Author Topic: [IC] Ojou - An O-ring mount 60%  (Read 30764 times)
Offline Esheu2
« on: Tue, 16 November 2021, 18:48:04 »
The Ojou
Design inspired by Hololive 2nd Gen VTuber, Nakiri Ayame. This my rendition of an endgame O-ring mount 60% with no external screws and a polished bead-blasted stainless steel bottom.
New Prototypes
More pictures here:https://imgur.com/a/mqJuTaG
Photos courtesy of Trifelife!
Features
  • 50A duro O-ring "gummy worm" mount
  • Anodized 5052 Aluminum for the top and internal case
  • Stainless Steel Weight
  • 6.5 Degree Typing Angle
  • 18.5mm Front Typing Height
  • Universal USB-C Daughterboard
  • PCB Compatible with QMK/VIA
  • No external screws
Supported Layouts
  • Split/full backspace
  • Split/full right shift
  • Stepped/normal capslock
There will be a choice of HHKB or WKL top.
Plate
The plate will be a standard 1.5mm thickness.
I have yet to decide on material, but it will be one of the following:
  • Aluminum
  • Carbon Fiber
PCB
  • QMK/VIA Compatible
Designed by Trifelife
Colors
  • Black
  • Wine Red
Price: TBA but NOT cheap
Updates
Commence prototyping soon. Prototypes made! We had both polished and bead blasted weights were made for the prototypes.
My manufacturer complained to me that the production of polished stainless steel pieces that large was too difficult to produce and QC. It is looking likely that we will be moving towards only providing a bead-blasted weight finish for production.
More Renders
More Information and Updates
Discord Server Invite: https://discord.gg/pYVsseU
Please join the Discord server and subscribe to the !ojou role if you would like to get updates on the project as soon as possible.
Special Thanks To
Exfinite (Vov) for aesthetics feedback
Juaninamilli for proofreading the design, giving feedback, and making the keycap'd renders
Trifelife for the idea, aesthetics feedback, designing the PCB, and being a degenerate weeb
FAQ
Q: Why no bumpons?
A: It was an aesthetic decision. Aside from the emblem/logo, I didn't want to interrupt the curves and smooth design of the weight with cutouts for bumpons. For those that are worried that the polished stainless steel weight will get scratched, I understand your concern. However, stainless steel is relatively hard. Unless the board is very seriously mistreated, it won't get damaged very easily. Though, I still wouldn't rough it up needlessly. As such if you're interested in this board, I recommend using a deskmat with it and storing it away properly when not in use.
« Last Edit: Fri, 13 May 2022, 23:10:31 by Esheu2 »
Ojou
Offline Esheu2
Re: [IC] Ojou - An O-ring mount 60%
« Reply #1 on: Tue, 16 November 2021, 18:48:46 »
Photos and Typing Tests of Original Prototypes
« Last Edit: Fri, 13 May 2022, 23:08:51 by Esheu2 »
Ojou
Offline yoot
    • none
« Reply #2 on: Tue, 16 November 2021, 18:52:07 »
Looks nice ! I love hololive boards !
Offline TheTriggeredPony
« Reply #3 on: Tue, 16 November 2021, 18:54:20 »
Very attractive design so good work there, just wish it wasnt an o-ring mount board. But if it sounds good ill prob be in for one!
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #4 on: Tue, 16 November 2021, 19:02:33 »
What the **** is a hololive
Offline zea
  • yeh
« Reply #5 on: Tue, 16 November 2021, 19:09:04 »
google.com
Offline CookieFlow
« Reply #6 on: Tue, 16 November 2021, 19:21:17 »
Very pretty board
Wish it was a 65% instead
Also no "full" 60% layout?
Offline 7h3of7
« Reply #7 on: Tue, 16 November 2021, 19:27:53 »
ne protos avail
Current Board: OTD 356 Mini v1 Black
Offline engyshow
« Reply #8 on: Tue, 16 November 2021, 19:28:14 »
Nahone...  :-X
We do a little Ayame enjoying
Offline Sicowa
« Reply #9 on: Tue, 16 November 2021, 19:43:04 »
I like ayame, would be very interested in a sandblasted SS version if possible. And would like to see a proto before GB as well. Very keen.
« Last Edit: Wed, 17 November 2021, 17:59:04 by Sicowa »
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #10 on: Tue, 16 November 2021, 19:43:26 »
where are the bumpons?
Offline ddnomad
« Reply #11 on: Tue, 16 November 2021, 19:44:35 »
Now that looks pretty
Offline hover0423
« Reply #12 on: Tue, 16 November 2021, 19:44:45 »
Why not wk.. I love wk
Offline ddnomad
« Reply #13 on: Tue, 16 November 2021, 19:45:15 »
Double that :)
Offline Esheu2
« Reply #14 on: Tue, 16 November 2021, 19:46:54 »
no bumpons. This will be a deskmat exclusive board
Ojou
Offline Esheu2
« Reply #15 on: Tue, 16 November 2021, 19:49:10 »
ne protos avail
I've had a first round of protos that have been made for half a year already, but the design has changed a decent amount since then so I wasn't sure if it was appropriate to post pictures of those. A second round of prototyping will commence soon.
Ojou
Offline ddnomad
« Reply #16 on: Tue, 16 November 2021, 19:49:39 »
Uhh, it depends on the weight of the board but it will defo tend to slide around without bumpons. And the weight will scratch pretty quickly if you just need to put the board aside on any hard surface (e.g. when cleaning the table).
Offline dRnRcRr
« Reply #17 on: Tue, 16 November 2021, 19:50:07 »
Love the lines.  Super clean
Offline Esheu2
« Reply #18 on: Tue, 16 November 2021, 19:52:08 »
5lbs built. It doesn't slide around very easily. I've been keeping my first prototype in a case when not in use. I'll be looking into getting a custom carry/storage case made for this board when GB comes around.
« Last Edit: Tue, 16 November 2021, 20:01:18 by Esheu2 »
Ojou
Offline ddnomad
« Reply #19 on: Tue, 16 November 2021, 19:57:19 »
6lbs built. It doesn't slide around very easily. I've been keeping my first prototype in a case when not in use. I'll be looking into getting a custom carry/storage case made for this board when GB comes around.
Dedicated carrying case would be definitely appreciated.
Still not sure whether I find an absence of bumpons a big deal or not though. It does sound like a potential issue to me, but at the same time I use deskmats at all times and this board won’t be the one to use for travel for sure.
Offline shima
  • keeb weeb
« Reply #20 on: Tue, 16 November 2021, 20:13:44 »
yo dayo
boards: anura
Offline hali
  • OHHHH MY GODDDDDD
    • hali.studio
« Reply #21 on: Tue, 16 November 2021, 21:25:57 »
so you either have a prototype and you're not showing us or you're lying about having a prototype
Offline Visionaire
« Reply #22 on: Tue, 16 November 2021, 21:26:08 »
Looking good. Following for more information. Best of luck!
Offline Fraaaan
« Reply #23 on: Tue, 16 November 2021, 21:32:27 »
ne iso avail?
i love anime btw
Offline Baka Bot
« Reply #24 on: Tue, 16 November 2021, 21:34:33 »
where prototype?
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #25 on: Tue, 16 November 2021, 21:34:51 »
where we're going we don't need prototypes. also weebs out.
Keyboard Collection: Unikorn, Orion v1, Orion v3, Realforce 87u, Das II, 356mini, Wang 325-3770, Lightpad v2, Deko Fast Action
Keyset Collection: OG Doubleshots x2, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild, Minimal R1, SAD Dyesubs,
Offline Esheu2
« Reply #26 on: Tue, 16 November 2021, 21:36:04 »
This was an early version that wasn't weebified yet. That's why I wasn't sure if it was appropriate to post it
Ojou
Offline Vov
« Reply #27 on: Tue, 16 November 2021, 22:00:01 »
replying to this thread with my proto from earlier this year  :)
« Last Edit: Tue, 16 November 2021, 22:03:04 by Vov »
1.2 og | 2.0 add | Fallacy | Alpha65 | Ojou | Orion v2.5 | Kei | FMJ Poker | GSKT-00 | Unikorn 2.1
Offline Ustinj
« Reply #28 on: Tue, 16 November 2021, 22:11:19 »
nice looking board
Offline Raian
« Reply #29 on: Tue, 16 November 2021, 23:04:39 »
not sure how I feel about this on polished ss sounds like a world of hurt especially on a keyboard that you are saying is not gonna be cheap...
Offline MIGHTY CHICKEN
« Reply #30 on: Tue, 16 November 2021, 23:10:44 »
Wow that's a beauty
Offline sally
« Reply #31 on: Wed, 17 November 2021, 00:31:50 »
Price not "CHEAP"
Not to be rude, but not cheap for a oring-mount is not working for me
Offline ddnomad
« Reply #32 on: Wed, 17 November 2021, 03:41:40 »
Without bumpons it will get sandblasted over the time
Offline Ella
  • Why is it called an oven
« Reply #33 on: Wed, 17 November 2021, 04:01:22 »
Weebs out
Offline VXQN
« Reply #34 on: Wed, 17 November 2021, 04:09:02 »
"This will be a deskmat exclusive board"
Absolutely amazing. Every time I think I've "seen it all" someone comes out with some gold like this.
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #35 on: Wed, 17 November 2021, 04:39:44 »
no bumpons is a very bad idea
Offline Esheu2
« Reply #36 on: Wed, 17 November 2021, 05:01:55 »
You can add on bumpons after the fact just fine. I just chose not to put dedicated bumpon cutouts for aesthetic reasons. Plus, there are literally pictures of two different prototype units posted in this thread after months of use without being scratched up. Stainless steel is pretty hard. It doesn't scratch easily unless you do something very wrong to the board.
Ojou
Offline ddnomad
« Reply #37 on: Wed, 17 November 2021, 05:10:47 »
Adding bumpons after the fact on a board which is probably gonna cost way over 500€ feels wrong
Offline pfcmickey
« Reply #38 on: Wed, 17 November 2021, 07:01:35 »
is this gonna be compatible with gh60 standard pcbs?
Offline stidal
  • milo#3939
« Reply #39 on: Wed, 17 November 2021, 09:24:58 »
vtubers and their consequences have been a disaster for the human race
transition tkl // aksara ce // bully // valhalla // voyager // rs60 // adiuvare // ciel60 // jules // prime e // ut47.2 // sequence // bumper // q1 // gaff60
Offline Esheu2
« Reply #40 on: Wed, 17 November 2021, 13:58:57 »
no it will not
Ojou
Offline stewfayew
« Reply #41 on: Wed, 17 November 2021, 15:09:21 »
I see screw holes in the bottom. What're those for?
Will the weight be exposed internally at all? I worry about the sound
Offline Esheu2
« Reply #42 on: Wed, 17 November 2021, 15:12:56 »
Those screws hold in the weight. The weight isn't exposed internally except for a small opening for the daughterboard cable routing channel.
Ojou
Offline jewleeuhn
« Reply #43 on: Wed, 17 November 2021, 15:23:23 »
board with bumpon delete? sick
Brutal60 | GS6O | IU | Mc65 | 2.0add
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #44 on: Wed, 17 November 2021, 15:48:12 »
no bumpon stainless steel bottom is definitive proof of brain on vtuber
Offline Vorge
« Reply #45 on: Wed, 17 November 2021, 16:30:21 »
Out of the 3 Ayame boards I like yours the best, idk about the lack of bumpons since I tend to use my keyboards in strange positions and places, but tbf it would be a problem with everything that isnt sandblasted in my case so Im letting it slide. GLWIC
Offline chat and team
« Reply #46 on: Wed, 17 November 2021, 16:43:50 »
this just isnt needed no thanks
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Esheu2
« Reply #47 on: Wed, 17 November 2021, 17:37:40 »
Typing test of Vov's original prototype!
Ojou
Offline Sicowa
« Reply #48 on: Wed, 17 November 2021, 17:58:15 »
the theme just kinda seems slapped onto this board...
I would rather this board be sold as just a nice 60 honestly. The addition of an ayame theme just seems very weird to build more attention. if you friend really likes it then just run it for him maybe. otherwise this just seems like your trying to bring attention to the board via weebs rather than what the board brings to the community. idk. I just beileve that designers should design around a theme they care for. not what their friends like *shrug*
its a nice board, but I just dont like the way the theme was done. otherwise GLWIC,
Offline treeleaf64
    • treeleaf64
« Reply #49 on: Wed, 17 November 2021, 18:18:59 »
nice "Ayame keyboard"
Not protected polished stainless steel back  :'(
Everyone must pay the cat tax
