Author Topic: [IC] GMK CYL Deathly Queen  (Read 291117 times)
Offline Tyson
Re: [IC] GMK Deathly Queen
« Reply #50 on: Sat, 10 July 2021, 01:14:02 »
I love the colourway and what novelties are there but there could be some more. Maybe something like the skull on Killer Queens belt buckle, or something with Sheer Heart Attack, or even the Stray Cat.
As mentioned previously, I really would like to run this and not risk any chance of infringing anything. I do not think I will be adding any more novelties to this set.
Offline Tyson
Re: [IC] GMK Deathly Queen v2 Updates!
« Reply #51 on: Thu, 15 July 2021, 12:55:32 »
Updates have been added!
Adjustments:
Base Kit Changes:
- Add 3 key 40s support (R2 1.75u Backspace, R3 1.25u Tab, R2 1.5u Enter)
- Add  the ー quaternary (top-right) sublegend on the -_ホー key
Alt Alphas Changes:
- Add a standalone R1 1u ー key
- Add a 半/全 key
Menacing Alphas Kit:
- Using the "Go" Novelty just copy alt alphas kit, but make every legend the "Go" Novelty. lol
Updates to come:
Spacebars Kit Changes:
- Add alpha-colored 2x 1u c, 1.25u c and 2x 3u c bars
Novelties Kit Changes:
- Add Accent colored Arrow Keys
Offline clickpig
  • naisu naisu naisu
« Reply #52 on: Sun, 18 July 2021, 18:31:20 »
You madman, you actually did it.
This set just went from probably cop to instacop.
Offline NoteMakoti
  • for sale, baby shoes, never worn
Re: [IC] GMK Deathly Queen | v2 Updates!
« Reply #53 on: Sun, 18 July 2021, 21:14:39 »
How about a "To Be Continued" novelty?
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #54 on: Mon, 19 July 2021, 12:46:17 »
Can we get some bars on GO Alphas so they can be used with other sets?
Offline Havattack
« Reply #55 on: Mon, 19 July 2021, 13:29:04 »
Getan artisan (Rama maybe) to make a cap with that belt buckle symbol. Would be too cool.
Offline SolidmetalAce
« Reply #56 on: Mon, 19 July 2021, 22:22:36 »
Very nice set, I love the theme, and the colors are preemo! I'll keep up with this for sure!
Offline RachaXD
« Reply #57 on: Fri, 23 July 2021, 16:02:13 »
Love the color scheme and menacing alphas. Couple of things that I think could be improved:
1. I do think the base legends for the R1 num row is very cluttered. If it was more in the format of like ePBT Origami I think it'd look cleaner.
2. The sub-legends font size should be smaller because they're sub-legends. I also don't think it's needed to have the rAlt say "Alt Gr".
3. For the mods - feel like you might as well as choose between putting either icon or text. Cluttered to have text + mods like the GMK Botanical R2. It also looks a bit weird to have the icons for tab, shift, enter, backspace but not for caps lock or the other mods.
Offline Space_Case88
  • keebs, anime, video games and coffee
« Reply #58 on: Sat, 24 July 2021, 04:47:26 »
Do some 40's and I'm all in
Offline doggo1dance
« Reply #59 on: Sat, 24 July 2021, 05:28:13 »
why even make 40s when its not going to hit moq anyway   :p
Offline HungHingDaiLo
  • 無間道
« Reply #60 on: Sat, 24 July 2021, 05:41:38 »
Base Kit Changes:
Updates to come:
Love the updated base kit  :thumb:
On Novelties kit changes: Can one accent-colored vertical Enter 2u (Numpad) be included there as well along the accent arrow keys?
IG: @rayhhdailo
Offline Surostu
  • switchkeys.au x keyboardfinder.com
    • keyboardfinder
« Reply #61 on: Sat, 24 July 2021, 06:29:32 »
Loved the changes Tyson. Looking forward to this set
Offline Tyson
« Reply #62 on: Mon, 02 August 2021, 11:42:34 »
More Updates have been added!
Novelties/Accent Kit Changes:
- Add Accent Arrows
Spacebar Kit Changes:
- Add 40s spacebars
Next update should hopefully be deskmat designs.
Overall General Update:
I've been talking to vendors and now have Proxies for each region! I don't want to pin down a GB date just yet as there is still work to be done for pricing of kits along with deskmat designs, cables, and potential Rama caps. Thank you everyone for all the support! I'm super excited to get this set going! I also have another set in the works that I've been teasing on my Insta and Discord, that one will probably run sooner than Deathly Queen, only because it's a PBT set and will be running with a different manu. Be on the look out for that set too ;)
Offline Tyson
Re: [IC] GMK/PBT Deathly Queen | v3 Updates!
« Reply #63 on: Fri, 06 August 2021, 23:31:14 »
Update:
While working with vendors I have started talks to possibly run this in PBT, if that happens kitting will drastically change, both alpha kits will more than likely be cut, 40's might be cut, support would be for 60s, all the way up to full size and Alice (split bars will be in base if PBT happens).
Offline clickpig
  • naisu naisu naisu
« Reply #64 on: Sat, 07 August 2021, 00:10:09 »
༼ つ ◕_◕ ༽つ
« Last Edit: Fri, 02 December 2022, 20:25:52 by clickpig »
Offline doggo1dance
« Reply #65 on: Sat, 07 August 2021, 00:41:27 »
please no pbt
Offline hali
  • OHHHH MY GODDDDDD
    • hali.studio
« Reply #66 on: Sat, 07 August 2021, 12:16:42 »
I'm for ABS but not against a change to a different ABS manufacturer
Offline The0rigina1
  • fumoposting
« Reply #67 on: Sun, 08 August 2021, 06:42:57 »
Five side dyesubs?
No thank you.
  • 無間道
« Reply #68 on: Sun, 08 August 2021, 22:46:09 »
Please consider no pbt (2)
Colors this good should be only in GMK.
IG: @rayhhdailo
Offline juniper37559
« Reply #69 on: Wed, 11 August 2021, 12:10:47 »
No pbt+1
Color will be more saturated in abs, and five side dyesub can even make the color worse.
No manu can solve the shrinkage and the deep color faded on five side dyesub keycaps.
These QC problem will eventually cause huge delays. There are plenty of examples happened in well known pbt manus.
Offline Hdjekso
« Reply #70 on: Thu, 12 August 2021, 06:46:49 »
No pbt +2
Sent from my Pixel 3a using Tapatalk
Offline musdem
« Reply #71 on: Thu, 12 August 2021, 10:22:25 »
No PBT +3
Offline dm996
« Reply #72 on: Thu, 12 August 2021, 10:41:39 »
+1 for pbt , ignore gmk simps
Offline MIGHTY CHICKEN
« Reply #73 on: Thu, 12 August 2021, 11:34:20 »
No PBT +4
Offline denibhoxha
  • cock and balls technology
« Reply #74 on: Thu, 12 August 2021, 15:06:51 »
5 side dyesub mods make a man sad
Offline doggo1dance
« Reply #75 on: Fri, 13 August 2021, 07:05:33 »
yeah sure lets go for pbt where its already widely known that pbt does colours like these horribly. what a moron
Offline rainb1ood
  • so pretty so plastic
« Reply #76 on: Fri, 13 August 2021, 08:06:02 »
pbt or gmk, i'm good on either!
My name is yoshikage kiwa. I'm 33 yeaws owd. My house is in the nowtheast section of mowioh, whewe aww the viwwas awe, and i am not mawwied. I wowk as an empwoyee fow kame yu depawtment stowes, and i get home evewy day by 8 pm at the watest. I don't smoke, but i occasionawwy dwink. I'm in bed by 11 pm, and make suwe i get eight houws of sweep, no mattew what. Aftew having a gwass of wawm miwk and doing about twenty minutes of stwetches befowe going to bed, i usuawwy have no pwobwems sweeping untiw mowning, just wike a baby. I wake up without any fatigue ow stwess in the mowning. I was towd thewe wewe no issues at my wast check-up. What i'm twying to expwain is that i'm a pewson who wishes to wive a vewy quiet wife. I take cawe not to twoubwe mysewf with any enemies, wike winning and wosing, that wouwd cause me to wose sweep at night. That is how i deaw with society, and i know that is what bwings me happiness. Awthough, if i wewe to fight i wouwdn't wose to anyone.
Offline NoteMakoti
« Reply #77 on: Fri, 13 August 2021, 17:13:44 »
I'm pro PBT.
Offline Tyson
Re: [IC] GMK Deathly Queen | Google Form Added!
« Reply #78 on: Fri, 13 August 2021, 22:27:04 »
No need to call that person a moron. Also upon talking to a few amount of people in DMs and making a pros vs. cons sheet for the set I have come to a decision. This set will be staying GMK, GB date is still TBD and kits have not been finalized. I've talked to a vendor about the set and he was telling me that if I want to run a alphas kit I should only be looking at running one, not two.
I've created a google form to get more feedback on a few questions for the set. Please feel free to fill out when you get the chance if you are interested in this project: https://forms.gle/KZEtU3mdMZKuAJof8
Offline tacotacx
« Reply #79 on: Mon, 23 August 2021, 08:11:30 »
Really like this colorway. Especially since I'm planning on building a board for next Christmas for my little cousin but man i wish we weebo alphas weren't forced lmao
Offline kiwwi
« Reply #80 on: Mon, 23 August 2021, 10:29:21 »
My name is Yoshikage Kira. I'm 33 years old. My house is in the northeast section of Morioh, where all the villas are, and I am not married. I work as an employee for the Kame Yu department stores, and I get home every day by 8 PM at the latest. I don't smoke, but I occasionally drink. I'm in bed by 11 PM, and make sure I get eight hours of sleep, no matter what. After having a glass of warm milk and doing about twenty minutes of stretches before going to bed, I usually have no problems sleeping until morning. Just like a baby, I wake up without any fatigue or stress in the morning. I was told there were no issues at my last check-up. I'm trying to explain that I'm a person who wishes to live a very quiet life. I take care not to trouble myself with any enemies, like winning and losing, that would cause me to lose sleep at night. That is how I deal with society, and I know that is what brings me happiness. Although, if I were to fight I wouldn't lose to anyone.
Offline kakasa
« Reply #81 on: Tue, 24 August 2021, 09:40:57 »
Offline 74236x
« Reply #82 on: Tue, 31 August 2021, 00:21:17 »
Huge Jojo's fan just a bit reluctant to join any GMK set. Lead times are outrageous and we keep making more GMK sets.
Offline speedyzy
« Reply #83 on: Fri, 01 October 2021, 16:00:37 »
looks good!
Offline Tyson
« Reply #84 on: Fri, 01 October 2021, 16:35:01 »
looks good!
Thank you! This set is still in the works, just waiting on a few things before we move forward with GB information! :)
Offline konstantin
  • Formerly constexpr
« Reply #85 on: Fri, 01 October 2021, 16:52:30 »
I think the accents in this set are pulled of exceptionally well. I wish more sets would do accents in a similar manner.
Offline Curin Derwin
« Reply #86 on: Sun, 10 October 2021, 21:26:17 »
This will help me live a clam, ordinary, peaceful life.
Offline akejojo
« Reply #87 on: Tue, 12 October 2021, 09:10:02 »
Nice I'm interested
Offline Ravenhar
  • Merely an observer
« Reply #88 on: Tue, 12 October 2021, 10:32:24 »
seriously, what the hell?
Offline Tyson
« Reply #89 on: Tue, 12 October 2021, 13:07:11 »
 :)) It's a quote from the anime. lol
Offline Evasive
« Reply #90 on: Tue, 12 October 2021, 16:27:03 »
Offline Tyson
Re: [IC] GMK Deathly Queen | Vendors Announced!
« Reply #91 on: Sun, 05 December 2021, 17:50:41 »
Hello! Just wanted to update everyone on the progress of this set! I'm sure a lot of you guys thought it was dead. But just like Kira himself I prefer to lay low and work on things behind the scenes! Below are the list of changes along with the addition of vendors for this set!
Changes:
- Removed both Alt alphas kits due to the amount of interest behind them. While interest for both was there the lead vendor and I are just concerned that either one of the kits would not hit MOQ dealing with us possibly having to cancel the kits. Thankfully the Menacing novelty will be made for each row, so true fans can technically make a full mod colored base kit with the novelties if they buy enough kits! So the dream is not dead of having a ultra spook menacing keyboard!
Addition:
- Vendors have been added to run this set, I am still in talks with other vendors for the regions that are listed as TBA. I hope to have all the vendors fully listed by the next update!
   -NA: Space
   -CA: TBA
   -SA: TBA
   -UK: Proto[Typist]
   -EU: Mykeyboard.eu
   -SEA: TBA
   -CN/ASIA: TBA
   -AU: SwitchKeys
   -JP: BaseKeys
- Deskmats, Metal artisans and Artisan Collabs! I just wanted to let you guys know that the deskmat designs are coming, they have been complete and I am waiting on high res images of them to arrive to me so I can work on posting them and ordering some sample mats to make sure they turn out ok before the beginning of the GB! As for Metal Artisan caps I am in talks with a vendor who makes caps for different sets already. I should have stuff to post soon and will post it once it is available to me! Artisan collabs are the final thing for this set, I have already talked to Win_Keys about a collab and will be in contact with other artisan makers to try and get collabs to happen for this set.
Thank you everyone for having patience and waiting for this set to run! I can't wait for the group buy and look forward to all the collabs with this set once it is up and running! For those of you who don't know I have been working on this set now for 2 years. To finally see it get to Group Buy has been amazing! Hope all of you guys have a nice one and I look forward to updating everyone once I have more content!
Offline Tyson
« Reply #92 on: Mon, 03 January 2022, 10:05:04 »
Hope everyone had a great new year! Just wanted to update everyone on the status of the Hibi collab, I'm still waiting for renders to come in. Once I get those I'll make sure to update the post with them along with the GB date!
Offline Evasive
« Reply #93 on: Mon, 03 January 2022, 23:01:59 »
Really sad to see the go alt alphas go. Is it possible to make a kit with the go novelties in the alphas colorway?
Offline BloremBipsum
  • Yes, I am a Dumb Ass Boi
« Reply #94 on: Sat, 08 January 2022, 12:47:07 »
It looks really great! Defo would love a board filled with novs
Offline C_L | Soup
« Reply #95 on: Tue, 11 January 2022, 19:58:56 »
YES       YES
      YES       YES
Offline Tyson
Re: [IC] GMK Deathly Queen | Vendors Announced | GB Date: 2022
« Reply #96 on: Thu, 13 January 2022, 12:15:56 »
Quick Question for those that want the Go novelties in alpha color. https://forms.gle/GfgwVBAyHbSDBE5RA
Offline Tyson
« Reply #97 on: Wed, 02 February 2022, 14:48:32 »
Update! Deskmat designs are complete and will be getting samples made to make sure colors come out accurately! Look forward to the next updates!
To Come:
- Added small Menacing Alphas child kit
- Added additional novelty to Novelty kit
- Hibi MX cap reveal
- GB Date & Pricing
- Artisan collabs
Offline xijnimx
  • kimi
Re: [IC] GMK Deathly Queen | Deskmat Designs Announced | GB Date: 2022
« Reply #98 on: Sun, 20 March 2022, 01:52:24 »
woohoo  :)
Offline TimeToGetBroke
« Reply #99 on: Thu, 31 March 2022, 06:55:01 »
10/10 would buy,
