Author Topic: [IC]KBM Fairy - GB LIVE  (Read 26718 times)
Offline Wintea
« on: Sun, 17 April 2022, 00:25:34 »
GROUPBUY IS LIVE HERE
KBM Fairy
Inspired by the whimsical and magical creatures hidden behind the lush of the forest, waiting to be found. But be careful and try not to fall for their charm, as they can keep you trapped for eternity…
_______________________________________________________
GB DATE: SEPTEMBER 16th - OCTOBER 16th
Vendor
US - Otakeebs
CA - Deskhero
EU - Lykko Studio
UK - Protozoa Studio
SEA - PantheonKeys
OCE - AllCaps
VN - The Keeb Store
IC Form
Pricing
Update
8/16/2022 - GB date announcement
8/14/2022 - Update deskmat colors
8/2/2022 - Changed R3 mod's color
4/17/2022 - Changed alpha's legends colors
4/18/2022 - Added F13 to base kit
4/19/2022 - Fixed 40s kit
4/20/2022 - Updated novelties kit and renders. Vendors update
6/19/2022 - Updated vendors
6/24/2022 - Updated collabs
Keycap Details
Profile: Cherry
Method: Dye sub
Plastic: PBT
Manufacturer: KBM - Keybee MFG
Kitting
Render
Mode65 by ModeDesigns
Note: Colors might vary with different monitors and lighting conditions!
Renders by Beesley
Deskmat
Forest Deskmat
Fairy Deskmat
Collab
KBM Metal Artisan
DELLAKEY
RAYKEY
Bungkee.Caps
Zuno Studio
Link
Twitter 1: https://twitter.com/iliana_VT
Twitter 2: https://twitter.com/wiintea
Instagram: https://www.instagram.com/wiintea/
Discord: https://discord.gg/yQeezcHWYY
Banner
If you want to support this project, please share this in your signature!
Code: [Select]
[url=https://geekhack.org/index.php?topic=116935.0][img width=239 height=120]https://i.imgur.com/orD6xry.jpg[/img][/url]
« Last Edit: Mon, 19 September 2022, 20:47:08 by Wintea »
Offline Wintea
Re: [IC]KBM Fairy
« Reply #1 on: Sun, 17 April 2022, 00:35:18 »
Reserved
Offline zryn
Re: [IC]KBM Fairy
« Reply #2 on: Sun, 17 April 2022, 00:58:51 »
imo the pink spacebar looks kind of out of place. overall great set, take my money
Offline jewleeuhn
Re: [IC]KBM Fairy
« Reply #3 on: Sun, 17 April 2022, 01:07:43 »
Not bad, I think the 1.5u mods should be the same color as the 1.25u mods; might flow better
Brutal60 | GS6O | IU | Mc65 | 2.0add
Offline Wintea
Re: [IC]KBM Fairy
« Reply #4 on: Sun, 17 April 2022, 04:29:39 »
Thank you for your feedback, I'll update the kit!
Offline Ciantha
Re: [IC]KBM Fairy
« Reply #5 on: Sun, 17 April 2022, 05:47:31 »
I think you've gotten your colours mixed up on the 40s kit. As far as I can see the shift row should be blue and the mod row green. However in the 40s kits some shifts are green and some mods are blue.
You might want to look at some recent gradient sets (mw gelato and epbt kavala for example) for which keys belong to which row.
Offline Wintea
Re: [IC]KBM Fairy
« Reply #6 on: Sun, 17 April 2022, 05:57:24 »
Thank you for your feedback! I'll do some more research of the 40s and adjust the kit!
Offline QWER|key
Re: [IC]KBM Fairy
« Reply #7 on: Sun, 17 April 2022, 07:20:19 »
I think a F13 key and full UK ISO support should be included as it won't add much to the cost.
Offline Fraaaan
Re: [IC]KBM Fairy
« Reply #8 on: Sun, 17 April 2022, 08:16:46 »
Pretty healthy base kit size. Putting size labels in the spacebar kit would be great, kinda hard to eyeball spacebars. Replace the 1u Backspace with an F13 and you're good to go. There's a 1u Backspace in the 40s kit anyways.
Never heard of KBM so it would be great if we could see some prototypes.
Offline itsazly
    • website place
Re: [IC]KBM Fairy
« Reply #9 on: Sun, 17 April 2022, 09:04:52 »
Super cute and most likely in! Also asking for F13.
Could we get some info on KBM as a manu? I don't think I've really heard of them.
Offline Cylent
  • Formerly cylentshadows
Re: [IC]KBM Fairy
« Reply #10 on: Sun, 17 April 2022, 12:07:34 »
Hi! As a creator of a mod-gradient myself, I like this! However, there are points for improvement.
Base kit:
-make all spacebars alpha colored.
-remove mod ansi enter, replace 2nd iso enter with R2 purple
-remove alpha arrows, add R5 light blue up arrow
-Remove R4 tilde and <>
-add R5 light blue 1u Fn
40s:
-please come to the 40s server for feedback, as this kit needs a LOT of changes.
Spacebars
-please label spacebar sizes
Novs:
-see feedback above on alpha colored enters
-Also, please replace all kit render backgrounds with something simple so it's easier to see the colors
« Last Edit: Sun, 17 April 2022, 12:11:31 by Cylent »
Offline Fraaaan
Re: [IC]KBM Fairy
« Reply #11 on: Sun, 17 April 2022, 13:12:57 »
Base kit:
40s:
Spacebars
Novs:
Regarding the removal of r4 <>, I think OP is trying to cover both terminal ISO as well as UK ISO so it makes sense kitting-wise. We have seen this on sets like DCS 9009 before. I agree that r4 tilde isn't necessary, not even sure what layout that is for, I assume it's a regional thing.
Offline Cylent
Re: [IC]KBM Fairy
« Reply #12 on: Sun, 17 April 2022, 13:31:40 »
Base kit:
Hi Fraan! AFAIK supporting terminal in base is unnecessary if UK ISO is already in base. However it's really just a single 1u in a dyesub set so in the grand scheme of things it's nbd.
Offline Wintea
Re: [IC]KBM Fairy
« Reply #13 on: Sun, 17 April 2022, 18:44:54 »
Base kit:
40s:
Spacebars
Novs:
Thank you for your feedback, I'll look into it and adjust the kit!
Offline razorblade04
Re: [IC]KBM Fairy
« Reply #14 on: Mon, 18 April 2022, 11:30:50 »
Saw this on Reddit, really happy to see it make it to a proper IC, I'm excited to see where this goes and ill probably pickup a deskmat at the very least, also interested to see how KBM is,
« Last Edit: Mon, 18 April 2022, 11:32:37 by razorblade04 »
Offline Wintea
Re: [IC]KBM Fairy
« Reply #15 on: Mon, 18 April 2022, 19:02:20 »
Thank you very much. I'm still very surprised and happy how well-received this set is!
Offline granola bar enthusiast
Re: [IC]KBM Fairy
« Reply #16 on: Tue, 19 April 2022, 09:31:28 »
never seen the KBM manu before, how does their quality compare to that of GMK, MW, and other's?
Offline fairypenguin
  • zzz
Re: [IC]KBM Fairy
« Reply #17 on: Tue, 19 April 2022, 17:14:22 »
This set is so cute :D
Offline Wintea
Re: [IC]KBM Fairy
« Reply #18 on: Tue, 19 April 2022, 19:39:12 »
Here's an album of another KBM set's sample: https://imgur.com/a/qn40HAN
I'd say their quality is pretty good and they have a very decent turnaround time!
Offline Wintea
Re: [IC]KBM Fairy - VENDORS UPDATE
« Reply #19 on: Wed, 20 April 2022, 01:40:57 »
Vendors has been announced!
Offline Wintea
Re: [IC]KBM Fairy - NEW COLLABS UPDATE
« Reply #20 on: Thu, 23 June 2022, 19:11:04 »
6/24/2022 - Updated collabs with new renders!
Offline Cylent
« Reply #21 on: Thu, 23 June 2022, 20:39:02 »
Hi, seeing this a second time, this is a clear improvement. I like the colors and am definitely interested.  Good job :thumb:
I have a few more recommendations I hope you consider  :D
Base kit
-numpad kit 2nd - should be =
-Iso support still feels a little overkill, but not a big deal if the pricing's still good
-You added R5 color up arrow which was great, but missing R5 color 1u fn. You don't need 3 1u ctrl keys really, so you can just make one of them fn and cover that with no added keys.
Novs
-adding a 1.25u R5 would be great to cover some bottom row layouts
-I'm not entirely sure what layout you're attempting to create with the R3 purple ansi enter, could we see a render of that?
Offline Wintea
« Reply #22 on: Thu, 23 June 2022, 21:43:54 »
Base kit
Novs
The R3 purple enter can be used as an accent! As for your other suggestion, I'll take note of them and adjust the renders!
Thank you very much!
Offline Cylent
« Reply #23 on: Thu, 23 June 2022, 21:55:20 »
Base kit
Novs
Yes, but you have a mod gradient, so I am not sure how it will look like. Could we see a render of that layout used?
Offline MattVortex
« Reply #24 on: Mon, 27 June 2022, 12:18:34 »
Great colours and kitting, I don't think i've seen better kitting from a base kit before.
One small thing that's missing: R1 [§±] for UK Mac ISO support; I can see you already have R3 [\|] and R4 [`~] for UK Mac ISO.
Offline LumiP
  • A lil Faedude on the net. Fave layout is FRLTKL!
    • Sometimes I do builds on Twitch! :3
« Reply #25 on: Wed, 29 June 2022, 22:36:30 »
That first deskmat is a STRAIGHT BANGER so if nothing else I'll be in for that.
Current Boards: Aaru TKL Old Dark Sand, Drop + Planck Purple, Mr Suit WKL Black w/Gold Chamfers, Sangeo60 Black, KBD67Lite White, D45 E-Grey, Wind X Pink, NCR 80 Beige, QK65 Dark Green, Gentleman65 Black, Av4 Claymore, TGR x Monokei Tomo Suave Blue, Heracles80 Holy White, Snake60 Rust, Array E-White, Capsule E-White, QK75 E-White, Zoom75 Milky Green, QK80 Black, Envoy 65 PC, Mode Sonnet Ice Blue, Cycle 7 Lavender, E-White; Neo70 Retro White, Black; Reflection Chocolate, Neo80 Champagne, Matra Alice 90 Glossy Red;
Offline Daesya
  • 💜 purple supremacy 💜
    • social mediass
Re: [IC]KBM Fairy
« Reply #26 on: Tue, 05 July 2022, 17:36:16 »
I actually wish there was more pink accents on the kit, feel sad only the top row have this color !
But depending on how my wallet feels at the time this comes out, I definitely want to support the set and see how KBM keycaps feel and sound.
Love the forest deskmat too 💜
Offline Wintea
Re: [IC]KBM Fairy
« Reply #27 on: Thu, 07 July 2022, 21:30:40 »
Thank you very much for your support!
Offline alvrnicu
  • Collecting Bongo Cat Keycaps
« Reply #28 on: Sat, 23 July 2022, 15:40:42 »
Beautiful set! My girlfriend would love this. Hope it comes to fruition :)
Offline Wintea
« Reply #29 on: Sun, 24 July 2022, 22:06:55 »
Thank you very much for your kind words!!
Offline Wintea
« Reply #30 on: Mon, 01 August 2022, 20:31:22 »
8/2/2022 - Changed R3 mod's color - Updated renders!
Re: [IC]KBM Fairy - UPDATED RENDERS
« Reply #31 on: Thu, 04 August 2022, 16:45:27 »
I like the new R3 color better than the old one (more pastel-y).  :thumb:
Offline Wintea
« Reply #32 on: Thu, 04 August 2022, 19:25:06 »
Thank you! I'm glad you like it!
Offline giuliano.cz
« Reply #33 on: Tue, 16 August 2022, 12:55:06 »
Beautiful set! I know it may be too much to ask for, but a single ISO enter in 40s kit would be much appreciated. Other than that, love the set, GLWIC and I'm waiting for the GB!  :thumb:
Offline Wintea
Re: [IC]KBM Fairy - GB DATE ANNOUCEMENT
« Reply #34 on: Tue, 16 August 2022, 17:29:11 »
GB DATE ANNOUCEMENT: SEPTEMBER 16th - OCTOBER 16th
Offline Wintea
« Reply #35 on: Thu, 15 September 2022, 05:27:38 »
PRICING HAS BEEN UPDATED
