Author Topic: [IC] Sperno59 | GB LIVE  (Read 56735 times)
Offline Biscuit
« on: Fri, 11 March 2022, 17:51:47 »
« Last Edit: Sun, 06 November 2022, 08:38:55 by Biscuit »
Offline Biscuit
Re: [IC] Sperno59 keyboard | R-shift?
« Reply #1 on: Fri, 11 March 2022, 17:52:11 »
Reserved
Offline ee
  • hi
« Reply #2 on: Fri, 11 March 2022, 18:19:02 »
gasket tray mount so lit
Offline Getsome!!!
« Reply #3 on: Fri, 11 March 2022, 19:33:43 »
Dope layout. I really like it. The bezels are too small for me though.
Offline swift
« Reply #4 on: Sat, 12 March 2022, 02:43:41 »
As a fellow non right shift user, I think this looks really interesting.  Arrow keys separated like that almost makes me think of the Cajal but made into a 60, which is definitely a good thing :)
Offline QWER|key
« Reply #5 on: Sat, 12 March 2022, 02:49:15 »
Looks nice, but as I type "properly" that would mess me up.   I suppose there are enough who type "incorrectly" though. [edit]  The quotes denote sarcasm - I know there is no "correct" way...  but for those who touchtype using the home row method already have muscle memory for right shift every time you start certain sentences.
« Last Edit: Sat, 12 March 2022, 02:52:41 by QWER|key »
Offline Biscuit
« Reply #6 on: Sat, 12 March 2022, 04:00:04 »
This is a tough one, I've had people say both too thick and too thin bezels.
Going to see what the best option is, might be to keep it this way, but I will see once I get more responses.
Offline Biscuit
« Reply #7 on: Sat, 12 March 2022, 04:02:57 »
Yes, this layout is definitely not for people who type correctly. I have to tried to do it the right way, but it didn't work for me and I also guess many others.
Offline Vigrith
« Reply #8 on: Sat, 12 March 2022, 08:33:01 »
**** right shift
Buying
Offline Rpmorrison10
« Reply #9 on: Sat, 12 March 2022, 11:38:05 »
tap holds are amazing, You can easily make the up arrow, shift on hold, up arrow on tap
Offline djmantis
« Reply #10 on: Sat, 12 March 2022, 19:48:31 »
I like this layout idea a lot. I have thought about something similar in the past. I think my only issue so far is the "sperno" engraving on the front. I makes me think of "sperm" to much.
Offline Getsome!!!
« Reply #11 on: Sat, 12 March 2022, 20:14:21 »
It's pure preference. I'd just go with what you yourself prefer. Personally, i LOVE giant MEGA bezels i.e. Piggy, M0110, etc.
Offline Biscuit
« Reply #12 on: Sun, 13 March 2022, 05:08:53 »
Yes, we are currently changing that. It did catch some eyes, the font I mean.
Offline 8um8lebee
« Reply #13 on: Sun, 13 March 2022, 18:25:38 »
I understand the idea but it'd be a very audience-dividng idea. As others have said, plenty of people type using rshift, myself included. "I never use rshift lol who uses rshift? therefore rshift is functionally pointless for everyone" is the same as saying "I hit spacebar with my index finger lol who uses thumb? therefore spacebar should just be on r3 somehow and here's a true ergnomic SKL (spacebar keyless) layout.". Of course if you just wanna make a keyboard for you, go for it! Just know you are actually alienating quite the userbase.
« Last Edit: Sun, 13 March 2022, 18:27:18 by 8um8lebee »
Offline fishbiscuit13
  • do you realize ???
« Reply #14 on: Sun, 13 March 2022, 19:13:41 »
why the uneven gaps for arrows
« Last Edit: Sun, 13 March 2022, 19:15:36 by fishbiscuit13 »
Offline syberghost
« Reply #15 on: Mon, 14 March 2022, 08:32:02 »
nooooo my poor right shift what has the bad man done to you
yes, I'm the guy who put box jades on a Polaris
Offline mr_foggy
  • neue = nope
« Reply #16 on: Mon, 14 March 2022, 10:01:19 »
something refreshing for a chance. nice to see a flex hotswap layouts for the beginners.
very nice.
Offline granola bar enthusiast
« Reply #17 on: Mon, 14 March 2022, 10:08:20 »
thought it was a 65% for a few seconds
Offline djmantis
« Reply #18 on: Mon, 14 March 2022, 14:06:31 »
Yes, that is why there a plenty of other keyboards for you to use that have Rshift. This board is for people that don't ever touch Rshift or right hand mods and instead would like arrow keys. 40%'s "alienate quite the userbase".
Offline Biscuit
« Reply #19 on: Tue, 15 March 2022, 03:18:02 »
We didn't want too big of a chin, so it is horizontally thinner. And we moved the arrows to the right, because otherwise it would look too empty.
Offline Biscuit
« Reply #20 on: Tue, 15 March 2022, 03:19:29 »
Exactly this. Thank you.
Offline Getsome!!!
« Reply #21 on: Tue, 15 March 2022, 04:55:03 »
EVERY design decision is going to be "audience dividing". Including the R-shift would "alienate" people who like this layout becasue it lacks it. Your analogy in incredibly flawed. He's removing a duplicate key, not moving a key.
Offline ankit
  • Formerly ankit-sachdeva
« Reply #22 on: Wed, 16 March 2022, 01:40:47 »
deleted sorry.
Offline WHAT!?
  • WHAT!?
« Reply #23 on: Wed, 16 March 2022, 10:11:55 »
I too have never employed the use of a right shift key. I've often wanted to just chuck it off of my keyboard. What I don't want to chuck off of my keyboard is the function row though. I like having my F keys and a tilde. Love the layout aside from that.
Even given this drawback (for me) I might still consider this. You end up with a pretty compact board with a fairly minimal sacrifice at the end of the day, and I do appreciate the exploded arrow cluster.
Offline Nurseh
  • Sorry for always apologizing
« Reply #24 on: Wed, 16 March 2022, 11:35:38 »
Digging the layout, barely ever use r-shift. Nice to have the size of a 60% with arrows.
« Reply #25 on: Wed, 16 March 2022, 11:38:06 »
10/10 **** right shift
not that i use dedicated arrows either though
Offline Biscuit
Re: [IC] Sperno59 | Big update
« Reply #26 on: Tue, 26 April 2022, 12:16:00 »
Big update
Offline Biscuit
Re: [IC] Sperno59 | More Renders
« Reply #27 on: Wed, 25 May 2022, 09:54:20 »
More renders
Offline Biscuit
Re: [IC] Sperno59 | Protos shipping now
« Reply #28 on: Mon, 27 June 2022, 04:50:16 »
protos have finished production and are shipping to us.
We have received pictures that we posted in the discord server.
Because the pics by the manu are not that great i haven't posted them here.
We will provide better pics of the protos when received and do post them here.
Offline Biscuit
« Reply #29 on: Wed, 13 July 2022, 09:49:12 »
THESE ARE R1 PROTO PICS.
THE RED AND BLUE COLOR HAVE BEEN IMPROVED IN THE R2 VERSION
« Last Edit: Tue, 01 November 2022, 03:28:17 by Biscuit »
Offline bobbistef
« Reply #30 on: Wed, 13 July 2022, 10:08:37 »
This is sweet, my only wish is that the hotswap PCB supported split backspace, which I guess would need to be done Wuque style with the split keys being north-facing
Offline rossi94
« Reply #31 on: Thu, 14 July 2022, 01:56:02 »
Any chance for a e-coated black version?
Offline RoyalOak88
« Reply #32 on: Thu, 14 July 2022, 04:43:32 »
That Blue proto doesn't look close to the initial renders. Are you happy with it or are you still planning to tweak it a bit before?
Asking just because I loved the blue from the renders.
Offline Biscuit
« Reply #33 on: Fri, 22 July 2022, 06:23:47 »
nope sorry, possibly cerakote though
Offline Biscuit
« Reply #34 on: Fri, 22 July 2022, 06:31:30 »
I am happy with the finishing and the color on the sample pic looks nice.
And i agree, the render color doesn't look like the sample pic.
Hoping this difference is caused by bright studio lighting in the sample pic and dim light in the render, so when you have it on your desk it would be closer to the render.
If this is not the case we will be tweaking the colors, but they will never be exactly like the renders.
Offline rossi94
« Reply #35 on: Fri, 22 July 2022, 09:00:39 »
Could see if we can mod the hotswap pcb to iso? By resoldering the hotswap socket?
Offline rossi94
« Reply #36 on: Sat, 23 July 2022, 04:43:09 »
What do I need to do to get a sperno plus with a function row?  :eek:
Offline Biscuit
« Reply #37 on: Mon, 25 July 2022, 07:14:08 »
Things I'd rather not mention publicly.
But yeah, this sounds like a good idea.
We'll be focusing on the original layout first though.
Offline Biscuit
Re: [IC] Sperno59 | Reviewing protos
« Reply #38 on: Mon, 25 July 2022, 07:15:42 »
Protos have been received.
Reviewing them now and already making changes.
Will be posting the changes soon.
Also the color will be made darker (closer to renders) for final production.
Offline Biscuit
Re: [IC] Sperno59 | Vendors announced
« Reply #39 on: Fri, 12 August 2022, 05:20:42 »
Vendors:
US: Mechs&Co
EU: MyKeyboard
CA: Ashkeebs
AU: SwitchKeys
Offline santela
« Reply #40 on: Mon, 29 August 2022, 19:57:05 »
As a right shift user I'm personally offended.
Kidding, actually an interesting take on the layout, GLWGB.
Offline mr_foggy
  • neue = nope
« Reply #41 on: Thu, 01 September 2022, 13:06:09 »
Vendors:
US: Mechs&Co
EU: MyKeyboard
CA: Ashkeebs
AU: SwitchKeys
please make sure Mykeyboard does not add insane markups to the price as usual.
black/brass looks gorgeous though. will consider it depending on final price in €.
Offline EdTheNerd
« Reply #42 on: Thu, 08 September 2022, 07:29:06 »
Looks interesting. Different layouts from the ones we have hundreds of are always nice to see.
I'd be in for the brass bottom version if we could get it without the logo on the top side.
Offline Biscuit
Re: [IC] Sperno59 | Proto R2 and MORE!!
« Reply #43 on: Mon, 19 September 2022, 10:46:13 »
- Last round of samples there was an issue with the switch tolerance, which is now fixed.
- The R2 blue and red sample are now closer to the renders and just Better
- There is now a sound test of the full alu and brass bottom version. The video switches between different microphones.
- Asia vendor is QwertQop
- Looking into UK vendor per demand.
- Keyboards being sent out to streamers, so expect more contect on this board.
- redoing the renders like the exploded one to match the final colors. (But we will also have pics of each proto color)
Offline Biscuit
Re: [IC] Sperno59 | Pricing and GB date
« Reply #44 on: Sat, 22 October 2022, 13:24:55 »
update
Offline MoltenKhor
  • www.khor.store
    • Khor Store
« Reply #45 on: Mon, 24 October 2022, 10:40:11 »
I can already see a €500+ price tag for the alu version
Offline Verrine
« Reply #46 on: Mon, 24 October 2022, 10:45:55 »
According to folks in the discord MyKeyboardEU confirmed  459 for alu and 569 for brass.
Offline saab
« Reply #47 on: Mon, 24 October 2022, 11:35:28 »
GL with GB :)
Offline Biscuit
Re: [IC] Sperno59 | GB OCT 28th!!
« Reply #48 on: Thu, 27 October 2022, 09:36:50 »
GB tomorrow
Offline Biscuit
« Reply #49 on: Thu, 27 October 2022, 10:05:07 »
Sadly this is the case with all keyboards recently.
For example the freebird75. 180 usd and 240 euro on candykeys. Which is a 33% increase (just numbers), this is the same with the sperno.
