Author Topic: [IC] Spectacle - ClickClack will be re-running the GB!  (Read 34863 times)
Offline Stilou Studio
  • Formerly Seo
  • Danish Designed Keyboards
« on: Tue, 25 January 2022, 04:59:33 »
281532-0
S P E C T A C L E
ClickClack.io Will Be Re-running The GB!
ClickClack updated IC
https://geekhack.org/index.php?topic=119998.0
Heya folks!
As the BEAK 6.5 is entering production, I wanted to show you our newest offering.
INTRODUCTION
The spectacle is a one-of-a-kind design featuring a soothing curve as its side profile, making it pleasing to look at.
We wanted to take make something eye-catching while keeping the design subtle and gentle.
Taking advantage of the available technology, the Spectacle utilizes 5 axis CNC machining.
We took a lot of notes in terms of critiques people had with our previous launch and tried to incorporate all the requested features
Whether we achieved that is for you to judge
THE CURVE
The soothing curve on the side profile is the main kicker for the Spectacle.
Utilizing 5 axis CNC machining to achieve the look.
281571-1
TYPING TEST
SPECIFICATIONS
Weight: Alu kit 1.1kg (2.4lbs) Poly kit 0.9kg (2.0lbs)
Typing angle: 6.0 deg
Mounting style: Top mount
Front height: 18.9mm
Plate: 5052 Alu and Polycarbonate (Both included in each kit)
PCB: WT60-G designed by the one and only WILBA.TECH
Daughterboard: Unified C3
MEASUREMENTS
281640-2
EXPLODED VIEW
281534-3
VARIANTS
281536-4281538-5
281540-6281542-7
281544-8281546-9
SALE/PRICING
The Spectacle will be available for
$299
all variants
There will be around
400
Units available
Vendors:
NA - ThocKeys.com
Rest of the world - stiloustudio.com
FAQ
Q: When will this be available?
A: Hopefully around the April
Q: What sale format will this be?
A: FCFS
Q: How many units will be available?
A: Around 400
Q: Where can I find you?
A: Instagram: https://www.instagram.com/stiloustudio/ or Discord: https://discord.gg/3ka3y6gbQs
Q: Will any content creator be reviewing this before GB?
A: Yes! I am aiming for a wider range of content creators this time around
« Last Edit: Fri, 28 April 2023, 03:53:22 by Stilou Studio »
  • Formerly Seo
Re: [IC] Spectacle - a 5 axis keyboard, with a twist!
« Reply #1 on: Tue, 25 January 2022, 05:03:23 »
RESERVED i guess
  • Formerly Seo
« Reply #2 on: Tue, 25 January 2022, 05:03:44 »
PROTOTYPE GALLERY
281566-2281567-3
« Last Edit: Tue, 25 January 2022, 05:11:18 by Stilou Studio »
Offline atl22033
  • Signature art by Shima
« Reply #3 on: Tue, 25 January 2022, 05:17:31 »
Gib me board
Offline Detrimend
« Reply #4 on: Tue, 25 January 2022, 05:22:19 »
That side profile is so hot  :p
Offline darthcapn
« Reply #5 on: Tue, 25 January 2022, 06:09:23 »
So the brass looking weight is actually just anodized alu? Or is brass bottom gonna be an option?
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
  • Formerly Seo
« Reply #6 on: Tue, 25 January 2022, 06:15:11 »
As of now it is set to be anodized brass color.
Might do a limited run of brass bottom variants depending on feedback! :)
Offline Alessio
    • YT Channel
« Reply #7 on: Tue, 25 January 2022, 06:36:55 »
Price is decent, plate mounting distribution is nice.
A few gripes however, the sides are a main selling point yet there's no renders of a proper side profile of the keyboard, only slightly in the exploded view of the board. Moreover, 8 internal screw points is rather overkill in a design like this, specially when it's a "seamless" design; could get away with 4 and save a little bit of unnecessary machine time as well as reducing possible points of failure in production.
On top of providing a proper side profile render, one of the bottom would be nice as there isn't one in the post (at least that I can see). Also, you say the front height is 18.9mm but where is this measured from? An effective front height would be nice to have as I assume 18.9 is the height of the front lip.
Finally just a minor concern that you might want to check just in case, make sure to measure the bottom of the screw holes on the lower side of the case bottom to the other side. That part looks awfully thin as it is so it may cause issues down the line if the material at bottom of the screw hole is under 1mm in thickness.
Overall, not really my thing but I appreciate the pricing as well as some elements of the design. GLWIC
  • Formerly Seo
« Reply #8 on: Tue, 25 January 2022, 06:50:51 »
Very valid points, I will make sure to provide more renders of side profiles, plate bottom. As well as measurements!
Will update tomorrow
Offline rodok
« Reply #9 on: Tue, 25 January 2022, 07:34:59 »
Looks like a really nice product. The price is astonishing, honestly.
IC filled, wishing you all the best with this GB!
*signed by rodok
Offline .jan
    • keebsta
« Reply #10 on: Tue, 25 January 2022, 08:02:02 »
Oh that’s hot
Offline Bl4ck
« Reply #11 on: Tue, 25 January 2022, 08:05:48 »
Where is this shipped from, Denmark?
And may I add, are you planning to have this in GB after fully delivering the Beak correct?
« Last Edit: Tue, 25 January 2022, 08:16:58 by Bl4ck »
  • Formerly Seo
« Reply #12 on: Tue, 25 January 2022, 08:20:28 »
It will ship from Denmark yes. The GB will not start until the Beaks have been shipped (unless there are some major delays)
The GB will most likely start before the Beak ships
« Last Edit: Thu, 17 February 2022, 11:20:53 by Stilou Studio »
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #13 on: Tue, 25 January 2022, 08:30:57 »
looks nice; would personally prefer thinner side bezels
Offline Bl4ck
« Reply #14 on: Tue, 25 January 2022, 08:44:37 »
Even with major delays, since you are not using a vendor, for trust within the community I would always wait for beaks to be delivered before starting this one.
Offline powwu
    • Discord
« Reply #15 on: Tue, 25 January 2022, 12:02:55 »
its more fun if you read spectacle in a french accent
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #16 on: Tue, 25 January 2022, 15:26:42 »
Amazing work! do you think breaking up the bottom into two pieces and having even two tones of alu (not necessarily a brass inner piece) would improve sound?
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline C_L | Soup
« Reply #17 on: Tue, 25 January 2022, 15:58:46 »
Wow, those side views look really really nice. Amazing price point too, love the whole thing. I don't mind the brass-color anodized bottom to achieve that price. GLWIC, can't wait to hear some sound tests.
Will the alu plates be anodized different colors like in the renders?
  • Formerly Seo
« Reply #18 on: Tue, 25 January 2022, 16:15:41 »
Thank you! All colors will have a matching aluminum plate, and a polycarbonate plate included :)
Offline Delbs_
« Reply #19 on: Tue, 25 January 2022, 20:24:09 »
Stunning board, dude! Nice to see some more 60% coming up, specially with a polarizing and interesting look like this! :)
Offline the flying penguin
« Reply #20 on: Tue, 25 January 2022, 20:47:02 »
Looking good!
Will the PC version have threaded inserts?
Offline catamscott
« Reply #21 on: Tue, 25 January 2022, 21:27:23 »
really attractive price for case + pcb + alu and pc plate. will the plate file be made public?
Offline SDKCAMPING
« Reply #22 on: Tue, 25 January 2022, 21:49:49 »
i like the concept of the side, but i think there needs to be some more clever design to utilize it without having it affect the top view so negatively (personal opinion)
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline DaaDaa
« Reply #23 on: Tue, 25 January 2022, 22:13:56 »
LMAO at the people gushing over the price lol
piggy60 red upgraded PVD w/ GMK umka zaku | tiramisuit w/ GMK noire JWK silk emerald | mr.suit black/chrome glossy chamfers w/ GMK minimal cow POM stem | jelly epoch w/ SA oblivion zaku | mode80 deco w/ gmk boneyard alpaca | mode 80 imperial with ePBT origami alpaca| MODE80 viridian /w CRP boba LT | RAMA thermal kuro w/ GMK muted 2 pewter | BBox60 C64 wih marshmellows and c64 keycaps | MODE Sonnet green /w MW voynich gateron ink box pink
  • Formerly Seo
« Reply #24 on: Wed, 26 January 2022, 01:18:27 »
Yes! Plate files will always be made public after the GB
  • Formerly Seo
« Reply #25 on: Wed, 26 January 2022, 06:31:43 »
Added measurements, front height, and typing angle!
  • Formerly Seo
« Reply #26 on: Thu, 27 January 2022, 11:20:03 »
Slightly scuffed typing test (accidentally oriented stab cutouts wrong on the plate) can be found on our discord: https://discord.gg/3ka3y6gbQs
Offline DubbTom
« Reply #27 on: Thu, 27 January 2022, 12:22:13 »
Will these be manufactured locally in Denmark as well? The price leads me to believe they're not but just thought I'd ask.
poker II
Offline lush_bunny
« Reply #28 on: Thu, 27 January 2022, 12:23:03 »
I know that the side profile is the main attraction, but may I just say:
Praise be to top mount!
  • Formerly Seo
« Reply #29 on: Thu, 27 January 2022, 15:51:23 »
They will not, as far as I am concerned there are no real positives to machining in Denmark compared to overseas.
Offline Nonnegaard
« Reply #30 on: Fri, 04 February 2022, 15:53:51 »
fød mine børn
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline NovaRMK
« Reply #31 on: Fri, 04 February 2022, 20:41:09 »
yes yes oh my god please yes
Offline Thockologist
  • Formerly PoorlyDrawnKeebs
« Reply #32 on: Sun, 06 February 2022, 08:56:23 »
Really love the curves and the thick bezels of this board. It kind of has an odd feeling of similarity to the Blade 60 in my opinion, this and the Blade are definitely different but when I see the side profile not straight on it reminds me of the Blade.
  • Formerly Seo
« Reply #33 on: Mon, 07 February 2022, 12:52:45 »
Typing test has been added - keep in mind the stabs are scuffed due to me accidentally orienting them the wrong way... (Whops)
  • Formerly Seo
Re: [IC] Spectacle - a 5 axis keyboard, with a twist! 2nd proto ordered
« Reply #34 on: Sat, 12 February 2022, 16:00:38 »
Proto number 2 has been ordered. Expect it to arrive early next month.
Hopefully some streamers will check it out sometime next month - join our discord for more info and updates!
Offline less_blank
« Reply #35 on: Sat, 12 February 2022, 17:23:36 »
Hoping HHKB will be an option, think it would look really nice with that side profile.
Offline vkeycaps
  • Artisan keycaps maker
    • Website/Store
« Reply #36 on: Sat, 12 February 2022, 19:58:20 »
Love that curve. Maybe some one will make accent keycap to match/continue it.
Offline HelloThisIsDog
« Reply #37 on: Sat, 12 February 2022, 20:18:35 »
Would be so down for a real brass option down the line!
  • Formerly Seo
« Reply #38 on: Sun, 13 February 2022, 01:08:42 »
Strongly considering brass bottom as an option. Although the price will be $449 so I am not sure I can reach MOQ for the brass.
Offline sup3r170va
« Reply #39 on: Sun, 13 February 2022, 01:14:29 »
My 2c - with the 5 axis CNC this won’t be a cheap board. If I’m going to get a premium board I’ll expect brass/SS/copper bottom.
  • Formerly Seo
« Reply #40 on: Thu, 17 February 2022, 14:24:46 »
I hear you, I am also considering doing an SE version, collaborating with a patina artist to get a special brass look. (This will be an in-stock offering after the GB if it happens)
Offline Jewpac Shakur
« Reply #41 on: Sat, 19 February 2022, 04:56:30 »
It's a shame that this board has such an immaculate profile, and a disappointing (to my taste) top view. Especially because the top view is what you're going to see most of the time.
Offline TomatoMan
« Reply #42 on: Sat, 19 February 2022, 10:06:26 »
That side profile is sleeeek
  • Formerly Seo
Re: [IC] Spectacle - a 5 axis keyboard, with a twist! NA vendor announced
« Reply #43 on: Fri, 04 March 2022, 07:25:12 »
NA vendor has been added - thockeys.com
Offline theos
« Reply #44 on: Sat, 05 March 2022, 09:58:29 »
I'm in for sure!
Offline TheIcyKoala
« Reply #45 on: Mon, 07 March 2022, 09:23:21 »
Wow, I'm a sucker for unique side deisgns and 60s. Very awesome  :thumb:
Offline KeebCommie
« Reply #46 on: Fri, 11 March 2022, 20:03:00 »
Will there be a hot-swap version of the PCB available?
  • Formerly Seo
Re: [IC] Spectacle - GB date April 1st!
« Reply #47 on: Mon, 14 March 2022, 06:32:04 »
GB date has been set to April 1st.
NA vendor - thockeys.com
International vendor - stiloustudio.com
Offline TibtibThePrincess
  • Look but don't buy
« Reply #48 on: Wed, 16 March 2022, 10:11:21 »
It is very hot
Sent from my CLT-L29 using Tapatalk
  • Formerly Seo
« Reply #49 on: Mon, 28 March 2022, 06:02:50 »
Alexotos will be streaming today March 28 @ 11pm GMT!
https://www.twitch.tv/alexotos
