Author Topic: [IC] Ex Idol - Has now been open-sourced.  (Read 51483 times)
Offline Lil
    • designedbydark
« on: Fri, 20 May 2022, 19:10:52 »
Ex: Idol [Open sourced]
Stay up to date with this and my other projects - by joining my discord, linked here: https://discord.gg/5EHyfwCchZ
Open sourced here: LINK TO GITHUB
Specifications
.F12 layout TKL, WKL + WK. Changed to F12 in the open sourced version.
.9 Degree typing angle and below 17.5mm adjusted front height [front height measured from the inside of the bezel to the bottom of the case]
.Top mount variation based on the 'ecliptica' plate. Stylised for this keyboard.
.Large through-weight
.Easy to pick up due to the side profile/bottom shape
.Original design yet reminscent of the styling of KPOP themed boards; faithful as an evolution to the spirit of the design language inherited from the Camp C225 Keyboard
Inspiration
Typing test by Shoobs of V1 using bumpon mounting
« Last Edit: Thu, 14 December 2023, 02:20:46 by Lil »
Offline Lil
    • designedbydark
Re: [IC] Ex Idol - [TKL] Next generation mounting method
« Reply #1 on: Fri, 20 May 2022, 19:12:02 »
RESERVED
Offline ankit
  • Formerly ankit-sachdeva
« Reply #2 on: Fri, 20 May 2022, 19:15:00 »
I love you dark.
« Last Edit: Sun, 06 November 2022, 15:48:53 by ankit »
Offline Gondolindrim
    • My GitHub
« Reply #3 on: Fri, 20 May 2022, 19:15:44 »
Let's goooo
A pessimist will tell you the cup is half empty. An optimist will tell you the cup is half full. An engineer will tell you it's exactly twice the size it needs to be.
Offline chat and team
« Reply #4 on: Fri, 20 May 2022, 19:17:59 »
sick mounting, estimated price?
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Diggidy
« Reply #5 on: Fri, 20 May 2022, 19:23:32 »
« Last Edit: Fri, 20 October 2023, 05:41:28 by Diggidy »
Offline caap
« Reply #6 on: Fri, 20 May 2022, 19:25:23 »
nicely written IC, good work on the board! :thumb:
excited for the public buy!
Offline 7empest
  • ༼ つ ◕ ◕ ༽つ
« Reply #7 on: Fri, 20 May 2022, 19:28:17 »
the plate on this board looks amazing. i love it! great stuff
Offline Hinkerbottom
« Reply #8 on: Fri, 20 May 2022, 19:29:28 »
Let’s goooo Dark, consider me in :)
Offline Zeelobby
« Reply #9 on: Fri, 20 May 2022, 19:30:45 »
Awesome stuff. As always. Pushing that design limit
Sent from my Pixel 3 XL using Tapatalk
Offline SDKCAMPING
« Reply #10 on: Fri, 20 May 2022, 19:32:35 »
i don't know how effective those leaf springs will be on the bottom two mounting points considering the point is directly mounted to the plate avoiding the spring, but cool none the less with the bumpons,
The bottom shape is not my style, feels a little weird and forced or something not sure. but really I don't think this board shares any similar design to most of the K-pop boards i know like the jinsoul or IU or RBB, those have the simple and clean design but not very original, while this one is original but it looks kind of unsure or lost in what it wants to look like if that makes sense. maybe the one trait they share is a K-pop engraving
« Last Edit: Fri, 20 May 2022, 23:02:17 by SDKCAMPING »
Blue Gray Ciel 60 with BCPs | E-white 7V (plateless) with Aqua Kings
Offline fropsie
« Reply #11 on: Fri, 20 May 2022, 19:45:27 »
Dark so stinky. Good thing the work is good  :)
« Reply #12 on: Fri, 20 May 2022, 19:48:30 »
taking the under on this one making it past GB based on your previous projects, also taking the under on this board feeling notably different from other gasket mount leaf spring boards
but the plate looks cool, shame it goes inside the board where i will never see it
« Last Edit: Fri, 20 May 2022, 19:50:43 by Puddsy »
Offline Lil
    • designedbydark
« Reply #13 on: Fri, 20 May 2022, 19:59:06 »
Your lack of reading comprehension never fails to amaze me
« Reply #14 on: Fri, 20 May 2022, 20:06:04 »
what am i not comprehending
there's no gb date or info in post (except that it might be private gb, at which point, why make a GH post), no clear testimony about the feel, and i can't see the plate in the photos where the board is put together
« Last Edit: Fri, 20 May 2022, 20:07:43 by Puddsy »
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #15 on: Fri, 20 May 2022, 20:13:28 »
These naming schemes are always so odd all I can think about is how the designer has most absolutely definitely whacked it to the idol these names are based off of
Bumpon mount is neat and paired with spring leaf I can see how you want something a little more stuff like a bumpon but I can't imagine it makes that drastic of a different over it being screws into a post. At least you can replace the bumpon with harder/softer materials? Still very complicated.
« Reply #16 on: Fri, 20 May 2022, 20:15:14 »
rare kokaloo puddsy agreement
Offline Lil
    • designedbydark
« Reply #17 on: Fri, 20 May 2022, 20:19:55 »
In the first paragraph of the post I state I have successfully run and delivered 4 GBs/projects/private buys in a row (Since mid 2021), and you are saying based on this you think it's unlikely I will be able to successfully run a public GB.
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #18 on: Fri, 20 May 2022, 20:21:48 »
Christ look at all those typos how embarrassing
« Reply #19 on: Fri, 20 May 2022, 20:22:49 »
https://geekhack.org/index.php?topic=110579.msg3000385#msg3000385
https://geekhack.org/index.php?topic=111859.msg3027892#msg3027892
https://geekhack.org/index.php?topic=113347.msg3058625#msg3058625
https://geekhack.org/index.php?topic=114305.msg3076945#msg3076945
Offline Lil
    • designedbydark
« Reply #20 on: Fri, 20 May 2022, 20:27:46 »
Yes, my first keyboard design failed. All the rest are keysets which I shelved in order to focus on keyboards.
The past 4 keyboard GBs have all been made, and have been delivered or are currently being delivered.
There isn't any other designer in this hobby that has turned around so many self run projects in the same time frame.
If you continue to try to baselessly throw mud at me trying to make something stick, just because you dislike me, you might find yourself regretting it.
« Reply #21 on: Fri, 20 May 2022, 20:32:17 »
Offline wigol2506
    • Instagram
« Reply #22 on: Fri, 20 May 2022, 20:44:18 »
Tbh your contention with Puddsy's opinion that this might not make it past GB based on your past projects having not gone past the GB stage is bewildering when its your own fact that you shelved those abovementioned projects after IC.
GLWIC tho
Nice design overall but indifferent about the plate design till a review on it is made.
https://www.flickr.com/photos/wigol2506/
Singa Ocelot R1 Prototype | Singa x TGR Unikorn R1 Prototype | Singa x TGR Unikorn R2.1 PC & FG | Singa Kyohaku | TGR Jane V2 CE | TGR Police | TGR 910 OG (01/23) |TGR 910RE PC | LZ Phase | LZ XE | LZ erGhost | LZ erGhost CL | LZ REs | LZ Trik X_T | LZ SQ | LZ GHv1 | LZ GHv2 |LZ Prism | Palmetto60 | HBCP | Ibis | No2Rev2 TKL Black Unfinished | 1/60 Rev. 1 | Keynergy Serratus Chrome | DNworks SBL (DN)
Offline shima
  • keeb weeb
« Reply #23 on: Fri, 20 May 2022, 20:58:40 »
ex idol so lit
boards: anura
Offline Yaezaki
« Reply #24 on: Fri, 20 May 2022, 21:10:52 »
sick mount bro, love to see this on live gb
Offline keyjemm
  • Gohnny#5371
« Reply #25 on: Fri, 20 May 2022, 21:16:23 »
yes yes yes yes yes yes yes yes .... yes
Consider ______
Offline Shoobs
« Reply #26 on: Fri, 20 May 2022, 21:19:42 »
I like it
Offline subieboobies
« Reply #27 on: Fri, 20 May 2022, 21:31:43 »
really liking the look of this, definitely interested if alternative engravings are available
Offline tngpq
« Reply #28 on: Fri, 20 May 2022, 21:50:11 »
It’s a leaf spring with bumpons. How innovative, lol.
Offline Screen.jing
« Reply #29 on: Fri, 20 May 2022, 21:51:10 »
Mr Dark i love you, i love this, good luck with this  :cool:
Too many projects going on at once
Papilio
MF60
Disco
Vlad
65
Adamo
Offline TypicalOranges
« Reply #30 on: Fri, 20 May 2022, 22:20:35 »
Have you guys done a fatigue analysis of the leaf spring?
Offline granola bar enthusiast
« Reply #31 on: Fri, 20 May 2022, 22:37:09 »
i feel this is less of a "next-generation mounting method" and more of a mod on the existing isolated gasket mount. Regardless a nice design
« Last Edit: Fri, 03 June 2022, 10:17:18 by granola bar enthusiast »
Offline LaserCrafter
  • reeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
« Reply #32 on: Fri, 20 May 2022, 22:37:53 »
i would take this over gasket mount poron foam pe foam meme boards
Keyboard Collection: Unikorn, Orion v1, Orion v3, Realforce 87u, Das II, 356mini, Wang 325-3770, Lightpad v2, Deko Fast Action
Keyset Collection: OG Doubleshots x2, CRP 2551 R4, Muted 2, Cyan R1, WoB, DCS Wyse, ISO OG POM, ePBT Blanks, BSP Blanks, BoW + Gigachild, Minimal R1, SAD Dyesubs,
Offline jrfhoutx
  • Post count is meaningless if the content is trash.
« Reply #33 on: Fri, 20 May 2022, 23:39:37 »
since these 4 projects were all private buys, out of curiosity, how many units of each were produced?
Offline FatefulStranger
« Reply #34 on: Fri, 20 May 2022, 23:43:37 »
This actually goes pretty hard, I dig it. Hope to see an estimated price for this cool board.
Offline dérobé
« Reply #35 on: Sat, 21 May 2022, 00:20:43 »
Very unique and cool looking board. Will be keeping up with this one.
Wish there was some more info on this IC though...
« Last Edit: Sat, 21 May 2022, 00:24:23 by dérobé »
Offline Sicowa
« Reply #36 on: Sat, 21 May 2022, 00:32:47 »
wickedge board dark,
glwic
Collection: Khajit 60, Leopold FC980C, Pepper, Ex. Visa, Daedalus
pfp:https://twitter.com/kuroseP/status/1305179874429079553?s=19
« Reply #37 on: Sat, 21 May 2022, 03:30:44 »
No puddsy!!! Ics should be friends of the TC and good comments only!!!! inb4 500+ for this
Offline linell
« Reply #38 on: Sat, 21 May 2022, 03:41:50 »
bumpon mount is hawt
bro this a **** set, just be thankful you even getting 1 base running fr
Offline zekkin
  • my entire life was unlimited zekk works
« Reply #39 on: Sat, 21 May 2022, 03:55:57 »
Been lurking around your socials and I'm really liking this, it's clear you put a lot of thought and work into it.
:thumb:
Offline unusuaL_
« Reply #40 on: Sat, 21 May 2022, 04:56:18 »
Happy to see visas' mounting on a TKL. I'm also really appreciating the distinguishable looks, as with your design language in general. GLWGB
collection: hibike 1/1, garderie tkl, casper60, hhkb pro2, matrix 2.0additional, f1-8x og
Offline Lil
    • designedbydark
« Reply #41 on: Sat, 21 May 2022, 06:18:20 »
Let's goooo
I like it
Thank you brothers for supporting me
Offline Lil
    • designedbydark
« Reply #42 on: Sat, 21 May 2022, 06:26:46 »
Thank you!
I love you dark.
Thanks for your kind words ankit
I love it - great design, the mounting method is very interesting.
Is the proto that shoobs built without the front lip? I agree that it definitely improves the overall look - given that the front bezels need to be so thick to accommodate for the mounts - and is probably more comfortable to type on as well.
Thank you, yes you are correct. It was without the lip and I feel like it would look better with it. The CCRX is used as an example of how it looks in real life. Since it doesn't affect the height of the keycaps it won't affect the typing experience, but I really like how it looks.
Thank you Yung Jing.
ex idol so lit
Fire emoji
yes
Ty. What information would you like to see?
Your interest has been noted.
glwic
Thank you.
Thank you. To be honest, for the first protoype, I only got a quote for one unit and not more. I am getting a quote with the changes, like changing to F13 and the lip etc for higher unit counts, I am aware that going with or without a vendor could impact the price by a large amount.
Understood, it should be possible to offer an alt version without
Thank you!
Pray Emoji
Thank you sir. I liked your hali collab
Offline Lil
    • designedbydark
« Reply #43 on: Sat, 21 May 2022, 06:33:00 »
:thumb:
I really appreciate you saying that! Your recognition means alot, like being complimented by a renowned sushi chef for my fish or something
Offline denibhoxha
  • cock and balls technology
« Reply #44 on: Sat, 21 May 2022, 07:41:43 »
Very cool seeing in detail how the bumpon mount works, really cool showcase Mr. Dark.
Offline CookieFlow
« Reply #45 on: Sat, 21 May 2022, 08:10:18 »
I'm really not a big TKL fan and I never understood these boards inspired by/designed for K-Pop and idols.
I really can't grasp the connection between the two.
But the board itself looks nice and the mounting looks fun (not sure it really feels any different than a regular leaf spring, but at least it's something a bit different), will keep an eye on the project  :thumb:
Offline Vigrith
« Reply #46 on: Sat, 21 May 2022, 08:29:36 »
Is this serious or satire? It better be satire LOL
PS: the whole thread reeks of discord. Unfortunate.
« Last Edit: Sat, 21 May 2022, 08:31:07 by Vigrith »
Offline Zeelobby
« Reply #47 on: Sat, 21 May 2022, 08:45:12 »
If you mean supporters from Lil's private buys are here to support this one, there's nothing shocking about that. If you mean drama carried over from discords, well they're kind of central to the hobby at this point. Agree the response was misplaced but not sure why "discord" = bad.
Offline Lil
    • designedbydark
« Reply #48 on: Sat, 21 May 2022, 08:55:33 »
Offline zekth
« Reply #49 on: Sat, 21 May 2022, 09:27:48 »
Mount looks sick
Inspiration / engraving total meh
[Changing to F13 from F12 in the second rendition/prototype]
RIP...
