Author Topic: [GB] LW-75 | GB Closed |  (Read 38527 times)
Offline Laneware
    • Laneware Peripherals
« on: Sun, 23 January 2022, 20:54:29 »
Introducing the
LW-75
By Laneware Peripherals
Product Page
Keep Informed
Instagram
Discord Server
Prototype Build Streams
Filled Types
Sound Test
Mechmerlin
Unboxing First Impressions
Build Stream
Typing Test
Typing Test On Stream
Manoil Visuals
Sound Test Stock
Sound Test + Case Foam
Sound Test + Tape Mod
Sound Test + Case Foam & Tape Mod
Full Stream
Dutchmasterw
Build Stream
Clackbait
Build Review
Plenty more from community content creators still to come...
GB Key Information
Quantity: 500 Orders
Timing: 26th February 2022 at 20:00 PST to 31st March 2022 or Until Sold Out
Projected Shipping Date: Early Q4 2022
Details
Form Factor: 75%
Mounting Method: Gasket
Layouts: Per Below
Angle: 7 Degrees
PCB: USB Type C Daughter Board, QMK/VIA, Rotary Encoder, Hotswap Option
Encoder: With Press Function
Plate: Aluminium 1.5mm with Brass Upgrade Option and FR4 Option
Built Weight: ~2.2kg / 4.85lb
LW-75 Base Kit Includes
Case: Annodized/Powder Coated Aluminium Top and Bottom
Switch Plate: Annodizes Aluminium, 1.5mm
PCB: Supports Layouts Shown Below
Knobs: 2 x Standard Knobs (Silver, one with line marking, one without)
Hardware: Screws, Bumpons, Gaskets, Practice PCB, Laneware Sticker
Coaster: Day 1 Orders Include Coaster Gift Color Matched to the Base Kit
Color Options
Top & Bottom Case:
Annodized Blue
Annodized Grey
Annodized Green
Annodized Pink
Powder Coated White
Plate:
Matches Base Kit
Price Tags (USD)
LW-75 Base Kit: $325
LW-75 Artisan Color Matched Knob Aluminium/Brass: $25/$50
LW-75 Artisan Color Matched Knob Set (x5): $100
LW-75 Artisan Color Matched Coaster Aluminium/Brass: $25/$60
LW-75 Artisan Color Matched Coaster (x5): $100
Brass Plate Upgrade: $25
Hotswap PCB Upgrade: $30 (Standard layout only, encoder will also come pre-soldered)
Extra Top Color: $75
Extra Plate Aluminium/Brass: $30/$55
Extra PCB Standard/Hotswap: $40/$70
Extra Feet and Gaskets: $5
Content Creator Gallery
Gallery
"Nature"
"Blossom"
"Nautica"
"Obsidian"
"Snow"
LW-75 Artisan Color Matched Knobs
CNC Aluminium
18mm OD, 6mm Shaft
Colors: Blue, Pink, White, Grey, Green, Black and Silver
Fillet Matches Case Fillet
Layout
Contact
My Personal Discord: LANEWARE#0468
Email: support@laneware.xyz
Previous Projects
LW-67
Macro-1
Raindrop 60%
Update Fequency, Terms & Conditions
We will update you on GB progress, manufacturing and shipping details at minium once every 2 weeks, or when important information becomes available.
You can expect to recieve your items before the advertised time, however uncontrollable circumstances may cause this time frame to be extended.
We aim to provide the highest quality Keyboards to our users. Our QA process should pick up any imperfections, however if a sub-par keyboard does manage to reach you, imperfections will be evaluated based on their location and size.
The outcome of this evaluation may result in a full/partial replacement, full/partial refund or return depending on the severity of the imperfection.
Specific Pantone Colors and Switch Plate .stp files will be released after the GB.
« Last Edit: Mon, 04 April 2022, 19:18:02 by Laneware »
Offline Laneware
Re: [GB] LW-75 | 75% Gasket Mounted with Rotary Encoder |
« Reply #1 on: Sun, 23 January 2022, 20:55:11 »
Reserved - I will update this comment with any top and bottom color combination requests :D
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #2 on: Mon, 24 January 2022, 06:31:47 »
approved
Offline nullinasou
« Reply #3 on: Mon, 24 January 2022, 06:52:59 »
honestly the best coaster ive ever seen
Offline kaicrumbs
« Reply #4 on: Mon, 24 January 2022, 12:55:07 »
never thought i would by a coaster with a keyboard… but they look so nice
Offline Laneware
Offline wilferdg
    • wilferd.com
« Reply #6 on: Mon, 24 January 2022, 19:14:45 »
I would looove to see Snow bottom + Blossom Top & Snow bottom + Nature Top :)
Offline Laneware
« Reply #7 on: Tue, 25 January 2022, 01:49:18 »
Here you go :D (Images are expandable)
281527-0
281529-1
« Last Edit: Tue, 25 January 2022, 01:50:57 by Laneware »
Offline kcching
« Reply #8 on: Tue, 25 January 2022, 06:44:50 »
Is the top panel interchangeable ?
Offline Laneware
« Reply #9 on: Tue, 25 January 2022, 16:26:56 »
Yes it is :) You are able to purchase extra tops.
Offline Techdude594
« Reply #10 on: Wed, 26 January 2022, 03:13:49 »
Great price and nice design!
Offline Inversecrowd
Re: [GB] LW-75 | Giveaway Live! |
« Reply #11 on: Thu, 27 January 2022, 05:33:49 »
Keen as always, that green 👌
Offline Laneware
« Reply #12 on: Fri, 28 January 2022, 16:40:56 »
Thank you!
Offline Laneware
« Reply #13 on: Sat, 29 January 2022, 16:20:13 »
I’ve had a lot of requests for the grey base combos in our discord, so I will post them here as well :)
281805-0
281807-1
281809-2
281811-3
Offline alper_maestro
« Reply #14 on: Mon, 31 January 2022, 07:59:40 »
Can you also post all the pictures for the white base combos  ?
Offline Laneware
« Reply #15 on: Mon, 31 January 2022, 15:50:03 »
Sure! Here are the additional photos, see above for white/pink and white/green :)
281883-0
281885-1
Offline Laneware
Re: [GB] LW-75 | Build Stream Live! (8PM est) see post for details |
« Reply #16 on: Mon, 31 January 2022, 19:13:46 »
Build stream is currently live with Manoli Visuals! https://www.twitch.tv/manolivisuals
Offline Laneware
Re: [GB] LW-75 | First Sound Test Now Up! |
« Reply #17 on: Tue, 01 February 2022, 05:33:12 »
First build stream is up! Let us know your thoughts on the sound test :D
Offline Techdude594
« Reply #18 on: Sat, 05 February 2022, 03:26:10 »
Sounds great! Will the encoder on the hotswap pcb require soldering?
Offline Laneware
« Reply #19 on: Sat, 05 February 2022, 23:04:07 »
Thankyou :D The encoder will come soldered for the hotswap orders.
Offline tuxkey
« Reply #20 on: Fri, 18 February 2022, 10:48:32 »
i really like the layout.. bottom row is nice..No waist of space with unnecessary blockers.
And i like the right row of keys (4). Give's me room to have home/end + page up/down.
all without having to use Fn to reach them. And the exploded nature keeps things nice and
separated. And having the encoder on the other side is refreshing for sure..
And while taste is subjective i think it works my compliments.
i don't mind the price for a board that works so well with the layout i love to see.
Only question i have is " will there be any EU vendors" (like CandyKeys in Germany)..
Because if i have to add 21% + 11% on top of the total price it's kind of to much for me..
i really don't mind the shipping fees. I just don't like having to pay all that extra on the price including shipping.
Because that turns this board in to a $490 to $520 board..
Offline Laneware
« Reply #21 on: Mon, 21 February 2022, 19:46:25 »
Thanks for the feedback :D We are the global vendor for this product, no region specific vendors. We chose this approach to keep the delivery time and logistics reasonable in the current global environment.
Offline Stephie2729
« Reply #22 on: Thu, 24 February 2022, 19:53:45 »
Can you show pink with green top and green with pink top please  :)
Offline Laneware
« Reply #23 on: Fri, 25 February 2022, 03:44:27 »
The product page is up for those looking to get ready for the GB launch :D https://lanewareperipherals.com/collections/lw-75
Offline Laneware
« Reply #24 on: Fri, 25 February 2022, 21:11:26 »
Sure, you will be able to find all the combos in the following link :D
Offline Laneware
Re: [GB] LW-75 | <24hrs to GB! |
« Reply #25 on: Sat, 26 February 2022, 21:02:03 »
1Hr unit we are live! A huge thankyou for all of the support and feedback that helped us get to this stage, very excited to see these keyboards out in the community :D
Offline Laneware
Re: [GB] LW-75 | 1Hr to GB! |
« Reply #26 on: Sat, 26 February 2022, 22:25:20 »
We are live! :D
Offline JackPikatea
Re: [GB] LW-75 | GB Live! |
« Reply #27 on: Mon, 28 February 2022, 14:49:37 »
amazing stuff!
Offline Laneware
« Reply #28 on: Tue, 01 March 2022, 20:30:21 »
Full picture set of top and bottom color combos:
https://imgur.com/a/AVQ8yzD
Offline Barbadus
« Reply #29 on: Thu, 03 March 2022, 11:18:55 »
Beautiful board! I noticed the page mentioned a practice PCB. Is this just a dummy board to practice soldering on?
Offline JackPikatea
« Reply #30 on: Thu, 03 March 2022, 12:54:16 »
What kind of interface is the encoder? D or star?
Offline Laneware
« Reply #31 on: Fri, 04 March 2022, 02:12:42 »
Thankyou for the kind words! Yes, you are correct :) Here is a look at it:
https://www.reddit.com/r/MechanicalKeyboards/comments/mrwh2d/soldering_practice_for_our_macro1_customers/
Offline Laneware
« Reply #32 on: Fri, 04 March 2022, 18:30:23 »
We use a PEC11R encoder :)
« Last Edit: Fri, 04 March 2022, 19:32:44 by Laneware »
Offline Laneware
« Reply #33 on: Sat, 05 March 2022, 23:15:20 »
Week 1 of the GB is done, thankyou all for the amazing turnout! We blasted through MOQ in the first Hr of the GB. Just a friendly reminder that we have a cap of 500 units on this project, so don't miss out :D
Offline Laneware
« Reply #34 on: Wed, 16 March 2022, 19:02:15 »
Week 2 of the Gb is down and the content is still flowing in! Checkout the awesome content from @dutchmasterw and @clackbait!
Offline Laneware
« Reply #35 on: Tue, 29 March 2022, 04:08:45 »
Thankyou everyone for the support on the GB, it is awesome to see such a great turnout for every product that we release, we are truely greatful to be a part of such an awesome comminuty. With only 2 days remaining, you still have a chance to jump aboard this GB, we would love to have you!
