Author Topic: [IC] Epomaker 680 Gasket DIY Kit - 65% Hot Swappable CNC RGB Wired DIY Kit  (Read 5237 times)
Offline EpomakerKeyboard
    • Epomaker
285419-0
Hi everyone!
We are thinking about starting a new Group Buy. It will be much appreciated if you could spend some time giving us some feedback!
Find details in IC Form
Get more updates on our Discord Server
Groupbuy LIVE till 25th May!
Est. shipping date: Late June - July, 2022
Super Early Bird Price at $69 only. Check this Groupbuy
A 65% gasket mount hot-swappable acrylic wired mechanical keyboard DIY kit! It is made with a CNC acrylic case to be shine-through. Without any screw holes on the plate, the DIY kit is gasket-mount to present a soft typing flow. With south-facing LEDs, the RGB backlights are perfect with the shine-through CNC acrylic bottom case. To offer more fun in customzing the keyboard, it also supports the VIA/QMK program.
Specs:
Model: Epomaker 680 Gasket DIY kit (switches and keycaps not included)
- Number of Keys: 68 keys
- Size: 65%
- Structure: Gasket-mount
- Hot-swap Availability:  3/5-pin Hot-swappable
- Connectivity: USB-C
- Case Material: CNC Acrylic Case
- Program: Compatible with VIA/GMK
- Backlight: South-facing LEDs, RGB
Here are some details and scene images.
285421-1
285423-2
285425-3
« Last Edit: Thu, 12 May 2022, 22:33:20 by EpomakerKeyboard »
Offline iinko_mk
  • Status: broke
Offline Fraaaan
Epomaker is a big company. Is there really a need for group buy?
Offline Keeblet_257
Im litteraly blind after seeing this in my dark room
Offline Screen.jing
flashbang OUT!
Too many projects going on at once
Papilio
MF60
Disco
Vlad
65
Adamo
Offline AshF
I like backlighting, but it has to be tasteful.
 GLWIC
Sent from my ASUS_I003D using Tapatalk
Offline yotasan
    • ARCANE - PHOTOGRAPHY ARCHIVE
I'll buy if there's gonna be a way to turn the RGB brightness down...
Offline Jarhead
Prob needs screw-in stab support to get more people into it.
    • Epomaker
It's more for making our own keyboards and DIY kits  :D
