Author Topic: [IC] SPV1 - 75% + Left Numpad (GB DATE AND PRICING SET!!!)  (Read 32719 times)
Offline bisoromi
  • Formerly Duwang
  • owo
« on: Wed, 05 October 2022, 20:22:32 »
    SPV1 by Bisoromi x [H]
    Hi all!
    After many years I'm excited to finally announce the SPV1, a Southpaw 75%! This was a joint effort between myself and H3NT4I to create a practical and productive layout.
    At the time of designing this back in 2018 there weren't any layouts like this so we decided to make our own with the help of Gondolindrim for designing the PCB.
    Big thank you to CannonKeys and all of their staff for graciously helping out with fulfilment of this board!!
    Specs
    8° angle
    Top mount
    1.5mm plate
    2x 8mm brass reversible weights
    Aluminum case
    Numpad, mirrored numpad, or macropad options
    USB-C
    Fixed ANSI 7u WKL layout (will provide plate file)
    10mm top/bottom bezels, 5mm side bezels
    Caps/num/scroll LED indicators
    18.8mm front face height
    Solder-only PCB (For first run)
    Renders (by Pontus)
    Proto Images
    Layouts
    Plate
    Pricing
    $420
    Timeline
    Launching February 14th, 2023
    Vendors
    NA: CannonKeys
    China: ClickClack
    Indonesia: Acid & Co
    Australia: DailyClack
    EU: MyKeyboard
    Thanks for looking!! Huge shoutouts to Upas, Alchemist, Chippy, Gondolindrim, and everyone else who helped out with this project! :thumb:
« Last Edit: Tue, 03 January 2023, 11:21:35 by bisoromi »
(credits to Kokaloo)
Offline bisoromi
  • Formerly Duwang
  • owo
Re: [IC] SPV1 - Southpaw 75%
« Reply #1 on: Wed, 05 October 2022, 20:24:04 »
first
Offline ankit
  • Formerly ankit-sachdeva
« Reply #2 on: Wed, 05 October 2022, 20:24:15 »
second
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #3 on: Wed, 05 October 2022, 20:25:34 »
top mount is a top mount; just hope it's cheap
Offline pancake
    • mizuena.com
« Reply #4 on: Wed, 05 October 2022, 20:30:30 »
hi where is the yuktsi backplate
SA Bisoromi | GMK Gregory | GMK Stonks | GMK Faceless | GMK Gregory 2
HHKB Snow 25th | RS | RS60 | RS65 | TGR Jane v2 CE
Offline Lysol_
« Reply #5 on: Wed, 05 October 2022, 20:40:38 »
Very cool biso
Offline nicksmizzle
« Reply #6 on: Wed, 05 October 2022, 20:48:28 »
good stuff, i love top mount
Offline Chippy
  • sus chef
« Reply #7 on: Wed, 05 October 2022, 21:18:18 »
Top mount is king. Happy to see this hit IC!
1.2og | Buddy 6xx | Le Fishe V1 Proto | xyz60 Rev2 | Quartermaster | Chimera65 | Satisfaction75 | Realforce 84u | Zenith Z-150 | Realforce 86u | 378
This and the swiss cheese keyboard is the next generation of keyboards
Offline niakulah
« Reply #8 on: Wed, 05 October 2022, 21:42:11 »
Wouldn't this be a southpaw 96%?
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #9 on: Wed, 05 October 2022, 22:03:56 »
honestly guys idk what % this board is
Offline Oogtug84
« Reply #10 on: Wed, 05 October 2022, 22:10:47 »
I dunno what percent I'd consider it either, but looks far closer to a southpaw 1800 than a 75 :D
Just as a lefty that's what I'd consider it. Great looking board mate!
Offline Francisco
« Reply #11 on: Wed, 05 October 2022, 22:43:29 »
Nice!  :thumb:
Offline eyesupguardian
« Reply #12 on: Wed, 05 October 2022, 22:45:24 »
Need  :D
« Reply #13 on: Thu, 06 October 2022, 01:26:18 »
Isn't this more of a southpaw 98%? I feel like southpaw 75% would be a 75% with the nav column and arrows on the left.
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #14 on: Thu, 06 October 2022, 01:59:03 »
If you guys can settle on what % it is then I’ll change the title, but for now Southpaw 75% makes the most sense!
Offline Razer1987
« Reply #15 on: Thu, 06 October 2022, 05:17:20 »
hi, nice project! i understand that the plate has a fixed ansi layout, what about the pcb? no iso support? ty
« Last Edit: Thu, 06 October 2022, 05:21:34 by Razer1987 »
Offline futurecrime
  • Get Zooted
« Reply #16 on: Thu, 06 October 2022, 05:26:21 »
This is lovely. I don't need southpaw numpad but it's a very lovely looking board nonetheless. Have a great GB mate.
Offline fortissim2
« Reply #17 on: Thu, 06 October 2022, 12:12:26 »
I never understood why the big 0 key on the numpad was on the left, especially if it's on the left side of the keyboard. Normally you would use your right thumb (at least that's how I use a numpad), but you're going to use it with your left hand, and how would you press the 0 with your left thumb?
Looks clean though, GLWIC :) Also I don't think this is a 75% :p
Offline Oogtug84
« Reply #18 on: Thu, 06 October 2022, 13:41:30 »
You got jokes, us settle on something together. This one's great but I'm more interested in Wrist Breaker :D
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #19 on: Thu, 06 October 2022, 13:50:02 »
That's why I know the title isn't changing anytime soon ;)
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #20 on: Fri, 07 October 2022, 16:00:44 »
no iso support?
Unfortunately not, sorry!  :-[
Offline ZavaZ86
« Reply #21 on: Fri, 07 October 2022, 18:03:16 »
Will the phillips be removed/changed to something that won't get stripped?
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #22 on: Fri, 07 October 2022, 19:56:02 »
yes
Offline HappyB0T
  • I'm a Piggie
« Reply #23 on: Sat, 08 October 2022, 02:08:25 »
The R4 gap between the num pad and Esc is a cool design choice. If the price is low enough i'll consider left handing it.
Offline Butterbeer
« Reply #24 on: Sat, 15 October 2022, 14:17:10 »
This is a Compact Full Size Keyboard.
Focus on the key count.
There are 102 keys! That is wayyy too many keys to categorize this as a 75% keyboard. The intention of the percentage is to represent the number of keys relative to the number of keys typically found on a full size keyboard. A typical 75% keyboard will have (78-84) keys, give or take.
The reason why I would call this a Compact Full Size Keyboard is because it has the same number of keys as the Austin keyboard.
Offline lush_bunny
« Reply #25 on: Mon, 17 October 2022, 13:44:33 »
southpaw 75%? yawn
checks IC
sweet baby jesus, a southpaw 1800 bisoboard!
Offline H3NT4I
  • 気持ちいい
« Reply #26 on: Mon, 17 October 2022, 21:17:03 »
SPV1 Hype
Offline xh
« Reply #27 on: Mon, 17 October 2022, 22:41:55 »
Nice!
Offline Its Salty
  • I have no idea what I'm doing
« Reply #28 on: Tue, 18 October 2022, 00:43:28 »
85% southpaw is my best guess
75%+10%(numpad)
85% ≠ TKL
Offline just.hymn
« Reply #29 on: Tue, 18 October 2022, 03:15:34 »
niceeee!!!
Offline termination1
« Reply #30 on: Wed, 19 October 2022, 22:20:02 »
really interested in this design, any eta on the gb?
Offline jammiiew
« Reply #31 on: Thu, 20 October 2022, 09:22:14 »
nice layout, but the screws on weight shout really loud. haha
Offline blakstealth
« Reply #32 on: Sun, 23 October 2022, 11:16:52 »
This looks pretty cool. Looking forward to hear more.
Offline powwu
    • Discord
« Reply #33 on: Tue, 25 October 2022, 20:30:52 »
nice
+1
Offline okidna
« Reply #34 on: Sat, 29 October 2022, 13:23:30 »
This might be a silly question, does the brass weight fit into KFE-CE case?  ;D
Offline PinkCynicism
« Reply #35 on: Mon, 31 October 2022, 14:11:31 »
As someone who loves non exploded 75, is southpaw, and needs my numpad for blender this is just perfect. Is there still a chance for a winkey option?
Offline yoak
« Reply #36 on: Sat, 05 November 2022, 11:10:00 »
Really love this. A bit outdated design at this point though. Would love for this to get a little more modernized design because I want this layout!
Offline Dmitri
« Reply #37 on: Wed, 16 November 2022, 16:29:41 »
Does it come with QMK?
Offline nicksmizzle
« Reply #38 on: Thu, 17 November 2022, 20:39:25 »
so hot
Offline niakulah
« Reply #39 on: Thu, 17 November 2022, 21:42:10 »
I don't mind either way. Just a quick question. Would you consider this:
https://geekhack.org/index.php?topic=96648.0
to be a full size southpaw? Or is that a TKL southpaw. If you would call that a TKL southpaw, then you can go ahead and call yours a 75% southpaw.
Offline desgeek
    • Desgeek
« Reply #40 on: Mon, 21 November 2022, 20:58:31 »
strange layout :D
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #41 on: Wed, 07 December 2022, 19:53:43 »
Yes! QMK/VIA!
December!!!
Unfortunately not :(
That's the point!!
Offline aicyborg
« Reply #42 on: Mon, 12 December 2022, 19:52:55 »
If you're going solder only PCB, what's your excuse for not having ISO support? Fine if you don't want to support it on the plate and let community members sort that out, but it literally costs you zero compatibility to just add the holes for a solder PCB...
Offline bisoromi
  • Formerly Duwang
  • owo
« Reply #43 on: Tue, 20 December 2022, 19:06:37 »
It wasn't out of ill intent to exclude ISO compat from the PCB. The PCB was commissioned a while ago (2019) and was only supposed to be a limited run with a small friend group who only uses ANSI. The partnership with CannonKeys was a recent decision. But now that the logistical gears are turning on CK's side, it's a bit too late to offer ISO compatibility as the protos and BOM have already been finalized!
But ISO support, amongst other things, are definitely plans that I would like to offer for future runs if there's enough interest!
Offline Ikeygai Designs
« Reply #44 on: Tue, 20 December 2022, 21:05:38 »
clean
Offline lakeboredom
« Reply #45 on: Thu, 22 December 2022, 07:31:25 »
Whatever you did to the seam, it's not pronounced enough. It looks like a normal seam that stands out just a little bit more. Which is not a good thing in my opinion.
Offline treeleaf64
    • treeleaf64
« Reply #46 on: Fri, 23 December 2022, 03:20:41 »
I'm a keyboard and bisoromi twitter page is useful for eating Chicken Nugget
Everyone must pay the cat tax
Offline bisoromi
  • Formerly Duwang
  • owo
Re: [IC] SPV1 - 75% + Left Numpad (GB DATE SET!!!)
« Reply #47 on: Tue, 03 January 2023, 11:20:31 »
GB DATE IS SET FOR FEBRUARY 14TH, 2023 AND STARTING AT $420 USD!!!!! OP ALSO UPDATED WITH NEW RENDERS!!!!
Offline blakstealth
Re: [IC] SPV1 - 75% + Left Numpad (GB DATE AND PRICING SET!!!)
« Reply #48 on: Sun, 15 January 2023, 13:47:47 »
Woo!
Offline Aethelberht
« Reply #49 on: Fri, 03 February 2023, 01:13:37 »
This board looks very interesting. I just hope that the front has some sort of logo or badge or something to make it more appealing. Still, waiting for gb :D
I'm better than all of you combined.
