Author Topic: [GB] LW-67 [EXTRAS R2 RELEASED]  (Read 46540 times)
Offline Laneware
    • Laneware Peripherals
« on: Sun, 18 July 2021, 00:12:52 »
R2 extras are live! Very limited quantity, if there is a color that you have your eyes on make sure you don't miss out! We won't be re-running this GB!
LW-67
By Laneware Peripherals
"Macro-1's Big Brother"
Keep Informed
My Personal Discord: LANEWARE#0468
Email: support@laneware.xyz
Build Streams & More Prototype Photos
Build Stream: By ByteSizedSeamus
Build Stream: By ManoliVisuals
Sound Test: By Filled Types
Unboxing Stream: By MechMerlin
Still to Come:
Prototype Photos: By Taeha Types, ByteSizedSeamus & Manoli Visuals
GB Key Information
Quantity: 500 Orders
Timing: 31st July 2021 at 20:00 PST for 1 Month or Until Sold Out
Projected Shipping Date: Q1 2022
Details
Form Factor: 65% (Standard 2.75u Right Shift Lets You Utilize Standard Keycap Base Kits)
Layouts: Per Below
Angle: 7 Degrees
PCB: USB Type C Daughter Board, QMK/VIA, Rotary Encoder, Hotswap Option
Encoder: With Press Function
Plate: Aluminium 1.5mm with Brass Upgrade Option
Built Weight: ~1.94kg / 4.28lb
LW-67 Base Kit Includes
Case: Annodized/Powder Coated Aluminium Top and Bottom
Switch Plate: Annodizes Aluminium, 1.5mm
PCB: Supports Layouts Shown Below
Hardware: Screws, Bumpons, Standard Encoder Knob, Gaskets
Color Options
Top & Bottom Case:
Annodized Red
Annodized Grey
Annodized Blue
Annodized Gold
Powder Coated White
Plate:
Annodized Red
Annodized Grey
Annodized Blue
Annodized Gold
Price Tags (USD)
LW-67 Base Kit: $275
LW-67 Artesian Color Matched Knob: $25
LW-67 Artesian Color Matched Knob Set (x5): $100
Brass Plate Upgrade: $25
Hotswap PCB Upgrade: $30 (Standard layout only, encoder will also come pre-soldered)
Extra Top Color: $75
Extra Plate Aluminium/Brass: $30/$55
Extra PCB Standard/Hotswap: $40/$70
Extra Standard Knob: $10
Extra Feet and Gaskets: $5
Gallery
RED Ft. GMK Nautilus & ePTB Kuro/Shiro
BLUE Ft. GMK Nautilus & ePTB Kuro/Shiro
GREY Ft. GMK Samurai & GMK Godspeed
WHITE Ft. ePTB Kuro/Shiro
GOLD Ft. GMK Samurai & ePTB Kuro/Shiro
CNC Aluminium
24mm OD, 6mm Shaft
Color Matched to Cases
Chamfer Matches Case Chamfer
Standard Knob Options
Layouts
Update: Stepped Capslock Also Available
Previous Projects
Macro-1
Raindrop 60%
Update Fequency, Terms & Conditions
We will update you on GB progress, manufacturing and shipping details at minium once every 2 weeks, or when important information becomes available.
You can expect to recieve your items before the advertised time, however uncontrollable circumstances may cause this time frame to be extended.
We aim to provide the highest quality Keyboards to our users. Our QA process should pick up any imperfections, however if a sub-par keyboard does manage to reach you, imperfections will be evaluated based on their location and size.
The outcome of this evaluation may result in a full/partial replacement, full/partial refund or return depending on the severity of the imperfection.
Specific Pantone Colors and Switch Plate .stp files will be released after the GB.
« Last Edit: Sat, 09 July 2022, 02:29:17 by Laneware »
Offline Laneware
Reserved :D
Approved :thumb:
Offline g_hack_it
Simply gorgeous. Love the layout. Can't wait
Sent from my LM-V600 using Tapatalk
Offline Laneware
I'm happy to take photo requests of any combinations :) Just let me know the below:
Top Color:
-Blue/Red/Gold/White/Grey
Base Color:
-Knob Color:
Keycaps:
GMKGodspeed/Nautilus/Honey/Samurai, epTB Kuro/Shiro, IFK Cafe, SA Mitospeed
Offline LiTurk
love this layout. wish i was still doing smaller GB's
Offline SwitchKeys
    • SwitchKeys
Runner is trusted and shipped many prior units if you were worried.  :thumb:
Offline uclatommy
This is excellent.
Can we see black case with gold top plate? Like this kind of aesthetic: https://en.wikipedia.org/wiki/File:HP-12C_programmable_calculator.jpg
And also a white case with gold plate. :thumb:
Offline Laneware
This is excellent.
Sure can :D
272754-0272756-1
« Last Edit: Tue, 20 July 2021, 21:47:57 by Laneware »
Offline Jyobah
Love the look of this board, great work!
Really digging the grey! Would it be possible to see grey top with black case and black top with grey case?
Offline Laneware
Offline Laneware
Thanks! Unfortunately we aren’t offering black as a color option with this GB :)
Offline Laneware
Offline Liub
Wowee. Very excited, now to decide on colours!
Offline Laneware
Offline darksmile
Would appreciate some photos with gold top and red/blue bottom. Thanks!
Offline Laneware
Offline Laneware
No worries 😁
272934-0 272936-1
Offline cigs_coffee
Awww...would have loved that pink color you showed in the interest check :(
Maybe another time?
Offline Laneware
30mins until the LW-67 is live!
Offline Leafite
Re: [GB] LW-67 | 65% Gasket Mounted & Rotary Encoder | by Laneware Peripherals
« Reply #21 on: Mon, 02 August 2021, 13:37:29 »
Any chance I can see it with a white top and gold bottom with a gold knob
Offline Laneware
« Reply #22 on: Tue, 03 August 2021, 05:46:17 »
Sure can :)
273421-0
Offline Laneware
Re: [GB] LW-67 Gasket Mounted 65% (250/500 Units Sold in First 3 Days!)
« Reply #23 on: Tue, 03 August 2021, 18:01:04 »
250/500 units sold in the first 3 days! What a turnout and a hige thanks to everyone for all the support and feedback on this project!
Offline AshF
« Reply #24 on: Wed, 04 August 2021, 03:26:07 »
This looks soo nice  :thumb:
Is there a link to the sounds tests / build streams?
Offline jk_pens
« Reply #25 on: Thu, 05 August 2021, 20:36:09 »
Thinking I'll jump on this one, but would be great if we could see white/blue and blue/white combos.  ;D
Offline Laneware
« Reply #26 on: Fri, 06 August 2021, 03:01:05 »
Would love to have you onboard! Had this one sitting in my camera roll, will grab the alternate combo for you at my earliest chance
273590-0
Offline jk_pens
« Reply #27 on: Fri, 06 August 2021, 09:04:10 »
Thanks! That's actually perfect, pretty much exactly what I have in my cart. I'll go wrap up the order now. :)
Offline Purse
« Reply #28 on: Fri, 06 August 2021, 17:41:20 »
is there a sound test? also what is the "gold switch plate" option?
Offline Laneware
« Reply #29 on: Mon, 09 August 2021, 00:00:15 »
Sure is! I've just put them up on the post under build stream section :) There will be another build stream by Manolivisuals on Thursday at 9PM est :)
Offline Laneware
« Reply #30 on: Mon, 09 August 2021, 00:01:51 »
Yes, ive just up a link to it in the post :) The gold switch plate option is an option to change your switch plate to gold anodized aluminium. Our previous GB the MACRO-1 this was the only plate color available, so this is for those looking to color match the two builds :)
Offline Skeil
  • I drink art and draw coffee
« Reply #31 on: Mon, 09 August 2021, 08:38:32 »
Man I'd have snag this instantly if it had an EU proxy  :(
Offline sodrop
« Reply #32 on: Thu, 12 August 2021, 19:07:01 »
just jumped in on this, could I see white base and top with a black knob and IFK Cafe? Gonna put ePBT sniper on this bad boy when I receive both
Offline Raul-7
« Reply #33 on: Fri, 13 August 2021, 03:21:37 »
I reserved 1 unit. How do I indicate I want a white/blue combo?
« Last Edit: Fri, 13 August 2021, 03:23:28 by Raul-7 »
Offline SaintDoctor
« Reply #34 on: Fri, 13 August 2021, 13:09:38 »
Love it! Could we see a gold base + red top?
Offline tqkhanh
« Reply #35 on: Sat, 14 August 2021, 10:13:52 »
Do i need any soldering tools for the hotswap pcb :?
Offline Redzel
« Reply #36 on: Sun, 15 August 2021, 00:23:48 »
Why there is no Gold base with White top in GB?  :'(
Offline g_hack_it
« Reply #37 on: Sun, 15 August 2021, 05:04:30 »
You can do that, just need to get the gold top+bottom and an extra white top.
Offline retrorecall
« Reply #38 on: Thu, 19 August 2021, 22:18:36 »
looks slick, curious how the knobs are connected, can it take aftermarket knobs like guitar knobs or others?
Offline Un1f0rm
« Reply #39 on: Fri, 20 August 2021, 11:42:05 »
Could you show a grey/grey with a golden/grey/default black knob? If you have the GMK Godspeed set around as well that would be perfect  :D
Offline Laneware
« Reply #40 on: Sun, 22 August 2021, 04:07:56 »
Hoping to get some time to these combo requests early this week to give you all plenty of time to decide :)
« Last Edit: Sat, 28 August 2021, 15:55:35 by Laneware »
Offline ThorTheGray
« Reply #41 on: Mon, 23 August 2021, 14:30:34 »
Just built my first custom on a Tofu65 and now I'm hooked. I just got in on this GB since I love the look of this board.
Offline ZAND4
« Reply #42 on: Tue, 24 August 2021, 03:05:52 »
Reserved FTW !
Offline Dinerenblanc
« Reply #43 on: Sat, 28 August 2021, 06:25:25 »
Looking forward to receiving this.
Offline zlorfik
« Reply #44 on: Sat, 28 August 2021, 21:21:54 »
Great design! Ordered.
Offline Laneware
Re: [GB] LW-67 Gasket Mounted 65% (Closed)
« Reply #45 on: Mon, 17 January 2022, 04:02:54 »
281288-0
Offline Laneware
Re: [GB] LW-67 [EXTRAS ANNOUNCED]
« Reply #46 on: Sat, 28 May 2022, 20:07:42 »
Now that a large bulk of the keebs have been delivered, extras will be available two weeks from today. We will run this in the same way we did the Macro-1 extras, with two rounds. 75% of the extras will be made available in round 1, the remaining 25% we will hold onto for several months just to ensure all GB customers are completely satisfied. Then we will release the remaining 25% in an extras r2. Additionally, we will keep spare PCBs for 2 years.
Offline Laneware
Re: [GB] LW-67 [EXTRAS ANNOUNCED T-MINUS 45 MINS TO LIVE]
« Reply #47 on: Sat, 11 June 2022, 21:19:50 »
Less than 45mins until extras are live! These are very limited quantity and FCFS.
Offline Laneware
Re: [GB] LW-67 [EXTRAS IN STOCK]
« Reply #48 on: Sat, 25 June 2022, 01:45:26 »
Update: R1 of extras are almost sold out. All replacement packages fomr GB orders have been sent, so R2 of extras will release in 2 weeks time!
Offline Laneware
Re: [GB] LW-67 [EXTRAS R2 RELEASED]
« Reply #49 on: Sat, 09 July 2022, 02:28:07 »
