 January 2022, 07:07:51 »
RESERVED!!! I MUST HAVE IT RIGHT NOW!
  • MATRIXの日常
Offline anonympku
« Reply #88 on: Fri, 28 January 2022, 08:30:15 »
1. Personally, I don't like the novelties which looks like right and left eyes. A little bit weird as far as I'm concerned.
2. Did you change the color from WS1 to WS2? I think the old epbt version is a little bit darker than this set.
3. Is it possible that you move the four arrow keys from the novelties to the light accents?
I love this set and will buy it without any doubt. Hope it will be better :)
Offline Jr.Mars
« Reply #89 on: Sun, 30 January 2022, 12:13:49 »
Thanks for your feedback
1. will change the 1.25u eyes novelties to another artwork
2. no! i don't change the color way. it's still ws1
3. will add yellow arrow key novelties in the accent kit
Offline EdwardsLau
« Reply #90 on: Wed, 02 February 2022, 13:30:52 »
What a long journey! I can wait no more! Let's go Stone Age!
Offline Designerstudio
  • Keeb-related producer
« Reply #91 on: Wed, 02 February 2022, 13:34:07 »
What a fresh-looking keyset. I think this will be a great match with my avocado keyboard.
Discord:https://discord.gg/3TqZ2M8Hw2
Email: designerstudio@126.com
Wechat: DesignerStudio7
Offline misotsu
« Reply #92 on: Wed, 02 February 2022, 19:56:17 »
Oh, just saw this. looks good. GLWIC~
Offline FamilyJoule924
« Reply #93 on: Wed, 02 February 2022, 23:49:21 »
really like the set but is there any way you can make hiragana monos? or maybe the light green alphas with white letters?
Offline teddo
« Reply #94 on: Sat, 05 February 2022, 12:02:24 »
Yes for every pastel green set, glwic !
Offline Jr.Mars
Re: [IC] MW STONE Age (Vendor list set | GB date announced)
« Reply #95 on: Mon, 07 February 2022, 20:07:40 »
※ ChangeLog
1. Added arrow keys novelties in light acctent kit.
2. Adjusted r4 1.25u novelties in novelities.light accent kits.
3. Moved 6.25/7u yellow spacebars from light accent kit to spacebars kit
Offline CharlotteS
« Reply #96 on: Sun, 13 February 2022, 08:32:07 »
just saw this adorable set on reddit!
another clean set! Good luck!
Offline vkeycaps
  • Artisan keycaps maker
    • Website/Store
« Reply #97 on: Tue, 15 February 2022, 06:05:26 »
Color scheme is perfect! Waiting for this.
Offline Jr.Mars
Re: [IC] MW STONE Age (HIBI Collab announced)
« Reply #98 on: Wed, 23 February 2022, 21:13:29 »
HIBI Collab Announced!!
R3 2.25U ansi enter with gold PVD and green glow enamel fill
R1 1U with gold PVD
Offline Jr.Mars
Re: [IC] MW STONE Age (QK65 collab | GB next week)
« Reply #99 on: Thu, 31 March 2022, 22:30:06 »
※ ChangeLog
1. QK65 collab!!!!!!
>>>Renders Gellary<<<
If you have any interest in this collab, pls join my discord to get more information!
