Author Topic: [IC] GMK Bingsu R2  (Read 4626 times)
Offline Project Keyboard
    • Project Keyboard
« Last Edit: Sat, 12 June 2021, 14:08:42 by Project Keyboard »
Offline I_V_I
Re: [IC] GMK Bingsu R2
« Reply #1 on: Sat, 12 June 2021, 09:01:11 »
Wasnt interested in IC1-3. But posting it the fourth time really got my attention.
« Last Edit: Sat, 12 June 2021, 09:10:44 by I_V_I »
Offline Visionaire
« Reply #2 on: Sat, 12 June 2021, 09:03:08 »
IC R4 of Bingsu R2
Offline Fraaaan
« Reply #3 on: Sat, 12 June 2021, 09:04:56 »
Consider adding basic ISO support to base kit.
Offline Ella
  • Why is it called an oven
« Reply #4 on: Sat, 12 June 2021, 09:06:27 »
Not Interested
Offline ZavaZ86
« Reply #5 on: Sat, 12 June 2021, 09:13:42 »
So what is different compared to the one posted on instagram. You already got a lot of feedback from there and somehow still haven't changed anything like putting basic support like iso in it. I know it's hard to belive but USA is not the only country.
Offline Zeelobby
« Reply #6 on: Sat, 12 June 2021, 09:20:32 »
ISO support would be great in base, but no need to single out one country that uses ansi (of which there are many), and pretend like it's the reason.
Offline heyimpanda
« Reply #7 on: Sat, 12 June 2021, 09:28:32 »
Offline iinko_mk
  • Status: broke
« Reply #8 on: Sat, 12 June 2021, 09:36:04 »
The kitting makes me not wanna have eyeballs. Pls at least add some sort of iso to base.
Also, why are there 3 of the exact same post lol.
Edit: you have a b in base that does nothing because there are no bars and no extra 2.25 shift for Alice support.
« Last Edit: Sat, 12 June 2021, 09:40:36 by iinko_mk »
Offline onefivenine
    • Project Keyboard LLC
« Reply #9 on: Sat, 12 June 2021, 09:44:05 »
There was a 504 error on posting the thread, causing multiple posts. This thread will be locked and continued here:
https://geekhack.org/index.php?topic=113322.0
