Author Topic: [IC] ZB-7 : 75% Keyboard with extension modules  (Read 12042 times)
Offline BeOnIt
« on: Wed, 10 August 2022, 04:18:49 »
ZB-7
ZB-7 is a 75% keyboard coming up with extension modules connection on both left and right sides depending on your convenience.
With high free to use and layout customable, depend on user aptitudes, ZB-7 provides new experiences of feeling in usage and design.
290070-0
290072-1
The extension modules are Numpad and Knob available for now for your preference. Other extension modules also release soon.
290074-2
290076-3
DESIGN
The design is uplifting maturity and luxury with atmosphere of curcuit pattern, wiring, mechanical parts for users and collectors who love robotic and mechanic.
290078-4
290080-5
SPEC
Case Angle: 5°
Case Material: Aluminium
Dimension: 344mm x 142mm
Front Height:  ~21mm
Back Height:  ~32mm
Weight: 1.8kg (with 1 extension module)
Plate: Aluminium
Connectivity: USB type-c
Available extension modules: Numpad, Knob (Other extensions will be developed in the future)
Expected price: ~500USD
290082-6
290084-7
COLORS
Copper, Silver, Green
290086-8
KIT COMPONENTS
Standard Kits
Top Housing
Bottom Housing
Left Side Cover
Right Side Cover
Plate
PCB
Poron Foam Set
Screw Set
Extras
Numpad Module
Knob Module
290088-9
IC FORM
« Last Edit: Wed, 10 August 2022, 04:22:16 by BeOnIt »
Offline VXQN
Re: [IC] ZB-7 : 75% Keyboard with extension modules
« Reply #1 on: Wed, 10 August 2022, 08:45:43 »
Reserved.
500USD for something with as complicated design as that seems...implausible.
Offline panka
« Reply #2 on: Wed, 10 August 2022, 09:54:20 »
that sure is something
Offline P103
« Reply #3 on: Wed, 10 August 2022, 10:09:58 »
This feels like a project by someone that enjoys drawing CAD and that is all there is to it.
Offline chat and team
« Reply #4 on: Wed, 10 August 2022, 11:42:16 »
wheres the proto
geekhack mods constantly break tos and refuse to read
Chinese overlords won
Offline Nonnegaard
« Reply #5 on: Fri, 12 August 2022, 02:15:03 »
wheres the proto
because spending your hard-earned money on a one-off proto before gauging interest is now obligatory
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline InvXXVII
« Reply #6 on: Sun, 14 August 2022, 00:09:13 »
Need a touch screen module lol.
Offline Avantel
« Reply #7 on: Sun, 28 August 2022, 15:36:57 »
This looks incredible. Definitely would want to get one of these
Offline lw88
« Reply #8 on: Sun, 28 August 2022, 18:08:22 »
But why does it use plate mount stabilizers?
What?
Offline Ray Studio
  • A personal studio of architecture, jewelry etc.
« Reply #9 on: Tue, 30 August 2022, 09:21:57 »
I think I want it with the drawing pad function!
Offline herfalerf
« Reply #10 on: Tue, 30 August 2022, 15:15:31 »
wheres the proto
I mean you are more than welcome to support projects from unknown designers with 0 proof of concept.  Maybe you would be interested in a bridge I have for sale?
Offline Avantel
« Reply #11 on: Tue, 30 August 2022, 16:04:13 »
You aren't buying anything yet though, just expressing interest
Offline Avantel
« Reply #12 on: Sat, 03 December 2022, 16:29:32 »
sooooo, is there any update to this?
Offline Plurrkeebs
« Reply #13 on: Mon, 05 December 2022, 19:24:13 »
Someone likes spending hours in CAD or Fusion.
Offline Drew7822
« Reply #14 on: Tue, 20 December 2022, 13:52:42 »
Oh wow, I absolutely love this idea. Hopefully it comes through to fruition and I would get one!
Offline Its Salty
  • I have no idea what I'm doing
« Reply #15 on: Tue, 20 December 2022, 18:51:29 »
this is a neat design, that's for sure
I completely doubt the ability to paint, ano, etc. in that much detail for the tech geometry design
If you can create a proto sheet of that design, just like a small panel that has the cut and painted design. prove something like this is even possible for a not "sell your kidney" price point
there's no way this isnt going to require something like a 5 axis and a lot of QC on the finish to get this right
if you can prove you can even get this design past the render stage then this IC might look a lot more promising. but considering I'm only looking at renders of a case, no layout options, and an exploded view that makes it hard to see what kind of mounting system you're even planning on using. this is one big red flag right now.
