Author Topic: [IC]CKW80 - TKL/WKL, 3-in-1 type options | GB is live now! (Feb 7th - March 7th)  (Read 33653 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
Introduction
Hi keyboard friends, this is Velocifire. Today we bring one excellent 80% custom mechanical keyboard designed by CKW studio (CHAHNG KEY WORKS) -- CKW 80.
GB Time
February 7th- March 7th 2023
Product Page
Vendor
US: KeebsForAll
CA: DeskHero
EU: Mykeyboard
UK: Proto[Typist]
Oceania: SwitchKeys
Singapore: ktechs.store
Malaysia:mecha
JP: Basekeys
Rest of the world: Velocifire
Price
Anodized Aluminum Weight Version: from $349
PVD Brass Weight Version: from $439
Estimate Shipping Time: July 2023
Prototype
Black
Silver
Purple
Youtube Videos
TofuTypes
Dr.Hey
Pudding
bored bear
Sending prototypes to:
DBOKEY / Clackbait / Mecha Store
Please stay tuned  :D
Features
WKL or WK Layout
5 case colors and 8 weight options
More than one typing feel option
Left and right interchangeable type-c
Bluetooth Hotswap / Solder PCB (ANSI/ISO)
Design Concept
1. More than one typing feel option
(1) PCB Gasket(plateless): bounce; (2) Gasket: a little bounce; (3) Top: stiff
The method to realize it is to use a specially designed middle frame.
Turn over the middle frame to clamp PCB or plate with gaskets, so that we are able to switch between PCB gasket, gasket and top.
For PCB Gasket, the FR4 plate ear needs to remove;
For Gasket Mount/Top Mount, the PCB ear needs to remove (it’s irreversible)
(1)PCB Gasket → Gasket (By turning over the middle frame), below shows how it works.
(2)Top mount (The plates have screws holes for top mount)
2. Interchangeable type-c connector and decoration
Someone like left type-c and someone like right one, so we designed a type-c connector that can place left or right as you like.
Appearance Design
As the studio manager's name is Chain Smoker, and we want to make the keyboard more distinctive, so we add some cigarette elements to it.
Although we used some cigarette elements, we do not encourage smoking, so we engraved “ Smoking is harmful to health” inside the bottom case for reminding.
PCB Features
Hotswap PCB with various layouts: TKL/WKL, both support ANSI / ISO
Leave the solder place for knob on F13
Upgrade to black core Bluetooth Hotswap/ Solder PCB, which is better in quality than the ordinary one
What you can customize
Top Case: WK / WKL
Cases color  (Note: Type C color is the same as case color):
Black
Silver
Purple
Dark Green
Burgundy
Weight
Anodiezed Aluminum:Black, Silver, Gray
PVD Brass:Chroma, Gold, Silver, Black
E-Brass
Plate: PC/ POM/FR4/Aluminum
Specifications
Full CNC 6063 Aluminum top and bottom cases
Full built keyboard with alu weight: about 2kg; brass weight: about 2.6kg
Typing angle:7°
Front Height: 20mm
Welcome to join our discord for more discussion!
Welcome to visit the Product Page for more details.
« Last Edit: Tue, 07 February 2023, 20:09:37 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline plag
  • Formerly pepperonichicken
  • i also go by plag
This board looks really interesting!! However, in the “exploded” render, which shows all the parts separately, the pcb and pcb foams are upside down. I’d be cautious about something like that!
Offline dvllpxe
im digging this!
Offline Keeblet_257
damn thats a keyboard. (in a good way)
Offline john08099
  • Velocifire MK
Yeah, you are right. We don't notice this one before, thanks for pointing it out ;D We already correct it now.
Offline piteqiu
This is beautiful
Offline MMJ1999
Offline SzGeri
Why do you not include a plate without the mounting points? That way people could easily swap between a plateless build and one with a plate without crippling the PCB only using the PCB's mounting points (Like every other plateless keyboard does it)
Also, if the standard configuration that the board comes in is supposed to be plateless (since the plate is incompatible if I'm seeing it right using the PCB mount) why are you not offering a solder PCB which is more stable for plateless keyboards?
Offline piteqiu
I read that there are welds in the article.pcb
Offline john08099
  • Velocifire MK
Thanks for your suggestion, we will take it into consideration. What's more, we offer solder PCB as well. :D
Offline Morbii
Is the stepped caps also possible with hotswap?
Offline NexnaNet
Re: [IC]CKW 80 - TKL/WKL, 3 Mount Ways in one Keyboard, F13
« Reply #11 on: Tue, 11 October 2022, 03:54:49 »
Anyone have an estimated guess on how much this will cost. My guess is around 450-500 range Plus shipping
Offline john08099
  • Velocifire MK
Yes, hotswap can be used with stepped caps. ;)
Offline piteqiu
« Reply #13 on: Tue, 11 October 2022, 08:50:50 »
targeted price point?
Offline john08099
  • Velocifire MK
« Reply #14 on: Wed, 12 October 2022, 03:08:44 »
From 355 USD, the highest price will not exceed 470USD. We will announce the detailed price later.
« Last Edit: Wed, 12 October 2022, 03:13:23 by john08099 »
Offline mr_foggy
  • neue = nope
« Reply #15 on: Wed, 12 October 2022, 12:52:33 »
this is most definitely one of the keyboards ever made
Offline MMJ1999
Re: [IC]CKW 80 - TKL/WKL, 3 Mount Ways in one Keyboard, F13 (Prototype upgrade)
« Reply #16 on: Thu, 13 October 2022, 22:13:08 »
The new pictures are awesome!!! :thumb:
Offline Zimablue
« Reply #17 on: Thu, 13 October 2022, 22:19:19 »
Seems to have seen an update, love the design
Want to see a review of the video soon
Offline Its Salty
  • I have no idea what I'm doing
Re: [IC]CKW 80 - TKL/WKL, 3 Mount Ways in one Keyboard, F13 (Prototype update)
« Reply #18 on: Thu, 13 October 2022, 22:33:35 »
That black case with Purple PVD would look absolutely gorgeous; cant wait to see if I have the chance to get ahold of it
« Last Edit: Thu, 13 October 2022, 22:35:14 by Its Salty »
« Reply #19 on: Fri, 14 October 2022, 19:02:24 »
wait i thought there was a brown in the renders, is that cancelled?
Offline aicyborg
« Reply #20 on: Fri, 14 October 2022, 21:29:12 »
Is your layout image wrong or do you not support split LShift? Your PCB photo looks like it supports it, but your layout render doesn't. Since you have ISO enter it'd be a shame if you don't have split LShift which ISO layouts require.
I'm in solely because you have hotswap ISO. Thank you very much for that.
Offline john08099
  • Velocifire MK
« Reply #21 on: Sat, 15 October 2022, 20:18:28 »
Yes, we add red instead of brown because few people choose brown in the first IC form, and lots of them would like the red color.
Offline Fancytuna
« Reply #22 on: Sun, 16 October 2022, 08:25:21 »
Second this. Pls ensure split left shift for iso support.
Offline john08099
  • Velocifire MK
« Reply #23 on: Sun, 16 October 2022, 10:03:57 »
Yes, ISO support split left shift. We have updated the PCB layout, thanks for the feedback  ;D
Offline infinitum
  • i buy expensive plastic
« Reply #24 on: Mon, 17 October 2022, 08:59:16 »
this looks very cool
Offline TypeBis
« Reply #25 on: Tue, 18 October 2022, 11:35:01 »
very nice, any sound tests or streamer showcase planned?
Offline crookey
« Reply #26 on: Wed, 19 October 2022, 06:22:05 »
Pictures are awsome! Cool keyboard!
Offline john08099
  • Velocifire MK
« Reply #27 on: Wed, 19 October 2022, 21:32:23 »
Yes, we are contacting streamers right now, will send the prototype to them very soon, please stay tuned ;)
Offline raz_krm
« Reply #28 on: Sat, 22 October 2022, 09:41:34 »
send one to BlackSimon please
Sent from my KB2003 using Tapatalk
Offline john08099
  • Velocifire MK
« Reply #29 on: Mon, 24 October 2022, 20:29:20 »
Thanks for your suggestion, we will try to contact him ;D
Offline john08099
  • Velocifire MK
Update:
1. Add wine red case color instead of red according to feedback;
2. Update typing test video and youtube videos
3. Update more prototype pictures
4. We are sending prototypes to more YouTubers / streamers to review, please stay tuned ;)
Update 2:
The color of the prototype is more purple than wine red, so we change the wine red color to burgundy, thank you!
« Last Edit: Fri, 30 December 2022, 02:06:58 by john08099 »
Offline Plasma
Wine color is really pretty
Offline Zimablue
The dark green absolutely gorgeous :cool:
Offline john08099
  • Velocifire MK
Re: [IC]CKW80 - TKL/WKL, More than One Typing Feel Option, F13
« Reply #33 on: Fri, 27 January 2023, 00:16:40 »
Hi everyone,
CKW80 is going to have GB from Feb 7th-24th :D We have updated the vendors, please check it!
Offline john08099
  • Velocifire MK
Hi everyone, CKW80 GB is live now! Pls check the GB details here, thank you!
Offline xapikel988
How're the keycaps on the Dark Green build called?
Offline john08099
  • Velocifire MK
Hi there, the picture of Dark Green is a render pic, so the keycaps are not real, sorry for the inconvenience.
Offline NSkeptic
Ah so there won't be caps included? Good to know means I have until Summer to get a cap set that matches
