Author Topic: [IC]Mozano-Die for me × Domikey KeyCaps  (Read 13045 times)
Offline Mozano
« on: Thu, 10 February 2022, 20:09:24 »
"A beautiful, smart, innocent girl. She usually buys nice
clothes and eats delicious food. She will cry when she can't eat it, and then make fun of the people around her. She will pretend to be pitiful to attract other people's love...But she never hesitates to kill someone, and every time she does, she puts a rabbit doll on the corpse..."
Through the above description, you may come up with the image of an indifferent and female killer. This is an inspiration for a designer, who designed a mechanical keyboard keycap, also called "Little Pervert", named after Villanella, a heroine in "Killing Eve".
This keycap is designed by Mozano and manufactured by Domikey. Mozano is a professional brand focusing on high-end customized keycaps and key switches. It provides beautiful, comfortable, durable and highly customizable keycaps for the majority of mechanical keyboard users.
The keycaps are made of ABS and are produced by overmolding technology. The two-color molded keycap will not cause the characters to disappear due to wear and tear, and the service life is extremely long. Compared with laser engraving, laser filling or UV-coated keycaps, the characters of the two-color molded keycaps have no depressions or protrusions. Also, the touch of each part of the keycaps as well as the thickness and color of the characters are quite consistent. Besides, the high-quality ABS material can maximize the performance of color, bringing an excellent visual effect.
The keycaps have the original factory height with mod plus, iso, space and other kits are integrated in the arrangement, also the big base distribution mode is adopted, which can meet the needs of most arrangements.
The keyboard letter area is designed in black and white, providing English characters, and mixed collocation of English and Japanese keys. The dark keys in the large key area are slightly deeper than those in the alphabet area. Overall, black color is classic and elegant without losing texture, while white color is playful, lively and eye-catching. The personalized key pattern and the fresh pink keys are closer to the image of the female killer in the design theme. The green of the return key and personality keys is used as an embellishment to bring a touch of freshness to the overall tone. Different keys combinations can present different effects, providing players with different styles of choice.
KITTING
Details:
Height: Cherry height
Material: ABS two-color molding
Designed by: Mozano
OEM: Domikey
In addition, based on the Villanella keycap, there is also a shaft with the same theme, named "Eve switch". The color matching of the shaft body echoes the keycaps, and three main color matching are used, the upper cover is pale lavender, the lower cover is pale blue, and the axis is pink. The overall tone is fresh and vibrant and well-matching.
Mozano EVE switch details
Material: five-legged linear shaft, upper and lower shell nylon pa66, shaft lengthened upe
Spring: 48g trigger, 55g bottoming, extended single-stage gold-plated spring, Japanese material
Stroke: 3.7±0.3mm
Shaft life: 5000w times
Color: Axis Pantone 692c, upper cover Pantone 9244c, lower shell Pantone 4173C
Designed by: Mozano
OEM: JWK
Mozano EVE switch features:
Press smoothly
The shaft body is made of a full nylon shell. In order to ensure smoothness, it retains a slight sandy feeling, making the feedback of each tap more intuitive. Unlike the calmness of Cherry's black switch bottoming out, the dryness and crispness brought by the upe switch further strengthens the feedback of its body. Surely, players who like sound will be more satisfied with the percussion sound.
Strong rebound and moderate bond distance
The 48g long single section gold-plated spring with moderate trigger and bottom contact pressure is used, which is made of Japanese material. Under this pressure, it is very friendly for players who type and tap for a long time. Similarly, they can get a good sense of feedback.
Factory lubricated and unlubricated are available
The switch body is sufficiently moistened by the manufacturer, the spring sound is small. If you are a lazy person who humidifies the switch and doesn't want to throw it away, the factory damped EVE switch is a good choice. In addition, in view of the extreme pursuit of consistency by many players, you can also choose the non factory run version to facilitate your own operation.
After you have the "DIE FOR ME" keycaps and switches, you also need a high-end aviation plug data cable (mechcables) to match. This data cable is purely handmade by a professional studio, and the color matches our popular keycap and switch of the same name. It is your very excellent choice. Pink mesh and Uptown Gold Techflex material paired with white heat-shrink tubing (also with metal tips) and light green connectors characterize the DIE FOR ME — cute to death. Just like the female killer Villanella, this cable can give you a whole new experience. The coiled design easily integrates into a variety of spaces, while the detachable Air Plug port lets you change connections in seconds. Get started with Type-C connectors to add some unique character and the best experience to your desktop.
Mozano custom coiled cable Details:
Accessories: pure copper chrome plating
Wire material: PU set of imported woven cloth + Pet mesh
Separate connector: pure copper customized CNC aviation connector
USB shell and plug: pure copper customized CNC shell + 5u gold-plated terminal
Output shell and plug: pure copper customized CNC shell + 3U gold-plated terminal
Counterweight: pure copper customized CNC counterweight
Output type: type-C interface
Length: 1.4m
Designed by: Mozano
Inspired by the theme of “Killing Eve”, the above products are presented in a unique way, unlocking more interesting product experiences for players. Mozano is expected that the customization circle can develop better day by day, so that more players can choose their favorite customized products.
Contact
Discord: https://discord.gg/6BRuxDapUy
Mail: sunhao@noxgroup.com
QQ:1484724549
Wechat: oolon1g
« Last Edit: Mon, 14 February 2022, 23:51:50 by Mozano »
Offline zea
  • yeh
Re: [IC] “KILLING EVE” Villanella Keycaps- group buy starts Feb 28th
« Reply #1 on: Thu, 10 February 2022, 20:12:08 »
there's a lot of stuff missing in this IC, who's making it? who's running it? is there more than one vendor? where's the IC form? why even bother with an IC if you already have a date for the gb start?
Offline LilithAugustus
  • She/Her
« Reply #2 on: Thu, 10 February 2022, 20:15:15 »
Wtf did I just read
Offline Alessio
    • YT Channel
« Reply #3 on: Thu, 10 February 2022, 20:21:02 »
excuse me?
Offline of_sam
« Reply #4 on: Thu, 10 February 2022, 20:21:41 »
I too like drugs.
Typing on: HHKB Pro 2 - Stock :aware:
Collection: F1.69, Police, Jubi, RF 87U, En Dash, Rosenthal, Soulless, Frog, Calliope, GAF 910, Sabre, W1-AT
Offline TypeSaucy
  • meign
« Reply #5 on: Thu, 10 February 2022, 20:22:07 »
Crust
    1 box (14.1 oz) refrigerated Pillsbury™ Pie Crusts (2 Count), softened as directed on box
Filling*
    6 cups thinly sliced, peeled apples (6 medium)
    3/4 cup sugar
    2 tablespoons all-purpose flour
    3/4 teaspoon ground cinnamon
    1/4 teaspoon salt
    1/8 teaspoon ground nutmeg
    1 tablespoon lemon juice
Offline Alessio
    • YT Channel
« Reply #6 on: Thu, 10 February 2022, 20:22:15 »
I too like drugs.
Sharing is caring.  :thumb:
Offline purryoverlord
« Reply #7 on: Thu, 10 February 2022, 20:22:39 »
it's better to just read the original IC on zfrontier
Offline Lysol_
« Reply #8 on: Thu, 10 February 2022, 20:28:22 »
wha?
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #9 on: Thu, 10 February 2022, 20:31:57 »
I thought this  ran
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline treeleaf64
    • treeleaf64
« Reply #10 on: Thu, 10 February 2022, 20:33:42 »
GMK bolivia
Everyone must pay the cat tax
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #11 on: Thu, 10 February 2022, 20:33:43 »
Well, now we've seen it all....  :confused:
Offline rarekeyboards
« Reply #12 on: Thu, 10 February 2022, 20:41:29 »
impressive ****post  :thumb:
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #13 on: Thu, 10 February 2022, 20:45:34 »
Crust
Filling*
    3/4 cup sugar
    1/4 teaspoon salt
what does the lemon juice do?
Offline Neely_12
« Reply #14 on: Thu, 10 February 2022, 20:45:46 »
"A beautiful, smart, innocent, and even a little ‘perverted’ girl.
Aight imma head out
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
« Reply #15 on: Thu, 10 February 2022, 20:47:11 »
u goofy
Offline linell
« Reply #16 on: Thu, 10 February 2022, 20:54:28 »
:SwomiDisgust:
wtf are words
bro this a **** set, just be thankful you even getting 1 base running fr
Offline Mozano
« Reply #17 on: Thu, 10 February 2022, 20:55:07 »
I'm very sorry, because this is the first time for me to post on geekhack, so I don't know much about the format and form of the post. If you have any questions, just reply below, and I will reply as soon as possible.
Offline linell
« Reply #18 on: Thu, 10 February 2022, 21:00:11 »
well you have apparently never thought to ask for help before creating this post
smh my head
Offline panka
« Reply #19 on: Thu, 10 February 2022, 21:08:37 »
what the ****
Offline keebnewb
« Reply #20 on: Thu, 10 February 2022, 21:16:10 »
tfw you create a set around a character and you don't even spell her name right XD love the show but am very confused by this set
Offline iinko_mk
  • Status: broke
« Reply #21 on: Thu, 10 February 2022, 21:17:48 »
my last two brain cells:
Offline wndy
« Reply #22 on: Thu, 10 February 2022, 22:02:16 »
Quick question - what the ****?
Thanks.
Offline P103
« Reply #23 on: Thu, 10 February 2022, 22:20:25 »
A new brand that is inventing terms that already exist in the hobby. If a post like this were made by companies like logitech it would be embarrassing, but at least it won't be on geekhack.
Offline whirlwind
« Reply #24 on: Thu, 10 February 2022, 22:39:21 »
Glorious, that you?
Offline QWER|key
« Reply #25 on: Fri, 11 February 2022, 00:06:59 »
I can't work out what show this is, as the "Killing Eve" I know bears no resemblance to this.  Pervert? Rabbit Doll?  Is there another Killing Eve?  Villanelle was a psychopathic Russian assassin.
Offline Ella
  • Why is it called an oven
« Reply #26 on: Fri, 11 February 2022, 00:11:46 »
Weebs out
Offline Mozano
« Reply #27 on: Fri, 11 February 2022, 00:50:41 »
excuse me?
I'm very sorry, because my unprofessionalism gave you a bad experience. Could you please tell me where my post is inappropriate, I will revise it immediately, thank you for your understanding and tolerance.
Offline Mozano
« Reply #28 on: Fri, 11 February 2022, 00:52:07 »
Hello, the design of this set of keycaps is inspired by "killing EVE", sorry for that.
Offline Mozano
« Reply #29 on: Fri, 11 February 2022, 00:54:20 »
Wtf did I just read
I'm so sorry, can you suggest something, I'll revise it right away, sorry I'm so unprofessional :'(
Offline Mozano
« Reply #30 on: Fri, 11 February 2022, 00:56:46 »
I'm very sorry, I'm consulting with experienced players, and I'll make changes to the post later, my apologies :'(
Offline Mozano
« Reply #31 on: Fri, 11 February 2022, 00:59:37 »
Hi, can you give me some suggestions for my post, I will revise it immediately. The current post is being revised, I am very sorry, I hope the revised post will be better
Offline Mozano
« Reply #32 on: Fri, 11 February 2022, 01:03:29 »
Hello, now this name is modified according to the name of the protagonist in the play, and the name of the protagonist cannot be used directly
Offline SRTChrisS1
Re: [IC]Mozano-Die for me × Domikey KeyCaps
« Reply #33 on: Fri, 11 February 2022, 02:10:17 »
What on earth...
Offline Ella
« Reply #34 on: Fri, 11 February 2022, 02:49:48 »
excuse me?
If you don't see it yourself then you're beyond saving
Offline Koniotaur
« Reply #35 on: Fri, 11 February 2022, 06:12:44 »
Hentai design let's go
PS. Obviously a joke
Offline Tyson
« Reply #36 on: Fri, 11 February 2022, 08:27:51 »
"A beautiful, smart, innocent, and even a little ‘perverted’ girl." & "This is an inspiration for a designer, who designed a mechanical keyboard keycap, also called "Little Pervert""
You could have 100% left out all the lines that mention perversion and just mentioned that this set was designed after Killing Eve... Designing something around a "Little Perverted Girl" doesn't seem very appealing to people who have never seen the show.
« Last Edit: Fri, 11 February 2022, 08:31:14 by Tyson »
Offline Keeblet_257
« Reply #37 on: Fri, 11 February 2022, 09:01:21 »
if base + mods is higher than 100$ then count me out
Offline Bachoo
« Reply #38 on: Fri, 11 February 2022, 10:06:36 »
What did I just read
Offline bigmaxnonions
« Reply #39 on: Fri, 11 February 2022, 10:36:06 »
there are no f13 keys in any of the kits
Offline Cipulot
    • Website
« Reply #40 on: Fri, 11 February 2022, 15:27:12 »
.........why......just why....
Offline Rumblethumps
« Reply #41 on: Fri, 11 February 2022, 15:45:33 »
"Perverted" is one of those words that has different connotations if you're a native English speaker vs someone who speaks English as a second language, so I doubt you meant for it to come across the way that it does. But it would still probably be a good idea to change the word choice.
I'm still hella confused though  :confused:
Offline ABABA
« Reply #42 on: Fri, 11 February 2022, 15:55:31 »
Found the original IC on zfrontier.  just so you know, "perverted" has an overwhelmingly sexual connotation in english.  I think the word(s) you are looking for is psychologically disturbed.
Offline Keeblet_257
« Reply #43 on: Fri, 11 February 2022, 16:58:42 »
Wtf did I just read
better should have asked someone that is actaully has experience with the english language to proofread this IC. chinese and english have different grammar and words should never be translated directly.
A good example using german for example. "Ich ziehe gerade Handschuhe an" translates to "I'm putting on gloves right now" but if you translate it direcly you'll get gibberish like this "I put now handshoes on" you get it?
an second make a better looking IC ppl arent interested in reading a book. You are presenting a product right here why not use bigger letters for important keywords anything else that makes the text easier to read for
people.
Look at other IC and you should see a big difference comparing yours to others.
Offline treeleaf64
    • treeleaf64
« Reply #44 on: Fri, 11 February 2022, 21:41:21 »
Wtf did I just read
people.
Uh
the subject matter. .  is the concerning part
Offline syberghost
« Reply #45 on: Thu, 17 February 2022, 12:06:30 »
Did DCS change his name to Mozano?
yes, I'm the guy who put box jades on a Polaris
Offline JackPikatea
« Reply #46 on: Thu, 17 February 2022, 12:40:59 »
This isn't really an IC. Just hurts my brain
Offline Mozano
« Reply #47 on: Fri, 25 February 2022, 04:02:32 »
I'm very sorry, because this is a new account, I can't post GB
