Author Topic: [IC] Ayleen TKL 丨 Top + Oring, Productions Pics Updated, In-Stock Drop Dec 21st  (Read 60891 times)
Offline TheColaMan
Hi Everyone, this is the first ever project from Tea House. We would call it the classic inspired, no-nonsense F13 88% TKL - Ayleen.
A little bit of back story: there is not really a theme when it comes to Ayleen.
The name was picked simply because designer and I feel this is just the right one! What we really want to achieve is a simple, classy, and semi-affordable TKL, since this is my favorite layout.
Oh did I mention, the sales format will be in stock? More on that Later!
Proto Pics
Basic Information:
Layout: F13 WKL/WK 88%
Mounting: Top + O-ring with Split Plate
Typing Angle: 9 degrees
Front Height: 16.5mm
Top Piece: 6063 Aluminum, Colored Acrylic
Badge: PC, Mirror Polished Stainless Steel
PCB: Hotswap (Optional), Solder (Default)
PCB Spec: 1.2mm, Blackcore PCB
Bottom Piece: 6063 Aluminum
Internal Weight: Brass
External Weight: Copper, Stainless Steel Mirror PVD, Mirror Polished White Copper
Weight: 6.6 Pounds/3.0 Kg
Plates: Aluminum Full (Default), Aluminum Half, FR4 Full
Sales Format: Instock sale FCFS on keyspensory, ship from China to worldwide
Sales Date: Early to Mid-December
Units: 150≈
Weight Detail
Price:
420 USD for the Standard Edition
440 USD for the Stainless Steel PVD version
520 USD for Gin Edition with White Copper Weight
(Gin Edition will be raffled on our Discord, link https://discord.gg/RCaEdNv9mm)
Color Combination
My Favorite Angle
Plate Render (Updated)
Since lots of you guys have asked about the plate, and what Split Plate means, we have since uploaded a complete plate overview here!
As you can tell, the main alpha area and function key area will have two individual plates, hence the "Split Plate"
Exploded View
An exploded view for a better understanding of how the board is put together
PCB Layout
ANSI Hotswap
Solder Support
Would Like to Hear Your Feedback!
https://forms.gle/oVjo9MEXQYBsdKSP6
Come Talk to us on Discord!
Typing Test and More Reviews Coming up
Project Timeline:
First Proto - Done
Second Proto - Done
Machining - On Going
Some More Proto Pics
Render For Each Color Combination
Render for Rose Gold
Render for Silver
Render for Black
Render for Lilac
Render for Gin Edition
Render for Black bottom with Copper Weight
Render for Silver bottom with Copper Weight
Render for Silver bottom with SS PVD Weight
Render for Black Bottom with SS PVD Weight
One More Side Profile
Mod Edit: Changed title to more standardize [IC] tags; please remove this note when you see it
« Last Edit: Mon, 19 December 2022, 07:42:00 by TheColaMan »
Offline TheColaMan
Production Pics Below
Black with GMK Nines
Rose Gold with Milkyway Coloradas
[/size]
Lilac With GMK Frosted Witch
Silver with DCS Deadbeat
« Last Edit: Mon, 19 December 2022, 07:38:44 by TheColaMan »
Offline Wh3IKlaDe
  • I3
sheesh dude
Offline ankit
  • Formerly ankit-sachdeva
what does the plate look like?
Offline sony
  • Formerly ultraidiot
what exactly is split plate?
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
I’d love to see pictures of the plate. That being said, I’m really happy with how this looks, and it’s great that it’s in stock. Sadly, since I’m a split right shift user, I can’t really join this buy  :-[
Offline keebivore
Gin edition looking clean af! More pictures of the internals would be nice. Any plan for reviews/streams before GB?
GLWIC!!
Offline Solitude95
  • Keeb, coffee addict
Been eyeing for a topmount board in the seas of gaskets
this might be the one
goodluck with IC!
« Last Edit: Wed, 21 September 2022, 11:31:43 by Solitude95 »
Offline zhywsl
优雅
Offline ProjectAchu
elegant :thumb:
Offline LightningXI
  • PPD
    • ArtisanMacro
Clean looking, but definitely interested in seeing more of internal structure/plate, etc.
Offline REBAO
sheet  :p so elegant!
Offline zekkin
  • my entire life was unlimited zekk works
Some thoughts:
  • Unsure about 4 fastening screws solely in the corners of the board -- I would worry about the middle of the front and the back not making complete contact and potentially leading to poor sound.
  • Looks to be using a proprietary daughterboard, will these be widely available for inevitable DB failure (i.e. it breaks)?
  • The o-ring mounting points don't look to be consistent with what was derived from the Jane V2 CE -- is there a specific reason for that?
  • What does the plate look like? What is split plate?
Offline HugoChowsky
Which top piece colour is “Coloured acrylic”?
Offline Frid4y
really geogerous!consider to add split backspace to the solder PCB?
Offline Kanya
So classy!!! ;D
Offline MaiTheSan
I'm in
Offline Kansir
Love the design and choice of materials, and ngl that gin edition is so lit. Would like to see the plate options (half plate please). Count me in!
Offline zkl1015
can can need ;D
Offline TheColaMan
Thanks for you interest Lightning! We have just updated the plate view and exploded view!
Offline TheColaMan
Some thoughts:
Hey Buddy, thank you for the insightful questions!
  • That is very true, the lack of binding strength can cause a severe rattle right in the middle, we have since left enough space in the middle to avoid such disaster!
  • In an ideal world, we will be running a stream of products with the same daughterboard design, but we have also taken the precaution to make quite a lot of them for future repalcement
  • It is more of a design preference, the designer himself is a real ocd, and is looking for all thing symetirical, and after some testing and prototype, this particular desgin yield a very consistent typing feel when pair with our plate
  • We have just updated the IC with plate view and exploded view, that should help answer your last questions!
Offline TheColaMan
Hey buddy, the plate view is updated in the post! That should help answer that question! Essentially the alpha and function keys will get two individual plates!
Offline herfalerf
Seems like a nice board for the price.  Will be keeping an eye on it.
Offline rookb
I don't understand the side mounting points for O-ring, this is just going to sound/feel inconsistent in a TKL as the left side is closer to the alphas than the right
Offline CxxC1
love the design
Offline suishibe
very pretty
Offline X7VN
blank
« Last Edit: Fri, 09 June 2023, 00:24:22 by X7VN »
Offline qiukulol
Ohhhhh,nice TKL!
sound test plz!better with different plates
Offline TypeBis
top mount TKL take my money!
also sound tests please!
Offline mr_foggy
  • neue = nope
finally some good taste. seriously considering it.
Offline yuzuu_
this is one sexy board, looking forward to the sound test!
also curious, what benefit does the split plate offer when compared to the regular plate?
Offline codog
very keen on this
Offline Sieglinde
Have you consider keeping the front of the board clean? Don't really like that tiny cutout.
Offline TheColaMan
very unlikely, cuz the designer loves it, and i am on the same side as him
Offline TheColaMan
thanks for the kind word!
Offline TheColaMan
Ohhhhh,nice TKL!
they will come for sure!
Offline iNKY Studio
  • long-term partner with Domikey
can can need :-*
Offline Der8auer
Very clean design. I like it :D
BTW. I want to put the diamond into the diamond slot  :cool:
Offline Nonnegaard
theres a lot of nonsense here but I'm here for it
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline PCov
This looks great.  Ayleen looks like Shelby's sister.  I'm very interested.
Offline TheColaMan
Hey, at least i am very glad you took an interetest!
Offline TheColaMan
Thanks, buddy! Stick around, only more good stuffs to come!
Offline MMJ1999
I like it!
Offline JQ27
Thankfully, this board has much better layout choices for the user!
Offline Keeblet_257
Did you upload the wrong pictures for the layout support under solder? You're surely joking right?
The reason why ppl buy solder PCBs (as far as I know) is to have more layout options, which the HS PCB simply doesn't support most of the time, like being able to freely choose between iso/ansi enter, split backspace, split right shift, split left shift, stepped or not, 6.25 or 7u space bar. I don't see a reason to offer a solder PCB that basically has a fixed layout.
At this point you might as well just offer 2 HS PCBs one for ISO and one for ANSI, since the solder PCBs basically only differ by allowing stepped caps lock, if the images I see are the ones you wanted to show and arent put out by mistake.
Other than the layout support on the solder pcbs I have nothing really to pick on, I like the looks of the board.
Edit
corrected some typos
« Last Edit: Fri, 30 September 2022, 12:18:33 by Keeblet_257 »
Offline Keeblet_257
« Last Edit: Fri, 30 September 2022, 12:18:48 by Keeblet_257 »
Offline TheColaMan
Edit
Hey man, i see your point, there may be some misunderstanding here, the solder will support both ISO and ANSI. The real factor that dictates the layout is the plate you chose to use on your solder pcb. Thanks for your interest again!
« Last Edit: Fri, 30 September 2022, 13:52:53 by TheColaMan »
Offline QWER|key
I absolutely love this side profile. This is one handsome TKL.  I'd case screws in the middle as well as just the corners though, as I would worry about vibration if the surfaces don't perfectly meet.
Offline TheColaMan
Thanks for the kind word! We have thought about it, and have design around this concern. It is solid as a block as for the moment!
Offline Flybeck
Really like the accent piece by the arrow cluster. :)
