Author Topic: [GB] Twilight switches - a new JWK tactile - GB May 12-May 22nd  (Read 56510 times)
Offline Pylon
Twilight Switches
Group Buy May 12th-May 22nd. Estimated to ship around mid-July, followed by an in-stock sale around then.
  • New, very tactile JWK switch combining their Clear-like tactile stem with their T1 leaf
  • 5-pin housing
  • POM Stem (purple), PC top and nylon bottom (smoky gray)
  • 67g spring
  • Unlubed
  • By Pylon and brainandforce
Twilights are not a JWK recolor. It was born out of a JWK frankenswitch combo that Pylon and brainandforce discovered independently while experimenting: combining the MX Clear-like stem from a Durock Medium Tactile switch with the tactile leaf of the Durock T1 housing. The result is a sharp, punchy, tactile switch, with just a bit of pretravel. Imagine a smoother, much more tactile Ergo Clear. A tactile switch as intense as an NK_ Blueberry that can hold its own at lighter spring weights.
If you want a taste of what this switch feels like, you can use the stem off a Durock Medium Tactile, Mode Signal, Penguin, or RARA V2, and pair it with the housing from a Durock T1 or Koala. We are making this a pre-assembled switch so you can avoid the hassles and costs of frankenswitching.
Teal T1 stem for comparison
Force curves:
Vendors and prices
  • [US] Dangkeebs- $0.55 USD per switch, in packs of 10
  • [CA] AlphaKeys - $0.55 USD per switch, in packs of 10
  • [AU] Daily Clack - $0.84 AUD per switch, in packs of 10 (link not live yet)
  • [SEA] Zion Studios - $0.65 USD per switch, in packs of 10
« Last Edit: Sat, 22 May 2021, 18:38:35 by Pylon »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Twilight switches - a new JWK tactile - GB May 12-May 22nd
« Reply #1 on: Fri, 14 May 2021, 11:29:54 »
approved
Offline Pylon
« Reply #2 on: Sat, 22 May 2021, 18:38:52 »
Last day! Our vendors will also have extras in stock, but it will likely be at a higher price.
Offline Pylon
« Reply #3 on: Fri, 02 July 2021, 08:24:03 »
Switches have been manufactured! We're waiting for shipping to vendors:
Offline Leo66
« Reply #4 on: Sun, 04 July 2021, 02:27:43 »
Boring color changes
Offline lakeboredom
« Reply #5 on: Thu, 29 July 2021, 15:49:27 »
Got the Twilights in, the feel of the leaf is basically identical to Crane tactiles. Obviously the Twilights are better tho. I mean, they're purple.
Offline lakeboredom
« Reply #6 on: Thu, 29 July 2021, 18:43:00 »
On extended use, I'd say the Twilight housing is 10-20% more snappy, without moving the tactile event. The force curve graph seems very accurate. They feel a lot better with lighter springs.
Offline LordOwen
« Reply #7 on: Mon, 18 December 2023, 04:54:46 »
Is this something you'd ever consider coming back and doing a R2 for? I enjoy mine quite a lot, but would like to be able to grab a few dozen more for use in other boards!
