Author Topic: [IC] GMK SOPHIE | More Renders (04/08/2022)  (Read 18392 times)
Offline juju___mk
« on: Tue, 08 March 2022, 12:28:11 »
Please share your thoughts and opinion through IC form!
GMK SOPHIE
INSPIRATION:
As a parent of a beautiful dog, it is almost a natural instinct to capture and share the beauty and cuteness of my adorable dog.
It is my joy to introduce you to Sophie, a White Swiss Shepherd.
White Swiss Shepherds or also known as Berger Blanc Suisse, originated from Switzerland as it is written in their breed.
They are known for their luxurious white coat, pointy ears, intelligence, and everlasting cuteness.
GMK SOPHIE will consist of 3 kits: Latin Basekit, Novelties, and Spacebar Kit.
There are only 2 colors used for GMK SOPHIE and both are from GMK standard colors, GMK CP and GMK 3C.
Novelties for GMK SOPHIE are represented through puppy paw, 8 variations of emoji-like Sophie's face, and 'SOPHIE' lettering.
COLOR CODE:
The color palette for GMK SOPHIE uses GMK standard colors CP and 3C.
Sophie's white coat is represented through CP to give a more natural tone, compared to GMK WS1 which has a brighter and flawless white tone.
GMK standard color 3C signifies Sophie's pink ears.
KITS:
Latin Basekit
The basekit will cover 60%, 65%, 75%, TKL, 1800, and full-size boards, with terminal ISO, F13, Tsangan support, and minimal compatibility for 40% and Alice boards.
Key unit labels have been added.
u - unit
s - stepped
c - convex (spacebar)
scpd - scooped homing
barred - barred homing
Novelties
Provides enough 1u keys to fill out a 5x2 macro layout, enter key + R4 mod novelties.
Spacebar Kit
DESKMATS:
'Paw Paw Paw'
'Home of Berger Blanc Suisse'
RENDERS:
D60 Lite by KBDFans
Nemui by Bachoo
TGR Alice by Yuk Tsi and render by eg0t1st1k4l
VENDORS:
Very happy to announce that we will be working with the following vendors for GMK SOPHIE with
MyKeyboard as our lead vendor!
EU: MyKeyboard
NA: Mino Keys
SA: Fancy Customs
Asia/International: KBDfans
UK: ProtoTypist
SEA: iLumkb
OCE: DailyClack
KOREA: SwagKeys
WHAT IS NEXT?:
Fix/Finalize identified kit issues
Collaborations
Find vendors
More renders
Pricing
LOGS:
8 MAR 2022
- GMK SOPHIE initial posting
- Removed Hiragana Basekit & added 40%/Ortho Kit
9 MAR 2022
- Removed 40%/Ortho Kit
- Added the following to basekit: (R2 1.75u backspace), (R3 1.5u Enter), (R3 1.25u Tab), (R1 1.0u F13) and (R4 1.0u B)
- Added the following to spacebar kit: (2 x 3u spacebar), (1.25u spacebar), and (6.25u spacebar for GMK 3C)
- Removed the following to spacebar kit: (1 out 2 6u spacebar), and (1 out 2 1u spacebar)
- Added legends to all kits
10 MAR 2022
- Additional adjustment to Latin basekit
- Removed Switzerland map and Matterhorn novelties and added more variation of Sophie's expression as novelties
- Added 2 deskmat options
15 MAR 2022
- Finalized Latin basekit by adding accent 6.25c spacebar
- Finalized novelties by removing the bandana and adding more variation existing novelties
- Added more renders but there is MORE COMING!
21 MAR 2022
- Vendors Updated!
08 APRIL 2022
- Renders by eg0t1st1k4l
Previous Kits
SIGNATURE:
Please show support to GMK SOPHIE by adding this to your signature!
Code: [Select]
[url=https://geekhack.org/index.php?topic=116496.0][img width=333 height=120]https://imgur.com/Umu9OJU.png[/img][/url]
Don't forget to share your thoughts and opinion through IC form!
SOCIAL MEDIA:
Special thanks to Biip, ImperfectLink, NoPunIn10Did, YXXX, and Kight, and DigitalMisfits for the phenominal advises and sacrificing their time to answer any questions I had. Thank you again!
« Last Edit: Sat, 09 April 2022, 16:14:46 by juju___mk »
Offline max.clacks
Re: [IC] GMK SOPHIE | Initial IC Post (03/08/22)
« Reply #1 on: Tue, 08 March 2022, 12:31:58 »
ne Alice B?
Offline Bub
    • big bub's beepers
« Reply #2 on: Tue, 08 March 2022, 12:36:10 »
ngl ive always wanted to do a keycap set for my dog.
consider adding accent bars in base. set looks nicer with the pink bar. also chances of getting a vendor to run 2 base kits here are low. i'd prepare to chop one. thats cool ur dog speaks japanese
Offline andromache
« Reply #3 on: Tue, 08 March 2022, 12:42:45 »
I love pet sets and the dog novelty designs are super cute.
I'm super confused about why there's a hiragana kit when the dog breed is Swiss.
Offline juju___mk
« Reply #4 on: Tue, 08 March 2022, 12:45:04 »
Thanks for the heads up! I'll keep the kit with the most vote :) I studied Japanese so I taught my dog to understand a bit haha
ne Alice B?
I don't have Alice B...but for next update I can try to render Amano by h40.io!
Offline nevin
« Reply #5 on: Tue, 08 March 2022, 12:57:10 »
my aunt had a "sophie" as well. she was a lab/pit mix extremely smart, lovable & very well trained.
Offline Ella
  • Why is it called an oven
« Reply #6 on: Tue, 08 March 2022, 14:24:39 »
Swiss Sheherd
>hiragana kit
makes sense
Offline max.clacks
« Reply #7 on: Tue, 08 March 2022, 14:48:06 »
ne Alice B?
I think there may be some confusion. I don't see an extra B for Alice layouts, so I'm not sure if the render on the Amano would have a key that doesn't exist in your kits or you'd use a different key in the place of the additional B?
Offline DirtyGingy
« Reply #8 on: Tue, 08 March 2022, 16:37:22 »
Sophie is a cute dog, but she'll be middle aged by the time GMK actually delivers.
Offline Fraaaan
« Reply #9 on: Tue, 08 March 2022, 16:45:39 »
Add F13 to base, 2nd B in 40s kit makes no sense, I don't think 2 r4 1u Controls are necessary in base, 2 3u bars in SB kit would be cool.
Offline juju___mk
« Reply #10 on: Tue, 08 March 2022, 18:08:21 »
Noted!! Still learning and I appreciate the information!
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #11 on: Wed, 09 March 2022, 08:26:10 »
Cute. Personally, I would ditch the swiss novelties, keep at most one. Also please more variation on the dog novelties. From more than 50cm distance they all look the same.
I think GMK Orange Boi’s, although not dog thematic, novelties are top-notch. What I am saying is, that having the same face and shape but with just different small face gestures is not enough to make the novelties appealing.
Will follow next updates on this set nevertheless! I like the colorway.
Offline 0xtanja
  • need 1.5u supers
    • linktr.ee/tanjarinne
« Reply #12 on: Wed, 09 March 2022, 08:32:00 »
Nice colours!
Please consider adding an R2 ESC (and accent) to complement the 40s compatibility you have.
Offline Neely_12
« Reply #13 on: Wed, 09 March 2022, 09:33:25 »
Just me, but I would really like for the mods to be reverse instead of having the all-white.
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #14 on: Wed, 09 March 2022, 09:51:05 »
Barkspace or bust
Offline TyPo.mk
« Reply #15 on: Wed, 09 March 2022, 11:29:53 »
I think this set would be stronger if you leaned into the dog theme more than swiss. Also if you’re going to have accent 1.5u enter maybe consider accent r2 escape.
Offline treeleaf64
    • treeleaf64
« Reply #16 on: Wed, 09 March 2022, 12:16:41 »
Where swiss base kit  When ?  I want that one
Everyone must pay the cat tax
Offline conternecticus
Re: [IC] GMK SOPHIE | Latin Basekit & Novelties Updated (03/10/22)
« Reply #17 on: Thu, 10 March 2022, 12:09:31 »
I also think it's a good idea to diversify the novelties. Maybe a toy that Sophies loves to play with, or a piece of clothing (like that scarf in the photo you posted) that fits her really well. Hell, maybe just her pointy ears would be a good idea. At the moment most of them look the same from a distance.
And maybe the Swiss novelty can go?
Offline IOVERCALLHISTIOCYTES
« Reply #18 on: Thu, 10 March 2022, 15:42:24 »
I am impressed by your efforts to refine and adapt after the initial IC posting. Keep it up
Offline Tree_
« Reply #19 on: Thu, 10 March 2022, 16:11:20 »
Heck.
Kit revisions look good, I like the paw deskmat.
Offline BloremBipsum
  • Yes, I am a Dumb Ass Boi
« Reply #20 on: Fri, 11 March 2022, 02:37:41 »
I see doggo, I like! GLWIC :thumb:
Offline juju___mk
« Reply #21 on: Fri, 11 March 2022, 09:10:25 »
Hi everyone,
Thank you so much for the awesome feedback and hope you have noticed some of the changes! The original IC form has been edited to where you can now edit your response if you have any updated feedback/suggestions! Additionally, 2 deskmat options have been added!! Please provide some feedback on which one you like the most.
Thank you for the feedback and the support!
DESKMAT POLL
Offline juju___mk
Re: [IC] GMK SOPHIE | Kits Finalized (03/15/22)
« Reply #22 on: Tue, 15 March 2022, 12:21:50 »
Hi everyone,
First, I want to thank everyone for leaving comments/recommendations on the form. Throughout the comments, there were some repeated comments so I decided to make the final change.
Currently, I'm working on reaching out to vendors and making a list of collaborators for this project so please continue to check on this page or on juju___mk instagram for updates!
Thank you for all the support and if you haven't already please continue to show support by completing the IC form!!
Offline XiXora
« Reply #23 on: Wed, 16 March 2022, 21:25:25 »
Literally everything except ISO getting accent colour including 40s in base. So sad to see.
Offline kight
« Reply #24 on: Thu, 17 March 2022, 00:16:55 »
OP, I know you said your kits were finalized but I would swap your accent 1.5u enter for an accent ISO enter.
Offline Malvix Studio
    • Malvix Studio
« Reply #25 on: Thu, 17 March 2022, 02:10:09 »
What a beautiful doggo, great work!
Offline juju___mk
Re: [IC] GMK SOPHIE | Vendors Updated (3/21/2022)
« Reply #26 on: Mon, 21 March 2022, 14:24:33 »
Hi everyone,
I'm happy to announce the following vendors for GMK Sophie and myKeyboard will be the lead vendor for this project :)
EU: MyKeyboard
NA: Mino Keys
SA: Fancy Customs
UK: ProtoTypist
SEA: iLumkb
OCE: DailyClack
KOREA: SwagKeys
Thank you!
« Last Edit: Tue, 22 March 2022, 07:55:11 by juju___mk »
Offline juju___mk
« Reply #27 on: Fri, 08 April 2022, 20:15:08 »
Hi everyone,
3 more renders have been added! Keyboard is TGR Alice by Yuk Tsi and render done by eg0t1st1k4l!
