Author Topic: [IC] BEAK 6.5 | A Boldly Designed 65% LIVE NOW!  (Read 60846 times)
Offline Stilou Studio
  • Formerly Seo
  • Danish Designed Keyboards
« on: Sun, 09 May 2021, 09:04:35 »
IT IS FINALY TIME!
The BEAK 6.5 is now live!
LINK:
https://stiloustudio.com/
GB post:
https://geekhack.org/index.php?topic=115302.0
267964-0267966-1
BEAK 6.5
A unique 65% keyboard by Stilou Studio
ABOUT
The BEAK 6.5 is designed to look elegant, yet aggressive.
Featuring a big weight doubling as part of the feet to strike a balance between looks, and practicality.
The large rotary encoder makes it easy to use, as well as precise.
SPECIFICATIONS
Case weight: ~2kg (4.4 lbs)
Typing angle: 6.5deg
Mounting style: Top Mount
Front height: 19.4 mm
Plate materials: Brass, Aluminium, Polycarbonate (Possibly more depending on feedback)
Case material: 6061 Aluminium
Weight material: Brass (Possibly more)
PCB: Designed by Trip-trap with the Unified C3 Daughterboard - configurable with QMK and VIA.
Foam: TBD (experimenting)
Price: TBD
Vendor: TBD
Availability: TBD
TYPING TEST
PHOTOS/RENDERS
267968-2267970-3
267972-4267974-5
267980-8267982-9
267984-10267986-11
FAQ
Q: Which layouts are supported?
A: This is currently undecided
Q: Do you have a discord server?
A: No, if there is demand for this project, then I will make one
Q: Do you have an Instagram account?
A: Yes! https://www.instagram.com/stiloustudio/
Q: Do you have a website?
A: Not yet – but it’s in the works!
Q: Is there a way to contact you?
A: Yes! Feel free to DM me on Instagram, or reach out to me on Discord: Seo | Stilou Studio#6046
SPECIAL THANKS TO:
Rotwitt, for helping me throughout the entire process.
Trip-trap, for designing the PCB.
YHS, for letting me try loads of boards for reference.
UPDATE MAY 14TH 2021
THE PROTOTYPE
268362-12
After feedback from the IC, we made a few design changes for the next prototype (Which has been ordered!)
Multiple small details were changed in the second version, the biggest of which being the removal of the feet.
Some of you might be worried that the keyboard will tilt/wobble when typing.
This is NOT the case - for the keyboard to wobble you would have to press way harder than you ever would in a real-world scenario.
Other changes include multiple small changes - primarily larger cutouts to make the tolerances more forgiving.
NEW DISCORD SERVER
Join here! https://discord.gg/74G844zanU
If you want to get to know the BEAK 6.5 better, we highly encourage you to check out our new Discord server!
IN OTHER NEWS
We are working on getting an estimate for the BEAK 6.5 pricing.
We are also talking with multiple vendors around the world.
And last but not least, we would like to thank you all for the support, it has been amazing!
« Last Edit: Fri, 19 November 2021, 09:32:46 by Stilou Studio »
  • Formerly Seo
Re: [IC] BEAK 6.5 | A Boldly Designed 65%
« Reply #1 on: Sun, 09 May 2021, 09:05:59 »
reserved
Offline rodok
« Reply #2 on: Sun, 09 May 2021, 09:09:00 »
Looks really good! Deffinately in. Though I really wish for it to have an extra column to the right. Other then it's amazing, really like it! Cheers for the months to come.
Offline yuutsu
  • Consumer of Brioche Loaf
    • Desktop Designs
« Reply #3 on: Sun, 09 May 2021, 09:16:21 »
+1 for the prototype, looks very unique compared to the 65% gasket mounts that have flooded everything.
Offline goddream
« Reply #4 on: Sun, 09 May 2021, 09:21:26 »
the beak looks like the pog emote lol
Rei XT-60 | Endash | KHDD | Jinsoul | Tengu | PC Dolphin | Nunu | Hyphen | Mc65 | Unikorn | Dahyun | CARDBORD
Offline eeveeatemyessay
« Reply #5 on: Sun, 09 May 2021, 09:41:49 »
If it comes with ISO it's probably instabuy. This, and Rotwitt's... DK design sure is leaving a mark.
Offline Rotwitt
  • I'm trying to have fun designing keyboards
« Reply #6 on: Sun, 09 May 2021, 09:46:51 »
It’s nice to see someone dare to be different than the rest! GLWIC!
Offline screen
« Reply #7 on: Sun, 09 May 2021, 10:52:18 »
I like the back weight, unnecessary which is going to make it expensive but cool.
Offline RA Can
« Reply #8 on: Sun, 09 May 2021, 11:03:10 »
love the design, finally something new and boldy
Offline frostykoala
  • consider Nightlight
    • Check out some Renders :)
« Reply #9 on: Sun, 09 May 2021, 11:06:23 »
i like knobs
Offline DaaDaa
« Reply #10 on: Sun, 09 May 2021, 11:33:45 »
I strongly encourage you to consider offering e-beige color and anodized gray.
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
Offline CookieFlow
« Reply #11 on: Sun, 09 May 2021, 11:42:50 »
I am not sure this board is quite for me just yet.
But I appreciate seeing something new and different.
The only things I would point out:
-The feets. I understand they are necessary, but they do feel like an afterthought and aren't quite as integrated into the design as I would like.
-I am not quite sure it is a 65%, that might require a small column somewhere to add some extra keys. But  I am not sure how that would be possible without changing the design.
  • Formerly Seo
« Reply #12 on: Sun, 09 May 2021, 12:17:04 »
Thank you for your interest.
We are definitely planning on having ISO support!
Offline PixelBoba
« Reply #13 on: Sun, 09 May 2021, 13:22:52 »
Love this. Very unique, but I know its going to be out of my budget f.
Offline UGunaLOSE
« Reply #14 on: Sun, 09 May 2021, 13:29:12 »
Now this is unique. GLWIC will watch!
Offline GreyAmbience
  • I can stop when ever I want
« Reply #15 on: Sun, 09 May 2021, 13:34:52 »
You should consider adding a "notes/comments" section to the IC
I think it would be a missed opportunity not to have the eye of Horus at the top of the pyramid.
Offline dingusxmcgee
« Reply #16 on: Sun, 09 May 2021, 13:56:00 »
This is neat. Really like how you executed this.
  • Formerly Seo
« Reply #17 on: Sun, 09 May 2021, 16:42:28 »
That is certainly a good idea - might do something like it in a future project. Although for this project I am going for more of a minimalist/industrial design.
Offline eljudio42
« Reply #18 on: Sun, 09 May 2021, 19:07:17 »
Probably an unpopular opinion, but I feel like having a cable come out vertically from the top of the pyramid might ruin the aesthetic of the board. Obviously a usb port on either the left or the right isn't possible. Would bluetooth be a possible option?
Offline lush_bunny
« Reply #19 on: Sun, 09 May 2021, 19:34:19 »
Reject humanity, return to... beakie?
Offline RexKorp
« Reply #20 on: Sun, 09 May 2021, 20:33:18 »
> New account
> Triangle
> Big knob
Blacksimon, we know this is you, nice try...
Jokes aside, it actually looks interesting. Kind of has a modern vibe to it.
Some thoughts:
Not a fan of how the ledge of the pyramid that faces you has been flattened, feels/looks unexpected.
I think it would look much better if the knob and entire pyramid was brass, not sure why the bottom is brass but the top part of it matches the case.
Offline badchad
« Reply #21 on: Sun, 09 May 2021, 21:46:34 »
Is WKL gonna be available. Also what’s it look like with the weight.
BAD
Offline NovaRMK
« Reply #22 on: Sun, 09 May 2021, 22:43:34 »
Thats a thick ass rotary encoder... respectable
Offline Yukinon
« Reply #23 on: Sun, 09 May 2021, 22:47:28 »
Looks really interesting, I kinda like it. glwic!
Offline kema
  • Designer
    • kevinmadesign
« Reply #24 on: Mon, 10 May 2021, 01:06:22 »
Love the layout, interested 👀
Offline Cowmovie4
  • hollow keyboard haver
« Reply #25 on: Mon, 10 May 2021, 01:10:38 »
I love the funky design! and it sounds good too? Best of Luck reaching GB, this is really sick and maybe you've kicked off the newest design trend!!
u/TheFourthCow - formerly TheFourthCow on geekhack... until I locked myself out.
Designer of the Funky40 - IC TBD
Working on a new board! IC inbound?
https://i.imgur.com/5GVY8I5.jpg
Offline blacksimon
  • illuminati.works
    • illuminati.works
« Reply #26 on: Mon, 10 May 2021, 01:35:34 »
> New account
> Triangle
> Big knob
#exposed. Sorry lads, the cat is out of the bag now
  • Formerly Seo
« Reply #27 on: Mon, 10 May 2021, 04:10:12 »
For the first run, it will probably not be Bluetooth compatible.
Although I hear what you are saying, and will note it for any future designs :)
  • Formerly Seo
« Reply #28 on: Mon, 10 May 2021, 06:22:31 »
> New account
> Triangle
> Big knob
Some thoughts:
The reason for it being flat is due to the limitations of the manufacturer.
As for the knob there is a poll in the IC form which is there to gather interest in a brass knob.
The reason for the beak being brass on the bottom, and another color on top is due to how the case is assembled.
In the image below you can see that the top part of the BEAK is aluminum, and the part you are referring to is in the same block of aluminum - therefore it is not possible to match the colors.
Picture:
Although a possible fix would be detaching the part, and having it machined in brass, and screwing it into the side.
Offline Flexmaster
« Reply #29 on: Mon, 10 May 2021, 08:23:13 »
Super cool!
Offline Rumblethumps
« Reply #30 on: Mon, 10 May 2021, 08:31:48 »
This is ridiculous and I love it. Will there be more colors added?
  • Formerly Seo
« Reply #31 on: Mon, 10 May 2021, 08:40:34 »
More colors are certainly in the works, if there are any specific colors you would like to see, then please fill out the IC form.
Offline Ranger_Trivette
« Reply #32 on: Mon, 10 May 2021, 09:28:47 »
do you have a building-video?
  • Formerly Seo
« Reply #33 on: Mon, 10 May 2021, 09:39:36 »
Not yet, although I am in touch with streamers/YouTubers to have it built on stream sometime in the future!
Offline nguyenhimself
« Reply #34 on: Mon, 10 May 2021, 09:49:53 »
I'm sure you have your own reasons for the weight/foot stand design,
But it's so obviously gonna be a dealbreaker for many,
I think you're just making things harder for yourself.
Best of luck though. I love how you position the knob. Might reconsider this later.
Offline rohbro
« Reply #35 on: Mon, 10 May 2021, 09:58:43 »
This design is very bold that’s for sure
Offline PradyXT
« Reply #36 on: Mon, 10 May 2021, 11:01:01 »
I personally like the inclusion of the large rotary encoder! The weight design is unique and rlly cool
Offline holer
« Reply #37 on: Mon, 10 May 2021, 11:16:51 »
It’s definitely bold!
I love the (very) separated arrow cluster and the big (Big!) knob, but I’m still on the fence about the beak.
+1 for ISO and good luck!
  • Formerly Seo
« Reply #38 on: Mon, 10 May 2021, 13:28:35 »
We are definitely looking into WKL layout, if you haven’t already you can answer the IC Form to vote on the layout!
Offline KevenKeys
« Reply #39 on: Mon, 10 May 2021, 14:52:50 »
Filled out the form! I must say this is pretty cool looking. As another user above posted, a part of me would love to see some additional keys on the right side. I feel like an additional column would just make this thing bigger than a TKL so maybe a knob that spans 2 rows vs 3, and then have a triple key section for function/toggles or page up and down. Just a thought but I like how it looks now. Great work and I do appreciate having prototypes already. GL!
Offline FredNeverDead
« Reply #40 on: Mon, 10 May 2021, 15:06:29 »
This is VERY interesting. but i love it. the huge knob look super nice. this would be such a flex to have on your desk lol. also IC form filled out :D
« Reply #41 on: Mon, 10 May 2021, 15:17:53 »
Please make a discord server :D
Offline JakeyPancakey
« Reply #42 on: Mon, 10 May 2021, 16:29:18 »
That knob is an absolute unit! And it actually looks really great on this board as compared to other boards trying to slap a knob in at any chance they get. Very sleek design!
  • Formerly Seo
« Reply #43 on: Mon, 10 May 2021, 16:45:28 »
I am currently working on one! I will link it in the next update - should be coming within the week.
Offline MIGHTY CHICKEN
« Reply #44 on: Mon, 10 May 2021, 17:35:22 »
Me is chicken, chicken has beak, me like this
  • Formerly Seo
« Reply #45 on: Tue, 11 May 2021, 00:08:05 »
WKL might be available depending on the feedback from the IC form.
Offline hicals
« Reply #46 on: Tue, 11 May 2021, 01:34:00 »
The lower part of the support is awkward
Offline DeMechanica
« Reply #47 on: Tue, 11 May 2021, 01:49:02 »
Split space support?
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
« Reply #48 on: Tue, 11 May 2021, 03:52:19 »
This kinda wild :cool:
Offline RoyalOak88
« Reply #49 on: Tue, 11 May 2021, 05:02:23 »
Very nice concept. A pity that doesn't have ISO
