Author Topic: [IC] GMK Pink on Black  (Read 14220 times)
Offline JonoColwell
« on: Fri, 22 October 2021, 03:26:21 »
Have you ever thought to yourself "Man this GMK WoB is really nice but it would be cool if instead of white it was pink"?
Well if you have, please consider
GMK Pink on Black
Interest Check Form
Concept:
I like simple sets, I like pink, I like black, GMK has stock colours for pink and black, why not just put the pink, on the black, bam, pink on black set.
Colours:
MG1/CR, yes technically it's magenta but I didn't like 3C
Kits:
Base Kit:
Extension Kit:
Additional Renders:
Probably more coming soon
Bean by Kingk22
Constellation by AEBoards
Endash by FinderWorks
Praxis by Ivery Boards
Wombat by Impulse Boards
Old Stuff:
Removed 2021-11-16
Base Kit:
Spacebars Kit:
Macro Kit:
Update 2021-11-16:
I've made some changes to the base kit, new renders now in place
« Last Edit: Mon, 15 November 2021, 23:57:50 by JonoColwell »
Offline KucherenkoZZZ
Re: GMK Pink on Black
« Reply #1 on: Fri, 22 October 2021, 03:31:52 »
Noice but please consider icon mods
GLWIC
Offline premise_
Re: [IC] GMK Pink on Black
« Reply #2 on: Fri, 22 October 2021, 03:32:24 »
Nice, glad you went with Text + Icon mods
Offline _haru
  • Formerly linuxfanatic
  • Back from the dead
« Reply #3 on: Fri, 22 October 2021, 03:33:50 »
I'm in if you put ISO in the base kit
AMJ60 - 45g MX White | GH60 Rev. C - Ghost Gateron Blacks | DFK101 - Alps SKCM Cream | Filco Majestouch 2 TKL - 62g Vintage MX Ergo Clear
Offline Silk
« Reply #4 on: Fri, 22 October 2021, 03:34:50 »
Not enough pink mods for Wombat???
Offline udller
« Reply #5 on: Fri, 22 October 2021, 03:35:09 »
looking good, the best parts of miami nights. +please add in handbag icon for capslock.
Offline JonoColwell
« Reply #6 on: Fri, 22 October 2021, 03:41:07 »
I could probably add another caps lock, bring it to 3 caps locks, one with handbag
At present I'm considering just rolling the entire spacebars kit into the base kit to be honest.
Offline VXQN
« Reply #7 on: Fri, 22 October 2021, 04:29:07 »
For the macro kit, please put in another single column of M1 to M5.
Offline The0rigina1
  • fumoposting
« Reply #8 on: Fri, 22 October 2021, 05:13:28 »
Maybe put UK iso in macro kit?
Maybe 3u spacebars in the spacebar kit?
R1 Equal in numpad is extremely based.
Offline Neely_12
« Reply #9 on: Fri, 22 October 2021, 07:56:33 »
The base kit already seems expensive. I'm pretty sure adding that entire spacebars kit would make the base like 160-170. I personally don't see the need for all of the accent minibars, but thats your call. +1 to adding a column of M1-M5 for single-column macros.
Offline Ella
  • Why is it called an oven
« Reply #10 on: Fri, 22 October 2021, 08:59:20 »
No ISO in the base kit, and ugly windows icons that nobody uses! AWESOME!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Offline NoPunIn10Did
    • NoPunIn10Key
« Reply #11 on: Fri, 22 October 2021, 09:09:15 »
Re: Macros
You can make the macro keys compatible with both one-column and two-column setups by doing it this way:
R1:    M1    M6
R2:    M2    M7
R3:    M3    M8
R4:    M4    M9
R4:    M5    M10
Offline clik_clak
« Reply #12 on: Fri, 22 October 2021, 11:56:36 »
Great looking set!
Can you point me to more information about that Wombat board? I can't seem to find anything anywhere
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #13 on: Fri, 22 October 2021, 15:43:30 »
your windows keys look a little too modern, can you please regress them into pad printed win95 logos
Offline JonoColwell
« Reply #14 on: Fri, 22 October 2021, 16:40:18 »
I would except that the plan is to have these moulded, my personal preference is for these particular windows keys
I'd potentially look at adding a couple of 3u spacebars, as a bonus they'd just be CR so you could mix and match with any other base kit which has CR as the base colour
I'll see what it comes out to, from what I can see base kits don't seem to vastly increase in price with more keys added or with keys removed (numpadless base kits cost very similarly to base kits with numpads) and it is a stock colour kit, either way I'll certainly be discussing with vendors and GMK to keep prices as reasonable as possible.
Great looking set!
Wombat is an upcoming board, I currently am waiting on prototypes before I throw the interest check out there, planned to be unlimited group buy but very, very expensive.
Re: Macros
R1:    M1    M6
R2:    M2    M7
R3:    M3    M8
R4:    M4    M9
R4:    M5    M10
Both of these are options I'm considering, probably leaning towards option 2 as that would allow for maximum freedom
Offline kapowaz
    • kapowaz industries
« Reply #15 on: Fri, 22 October 2021, 17:19:18 »
A black and pink set! Somebody’s Playing with Fire here!
But in all seriousness, it looks great. +1 for UK-ISO support if possible, somehow. If I were to offer my own two cents on the Windows logo key, I’d suggest if anything going with something neutral rather than any given version of the actual Windows logo. No matter which one you choose you’ll alienate somebody, whereas a neutral meta symbol can work for everyone (except of course those who absolutely want the actual logo).
Something I’ve seen a few sets do some variation on is this, which manages to be both Windows-like and Meta symbol-like at the same time:
Offline denibhoxha
  • cock and balls technology
« Reply #16 on: Fri, 22 October 2021, 17:34:38 »
the absolute most jacket the **** up base kit of recent times with the ABSOLUTE BASED move of even having a numpad equal key, love to see it
Offline JonoColwell
« Reply #17 on: Fri, 22 October 2021, 18:08:15 »
I kind of get where you're coming from with this, however the kit already comes with the standard bottom row options of code and super to fill out the space where the windows keys would go, in this instance windows keys are an optional extra which you can choose to use or not at your discretion.
Offline wahfuhls
« Reply #18 on: Fri, 22 October 2021, 19:37:42 »
probably should put iso in base. love the stepped control and the r4 caps tho dont change that:thumb:
Offline doggo1dance
« Reply #19 on: Fri, 22 October 2021, 22:32:07 »
looks interesting, but dear god the kitting is horrible
Offline JonoColwell
« Reply #20 on: Fri, 22 October 2021, 22:47:11 »
Perhaps you could elaborate on this? The interest check phase is the time to nail down kitting.
Offline kkd_20
« Reply #21 on: Sat, 23 October 2021, 00:39:06 »
move those 3x spacebars from base kit, to reduce the price.
Offline sirieous
  • help
« Reply #22 on: Sat, 23 October 2021, 11:23:21 »
Very interested good sir
Sent from my Pixel 5 using Tapatalk
Offline JonoColwell
« Reply #23 on: Mon, 15 November 2021, 23:58:36 »
Hey Guys
Made some updates to the kits, compacted to 2 kits, increased compatibility
Offline Anthixious
« Reply #24 on: Tue, 16 November 2021, 00:43:10 »
Even though GMK has ridiculous lead times, looking forward to grabbing this set, such a simple and clean colorway.
Offline Mecxs
« Reply #25 on: Tue, 16 November 2021, 01:32:16 »
You have 1-key 40s with the R2 1.75u backspace, but need R3 1.25u tab and R3 1.5u enter to bring it up to 3-key support. You could go a step further an add R2 accented esc for 4-key support if you really want to go wild.
Offline Hells
« Reply #26 on: Wed, 01 December 2021, 04:34:56 »
Love this set.
When you re-kitted the set you lost the accented Enter key, not sure if this was intentional?
You have that accented key on the renders and i think its worth keeping.
6
Offline XiXora
« Reply #27 on: Wed, 01 December 2021, 09:30:35 »
Bottom row support is comprehensive!
I always love me some 1.5U Supers but usually need another (2) 1u Alt to support my usual bottom row. Maybe a mistake as there are two R4 fn keys :)
Always here for more Wombat images :D
