Author Topic: [IC] Igloo - PCB Tadpole Mount FRL TKL [GB Updated]  (Read 29589 times)
Offline ToFuMaNiA
« on: Mon, 05 December 2022, 23:30:20 »
IC Form Link
Discord Server
Inspiration
Inspired by igloos, this function row-less (FRL) TKL was designed with a particular concept in mind:
comgining the grace of curvature of an igloo with a solid bottom ground.
Design
It is available in WK (WinKey) and WKL (WinKeyLess) options.
Why Plateless?
As two enthusiasts fond of the unique bouncy feeling a plateless keyboard is capable of
producing, we have decided to go full-in with the plateless design for Igloo.
Spec
Angle: 5°
Mount type: Plateless Tadpole Mount
Front height: 17.34mm
PCB
PCB specs
1.6t solder
Colors
Snow White
Winter Blue
IceBurg-undy
Kit Contents
Keyboard w/ weight
Solderable PCB
Tadpoles
Feet
Screws
Custom Carrying Case
Pricing
$329.99
Vendors
US: DangKeebs
Canada: Ashkeebs
Korea: KLC
OCE: Cafege
EU: Keygem
Prototype
V3
Note: Please refer to the renders for the actual colors.
V2
The production color for IceBerg-undy will be darker than the proto color to closely match the renders.
V1
Typing Test
Typing Test by Dbokey
TTC Titan
Typing Test by Penbird
Zaku
Typing Test by Enomooshiki
Sp-Stars White
Special Thanks to:
Penbird - Co-Designer, Co-Author
Keebibi - Help with GB and IC + Rendering
Zetina - Rendering
CurKey, PewPew, ToastyStoemp - PCB Help
Enomooshiki - Pictures and Typing Test
IC Form Link
Discord Server
« Last Edit: Mon, 21 August 2023, 20:25:23 by ToFuMaNiA »
Offline ToFuMaNiA
Re: [IC] Igloo - PCB Tadpole Mount FRL TKL
« Reply #1 on: Mon, 05 December 2022, 23:31:35 »
Reserved
Offline irithyll
« Reply #2 on: Mon, 05 December 2022, 23:54:35 »
I am very excited as a lover of the plateless tadpole mount. Hope there’s progress soon. GLWIC!
« Last Edit: Tue, 06 December 2022, 00:02:30 by irithyll »
Offline Bantalope
« Reply #3 on: Mon, 05 December 2022, 23:57:30 »
Seems interesting, definitely gonna keep an eye on it.
Offline stewfayew
« Reply #4 on: Tue, 06 December 2022, 00:07:17 »
No split backspace REEEE
Offline ToFuMaNiA
« Reply #5 on: Tue, 06 December 2022, 11:01:12 »
Will work on adding split space!
Offline Friendship
« Reply #6 on: Tue, 06 December 2022, 14:06:43 »
are those divots where the tadpoles rest so that you can achieve a lower typing height?
« Last Edit: Tue, 06 December 2022, 14:08:33 by Friendship »
Collection: LZ GHv2, Esheu Fallacy, Moesode Bliss, Daji Ocho Cuatro, Ace Saturn60, Bolsa Midway60, MLI NUM1, MLI VISION, PW ROTR
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #7 on: Tue, 06 December 2022, 15:18:52 »
interesting board  :thumb:
Offline ToFuMaNiA
« Reply #8 on: Tue, 06 December 2022, 15:57:15 »
Right and also so that the tadpoles do not move.
I originally wanted the board to be lower, but this was the lowest I could get sadly. haha
Offline keebibi
    • My Discord Server
« Reply #9 on: Tue, 06 December 2022, 16:47:15 »
GLWIC!!!
Offline Flybeck
« Reply #10 on: Wed, 07 December 2022, 08:45:45 »
No hotswap plateless... unlucky.
Super cool project, looks very clean. GL!
Offline Friendship
« Reply #11 on: Wed, 07 December 2022, 11:45:21 »
the tadpoles inserted into the top case should be more than enough to keep the assembly from moving. were you seeing xz movement in prototyping?
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #12 on: Thu, 08 December 2022, 12:21:19 »
it's really a shame that a solder pcb mount doesn't offer ISO support: please consider it.
And GLWIC :thumb:
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline epicdesk.shop
« Reply #13 on: Sat, 10 December 2022, 21:11:59 »
I love the minimalistic approach here. Bravo!
Offline ToFuMaNiA
« Reply #14 on: Mon, 12 December 2022, 15:29:38 »
And GLWIC :thumb:
Will work on the new pcb with ISO support, split spacebar and split backspace.
Offline enomooshiki
« Reply #15 on: Fri, 16 December 2022, 02:36:37 »
it was a pleasure to build and fun to type
well done!
Offline ToFuMaNiA
« Reply #16 on: Tue, 24 January 2023, 21:11:06 »
Updated PCB support:
- iso support
- split spacebar
- split backspace
- split left shift
- split right shift
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #17 on: Wed, 25 January 2023, 06:48:24 »
- iso support
- split spacebar
- split backspace
- split left shift
- split right shift
Wonderful!!!
Offline pott
Re: [IC] Igloo - PCB Tadpole Mount FRL TKL [Updated Proto Pictures]
« Reply #18 on: Mon, 13 February 2023, 23:51:34 »
I got to see and type on an Igloo this weekend. This board is a super cool combination of good design, and cute looks. It also felt and sounded great. The ano color on the weight was INCREDIBLE.
Offline Akele
« Reply #19 on: Tue, 14 February 2023, 03:02:56 »
- iso support
- split spacebar
- split backspace
- split left shift
- split right shift
Wonderful!!!
Haha, I was pleased to see this too. This board is quite tempting...
Offline Kuj0
Saw StaceySmash build this one today. Definitely interested in picking up the burgundy! Never used tadpole mount before. Will there be different durometers of "nails" or "pins" or "tadpoles" - whatever they're called?
Offline ToFuMaNiA
We've talked to Geonworks and will be buying in bulk from them.
There will be different hardness for tadpoles: 50a, 60a... up to 90a
I believe You can compare the 60 a to the tire tread and 90a to be hard as shoe heel
Offline Woovie
saw the proto in person at a recent SMK meetup, beautiful board, hope everything goes well.  :thumb:
Offline migkb
    • Google.com
Glwic!!
Sent from my Pixel 6 Pro using Tapatalk
Offline tactilesbad
« Reply #24 on: Wed, 08 March 2023, 05:43:12 »
And GLWIC :thumb:
apart from moaning about iso support are you actually buying these boards?
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #25 on: Sat, 11 March 2023, 03:00:35 »
Asking for ISO support is a concern for all those who use this layout, it is certainly not a personal matter: forgive me but I really don't understand the meaning of this question.
Whether or not I intend to participate in this GB, forgive my frankness, but that's none of your business.
