Author Topic: [IC] ePBT Winter Breath (GB CLOSED)  (Read 86814 times)
Offline Jr.Mars
« on: Tue, 03 August 2021, 09:01:40 »
>>> GB Thread <<<
Hey enthusiasts! Thanks for taking your time to check out my new keyset -- ePBT Winter Breath.
Please help me to fill out this form and provide any feedback that you have.
** ePBT- Winter Breath IC Form **        ** IKKI68 Aurora x ePBT Winter Breath IC form **
I will run the group buy in November 1st when winter comes.
※ Kitting
※ Renders
TGR Jane V2 by Yuktsi
TGR 910 V2 by Yuktsi
Satisfaction 75 by Cannon Keys
J-02 by Proto[Typist]
Angle80 by VERTEX & U80-A by Rama Works
※ Deskmat
※ IKKI68 Aurora x ePBT - Winter Breath collaboration
**GB will be started around mid November. Limited groupbuy/1000units.**
More Information
This board collaborated with Wuque Stuidio in purple is adorable.
The transparent top case is based on the Lavender Switch from Cannon Keys.
◇ Top case: Colorway of the purple transparent top case is based on the Lavender Switch from Cannon Keys.
◇ Bottom case: Based on the similar colorway of ePBT-Winter Breath's modifers (PANTON 524C). The pattern on the back of the bottom case is inspired by the pine forest.
◇ Custom badge & logo chip & plate: Badge is based on the backspace novelty.There are two options of custom badge.
Chip is based on the snowflake novelty.The badge/chip/plate will have the same colorway in purple.
The ANSI enter novelty has been redesigned
Collab deskmats (They will be sold on Wuque.com and aurora's vendors separately)
More high-res renders are here!
※ Collaboration
HIBI Metal Keycap
Thok Metal Keycap
RNcables
Artisan Labs (wrist rest)
Archetype (artisan)
Soooooon......
Mozicaps (artisan)
Sandun (artisan)
Soooooon......
※ Inspiration & Colorway
This set is inspired by my favorite Instagram wildlife&nature photographer Julie Audet from France. Her photos of winter are awesome.
The theme is winter camp and pine forest.The color was taken from the colors of the pine forests in her photos.
※ Contact
※ Information & IC Forms
☆ PBT material
☆ Dye-sub
☆ Cherry profile
☆ Compatible with Cherry MX switches and MX-style clones
☆ Estimated group buy date: November 1st
※ Vendors
Worldwide: KBDfans
USA: Vala Supply
Canada: Mech.Land
Canada: Fancy Customs
Canada: Candykeys
UK: Proto[Typist]
SEA: Zion Studios
Australia: Daily Clack - keyset / deskmat
※ To Do List
☆ Optimize ANSI enter novelty
☆ Make base/40s kits more rational
☆ Find more vendors
☆ Set accurate GB date and Price
☆ More collaborations (cables/artisan keycaps/others)
※ Signature
Please consider adding this to your signature to support this set:
Code: [Select]
[url=https://geekhack.org/index.php?topic=114064.0][img]https://i.imgur.com/E3iEl13.jpg[/img][/url]
« Last Edit: Fri, 03 June 2022, 02:02:32 by ElvisXSS »
Offline Jr.Mars
Re: [IC] ePBT Winter Breath & IKKI68 Aurora collaboration keyboard
« Reply #1 on: Tue, 03 August 2021, 09:03:24 »
※ Changelog
2021/10/5
Add a french kit to fit the inspiration better
2021.9.22   BIG UPDATE!!
1. Update the design of Aurora bottom case! Now the stars and moon can glow in the dark night!!
2. New metal keycap collab with thok can glow in the dark!!
2021.8.29
1.Added accent keys in num/40s/icon kit
2.Redesigned the snowman novelty
3.Added  R3 ' @ key and a R3 ~ # key in international kit to support UK layout.
2021.8.21 Big updates!!!!!
1.Added a dark purple accent kit (Dark Night) to match more dark keyboards! This kit is awesome i think :thumb:
2.Add a moon novelty in novelty kit.
3.Adjusted 40s/international/spacebars kits.
2021.8.7
Updated two new deskmats (Sunrise/Dark Night) which will be only sold with Ikki68 Aurora collab keyboard.
2021.8.7
Updated base + 40s kit
add:
r3: 1u hyper, 1.25u hyper
r4: 1.75u lock
sb: 2x1u, 2x1.75u, 2x2u, 2.25u, 2.75u, 2x3u
remove:
r1: 1u esc
r2: 1u delete, 1.5u backspace
r3: 1u ctrl
r4: 1.25u shift, 1.5u shift, 1.75u shift, 2u shift, 1u ctrl, 2x1u alt, 2x1u fn
Updated novelties
1.Redesigned ANSI enter novelty
2.Changed the gloves novelty from purple to white
Updated more renders
1.Updated keycaps renders
2.Updated more IKKI68 Aurora renders.
3.Updated the snowflake logo chip of IKKI68 Aurora.
« Last Edit: Mon, 04 October 2021, 22:26:50 by ElvisXSS »
Offline sirnottoday
  • hi!
Re: [IC] ePBT Winter Breath (IKKI68 Aurora collaboration keyboard)
« Reply #2 on: Tue, 03 August 2021, 09:11:44 »
the ikki collab looks dopeeeeeee!!
on my watchlist!
might also matched color with symbiote  ;D
Offline JohnYYZ
  • KanataKeys.co
« Reply #3 on: Tue, 03 August 2021, 09:56:55 »
Winter is coming :D
Offline tobiasvl
  • ISO 9995
« Reply #4 on: Tue, 03 August 2021, 10:10:32 »
Not a fan of the Enter keys that say "Winter Breath" but I'm a fan of everything else so I'm in
Offline Hi !!
  • Kiimari
« Reply #5 on: Tue, 03 August 2021, 10:14:03 »
Clean theme. Like it at first sight. But a little concerned with the WS1 color of Wuyin.
Saw somewhere else that the color is kinda warm rather than cool white. Warmer than GMK's WS1 rather.
Also slightly disliking the "winter breath" enter. ISO's dope tho!
Offline HappyB0T
  • I'm a Piggie
« Reply #6 on: Tue, 03 August 2021, 10:15:17 »
The base set looks awesome - fun coloway. Pricing should be good without the numb pad. That is interesting for sure.
Picky stuff:
• ikki collab is cool but the purple doesn't match the keys. It is more of the nintendo gameboy purple than a rich and more reddish plum. A closer match would be cool to see. Form filled.
• Weight on some of the legends for the numb pad are off
• The spacing on the 40s shift keys are inconsistently spaced.
Offline Cylent
  • Formerly cylentshadows
« Reply #7 on: Tue, 03 August 2021, 10:46:15 »
Cool set. It feels like we've had a big influx of neutral muted sets recently, hopefully they don't run on top of one another.
A few nitpicks:
-40s alignment is all over the place, please revise
-please consider all icons for non-bottom row 40s kit, including esc
-40s kitting will need a major update to increase compatibility
-00 above 0 in numpad is aesthetically cursed. IDK who started this trend but it's time to stop.
Overall solid set, GLWIC!  :thumb:
Offline Neely_12
« Reply #8 on: Tue, 03 August 2021, 11:40:17 »
I really like the colors. Very soothing and nice to look at. One nit pick is that the rows on the base kit are labeled incorrectly for the extra modifiers. (R4 is labeled as R3 etc) Anyways good luck!
Offline krzank
« Reply #9 on: Tue, 03 August 2021, 11:51:48 »
Icon Mods -> R2:CapsLock ?
Offline Lfgberg
« Reply #10 on: Tue, 03 August 2021, 14:26:13 »
So many ikki collabs
Offline Fraaaan
« Reply #11 on: Tue, 03 August 2021, 15:22:52 »
You don't need r1 End in base if you have it in the numpad kit.
Offline mr_foggy
  • neue = nope
« Reply #12 on: Tue, 03 August 2021, 16:06:41 »
thank god for numpad-less sets.
definitely not a fan of the novelties but the base set looks nicely calm and muted.
the ikki is beautiful and colormatching it to the lavender switches is a nice idea, I just think it doesn't blend too well with the base set colors.
Offline WillyWortel
« Reply #13 on: Tue, 03 August 2021, 16:47:09 »
Very nice. I guess winter is coming :)
Offline Ashen_21
« Reply #14 on: Wed, 04 August 2021, 00:19:51 »
That Ikki collab, and the whole set in general is gorgeous, definitely going to be grabbing both!
Offline mangostan
« Reply #15 on: Wed, 04 August 2021, 00:43:55 »
love the ikki collab and color of the case. would love more desk mats or maybe  cable. N to entirely sure how I feel about the design on back end of the case. Oh also would love a weight on the bottom of the case would be so elite. though not a big fan of the novelties
« Last Edit: Wed, 04 August 2021, 02:22:17 by mangostan »
Offline Jr.Mars
« Reply #16 on: Wed, 04 August 2021, 07:39:50 »
The novelty on enter will be redesigned soon. Please wait and see.
Offline dnaphi
« Reply #17 on: Wed, 04 August 2021, 21:58:45 »
So excited for this set! Especially the ikki collab. I love the clear top and opaque bottom! The snowflake led is a nice touch.
(I don’t normally comment on geekhack but this has me really excited!)
Offline chevngk0
« Reply #18 on: Wed, 04 August 2021, 22:15:57 »
Reserved and ready for more updates :cool:
Offline Jr.Mars
« Reply #19 on: Thu, 05 August 2021, 10:07:57 »
Picky stuff:
Thanks for enjoying this set!
1.I tried to make the purple top case more versatile. And the colorway of lavender switch makes it easier for you to imagine.
2.I will redesigned the 40s kit to make it more rational.
Offline Daim
« Reply #20 on: Thu, 05 August 2021, 20:57:01 »
Keeping an eye out on this one for the desk mat. Looks clean
Offline Psyoshi
« Reply #21 on: Fri, 06 August 2021, 05:21:59 »
Beautiful set, definitely makes me think of my own winters growing up. Absolutely love the deskmat.
Offline aerospice
« Reply #22 on: Fri, 06 August 2021, 19:58:36 »
The novelties instantly brings back memories of hot chocolate during the winter! Haven't owned an ePBT set before, but this set is really tempting me to try it out. Anyway, looking forward to the future updates!
« Last Edit: Fri, 06 August 2021, 20:00:53 by aerospice »
Offline domeng
Re: [IC] ePBT Winter Breath (IKKI68 Aurora collaborate keyboard)
« Reply #23 on: Sat, 07 August 2021, 03:16:20 »
Waiting for redesigned Enter key. Thanks.
Sent from my GM1917 using Tapatalk
Offline Jr.Mars
2021.8.7
add:
r4: 1.75u lock
remove:
r1: 1u esc
r3: 1u ctrl
Updated novelties
Offline llxvbltny
hurry come,plz!
This is a 100% buy from me when it launches :)
Offline EdwardsLau
Looks so damn beautiful on the collab with Ikki Aurora. 10/10!!!
Offline balbin
Looking real nice and quick work with the redesign!
Offline Jr.Mars
Thank you for your advice. I redeigned the ANSI enter novelty. Now it's in the same series as ISO enter novelty.
Offline CharlotteS
Really love this set and your theme. Solid work! Reserve it and look forward more update!
Offline nvh2092
I think the second iso enter in base kit should be in accent color (ePbt WS1) and not alpha (Gmk GR1). The alpha color is gloomy. Also,  in the novelty kit, is the white color accent? The white backspace seems gloomy like alpha color.
« Last Edit: Tue, 10 August 2021, 02:46:56 by nvh2092 »
Offline CharlotteS
BTW I'm confuse that i think your numbering is off in the base kit . In bottom half of the base kit, you duplicated R1 twice. F and J and ANSI enter are R2 also? Maybe F/J is R3?
Offline CharlotteS
Offline Jr.Mars
Thanks for your feedback.
That's my fault and i've already fixed it.
BTW thank you for putting this set in your signiture.🥰
Offline Raul-7
Is for the keycaps or keyboard?
Offline Friendship
Technically this is a keycap GB but there is also the IKKI68 that is being sold based on this. they are not tied together purchase wise though, at least from what i can tell.
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline VAMP
  • VAMP
    • Buy me a Ko-fi maybe?
This is such a calming set. Love the tones of the purple you chose! :D
p/s: Pine base kit has a typo on the Delete key
Your friendly neighbourhood graphic designer. Hit me up if you need any graphic works! ✏️
https://www.instagram.com/by.vamp/
Offline CharlotteS
I think so! The temperature of grey is decent.Or it is purple maybe?
Offline Jr.Mars
http://
It's a keycaps ic, the board is a collab.
Offline Nerisai
Oh my god I love it so much. Instant buy, especially the collab board!
Also please don't change the color of the Ikki Aurora! Some people said the purple doesn't match, but I think it'd be quite boring if it was the exact same color as the keycaps. It's perfect as is!
« Last Edit: Mon, 16 August 2021, 04:59:13 by Nerisai »
Offline Jr.Mars
I won't change the color of ikki collab! Most people love the purple top of this board.
BTW thanks for enjoying this set!
Offline Jr.Mars
Re: [IC] ePBT Winter Breath & IKKI Aurora collab(Updated two new deskmats)
« Reply #42 on: Wed, 18 August 2021, 09:47:42 »
2021.8.7
Offline CharlotteS
« Reply #43 on: Thu, 19 August 2021, 10:13:12 »
2021.8.7
Jesus! The dark night deskmat is incredible.
Maybe i will buy 2 deskmats of this set.
May i ask are there any artisans collab for this set?
Offline Jr.Mars
« Reply #44 on: Fri, 20 August 2021, 09:30:44 »
2021.8.7
More metal keycaps collab with Thok/RAMA and cables/artisans/wrist rest are coming soon :thumb:
Offline wryed
The dark accents look amazing! a must purchase with those novelties added in there too
Offline JustMilica
  • A weeb
Re: [IC] ePBT Winter Breath (HUGE UPDATES!! Add dark purple accent kit)
« Reply #46 on: Sat, 21 August 2021, 21:06:36 »
Looks lovely! I love the deskmats, they're gorgeous!!! Only thing I'd personally change is to make the symbols on the darker novelties white instead of black considering white is already part of the set and you don't have to add an unrelated color just for the dark novelties.
Offline outerspace
« Reply #47 on: Sat, 21 August 2021, 21:30:35 »
Wait a second, does that mean we can't buy the deskmats separately, like for real?
Offline bby
  • bby#0001
« Reply #48 on: Sun, 22 August 2021, 22:33:09 »
+1
Offline atlanticise
Re: [IC] ePBT Winter Breath (HUGE UPDATES!! Added dark purple accent kit)
« Reply #49 on: Sun, 22 August 2021, 23:36:30 »
That Ikki68 collab is beautiful!
Just some feedback on the kitting, I think it would make more sense if the novelties in the accent kit were moved to the novelty kit. And the 40s kit should have a few dark accents as well for the esc/enter keys. :)
