Author Topic: New TV: LCD vs. Plasma vs. ??  (Read 37977 times)
Offline instantkamera
« on: Mon, 20 September 2010, 08:28:11 »
Not making a poll since I would prefer some justification and discussion on specific models etc.
SO, if you were in the market for a new Television/entertainment display, what would you buy and why?
- LCD (if so, which backlight tech?)
- Plasma
- DLP/other Rear Pj.
- (front) Projector
- CRT
- Other
Just a bit of info, I am currently looking at two displays and Im not sure which one I will be going with (if either).
One is an LCD (CCFL), the other is a Plasma. Both are highly regarded.
Note, this is not about computer monitor technology, so please don't make arguments about monitors here (aside from the performance of a given display with an HTPC).
Realforce 86UB - Razer Blackwidow - Dell AT101W - IBM model MCST  LtracX - Kensington Orbit - Logitech Trackman wheel opticalAMD PhenomII x6 - 16GB RAM - SSD - RAIDDell U2211H - Spyder3 - Eye One Display 2
Offline itlnstln
« Reply #1 on: Mon, 20 September 2010, 08:56:10 »
LED-backlit LCD.
I have a DLP with an LED light engine, and I really like it other than the viewing angle issues.
« Reply #2 on: Mon, 20 September 2010, 09:11:20 »
Quote from: itlnstln;224861
LED-backlit LCD.
Any reason why?
It is a technology I'm not currently considering as by all accounts the viewing angles are worse and uniformity/flashlighting is generally far worse. Good LEDs are few and far between and CCFL is far better value at present.
Offline vils
« Reply #3 on: Mon, 20 September 2010, 09:15:32 »
Quote from: instantkamera;224862
Any reason why?
LCD has no burn-in issues as plasma does. LED backligthing is more even and black gets blacker. It also uses less power.
It\'s the glass pipe fallacy. You can only believe that if you\'re on crack.
Offline itlnstln
« Reply #4 on: Mon, 20 September 2010, 09:17:22 »
What vils said.  You also get longer life from LEDs.
Offline iMav
  • geekhack creator/founder
« Reply #5 on: Mon, 20 September 2010, 09:20:36 »
Another vote for LED-backlit LCD.
« Reply #6 on: Mon, 20 September 2010, 09:31:36 »
Quote from: vils;224863
burn-in is a non issue and IR is greatly reduced with the new sets as well.
Plasma has generally better motion and motion resolution (most offer a full 1080 lies of res in a full motion scene).
If you read other forums (AVS), you will hear tell of far more uniformity and flashlighting issues with LED than a good CCFL.
Plasmas generally have the best black levels.
Plasmas are more reflective, but most LED backlit are glossy (uggh, why??).
Im still not convinced on LED, does anyone own a set?
I care about:
- fairly accurate motion with no "soap opera" effect.
- solid black level performance with a uniform screen and good colour (I don't need the best blacks, but they have to be very good without other compromises and accurate colour).
- gaming - no lag. Again I don't need the BEST, but I can't deal with noticeable lag.
- size (52-60 inch)
I dont care about power-consumption, and the TV should have a decent 5 year life. I figure in that time I will have money for the latest and greatest.
Offline frvrngn
« Reply #7 on: Mon, 20 September 2010, 09:41:31 »
Where will it be used?
Will there be adequate light source control?  (blinds on windows, any reflection issues, over head lights, etc.)
What are you mainly using the TV for?  Sports, Movies, Sitcoms, Games
Dedicated theater setup with front and center seating or living room with chairs all around at many angles?
Plasma and LCD both have their pros and cons, but a lot depends on how and where it will be used.
Currently using: Cherry G80-1800 Ergo Clears, HHKB Pro 2, RF 87U Silent
Offline itlnstln
« Reply #8 on: Mon, 20 September 2010, 09:48:46 »
I think as long as you go with a direct backlight LED display (especially one with local dimming), you shouldn't have a problem, and the Vizios I have seen, as well as some Samsungs, didn't have any of the problems you mentioned.  I don't own one, however, so I don't get to stare at one everyday.  That said, while I like AVS, they have a tendency to spread panic there a lot, and you get a lot of "me too" posters that overplay some problems.  So much so, that I don't go there anymore unless I have a problem that I am trying to research.  The best thing to do is go to a high-end A/V store and look for yourself.  I wouldn't get too caught up in technology differences, just go to the store and pick the TV you like the best.
Offline itlnstln
« Reply #9 on: Mon, 20 September 2010, 09:57:40 »
I'm glad my GF likes my 61-incher.
« Reply #10 on: Mon, 20 September 2010, 09:59:29 »
Quote from: frvrngn;224867
fairly well controlled light-wise. Basement with small windows that are easily covered and dont allow a ton of light to begin with. Small recessed pot lighting with dimmers. I feel like a plasma would be no issue here, especially one with a  decent AR filter.
In order of importance:
- Bluray movies
- Gaming on my PS3 with no (noticeable) lag (I am NOT a hardcore gamer though).
- HDTV via cable provider, as few SD channels as possible.
- upscaled DVDs
Just to be clear, I have done A LOT of research on displays and am fairly confident that I am looking at two of the better sets in my price range (~$2000CAD), but I did want some feedback from you guys, being a fairly geeky forum and all. I am really curious to hear about specific models.
« Last Edit: Mon, 20 September 2010, 10:06:48 by instantkamera »
« Reply #11 on: Mon, 20 September 2010, 10:09:24 »
Quote from: itlnstln;224869
I HAVE heard good things about vizios.
Offline frvrngn
« Reply #12 on: Mon, 20 September 2010, 10:10:11 »
If you want the best in movie performance - Plasma.  Best blacks, best motion control.
basement setting is ideal for Plasma as you can make it as dark as you want.  You may still want some ambient lighting behind the screen at very low levels.
With the newest plasma screens you dont need to worry as much about IR.  Most screens have any number of ways to combat it from imperceptible pixel orbiters to scrolling white bars to "wipe" the screen clean if needed.  I would not game on one for hours on end, especially if it has static icons, but for short to medium gaming sessions you should be fine.
I would break in the screen properly before doing too much gaming.  After that, look up some base calibration specs on AVS for your model, get something like Video Essentials and do it yourself, or just tweak it to your liking.  For breaking it in you can do a slideshow of colored slides that you can download for free from AVS or other sites or you can just do the easy way of playing the Cartoon Channel on vivid/store/way too bright mode.  That actually works quite well with the random motion and bright color palette.
Just out of curiosity what models of Plasma and LCD are you looking at?
« Reply #13 on: Mon, 20 September 2010, 10:12:30 »
panny 54G25
Sony 60EX500
Offline Lanx
« Reply #14 on: Mon, 20 September 2010, 15:59:50 »
ppl who say
"plasma has burn in issues"
have info from 2001... yea
if you say movies? then you have to go plasma, if you say movies and big screen? then plasma
really LCD should only be regulated to rooms that get 18hours of direct sunlight a day or for the bedroom.
Offline Rajagra
« Reply #15 on: Mon, 20 September 2010, 16:18:59 »
I can't help but feel that every step the manufacturers make to reduce screen burn in is matched by broadcasters' determination to put permanent Digital Onscreen Graphics on show.
Also, don't most plasma makers recommend you set the brightness and contrast low for the first 100-200 hours of use? Do you think that is really a way of breaking in the TV? Isn't it more likely to be a way of recalibrating the user's taste so they keep those settings low? Clever trick, I think.
« Last Edit: Mon, 20 September 2010, 16:25:08 by Rajagra »
Offline itlnstln
« Reply #16 on: Mon, 20 September 2010, 16:46:41 »
I fully calibrate new displays as soon as I get them.  Out-of-the box settings typically suck.  Usually, brightness and contrast settings are way too high.
« Last Edit: Mon, 20 September 2010, 16:48:59 by itlnstln »
Offline Voixdelion
« Reply #17 on: Mon, 20 September 2010, 19:38:52 »
Another here for LED backlit - Specifically Samsung 8000 series I think.  The 240Ghz technology whatsisit (supposedly- according to the salesman who seemed pretty well informed -  it is the thing that is responsible for my staring at it agog with wonder and awe.  I think its to do with the motion issue)  is absolutely GORGEOUS.  Stunning, really. That is what I decided would be next TV, but thats a ways off still.
 Been in love ever since I saw one on display and spent about 45 minutes staring at the video of the store wanting to reach in the screen and tap myself on the shoulder. It was quite amazing.  Skinny *****, at about 1/2".  Was told it even more energy efficient than the LCD's too.
Picture was easily the best compared to anything else.  Sony had a nice offering, but the Samsung was better by a decent notable margin, and I am disenchanted with them anyways for their fall from grace in reliability and longevity.  By contrast, I've seen my 10 year old SyncMaster for sale used at a surprisingly high amount even as recently as last year and still love mine... I only wish it were bigger.   I bought that at the time when I was pretty exclusively a fan of Sony and I was struggling with the idea that I liked the picture on the Samsung better (and I do mean STRUGGLED; I stood there for about two hours in the aisle comparing picture between the Sony I would have bought and the 170MP before conceding that I was about to buy an electronic item that didn't say SONY on it for the first time in more than a decade.)  Despite the trepidation that it might not prove as trustworthy, it was just too pretty to pass up; Now it even seems that Samsung has taken up where Sony left off in terms of manufacturing quality.  My Samsung LCD is easily viewable from all sorts of angles, up down or sideways.  This is something Samsung has done better than anyone else as far as I can tell - I have grown used to it, and always forget when looking at other LCD's that the angle matters until I get annoyed and have to adjust something.  I had to schlep it to a friends briefly once, and there was much commentary on what a beauty she was even at 17", and I doubt anyone even realized how old it is.
I like the picture on the plasma's, but they suck up waaay to much electricity. My bill is high enough already that I am thinking about ways to get off the grid.  Plus they get REALLY hot, which makes me think that the electronics inside are not going to take that kind of punishment well after awhile.  Nice picture though.
Won't be going in for the whole 3D tv thing, though.  I think there is very little that needs to be 3-D on tv, if anything.  Anybody think that is gonna take off or what?
« Last Edit: Mon, 20 September 2010, 20:03:41 by Voixdelion »
"The more you tolerate each other, the less enforcement will happen."-iMav
Offline Rajagra
« Reply #18 on: Mon, 20 September 2010, 20:26:03 »
Quote from: Voixdelion;225024
When Internet porn is mostly 3D, TV will follow suit.
I can't see it being truly successful until they get rid of the glasses though. It's bad enough trying to find the remote without something else to look for.
Offline Voixdelion
« Reply #19 on: Mon, 20 September 2010, 20:30:37 »
Also just my two cents on 2 things in the OP:
1- CRT is plenty pretty but I think gone the way of the Dinosaur just because of the bulk issue.  My mom got her widescreen flatscreen crt Bravia for a song when Frye's was trying to get rid of em. It was actually on the ground, on a bottom shelf but both my Mom and I were attracted to the picture such that we both independently ended up in front of it despite that we weren't even shopping for a tv that day.  The thing actually dropped another $130 bucks off the price in the two days between our deciding she should snag it and the time she could arrange for it to be delivered, hence saving even more.  She had been toying with the idea of getting an HD but hadn't jumped in on the skinny sets because the picture left something to be desired on the LCD's and the Plasma was too hoggy on the juice.  Since the TV was going into a spot that wouldn't matter about the depth of the set anyway, it was the perfect solution.  (Plus she has the peace of mind that even if someone thief breaks in there's no way in hell that set is going anywhere unless they brought a crew of 4 to pick it up.  Its a BEAST easily over 2 maybe  even  3 hundred pounds.  A 1080p HD set with gorgeous picture and excellent sound quality for under 500 bucks with anti-theft built in.  Not bad for an impulse buy. )
If you have the space and aren't needing it to be easily moved and can actually find one for sale, I've never heard any complaints about CRTs picture-wise.  But when they begin aging they do start to darken or what have you.  They are a chunk of change cheaper than the comparable LCD variety in the same size, but End of Life in tech which may be problematic for longevity maintenance.
2- Projection screen tvs are always leaving something to be desired in terms of clarity. I have not yet seen a projection screen tv that even comes close to the picture quality of any CRT.  The main benefit, I think, is a size/cost ratio advantage over the other options, but it is a tradeoff since it will never match the picture quality of its rivals.  What you save in $ will cost in clarity.  I would rather a CRT than projection every time.
Offline Voixdelion
« Reply #20 on: Mon, 20 September 2010, 20:35:20 »
Quote from: Rajagra;225029
EEeeeewww!- gives new meaning to the phrase "Comin' atchya!"
Plus I read that some people have motion sickness issues/headache. and some percentage of people can't actually use the glasses at all due to the fact that its taxing on the synapses to sync images in the brain.  Frankly, I just don't think it all that nifty or adds much unless its specifically designed to be a blockbuster special effects bonanza.  Even then, it still needs story, so I think 3DTV I don't need, maybe don't even want.  Certainly not in porn.  Ugh.
« Last Edit: Mon, 20 September 2010, 20:41:14 by Voixdelion »
Offline Lanx
« Reply #21 on: Mon, 20 September 2010, 20:44:02 »
roger ebert on 3d
"IT’S THE WASTE OF A DIMENSION. When you look at a 2-D movie, it’s already in 3-D as far as your mind is concerned. When you see Lawrence of Arabia growing from a speck as he rides toward you across the desert, are you thinking, “Look how slowly he grows against the horizon”? Our minds use the principle of perspective to provide the third dimension. Adding one artificially can make the illusion less convincing."
seeing this i agree, and even tho he's a critic, i mean he has prolly logged more movie hours than 10 of the laziest couch potatoes.
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #22 on: Mon, 20 September 2010, 20:50:33 »
I would recommend getting a used TV. There's a lot of great stuff out by the side of the road there that people just throw away. I bet you could probably get 5 working televisions if you took a good look around town.
Offline Arc'xer
« Reply #23 on: Mon, 20 September 2010, 22:57:54 »
Ah, good ole' salesman, trying to "help". Most refresh rate technologies are lies to the consumers, using motion interpolation. There is black frame insertion and the other one is the motion predictor which often gives the soap opera effect.
Black screen insertion adds a black screen in place of the real refresh i.e. 120hz or 1000/120 = 8.33ms, a black frame is added that gives an illusion of smoother motion by tricking your eyes with the black frame and when the next frame hits your eyes it looks sharp, clear, and new. Ironically this motion interpolation is preferred by most people because it mimics the CRT refresh rate in reverse. See a CRT image decays and so the image is refreshed and redrawn so it pretty much stays in your eyes fresh so it look good.
The next one is probably more true to being an interpolation than the previous. It literally cuts out parts of the frame and draws them ahead in a new made image. For example a soccer player kicking a ball, there would literally be a fake leg in between frames. People call it a soap opera because they are seeing the frames being created individually and are acting as anomalies which people can see. And it's ironic because most people will say the human eye can't see more than 30 frames per second or whatever it is that bull**** myth that keeps popping around. And what's more this motion interpolate adds a ****load of input lag.
Only the 3D TVs with shutters are real 120hz accepting a 120hz signal from a source but not all 3D TVs are real some use tricks for 3D.
Most TVs are still actually 60hz(60Hz signal/30FPS) with 240hz motion interpolation. See 60Hz is 1000/60 = 16.68 millisecond(rounded up), the image is redrawn 60 times a second and the millisecond is the pixel update time. This is different from response time which is the amount of time it takes a pixel to change state for example a CRT of good quality usually operates in the low microsecond even nanoseconds.
See most broadcast frame rates are 30 frames per second. So in essence, each frame is being redrawn twice because 30FPS is 1000/30 = 33.33ms so there is an additional update per unique frame.
The reason why 120, 240, 480 are used is because they are equal divisors of lower frame rates. If real then there is a big difference compared to motion interpolation. The sad thing is most people have never experienced higher refresh rates than 90, so many people are so used to 60Hz.
Let's take 240Hz for example. Let's say you had a television with real 240Hz; let's go ahead and say it's an OLED television with ultra-low microsecond response time.
Let's clear something up:
1. Response time is simply the amount of time it takes the pixels to change state. i.e. say a high-end CRT it's electron gun operates in 10-20 nanoseconds but the phosphor say takes 150-200 microseconds to change state, ignoring phosphor decay FYI.
2.Refresh rate is the amount of times an image is drawn and or redrawn and also dictates the pixels change state of a frame. i.e. 90FPS(1000/90 = 11.1ms) with say 90Hz, so every 11.1 millisecond the pixels change state or should I say every 11.1ms an image is drawn or refreshed(if we used 180Hz, twice as much as 90 then it would refresh at 5.57ms), while the pixels themselves are able to change state as fast as say 120 microseconds.
First 1000/240 = 4.68ms(rounded up), this means that every about 4 milliseconds a frame is drawn or refreshed.
Let's say your watching a blu-ray film at 24P(24 frames per second; progressive scan); 240/24 = 10. The first frame is a unique frame, the next 9 frames are refreshes of the original. 10 refreshes x 24 frames = 240. If we used 30/60 as common then it's 2 refreshes x 30 = 60.
The whole divisor thing also works in another way. Say you had 480 frames per second in a game but your monitor is 120hz. If you get 480/120 = 4, so in essence your seeing 120 frames per second of 1/4th tears of 480. So even though your not seeing 480 frames per second individually or complete, your still seeing 1/4th of 480 frames per second clustered into 120 complete frames. Which is why serious/hardcore/pro gamers don't use v-sync because the game's feeling still changes despite not having complete frames both the game and the feeling of the mouse.
So in essence refresh rate is not just a to show a single image but also acts as a divider to less or more frames. So with less an equal say 30 and 120, there is enough refresh rate to show a complete frame and thus the images are simply refreshed. But if you have more than the refresh rate the complete frames drawn by the GPU are simply cut up and you see tearing in game because your only seeing a partial frame.
But now if you add more frame rates your opening up a whole new can of worms. Because it just makes things so much better but that is more so to gaming rather than films as higher frame rates slows down the film due to the way they are shot.
If your wondering redrawing the image with say a 30FPS source and 120hz, the image is updated more often despite being lower frame rate. And thus there is a smoother transition in between frames. Though the transition is more smoother with actual individual frames 120 with 120, even with less and equal it's still benefits the movements.
3D television is a good thing but not for obvious reasons.
First my view on 3D is that it is a gimmick, not fake. Just not my thing nor is it gonna be popular.
But it's a good thing because it pisses the living **** out of manufacturers because people complain that LCDs response time are too slow and causing issues. So it forces manufacturer to go to OLED or risk losing money. In fact most people don't realize just how much response time LCD monitors/televisions have they see 2-5 GtG, WtW, and BtB but what about the other colors. Those numbers are anywhere between 15-100+ms depending on color and that is on top of the 60Hz standard refresh rate so 16.68ms + response time.
It forces manufacturers to introduce higher refresh rates, for far too long refresh rates have been ignored. Even just a few refresh rates higher makes a difference, just going from 60 to 75 or 75 to 85 is noticeable. Though I'd say 90Hz should have been more standard because it's equal to the 30FPS when watching movies and clips online and whatnot.
It was only until last year 2009, that the first 120hz LCD monitors and later on in 2010 more LCD monitors and a few televisions with real refresh rates came out. It's like, really that goddamn long?. CRTs have had very high refresh rates in particular to high-end consumer CRTs even at respectable resolutions.
Do you know how many would have killed just to have say 90Hz on a 2560x1600 or 1920x1080/1200 monitor. Just a little extra bit that makes a difference.
A great example is this 1280x1024 Hanns-G LCD monitor I bought back in like '07 or so. Unfortunately it was a HORRIBLE TN panel but it had 85Hz over VGA. And it felt a lot smoother than LCD I had previously used. So just that little extra helped. It might have been an utterly horrible panel that had black levels so crushed you could run in front of me in a game that is dark and I wouldn't see you. But the refresh rate more than made up for it.
So the whole 3D is a last hurrah for the manufacturers to gouge people with LCDs before moving into OLED. LCDs have been manufactured for so long that moving into OLED is gonna cost them so much money so they'd rather eek out the last few dollars before people realize just how bad LCDs are.
Also I noticed a lot of talk on LEDs. I wanted to point something out to those who think LEDs are different. They aren't in fact some people believe LEDs are something new and don't realize it's just a backlight. Not just that but I've even read of salesman lying to consumers saying LED = OLED when it's not absolutely not.
LED is simply a backlight like CCFL. LEDs do not improve anything except power consumption and being thinner. The most common use is edge-lit which is the same **** as CCFL light.
LEDs don't improve the monitor images. In fact it can actually harm the image because the white point of the LEDs is usually around 9300K which makes the whites bluer rather than the more standard 6500K white point that is used in calibration for monitors.
The other method is local dimming. Now this method does make a difference and certainly helps a lot. But your not gonna see this on LED monitors and it's usually priced at a premium. But it's still not gonna be a complete solution.
But again LEDs aren't gonna help with image quality.
Remember they are still LCDs, they are still indirect lit. No matter what you do to improve the light it's still gonna bleed through. So no real blacks, it's gonna be grey and black crushed due to the inherent flaws in LCD panels.
Offline Voixdelion
« Reply #24 on: Tue, 21 September 2010, 00:37:13 »
I actually need to re-read that again to get my head around it, I'm not  quite getting about the refresh rates but thats not the first  explanation of that which has gone over my head, so it's probably my  comprehension at issue, not the explanation.  But I picked up a couple  things that struck a familiar chord from the discussion I had with the  salesman.
"Local dimming" was the issue of note. Which means I was looking at an  8500 series tv, not 8000 apparently.  I do know that it was a true  backlit (as opposed to edge lit) with localized dimming and I just  wanted to reach right into the screen it looked so real.  According to  ad specs Samsung has something called "Auto Motion Plus frame  interpolation technology that has a true 240Hz  refresh rate"  - this is what I was trying to reference originally.   Is this good? It looked good...  actually it looked spectacular.
 I'm not clear on whether the 8500 is the same as the 9000 series since I  didn't research it other than to figure out what it was I'd seen. It  was several thousand dollars so I wouldn't be in the market for one of  these right now, but I wanted to note what it was for when I was ready  to start  checking things off the wish list.   Til then I am actually still quite  pleased with the picture quality on my Sony Trinitron CRT.  I'd still be  singing SONY's praises if they hadn't had so many reliability problems  and such a bad attitude towards us loyal customers who have been paying a  premium for their products for years.  I wouldn't have started  complaining if the 35" I bought in 98 would have kept working at least  through '06, or even if the 36" I bought used to replace it had worked  at all when I got it home. I'm not using the one I got to replace that  one much, but I'm kind of afraid I'll kill it if I do, and  I can't  afford the Sammy yet.  Its not as HD spiffy as my mom's Bravia - which  kicks ass - but its good enough for me till I can afford something like  that Samsung.  It looked 3D without the glasses. (and I never really considered that whole wasted dimension thing, but it's an excellent point.)  If I'm gonna get a new set that costs a good chunk of  change anyway, I don't think I'd be happy with something less expensive  now that I've seen that one.  Samsung has at least earned my respect  with the experience I've had with my syncmaster.  I like their cell  phones too.
So actually yes  - why not get a used tv as suggested?  Especially if considering CRT since tons of people are dumping theirs in favor of the flatter kind.  Good quality to be found for cheap I would think...Recently Chad picked up a nearly new 46" HD LCD thing for 4 or 5 hundred on craigslist from someone who was either desperately in need of cash or found one that "fell off a truck."
Offline Arc'xer
« Reply #25 on: Tue, 21 September 2010, 03:59:51 »
There is no way a television can have 240Hz/480Hz/600Hz as of right now.
This is a great explanation especially of how plasmas work. http://www.best-3dtvs.com/guides/what-does-600hz-sub-field-drive-mean/
Basically with plasmas the refresh rate is decoupled from the pixel update. So in essence there is two different refresh rate except one draws the image. The other just refreshes the pixels independently of that image. One of the reasons why burn-in doesn't happen much because the image is being constantly forced to refresh kinda like a CRT except the CRT has an upper hand in that the refresh rate of the image is able to be increased and not just stay stuck at 60hz. Albeit the plasmas constant update independent of refresh rate is rather interesting in combating phosphor decay and flickering.
There is absolutely no way the bandwidth exists to provide 240Hz nor especially 480Hz. To have said display you need to have some sort of prototype like the SED/FED monitors which unfortunately the technology seems to be pretty dead due to legal issues and monetary issues. Or some old school high-end CRT probably with a 400-500+Mhz ramdac or professional display but most likely being CRT. And both would probably be very low resolutions.
What you are seeing is a motion interpolation doing one of two things. Black frame insertion or the interpolation of new frames in between transition period.
Black frame insertion is the reverse of a standard refresh rate so it acts more like a standard style CRT refresh rate. People prefer this because for a very small period of time your eyes are shown black and it forces your eyes to re-adjust to the next image, making the next image look fresh and with less blur. It was also done earlier on to give LCD liquid crystals time to fully change state or at least have them be ready for the next frame. Despite LCDs being incapable of true blacks, surprisingly they can change states of black quickly.
On a standard refresh rate with decay say a CRT or non sample-and-hold technology. The image fades until it is rescanned hence refreshed or a new image is drawn.
Unless a black image is shown on a CRT then it doesn't fade completely away.
BFI, works the opposite by refreshing the display on a standard 60Hz(16.68ms). But on the 120hz i.e. 8.36ms it's a black frame. So while the LCD displays 120 frames, 60 are just black and the other 60 are real.
The other one the interpolater literally pulls sections of the images to create new images. So when something happens it fills up the area in between the transitions. So 120Hz Motion Plus is really 60 real frames, with 60 guessed frames. With the guessed frames being once every 8.36ms apart.
A real refresh rate is redrawing the image or drawing a new image. It's meant to make the transitioning periods between frame rates appear more life-like. Remember while light isn't technically instantaneous neither are displays so a refresh rate a real one is merely trying to provide a more updated image.
So let's say you get a real 120hz display, 120 divides evenly into many standard signals like Blu-ray 24p, standard signal 30p. It literally refreshes the image truthfully i.e. 1000/120 = 8.33ms so it updates twice as fast as a 60hz display. The effect is more pronounced when you approach or reach 120 frames per second.
Because instead of dividing say a television channel 30p, 4 times. 1 unique frame drawn, 3 refreshes once every 8.33ms despite the frame rate being 30FPS(33.33ms) the unique images are spread across 120Hz and so to fully provide a per 1000ms(1 second) 30 frame rate. The unique frame is first drawn then refreshed until the next unique frame is drawn based on the refresh rate as said above.
But when you have 120FPS/120hz, your now drawing a unique frame every 8.33ms, instead of just refreshing the same unique image until the time for the next unique frame comes in.
Offline Arc'xer
« Reply #26 on: Tue, 21 September 2010, 04:21:56 »
This is an interesting video I found a while back explaining quite a lot.
Basically we use gimmicks to alleviate issues with response time. Or should I say the inherent flaws in LCDs that cannot be fixed. Maybe blue phase, but with OLED right around the corner gonna be tough.
Frame rates as in the video is another raising the frame rates is another good option. Albeit they need to fix the issue with slow-mo and higher frame rates for the source.
Sheer fact is it's 2010 LCDs have been around since the 60s-70s in prototypes and commercially available since late-80s. And yet they still cannot be fixed and they've subdivided the market into segments of different panels(TN, MVA, IPS etc.etc.) and made consumers into fools.
Some people don't care but the ones that do care i.e. the rare informed consumer pays attention to these things. I'm not  trying to completely bash LCD technology it has it's fine points but it's like come on. Even after all these years you still sell people 6bit+2bit dithering panels, that mimics RGBA and even then most consumer panels stay within 60-79% RGBA coverage. And if you want to reach at least true 100% RGBA, you not only pay a premium but have a slower response time and even then your blacks are still grey and crushed, no matter what an indirect light will bleed on some level.
So while LCDs have advanced a lot and are quite close, there are still those who choose to understand and continue to wonder why there isn't anything better.
« Last Edit: Tue, 21 September 2010, 04:40:31 by Arc'xer »
Offline itlnstln
« Reply #27 on: Tue, 21 September 2010, 07:54:38 »
Jesus, this isn't an essay contest.
Offline Rajagra
« Reply #28 on: Tue, 21 September 2010, 09:35:55 »
Seems to me most of the benefits of increased frame rates are pure hype. Unless the source material is recorded at those rates. Motion prediction is simply unneeded except to create an illusion of better quality (when it is lucky enough to work.) And black frame insertion? How cynical is that?
Everyone seems to ignore one important fact. Human eyes are good at detecting brief flashes of light. You can see a flashgun go off even if it only lasts 1/10,000s. But they are not good at detecting the opposite - if a light was shone in your eyes continuously but blocked for 1/10,000s, you wouldn't notice it. That's a consequence of the bleaching effect that underlies vision.
So I maintain that if you have a 30Hz screen and 60Hz source video, you can add together the bright areas from 2 adjacent frames, show 30 of those combo frames per second (so a footballer kicking would have one leg shown twice in one frame) and it would look nearly as good as a true 60Hz screen.
Personally, I think even that is irrelevant. I still passionately hate seeing the strobing effect that comes from high shutter speeds. If the frame rate is 30Hz, just use a 1/30 shutter speed FFS, the smoothing effect looks infinitely better than showing a 1/1000s snapshot taken every 1/30s. Sure still frames are less 'detailed', but are we recording photos or video? The answer should tell you what looks better. High shutter speeds are sampling very little of the whole timescale, slow shutter speeds are sampling more, if not all of the time.
Another idea I've been toying with is how to best treat captured video, with a mind on how it can be converted between different frame rates and resolutions later. I think the key lies in how the data is compressed - and let's face it, compression is going to happen one way or another. When you record something, you are sampling reality, with infinite resolution and frame rate, and recording it with very finite resolution and frame rate. I think the trick is to stop treating the information as a series of images. Instead, treat the view of reality over time as a 3D space, with two dimensions representing those of the captured view, and the 3rd dimension representing time. Imagine a series of frames put onto slides which are then stacked - that is the kind of 3D object I mean. What needs to be done is to use a compression method that treats the recorded frames as samples of the 3D object. Mathematically compress what you think the 3D object is, not the individual samples. That way you end up with compressed data independent of resolution and frame rate info altogether. You can later display it at any resolution and frame rate your equipment supports, though it will obviously be best if you match the original sampling method.
Did someone say something about essays?
« Last Edit: Tue, 21 September 2010, 09:39:31 by Rajagra »
Offline itlnstln
« Reply #29 on: Tue, 21 September 2010, 09:36:58 »
Well, maybe it is.
Offline Arc'xer
« Reply #30 on: Tue, 21 September 2010, 12:12:46 »
Quote from: Rajagra;225135
I was actually trying to say that we benefit more from real refresh rate rather than fake.
This is one of the reasons why I like 3D televisions. But not for 3D just for 2D enhancement. Why buy a real 120hz refresh rate monitor/television only to use it for 60Hz viewing.
And I'm not merely speaking gaming wise, I mean everything wise gets a benefit.
For the future, I'd rather see a stroboscopic refresh rate, were the entire frame is drawn/refreshed at once. Instead of the whole progressive scan or interlacing. That way there is a smoother transition between frames whether unique frames or refresh frame.
« Reply #31 on: Tue, 21 September 2010, 12:18:40 »
basically, if I could afford the 65" VT25 (panny 3d plasma) that would be end of story. I cant though.
I dont want an LED backlit tv that has more flaws than a CCFL - which is most of them - despite what "salesguys" will tell you. LED is just a backlight technology. CCFL is perfectly capable, the numbers on the sony 60EX500 im looking at rival plasmas for black level and have great contrast.
I dont want 240HZ of fake motion, and I would prefer something that doesnt require 3:2 pulldown (the panny im looking at does 48hz for 24p content, but I heard it's flicker is noticeable).
So ... im not buying till December, Ill def keep my eyes peeled for any new sets coming out.
Offline TheSoulhunter
  • ~ BOOO ~
« Reply #32 on: Tue, 21 September 2010, 14:45:29 »
Huge, solid black level, uniform screen, good color, no lag?
That's basically where plasmas are better than LCDs...
LCD user here btw,
but that's just because I need the higher resolution (PC),
and also because I can't (don't want to...) afford a Kuro!
A Ghost From The Past
Offline didjamatic
« Reply #33 on: Tue, 21 September 2010, 15:14:42 »
Beats my 32" CRT in an Entertainment cabinet.  I'm a lackie when it comes to home audio/video.
EDIT: Ever had to move an extremely large CRT TV?  Myself and 3 other guys injured ourselves (really) moving a single TV for a nice elderly man who was moving in our neighborhood.  It was the biggest CRT I've ever seen, AT LEAST 42" - I didn't even know they existed that big.  The freaking stand was barely movable with 2 guys.
« Last Edit: Tue, 21 September 2010, 15:18:17 by didjamatic »
« Reply #34 on: Tue, 21 September 2010, 18:45:43 »
You should've got a forklift for that. Or towed it with a tractor.
Offline Mercen_505
« Reply #35 on: Tue, 21 September 2010, 19:48:25 »
Throw some heavy curtains over the windows, mount a HD projector, and rock out to a massive screen. Mine's 93" diagonal. You get some benefits besides the obvious:
+ Excellent scaler means anything you put on it looks fantastic. I've got an HTPC (serving up MAME, emulators, and rips), Wii, Dreamcast, PS2, and Xbox hooked to it, and everything looks gorgeous.
+ No lag. No ghosting.
+ HD content looks ****ing nuts when it's covering your entire wall. Truly.
But...
- Requires infrequent maintenance. Keep those filters clean!
- Bulbs need replacement ~ every 3000 hours of use. That's a long time, but still...
- Ambient light degrades the picture, but not as much as you might imagine.
- Once you go projector, you never go back. Seriously; never.
« Reply #36 on: Wed, 22 September 2010, 06:25:27 »
Quote from: Mercen_505;225273
But...
Can't do yet my friend ...
yet.
« Reply #37 on: Wed, 22 September 2010, 06:30:22 »
Quote from: ripster;225206
Threads like this depress me.  I have a Sharp 32" LCD that my wife forces us to keep in an Entertainment cabinet.
HATE entertainment cabinets, almost as much as I hate fireplaces with tvs mounted above them.
Offline itlnstln
« Reply #38 on: Wed, 22 September 2010, 06:46:03 »
Quote from: instantkamera;225326
Agreed 100%.  Especially the fireplace part.  I couldn't think of a worse place for a television.  Chiropractors might like it, though, with all the neck-strain patients they must get.
Offline Voixdelion
« Reply #39 on: Wed, 22 September 2010, 14:29:07 »
Quote from: didjamatic;225211
Takes a dolly and 3 or 4 smallish puny people to move my Trinitrons (2 if one is my boyfriend + someone willing to risk a hernia...)  Having moved several times since I got the first and acquiring the other to replace it plus another to replace the replacement, at least we are getting it down to a science.  Gorgeous picture, though.  And people are practically leaving em on the street lately...  Got the 36" (might be HD capable for resolution, but no tuner) last summer for a hundred bucks and found a volunteer with an SUV with removable rear seat to help fetch it.  Good deal.
I can say I've never been anything but delighted looking at it, but I don't do anything in blu-ray, just dvd.  In fact, I don't think I've ever watched a blu-ray disc anywhere else either.    We do watch Smallville in 1080p on Moms tv though.  I really have to watch the HD version since the regular looks like crap comparatively on the HD screen vs the regular tv.  It actually too bad Sony stopped with the making things to last since I've never felt the need to upgrade from that picture-wise and would be content for quite some time.  That Samsung is a pipe-dream which will be well out of reach for a while....
Have fun shopping, though.  Let us know what you finally come up with as your choice.
« Last Edit: Wed, 22 September 2010, 14:42:40 by Voixdelion »
« Reply #40 on: Wed, 22 September 2010, 15:29:34 »
Quote from: ripster;225485
You should marry my wife.
We do have a very nice fireplace.  Got my cord stacked and ready to go for the winter.  And a dog.  And hot rum.  And a copy of a 1000 page book (Pillars of the Earth).  And a very nice wife (except for that entertainment cabinet thing).
Thanks but Im perfectly happy with my wife.
We have a new house that lacks a fireplace (as most houses had a fireplace consuming precious space in the basement), but with central air and a brand new furnace. And a dog. And any alcoholic beverage you can imagine. And many books, both digital and hard-copy. My wife is pro-big-tv-over-50"-in-dedicated-"cave" (aka anti-32"-in-entertainment-stand) too as she watches HNIC with me all winter, hence my search :P
Offline itlnstln
« Reply #41 on: Wed, 22 September 2010, 15:44:48 »
Quote from: instantkamera;225491
HNIC
Offline itlnstln
« Reply #42 on: Wed, 22 September 2010, 15:56:15 »
I didn't realize he was from Canada.  I used to watch ESPN's version of Hockey Night, but since ESPN dropped the NHL and I live in TX, it's a real treat to watch hockey at all.  VS is OK (and pretty much have all the old ESPN staff), but they don't play anywhere near as many games as ESPN did back in the day.
« Reply #43 on: Thu, 23 September 2010, 07:27:31 »
Quote from: ripster;225502
Next she woulda said, "Honey, let's go downstairs and watch some curling".
We're Canadian, How else would we get our rocks off? HURRY HAAAAAAAAAAAARD!
Offline itlnstln
« Reply #44 on: Thu, 23 September 2010, 07:54:28 »
Well done.
Offline ricercar
  • mostly abides
« Reply #45 on: Thu, 23 September 2010, 15:23:36 »
Been there. Done that. ...
Offline firestorm
« Reply #46 on: Tue, 28 September 2010, 12:04:02 »
Great thread.  On other forums, I usually come in a couple days late to raise the flag for plasmas.  Sometimes I fear that plasma will die off, or become a niche product, just based on the threads I come across.
What I love about plasma is, it doesn't rely on tricks for anything and they're typically slightly cheaper.  There are no lag issues; no motion blur issues; no soap opera effect; nothing of the sort.  The only feature that is remotely within that realm that is at all useful for plasma (IMHO) is 3:2 pull down to avoid telecine judder.  But that is true of any TV and that judder is something every person is accustomed to seeing.  Most people don't realize (or care) that it is an "issue".  IIRC, it's not even an issue if you have a 1080p/24 source and a 1080p/24 capable display.
As already mentioned, LCD excels in small displays and in rooms with extraordinary amounts of ambient light and poor light control.  They are also better for computer displays.
FWIW, when I first powered on our Panasonic TH-50PZ80U, it immediately displayed a question asking whether we were in a "Home" or "Store".  It was essentially asking whether to default to break-in settings or "torched" (aka Store) mode where settings are set to an extreme to give the most vibrant picture in stores.  At that time, Panasonic recommended 100 hours to break-in, but I now believe that wasn't necessary.  Regardless, we have never had any Image Retention, let alone burn-in.
Offline NamelessPFG
« Reply #47 on: Tue, 28 September 2010, 13:08:48 »
If I had an unlimited budget: Rear-projection laser DLP, like the Mitsubishi LaserVue L65-A90.
If I didn't: Aperture grille HD CRT, likely a Sony Trinitron WEGA XBR960 if I can find one.
The main things I want are no/negligible input lag, excellent all-round image quality, no resolution rescaling artifacts, and if by the slightest chance possible, a SCART or RGB21 input for my classic consoles.
Also, for PC use, it is important that displays that support higher refresh rates actually accept input signals that refresh that high. If I have a PC that can run a game at 120 FPS, I expect to see all 120 frames per second on that monitor. Unfortunately, HDTVs don't seem to take that into account-not even the L65-A90.
Existing media made for 29.5 or 60 FPS, such as movies, are not that much of a concern to me.
« Reply #48 on: Tue, 28 September 2010, 14:27:25 »
Quote from: instantkamera;225700
If you live up in Canada, why do you bother with air conditioning? I'd definitely rather have a fireplace up there!
« Reply #49 on: Thu, 30 September 2010, 11:47:16 »
Quote from: microsoft windows;227691
Thanks, I'll make sure install one toot sweet.
