Author Topic: [IC] FROG TKL - Sales start on 30st June  (Read 190076 times)
Offline Lolipopu
Re: [IC] FROG TKL
« Reply #200 on: Sat, 29 May 2021, 03:34:39 »
Good price and design. Absolutely buy
Offline phinix
Re: [IC] FROG TKL
« Reply #201 on: Sat, 29 May 2021, 08:44:26 »
This is pretty TKL case, I wish there was hot swap rgb pcb for it.
Check the PCB options, there seems to be hotswap options, and options with RGB too. (Unless I am misinterpreting something)
I see hot swap, but where do you see rgb?
Offline HungerMechanic
Re: [IC] FROG TKL
« Reply #202 on: Sat, 29 May 2021, 09:07:42 »
I am so curious about which keysets might go with the green one.
Camping? 9009? Something with soft pink? I have a weird premonition that even DSS Late Harvest may look okay on it.
Offline Surefoot
Re: [IC] FROG TKL
« Reply #203 on: Sat, 29 May 2021, 12:56:38 »
GMK British Racing Green :)
Offline Engedi_
Re: [IC] FROG TKL
« Reply #204 on: Sat, 29 May 2021, 13:28:58 »
GMK Botanical would work well. Maybe CRP green hebrew?
Also, good eye. DSS Late harvest has earthy tones. It would go well with green
Offline Gnome
Re: [IC] FROG TKL
« Reply #205 on: Sat, 29 May 2021, 13:30:33 »
If you read on the spacebars in the "Supported layouts" picture it says that all hotswap pcbs have rgb and underglow support.
Re: [IC] FROG TKL
« Reply #206 on: Sat, 29 May 2021, 14:51:36 »
I agree with you, and also almost went with CRP Green Hebrew because it is the same cost as regular alphas and might work with the green IKKI68 Aurora I am getting. But it might look even better on the darker Frog green.
Offline phinix
Re: [IC] FROG TKL
« Reply #207 on: Sat, 29 May 2021, 15:34:34 »
Holy ****, alleluja!
I always wanted to have WKL F13 hotswap with per-key RGB! This is amazing! Unbelievable!  :eek:
I'm in!!!!  :D
Re: [IC] FROG TKL
« Reply #208 on: Sun, 30 May 2021, 06:53:35 »
ePBT Soju would also be a good set for the Green Frog.
Offline Engedi_
Re: [IC] FROG TKL
« Reply #209 on: Mon, 31 May 2021, 13:47:56 »
Yeah, a little too much green for me.
We also forgot GMK Wild with green and red accents.
Offline Lazesummerstone
  • ҠѤӋϚΔΡѕ
    • MY Keycap set - Transmutation
Re: [IC] FROG TKL
« Reply #210 on: Mon, 31 May 2021, 14:57:46 »
I have been hearing about this keyboard, in whispers and rumor. But seeing it now it's simply stunning the amount of design  that is going into this board. I'm thinking this could be something very special.
Re: [IC] FROG TKL
« Reply #211 on: Mon, 31 May 2021, 15:16:43 »
Have the plate specifications been released? Because I might want to order an aftermarket plate.
Offline Shaqo_Wyn
Re: [IC] FROG TKL
« Reply #212 on: Tue, 01 June 2021, 03:41:12 »
Hi Geon,
If one manages to order one of the Frog TKL keyboards in mid June.
How many days do you expect for it to take for delivery in SK, since it's in stock?
Offline Stilou Studio
  • Formerly Seo
  • Danish Designed Keyboards
Re: [IC] FROG TKL
« Reply #213 on: Tue, 01 June 2021, 06:38:24 »
Instabuy!
Offline phinix
Re: [IC] FROG TKL
« Reply #214 on: Tue, 01 June 2021, 06:43:48 »
I think this is purely amazing.
I'll definitely will buy one.
Offline geonworks
    • GEONWORKS
Re: [IC] FROG TKL
« Reply #215 on: Wed, 02 June 2021, 02:16:08 »
You meant plate file?
Offline geonworks
    • GEONWORKS
Re: [IC] FROG TKL
« Reply #216 on: Wed, 02 June 2021, 02:17:48 »
Hi Geon,
ETA 2~3weeks. And in the case of SK, it will be sold separately at Swagkeys Korean store.
www.swagkey.com
Re: [IC] FROG TKL
« Reply #217 on: Wed, 02 June 2021, 09:03:39 »
Yes, absolutely. I know a custom polycarb plate maker who uses plate files. If FROG TKL has such plate files available, I could get a polycarb plate for it.
Offline phinix
Re: [IC] FROG TKL - sales date update_210602
« Reply #218 on: Thu, 03 June 2021, 07:02:42 »
See, this toad - if its made from really soft rubber, would it be even better than gasket mount?
50a and 80a - which one is softer?
Will both be added to kit?
Offline geonworks
    • GEONWORKS
« Reply #219 on: Thu, 10 June 2021, 05:42:39 »
- Its silicone and this is just top mount
- 50a is softer
- 80a is standard and 50a is an option
Offline phinix
« Reply #220 on: Thu, 10 June 2021, 06:17:52 »
- 50a is softer
Thanks for answers, looking forward to the sale :thumb:
Offline geonworks
    • GEONWORKS
« Reply #221 on: Thu, 10 June 2021, 06:21:07 »
- 50a is softer
Your welcome. Thanks for the interest
Offline Enroze
« Reply #222 on: Thu, 10 June 2021, 06:22:30 »
Hi geon, what is your favourite pepe emote?
Offline geonworks
    • GEONWORKS
« Reply #223 on: Thu, 10 June 2021, 06:28:16 »
Offline coelacanth
  • cheesed to meet you 💪😎
« Reply #224 on: Thu, 10 June 2021, 07:08:48 »
I'm definitely in! Absolutely need one for my first board! Thank you Geon  :cool:
Geonworks Frog F13 TKL | Gateron <3  —  1984 Volvo 240 DL 2l OG Redblock Owner
Offline kcching
« Reply #225 on: Thu, 10 June 2021, 08:58:30 »
Looking forward to add this to my collection!
Offline F eq ma
« Reply #226 on: Thu, 10 June 2021, 17:27:46 »
I cannot wait for that navy blue.   I suspect this board will be quick to sell out each month.   I hope I can get lucky, if not I can be patient.
Offline geonworks
    • GEONWORKS
« Reply #227 on: Fri, 11 June 2021, 02:08:00 »
i hope so
Offline Smoochie
« Reply #228 on: Fri, 11 June 2021, 19:33:12 »
endgame found.
Offline phinix
« Reply #229 on: Sat, 12 June 2021, 07:59:00 »
i hope so
Will axact release time be announced?
« Last Edit: Wed, 16 June 2021, 09:26:06 by phinix »
Offline kabocha
Re: [IC] FROG TKL - Sales start on 30st June
« Reply #230 on: Thu, 17 June 2021, 04:06:36 »
best boy. hope I can nab one.
Offline mr_foggy
  • neue = nope
« Reply #231 on: Thu, 17 June 2021, 05:12:26 »
amazing price point for an instock beauty... will be in no matter what, might ditch apollo for this
Offline clik_clak
« Reply #232 on: Thu, 17 June 2021, 09:11:09 »
I hope you can continue to get these out in a hurry. I'd like to think that I have a chance to pick one of this first batch up, but I'm pretty sure a snowball has a better chance of surviving in hell than I do of getting one of these before the bots eat them all up.
Offline clickpig
  • naisu naisu naisu
« Reply #233 on: Sun, 20 June 2021, 04:05:06 »
30th June at 11AM GMT+9
Offline MiguelFg
« Reply #234 on: Sun, 20 June 2021, 11:18:43 »
Yo Geon are you gonna release more colours in the future? Like E-white for example.
Offline phinix
« Reply #235 on: Sun, 20 June 2021, 13:26:59 »
Or off-white/retro white, beige?
Offline PixelBoba
Re: [IC] FROG TKL
« Reply #236 on: Sat, 26 June 2021, 07:32:37 »
Will there be a 60% with the similar design? I would love a 60% with design elements translated from frog or even the F1-8X.
Sent from my Redmi Note 7 Pro using Tapatalk
Idk if any has already said this, but there is a frog mini which is planned to go on sale next year after frog tkl. It is a 60 and there are pictures and more info on the discord and here:
https://www.notion.so/FROG-mini-27045786fdf844c2bb159f12a0775c68
Offline Minam
« Reply #237 on: Mon, 28 June 2021, 12:36:10 »
Every Month? Is this every month going to be legit or is this Keycult's "Every month".
Offline F eq ma
« Reply #238 on: Tue, 29 June 2021, 21:23:04 »
I had one in my kart and then it was sold out from under me.   Got to wait another month :)
Geon -   Thanks for the great looking board.   I hope you will keep up with the monthly allotments with such great demand.   15 second sell out is crazy, but respectable.
Offline Bruno7obe
« Reply #239 on: Thu, 08 July 2021, 05:08:27 »
Where is it sold to Europe?
Offline RoyalOak88
« Reply #240 on: Thu, 08 July 2021, 08:12:44 »
Offline deflorator24
« Reply #241 on: Sat, 17 July 2021, 01:56:25 »
When is the next sale? it says it's every month hmm....
Offline elongatedmusk
« Reply #242 on: Sat, 17 July 2021, 05:47:03 »
Geon said on Discord, next sale will be announced on the 20th.
Just assume the sales to be at the end of every month, the last sale wasn't even fully fulfilled yet.
Offline phinix
« Reply #243 on: Sat, 17 July 2021, 09:09:26 »
Yeah, there is also a problem with chips - this round will not have pcbs with it, just cases.
« Last Edit: Thu, 22 July 2021, 07:56:53 by phinix »
Offline Lord_Rabel
  • The geek that doctors trust.
« Reply #244 on: Tue, 17 August 2021, 01:48:57 »
Hey!
I know I am late for the party, but when will the Frog be in-stock again? Is there some sort of newsletter I can subscribe to?
Offline clickpig
  • naisu naisu naisu
« Reply #245 on: Tue, 17 August 2021, 04:08:59 »
Hey!
Jump on Geon's discord, best place to be kept up to date.
Offline IkaKeys
« Reply #246 on: Sat, 02 October 2021, 06:51:07 »
When you say it will be on sale every month will that also be for ocotober
Offline Mecxs
« Reply #247 on: Sat, 02 October 2021, 07:29:22 »
Sales information is posted to the discord.
Offline phinix
« Reply #248 on: Sat, 02 October 2021, 14:14:07 »
Every month I'm trying to buy one and every month its a total failure. It takes around 12 seconds and its all gone.
This is actually a really bad situation, as each month around 200-300 units is released and each month loads of people keep buying it and cannot do it.
Looking at around 2-3K of interested buyers, you won't be able to buy for next 6 months at least...
Then lots of those are flipped on market for twice the price.
I would rather to have a GB with 12 months turnaround, knowing that I paid for one and will get in 12 months, then being disappointed every f**ing month...
Madness...
Offline pixelpusher
« Reply #249 on: Sat, 02 October 2021, 16:36:36 »
Madness...
Need to just do a raffle tied to single discord user.  Would fix a lot of it.
