Author Topic: Help with repair of daughterboard connector  (Read 3427 times)
Offline the_useless_turtle
« on: Fri, 30 September 2022, 12:09:46 »
So I just broke the daughterboard connector of a keyboard I was building. Any tips on how to repair this? 291896-0
Re: Help with repair of daughterboard connector
« Reply #1 on: Sat, 01 October 2022, 12:26:13 »
Looks like all the traces are still on the PCB so you just need to solder it back on - easier said than done as it is very small.
Another option would be to follow the traces and solder the wires directly to nearby components - if you want help with this you'll need to move the shiny bit onto the connector area as black PCBs are hard to see anything on.
Offline Leslieann
« Reply #2 on: Sat, 01 October 2022, 12:43:37 »
Yep that looks rather simple other than size.
Looks like it was a rather cold joint to begin with.
| GMMK TKL
| Magicforce 68
| KBT Race S L.E.
Ergo Clears, custom WASD caps
| Das Pro
Costar model with browns
| GH60
Offline Rico
« Reply #3 on: Sat, 01 October 2022, 13:57:28 »
How lucky you are, the pads are still there!
Just resolder the connector and you will be good to go ;)
