Author Topic: [IC] GMK Diner | GB Aug 1 - Sep 1  (Read 32570 times)
Offline mvkb
  • Designer
    • MVKB
« on: Fri, 30 April 2021, 20:51:44 »
Group Buy Thread
Ketchup or mustard?
Inspired by the seemingly-mandatory diners present in most of the shows we watched growing up. Wouldn't it be cool to deck out your keyboard like it was actually part of your favorite 90's sitcom? It would, it would be totally cool. Proud to introduce to you GMK Diner.
Group Buy runs from August 1 until September 1
268383-0
Pricing
272426-1
268383-2
Base and modifier novelties on a RAMA M60a.
Base, spacebars and modifier novelties on a RAMA Koyu.
Base, spacebars, modifier novelties and macro novelties on a Vulcan Maja.
Base kit on a KeliumWorks Pillow65.
268383-3
Base Kit
A simple yet complete base kit covering your typical 60-100%, including HHKB and Alice layouts. ISO and minimal 40s support included.
Modifier Novelties
A variety of novelties for escape, enter, ISO enter, control, win, alt and fn keys.
Macro Novelties
4 columns and 5 rows of novelties – yours to mix and match.
NorDe
Spacebars
268383-4
Deskmats
268383-5
Collaborations
Artisans by Protozoa
Cable by Space
Soon™
268383-6
Vendors
  • EU: CandyKeys
  • Canada: AshKeebs
  • UK: Protozoa
  • US: Protozoa
  • Mexico: Rheset.mx
  • Argentina/Uruguay/Chile/Peru: Latamkeys
  • Oceania: Daily Clack
  • South Korea: Monstargear
  • SEA: Monokei
  • China: KBDfans
  • Japan: Basekeys
268383-7
Colors
Left to right: RAL 5007, RAL 5000, RAL 3028 and RAL 1023. 2 decades ago these would've been the brightest colors you can imagine, but the many many years of sitting in a diner had a fading effect on them. Is that grease I smell?
268383-8
Up next
  • Vendors
  • Deskmats
  • Collaborations
  • Group buy date
268383-9
268383-10
Signature
Code: [Select]
[url=https://geekhack.org/index.php?topic=112587][img width=300 height=120]https://i.imgur.com/z5cDhve.png[/img][/url]
« Last Edit: Mon, 02 August 2021, 09:45:53 by mvkb »
Offline mvkb
  • Designer
    • MVKB
Re: [IC] GMK Diner
« Reply #1 on: Fri, 30 April 2021, 20:53:44 »
Changelog
  • May 5 2021: Removed second 2u spacebar, reshuffled legends for macro novelties (so that people who buy both novelty kits don't end up with duplicates).
  • May 6 2021: Added deskmat renders.
  • May 7 2021: Added minimal 40s support (R2 1.75U backspace, R3 1.25U tab, R3 1.5U return).
  • May 12 2021: Added vendors
  • May 14 2021: Added signature
« Last Edit: Fri, 14 May 2021, 19:09:19 by mvkb »
Offline LittleAad
  • Hello
Re: [IC] GMK Diner
« Reply #2 on: Fri, 30 April 2021, 21:02:11 »
Your iso support is off. Choose between terminal or UK, I wouldn’t do both. Also, why the second 2u space in spacebars kit? Glwic!
Offline NovaRMK
Re: [IC] GMK Diner
« Reply #3 on: Fri, 30 April 2021, 21:04:14 »
Personally not a fan of the yellow spacebars, other than that this set is pog.
Offline dededecline
    • Linktree
Re: [IC] GMK Diner
« Reply #4 on: Fri, 30 April 2021, 21:48:54 »
Could we get three key 40s (r2 1.75u backspace, r3 1.25u tab, r3 1.5u enter) added to the base kit?
Love the colors here, reminds me of Nickelodeon/Cartoon Network show representations of diners.
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Diner
« Reply #5 on: Fri, 30 April 2021, 21:52:17 »
could the split bars in the spacebars set be RAL 500* and then you keep the accent yellow 6.25u and 7u?
in for it though
Offline Bub
    • big bub's beepers
Re: [IC] GMK Diner
« Reply #6 on: Fri, 30 April 2021, 21:53:19 »
VERY well formatted IC, but agreed with others your kiting could use some work
Offline Cubic // esc lab
  • Formerly 'esclab'
    • esc lab
Re: [IC] GMK Diner
« Reply #7 on: Sat, 01 May 2021, 04:31:08 »
It's not my style but I gotta admit this is cuuuuuute
GLWIC
Offline kk806
Re: [IC] GMK Diner
« Reply #8 on: Sat, 01 May 2021, 04:57:43 »
reserved.
Offline Fraaaan
Re: [IC] GMK Diner
« Reply #9 on: Sat, 01 May 2021, 08:32:03 »
Consider adding R3 PgUp and R4 PgDn to support blockered 65/75% boards
Offline guill3m
  • Shut up and take my money
Re: [IC] GMK Diner
« Reply #10 on: Sat, 01 May 2021, 09:11:55 »
My guess, based on the texture is that the answer is going to be yes: Please make the background of the Pillow65 render into a deskmat and you'll have my wallet.
Very interesting concept, glad to see a set going outside of the "typical" mod/alpha/accent color blocking, this one surely does not look like GMK Olivia.
Offline MIGHTY CHICKEN
Re: [IC] GMK Diner
« Reply #11 on: Sat, 01 May 2021, 10:42:31 »
I'll buy the macro kit
Offline mr_foggy
  • neue = nope
Re: [IC] GMK Diner
« Reply #12 on: Sat, 01 May 2021, 11:17:29 »
even if the colorway isn't for me, it is a great, well presented concept.
definitely a nice and fresh idea, good luck with IC.
Offline stotle.caps
Re: [IC] GMK Diner
« Reply #13 on: Sun, 02 May 2021, 07:39:00 »
why the punctutaion keycaps are in different color rather than the same color as the alphas,overall cute sets,GLWIC
Offline azzipa
Re: [IC] GMK Diner
« Reply #14 on: Sun, 02 May 2021, 13:21:04 »
nice original (to me) approach. glwic  :thumb:
Offline mvkb
  • Designer
    • MVKB
Re: [IC] GMK Diner
« Reply #15 on: Sun, 02 May 2021, 14:42:49 »
To everyone asking for adding keys to the base kit: With GMK's pricing being what it is recently I'm very careful making sure it's as light as possible. I'm balancing compatibility with base kit price. Either make an expensive set covering most keyboards but affordable by few, or try to make it a little bit more affordable by sacrificing a little compatibility. I'll keep listening though, but would need a stronger signal.
[...] why the second 2u space in spacebars kit? Glwic!
My bad, will remove.
That's the plan! (to take your wallet, but also to make it a deskmat)
Shame on you for making me snort.
That sounds incredibly boring, not at all something you'd see at your local burger joint.
Thank you my feathered friend. You'd look good on our menu.
Offline mvkb
  • Designer
    • MVKB
Re: [IC] GMK Diner
« Reply #16 on: Sun, 02 May 2021, 14:45:49 »
Re: Expanding the base kit: If you want to chat about it some more, feel free to join my new Discord server. Again, I'm open to it, but I want this to be a more affordable GMK set.
Offline mvkb
  • Designer
    • MVKB
Re: [IC] GMK Diner
« Reply #17 on: Wed, 05 May 2021, 12:10:45 »
Just removed the second 2u spacebar, and I reshuffled the macro novelty legends (so that people who buy both novelty kits don't end up with duplicates).
267801-0
« Last Edit: Wed, 05 May 2021, 14:55:24 by mvkb »
Offline zanzoy
Re: [IC] GMK Diner
« Reply #18 on: Wed, 05 May 2021, 12:24:49 »
This is one of the more actually unique sets I've seen around. GL!
Offline kidpid
Re: [IC] GMK Diner
« Reply #19 on: Wed, 05 May 2021, 14:58:23 »
+1
How much additional cost do those three keys add? I'm not trying to be facetious -- I'm legitimately curious, because I do not have a good idea of what these key additions cost.
If the base kit add is too high, would you consider a 40s child kit?
« Last Edit: Wed, 05 May 2021, 15:05:21 by kidpid »
Offline mvkb
  • Designer
    • MVKB
Re: [IC] GMK Diner
« Reply #20 on: Thu, 06 May 2021, 17:47:35 »
Just added some quick renders of the deskmats, gonna look at those 3 keys for 40s next (feedback was consistent, so let's do it).
Offline mvkb
  • Designer
    • MVKB
Re: [IC] GMK Diner
« Reply #21 on: Fri, 07 May 2021, 04:37:33 »
Minimal 40s support added to the base kit!
267891-0
Offline mvkb
  • Designer
    • MVKB
Re: [IC] GMK Diner (deskmats added)
« Reply #22 on: Wed, 12 May 2021, 16:02:23 »
Happy to announce all vendors have been confirmed!
  • EU: CandyKeys
  • Canada: AlphaKeys
  • UK: Protozoa
  • US: Protozoa
  • Mexico: Rheset.mx
  • SEA: Monokei
  • China: KBDfans
  • Japan: Basekeys
Offline akira7
  • akirabutter
    • akiratypes
Re: [IC] GMK Diner (all vendors confirmed)
« Reply #23 on: Thu, 13 May 2021, 06:32:12 »
Nomnom tasty set! So happy to see you coming into this hobby with fresh ideas.
PS: Only thing that's missing from this IC is a signature! :eek:
« Last Edit: Thu, 13 May 2021, 06:39:30 by akira7 »
Offline Kinesiologist
« Reply #24 on: Thu, 13 May 2021, 21:36:40 »
Can i get some fries with that?
« Reply #25 on: Thu, 13 May 2021, 23:06:07 »
I want onion rings
Offline xavierlh
« Reply #26 on: Fri, 14 May 2021, 10:34:59 »
I want onion rings
Omg i'm really down for both!!
Offline treeleaf64
    • treeleaf64
« Reply #27 on: Fri, 14 May 2021, 12:28:45 »
What did the Daddy tomato say to the Little tomato
"Ketchup or you'll be late for school!"
What did the Mommy mustard say to the Little mustard
"Remember, child. Ketchup is always  tastier than you."
 :thumb:
Everyone must pay the cat tax
Offline sohkatoa
« Reply #28 on: Mon, 17 May 2021, 00:54:38 »
I'm a big fan of this set and I'll 100% get this for my first custom build.
Offline mvkb
  • Designer
    • MVKB
« Reply #29 on: Fri, 25 June 2021, 07:46:00 »
Some more tweaks to the base kit:
- Removed Terminal ISO keys
- Added mod-colored tilde and pipe keys
271263-0
Offline surplusofchairs
« Reply #30 on: Fri, 25 June 2021, 15:22:34 »
this set isn’t for me (but i do love hot dogs); i just wanted to let you know i think you’re super creative and am looking forward to the future projects i see in your discord :)
Offline XiXora
« Reply #31 on: Fri, 25 June 2021, 18:36:55 »
Shame, I kinda like'd the option available between UK and US ISO. Still happy though.
Offline TheBlackHammer
« Reply #32 on: Sat, 26 June 2021, 13:25:25 »
just found this set and love it. really love the minivan support in base. this set is a must buy for me
Re: [IC] GMK Diner
« Reply #33 on: Sat, 26 June 2021, 13:43:39 »
I knew there was a distinct reason why i loved this set
Offline 3yatt
« Reply #34 on: Sat, 26 June 2021, 19:22:50 »
MACRO. NOVELTIES. ARE. WHERE. IT'S. AT.
Offline mvkb
  • Designer
    • MVKB
« Reply #35 on: Sun, 27 June 2021, 07:21:32 »
I feel like the colors are etched into our minds. This set was specifically inspired by the Saved By The Bell diner.
Offline acidbern
« Reply #36 on: Mon, 05 July 2021, 05:28:24 »
I’m Lovin’ it!
Offline busytimmy
« Reply #37 on: Thu, 08 July 2021, 00:56:23 »
ne price avail?  :thumb:
Offline mvkb
  • Designer
    • MVKB
« Reply #38 on: Thu, 08 July 2021, 05:20:40 »
Offline synthtastic
« Reply #39 on: Thu, 08 July 2021, 10:05:06 »
I have a few yellow keyboards that are calling out for this beauty…
Expensive plastic makes me sigh.
Offline mvkb
  • Designer
    • MVKB
Re: [IC] GMK Diner | GB Aug 1 - Sep 1
« Reply #40 on: Mon, 12 July 2021, 18:12:35 »
GMK Diner will be available in groupbuy from August 1 until September 1!
Offline mvkb
  • Designer
    • MVKB
« Reply #41 on: Fri, 16 July 2021, 06:53:06 »
With a little over 2 weeks to go until the group buy, I'd like to share pricing for the kits. Happy with the price point we were able to set.
272428-0
Offline mvkb
  • Designer
    • MVKB
« Reply #42 on: Mon, 26 July 2021, 20:22:49 »
Less than a week to go. Thanks for all the feedback during the IC, it really had an impact. Artisan prototypes are almost done, and so is the prototype for a cable from Space. First set of samples of the deskmats had some color issues so we’re doing another round of those soon.
See y’all Sunday for the kickoff of the GB!!
Offline IMZO
  • Matrix shill, and TKL WKL Lover
« Reply #43 on: Mon, 26 July 2021, 20:29:37 »
Deskmats look nice, atleast.
Current boards: Jane V2 CE , Matrix 1.2og Silver WKL , Matrix 2.0add coating black WKL, Matrix 2.0add WKL Coating yellow, Satisfaction75 R1 Cloud white, Korno65, Bloop65, HHKB Pro 2 white,Lin Whale Pink WKL, Gok 7v White, Gok 7v Black, Orion V3 Silver WKL, Orion V2.5 Red WKL, Geon F1-8x Silver WK, Haus65 BlueGray, Plume65, Vertigo, Frog TKL WKL GreenF13
Offline SwitchKeys
    • SwitchKeys
« Reply #44 on: Mon, 26 July 2021, 21:02:13 »
This is fantastic! Really original and shows great creativity.
Offline mvkb
  • Designer
    • MVKB
« Reply #45 on: Fri, 30 July 2021, 09:58:27 »
't was the Friday before the group buy... How about some artisans, huh? There will be 2: a R1 1u ketchup bottle, and a R3 2.25u ketchup squirt. Both are aluminum with a white coating, and use 3 different colors of enamel fill. They're quite unique IMO.
273202-0
273204-1
273206-2
273208-3
Offline mvkb
  • Designer
    • MVKB
« Reply #46 on: Sat, 31 July 2021, 19:45:20 »
Alright last announcement before tomorrow’s GB: Mr. Space Cables is making this awesome awesome cable for Diner.
See you all tomorrow!
273303-0
273305-1
Offline mvkb
  • Designer
    • MVKB
« Reply #47 on: Sat, 31 July 2021, 19:45:59 »
Full price list:
273307-0
Offline HungHingDaiLo
  • 無間道
« Reply #48 on: Sun, 01 August 2021, 04:56:02 »
IG: @rayhhdailo
Offline mvkb
  • Designer
    • MVKB
« Reply #49 on: Sun, 01 August 2021, 11:25:04 »
The group buy thread is now live! https://geekhack.org/index.php?topic=114034.0
« Last Edit: Mon, 02 August 2021, 09:45:27 by mvkb »
