Author Topic: IC Red Herring 75%  (Read 7676 times)
Offline EDITINC
IC Red Herring 75%
« on: Sun, 17 April 2022, 22:08:33 »
Red Herring.
This is a 75% board with a split ergo layout similar to an Alice, but with columnar-staggered keys like the Jabberwocky by NoPunIn10Did. The PCB features all through-hole components with the diodes laid out in a herringbone pattern that follows the contour of the top row keys. I left a lot of room around the rotary encoder, so it can fit a 48mm diameter knob. And finally, front and center is a 64x128 OLED display.
My excitement for this board stems largely from the ability to use standard keycaps. Whether they're cheap or expensive, as long as your kit has that extra 1.75u shift and a 2u key from the numpad, you're probably good to go. The oversized rotary knob is a bit ridiculous, but I personally find it amusing to look at. And even though it adds a lot of heft to the PCB, I love seeing exposed through-hole components, especially when they're laid out nicely.
As I mentioned, this is just a prototype I'm doing for fun, but I am working on a rev 2. The case design will be improved functionally and aesthetically, and the next PCB will support a full 2.25u left shift. I'm also considering moving the caps lock LED up to the top instead of under the key, and also move the knob slightly over to make it look less crowded.
Here are the build details of the pictured keyboard: custom laser cut clear gray/red acrylic case, Red Herring rev1 PCB, FR4 plate, silent Alpaca switches, Durock v2 stabs, Iron Man keycaps from Drop.
Let me know what you guys think! And here's the full album with a few extra pics: https://imgur.com/a/fM5yRbc
I also want to mention all the other amazing board designs that I took inspiration from: Boardrun Bizarre, Adelheid, Discipline & Mysterium, Mercutio, and Basketweave.
everything now is in EARLY stages
Email for Build Date/Purchase Info
Samuellshell@gmail.com
285101-0285103-1285105-2285107-3285101-4285101-5285109-6285111-7285113-8
Offline 0ldMate
Re: IC Red Herring 75%
« Reply #1 on: Sun, 17 April 2022, 22:12:15 »
Huge fan of the big knob. Love the look of it and the functionality of the keycaps is so good!
Offline dvllpxe
« Reply #2 on: Sun, 17 April 2022, 22:18:46 »
yo this is awesome for real   ;D
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
« Reply #3 on: Sun, 17 April 2022, 22:28:22 »
My friend, duplicate forum post, first time posting on geekhack, and e-mail as a method of finding out how to purchase or find a gb makes me really hesitant
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline hottnucks
« Reply #4 on: Sun, 17 April 2022, 22:34:58 »
Email for details?
« Last Edit: Sun, 17 April 2022, 23:47:03 by hottnucks »
Offline nevin
« Reply #5 on: Sun, 17 April 2022, 22:40:34 »
Very interesting and different. Love the look & design of everything about this board.
Hope the revisions go well for you and this eventually goes to group buy and does well for you.
We need more, new, interesting layouts & form factors.
Offline jollyeskimo
« Reply #6 on: Mon, 18 April 2022, 00:31:59 »
Where did the solenoid go?
The green/white one had my attention
Offline HappyB0T
  • I'm a Piggie
« Reply #7 on: Mon, 18 April 2022, 09:01:11 »
This is ****ing out of control - I love it.
Offline ee
  • hi
« Reply #8 on: Fri, 03 June 2022, 23:27:49 »
give me 1800 version and i will nut
