Author Topic: [IC] Paraluman - Top/Gummy O-ring Mount 60% Keyboard Kit  (Read 11071 times)
Offline anonymous
« on: Sun, 27 March 2022, 04:32:10 »
Hello everyone! Paraluman is my take on the gummy o-ring mount boards. Top mount is also an option for those who don't like the o-ring mount. We already ran 2 batches of GB for this board locally here in the Philippines. A prototype run (5 units) and a mini gb for local enthusiasts (30 units). This year, we would like to offer it to everyone!
Kit Details:
 - Aluminum Top and Bottom Case, and Plate
 - WKL top case by default but can offer standard top if there is demand
 - Center USB-C using daughterboard
 - Solder PCB
 - External Brass Weight (3mm Thick)
 - Mounting: Top Mount or Gummy Oring Mount
 - Front Height: 20.5mm
 - Typing Angle: 7 degrees
 - Includes a 50A NBR O-ring (default), 30A O-ring can be an option if people prefer that (I just need to find a supplier for it)
More Photos: https://imgur.com/a/zaaLLH8
Price and GB Schedule:
This is still TBD. We would like to gauge interest first before asking for updated quotes from the manufacturer. Prices have increased from the GB run to the mini GB so we also expect increase in prices this year. Our target price is $400 and lower
Colors:
The number of colors that will be available will depend on the number of units will be ordered. So far, we have 5 colors that we have used in our previous GBs. Dual color is possible (Different color for top case, plate, and bottom case)
  • Black
  • Silver
  • Purple
  • Burgundy
  • Pink
Typing Tests:(1st board is from the mini gb while the rest is from the proto run)
Feedback Form:
https://forms.gle/yzNShQGSqBQkK7ZZ8
« Last Edit: Sun, 27 March 2022, 07:49:46 by anonymous »
Offline conternecticus
Re: [IC] Paraluman - Top/Gummy O-ring Mount 60% Keyboard Kit
« Reply #1 on: Sun, 27 March 2022, 23:11:52 »
Purple looks awesome. GLWIC!
Offline Seunghyun Lee
« Reply #2 on: Sun, 27 March 2022, 23:19:23 »
60 wkl with thin bezel... i'm in!
« Last Edit: Sun, 27 March 2022, 23:22:48 by Seunghyun Lee »
« Reply #3 on: Sun, 27 March 2022, 23:20:30 »
1
« Last Edit: Sun, 27 March 2022, 23:25:38 by Seunghyun Lee »
Offline granola bar enthusiast
« Reply #4 on: Sun, 27 March 2022, 23:45:44 »
wkl 60%'s are for sure one of my fav looking layouts! will definitely look at this as an option when the gb comes around!
Offline lush_bunny
« Reply #5 on: Mon, 28 March 2022, 00:10:51 »
PH represent! Glad to see you here DeskDaily. GLWIC.
Offline Ustinj
« Reply #6 on: Mon, 28 March 2022, 00:17:16 »
Personally think the bottom would look much nicer if the external weight screwed in from the inside - too many screws / feet cluttering the layout of the bottom IMO. glwic!
Offline anonymous
« Reply #7 on: Fri, 01 April 2022, 08:07:02 »
Thank you!
Thank you for the feedback. I will take this into consideration. I agree that I looks cleaner that way. But that kind of weight is usually more expensive to manufacture. And at a few quantity it blows up the price.
Offline anonymous
« Reply #8 on: Fri, 01 April 2022, 08:08:36 »
Offline Ustinj
« Reply #9 on: Fri, 01 April 2022, 13:23:21 »
I think you can pull it off without changing much, just by putting the screw holes on the other side of the weight, and the countersunk screw pass throughs on the internal floor of the case. good luck!
Offline anonymous
« Reply #10 on: Sat, 02 April 2022, 21:42:19 »
Ah yes. That could work. I just need to increase the thickness of the brass weight.
Offline LMarci
« Reply #11 on: Fri, 08 April 2022, 05:32:18 »
I'm a fan of simple oring 60s, depending on the price might get a unit. GLWIC
