Author Topic: [IC] Series TY Type-00 | esc lab — A metal tray for your deskscape  (Read 6438 times)
Offline Cubic | esc lab
    • esc lab
SERIES TY TYPE-00
CNC machined. Anodized aluminum. Tray style container.
Please take the IC survey
Hello everyone!
We’re back to show everyone what we’ve been working on since Series 00, our first product.
This interest check is for Series TY, a CNC machined aluminum tray that sits on your desk. Its weight park itself and is not easily moved by accidental bumps with a soft silicone bottom. Wide opening for easily viewing your contents, sorting, and pouring objects in and out of the tray.
Today, we’re finally ready to show you Series TY Type-00.
We hope you like what you see, and as always, feel free to leave any feedback.
0. CONTENTS
⠀1. SPECIFICATION
⠀2. DESIGN VARIATIONS
⠀3. DESIGN DETAILS
⠀4. GALLERY
⠀5. VENDORS
⠀6. TIMELINE
⠀7. OUR COMMUNITY
⠀8. THANK YOU
1. SPECIFICATION
Color-Material-Finish
Design A
Material    Color    Finish    Coating      Size                Weight    Volume
AluminumSilverSandblastAnodization90 X 90 X 14.5 MM153.5 g41,072.1 Cubic MM
AluminumBlackSandblastAnodization90 X 90 X 14.5 MM153.5 g41,072.1 Cubic MM
Design B
AluminumSilverSandblastAnodization90 X 90 X 19.5 MM212.1 g59,796.7 Cubic MM
AluminumBlackSandblastAnodization90 X 90 X 19.5 MM212.1 g59,796.7 Cubic MM
Our plan is to only produce one of the two design variations, and we would like to get your feedback.
Design A is simpler and thinner. Design B is taller with the added functionality of holding pens in various diameters.
3. DESIGN DETAILS
Silicone feet to protect bottom case, grips to the table.
Silicone feet also protects itself from scratch during stacking with enough clearance for the stem.
The stem design allows it to hold a variety of pen in different diameters - from thin to thick.
4. GALLERY
Additional assets can be viewed here.
5. VENDORS
Series TY Type-00 is intended to be an unlimited GB with major regional vendors which will be confirmed at a later date.
6. TIMELINE
This is an estimated timeline for Series TY Type-00. We will update the timeline when it’s time for GB, and we will keep everyone informed with updates in our Discord and Research Facility.
7. OUR COMMUNITY
Discord
Instagram
Website
8. THANK YOU
Thank you all for taking the time to read this IC.
CONSIDER SERIES TY TYPE-00
Offline shima
  • keeb weeb
Re: [IC] Series TY Type-00 | esc lab — A metal tray for your deskscape
« Reply #1 on: Sat, 02 April 2022, 00:08:17 »
nice
boards: anura
Offline iinko_mk
  • Status: broke
« Reply #2 on: Sat, 02 April 2022, 00:14:56 »
I cannot tell if this is an April fools joke or not lmfao
Offline AuroraCamo
« Reply #3 on: Sat, 02 April 2022, 00:16:05 »
it's not...
    • esc lab
« Reply #4 on: Sat, 02 April 2022, 00:24:14 »
Not april fools joke and totally legit!  ;D
Offline oilpapers
« Reply #5 on: Sat, 02 April 2022, 03:35:35 »
No price is sus.
Offline rookb
« Reply #6 on: Sat, 02 April 2022, 06:25:53 »
Where are your protos? It's a tiny slab of machined alu, surely it's not that hard
Offline CookieFlow
« Reply #7 on: Sat, 02 April 2022, 09:24:20 »
why do you need a new account to post this?
I hope this is a late april's fool.
There are already plenty of options for in stock trays out there, not sure why anybody would join a 6-9+ months GB for a tray.
Offline LittleAad
  • Hello
« Reply #8 on: Sat, 02 April 2022, 10:14:41 »
Idk the point in this really nor do I understand why someone would join a gb for it.
imo trays are already pretty pointless and this one doesn't even look that great to me...
    • esc lab
« Reply #9 on: Sat, 02 April 2022, 11:31:55 »
I would like to get feedback on which design variation to make the prototype of. It's true that it's not hard to make, but due to the pandemic, the prototype's lead time has increased significantly.
Prototypes will be made and I'll take photos of them for GB!
    • esc lab
« Reply #10 on: Sat, 02 April 2022, 11:38:40 »
This is Cubic's account as the previous one is loop's.
There are always other options for trays, but not that many are in-stock options nor may fit their current desk setup/theme. I would like to provide another option for the community to choose from. The targeted GB fulfillment is 5-6 months!
Offline soundstage
« Reply #11 on: Sat, 02 April 2022, 12:04:08 »
So an expensive pen holder than can effectively hold 1 pen at a time?
