Author Topic: [IC] GMK Inverted  (Read 34835 times)
Offline FerPL
  • www.rheset.mx
[IC] GMK Inverted
« on: Thu, 07 October 2021, 05:31:31 »
DOWN
Ԁ∩
Hello! Im Fer from www.rheset.mx Welcome to the IC for GMK Inverted
This Low-Contrast set that was created thinking what would be the opposite of a BoB set, a WoW(ish) set.
Colors: GR1 WS2
INTEREST CHECK FORM
Kits
Renders
Vendors
TBD
Info
This is a project that still has work to do so any ideas, criticisms or feedback are welcome.
I want to thank Puncus for the renders and all my friends from the KatanaxKaji server for the recommendations.
Contact
FerPL | rheset.mx#0970
Signature:
Code: [Select]
[url=https://geekhack.org/index.php?topic=114883.0][img width=624 height=124]https://i.imgur.com/DPaVwQI.gif[/img][/url]
« Last Edit: Thu, 07 October 2021, 05:34:10 by FerPL »
Offline Fraaaan
Re: [IC] GMK Inverted
« Reply #1 on: Thu, 07 October 2021, 06:38:57 »
If you want to split the numpad from the base kit it would make sense to move r1 PgDn and End from the base kit to the numpad kit since those are for 1800 support.
The pipe key (\|) for ISO support needs to be r3, not r4 like in your render.
You don't need an extra ANSI pipe. Those are for sets that use different colors for alphas and mods so people can choose what they want.
You have 2 r4 1u Fn keys. I don't really see the need for more than 1.
Please add F13 to the base kit.
We'd also appreciate if you labeled the size of all spacebars/shifts.
Offline Cylent
  • Formerly cylentshadows
« Reply #2 on: Thu, 07 October 2021, 10:03:53 »
Offline Zetina
  • Big bird
    • Instagram
« Reply #3 on: Thu, 07 October 2021, 11:40:57 »
I really like how this looks on E-white boards  :thumb:
Reserved
Instagram: @zetina.kb
Offline Yuinth
« Reply #4 on: Thu, 07 October 2021, 11:59:54 »
I like the colors.
Could you put renders with dark boards like black and blue?
GLWIC
Offline matthewdias
« Reply #5 on: Thu, 07 October 2021, 15:01:56 »
3-key 40s in base would be more appropriate for this set
Offline IOVERCALLHISTIOCYTES
« Reply #6 on: Thu, 07 October 2021, 15:40:50 »
For simplicity’s sake, 3 key 40 and numpad in base would let you run two kits at lower MOQ and get both made. Really love these low contrast sets, hope this gets made.
Offline sup3r170va
« Reply #7 on: Fri, 08 October 2021, 00:28:07 »
Nice colors. Would WS1 work better than WS2?
Also, 40s kit should be all icon instead of icon + mod
Offline surplusofchairs
« Reply #8 on: Fri, 08 October 2021, 21:41:19 »
I like the low contrast very much. Glwic
Offline lukelex
« Reply #9 on: Mon, 11 October 2021, 02:53:30 »
I dig...deep
Offline Loquerish
« Reply #10 on: Thu, 21 October 2021, 08:45:51 »
Like the colors. GLWIC!
Offline kkd_20
« Reply #11 on: Thu, 21 October 2021, 23:22:20 »
You need to add a f13 in the base
Offline VXQN
« Reply #12 on: Fri, 22 October 2021, 04:52:47 »
Missing a R3 ISO key.
Offline PracticalJoke
« Reply #13 on: Sat, 23 October 2021, 17:02:58 »
Love the color scheme you went for.
Offline Dinerenblanc
« Reply #14 on: Fri, 24 December 2021, 17:20:31 »
This is dope. Is it every gonna get to GB?
Offline Fraaaan
« Reply #15 on: Fri, 24 December 2021, 17:27:52 »
Doubt it. It seems like OP abandoned the project as soon as he posted the IC. He never replied to any comments or made any adjustments to the set.
Offline Tyson
« Reply #16 on: Fri, 24 December 2021, 17:39:06 »
I mean, that doesn't mean someone abandoned the project lol. He might have just gotten busy with other things in his life.
Offline BirgusLatro
« Reply #17 on: Sat, 25 December 2021, 18:13:24 »
White on Grey is a yes for me depending on kits/pricing/vendors
Offline santela
« Reply #18 on: Sat, 25 December 2021, 21:50:53 »
Okay I actually really dig this color scheme. Love it in fact. But the designer MIA is somewhat concerning...
Offline potatobot
  • Her Endgame
  • GMK BLACK LOTUS
« Reply #19 on: Sat, 25 December 2021, 23:15:24 »
I just discovered this. I made a similar design with legends being lighter than the key color itself.
Is op still pushing this through?
I was planning to make an IC today.
Offline vheissu
  • Pragmatic Geometrist
« Reply #20 on: Sat, 25 December 2021, 23:38:35 »
Hi, the designer is a close friend of mine, he hasn't abandoned the project, just that he's been busy with things of daily life.
Expect updates in the next few weeks.
« Last Edit: Sun, 26 December 2021, 13:43:34 by vheissu »
Offline aicyborg
« Reply #21 on: Sun, 26 December 2021, 18:28:55 »
uk iso support avail?  :-[
Offline Tyson
« Reply #22 on: Sun, 26 December 2021, 21:32:01 »
Hype! Excited to see an update! Can't wait!
Offline Thon
« Reply #23 on: Mon, 24 January 2022, 23:09:42 »
solid gmk blank contender
