Author Topic: [IC] KEYKOBO RED CYRILLIC - GB from 7th to August 1st.  (Read 34416 times)
Offline J0hnojoheneczko
  • Discrod - https://discord.gg/26VvnCBzKZ
« on: Tue, 23 May 2023, 14:21:05 »
Hello everyone!
I would like to present you Something I've been working on for some time - Keykobo Red Cyrylic.
I figured I'd do GB by the fact that GMK Classic Retro Cyrillic had GB in 2017.
I've decided on keykobo because of lower prices, better quality, much shorter waiting time than GMK.
Information about GB
Group Buy will run from July 7 to August 1. Special thanks go to Vendors and others who helped me..
Information:
Lead Time: ~4 Months after Group Buy end from Keykobo to Vendors.
Profile: Cherry
Material: ABS Doubleshot + Pad printed sublegends
Manufacturer: Keykobo
Color: L9 U9 CR P3
KITTING:
PRICE:
Vendors:
US: Cannonkeys
EU: EloquentClicks
UK: Prototypist
JP: Basekeys
KR: Geon.works
Oceania: Allcaps
THA: Aiglatson Studio
CN: Keykobo
SGP: Ktechs.store
Special thanks to:
Hymn for renders,
All the vendors for help,
Everyone who helped with the project
Renders:
RYU ERGO V2 by Geonworks
TGR JANE V2 by Yuktsi
J-02 by Jae
U80-A by Rama Works
TYPE LESS by Hymn
FAQ
Will there be deskmat available?
Yes
When will the group buy happen?
TBD
How does the print pad look like from KKB?
I ordered samples from KKB (not the whole set, but a few keycaps is always something). Below is a photo from KKB
Updates:
V1 - New kitting
V2 - Allcaps joined the project
V3 - New set name
V4 - EloquentClicks replaced mykeyboard.eu
V5 - Aiglatson Studio joins the project
V6 - samples ordered and will arrive on June 1st
V7 - kitting changed a bit, (no support for 40%), render soon
V8 - Ktechs.store joins the project
V9 - I started testing samples from Keykobo
V10 - new kitting
V11 - Keykobo joins the project
V12 - Cannonkeys joins the project
If you have any questions feel free to write to my discord - Johnojoheneczko#9031. Спасибо :thumb:
« Last Edit: Sun, 16 July 2023, 17:38:34 by J0hnojoheneczko »
Offline TyPo.mk
Re: [IC] KEYKOBO HASRO
« Reply #1 on: Tue, 23 May 2023, 14:27:20 »
!beige
Offline The0rigina1
  • fumoposting
« Reply #2 on: Tue, 23 May 2023, 14:28:20 »
Are they offering pad print services? What is the durability of their pad prints? Do you have a prototype? Have you tested it yourself?
Offline rookb
« Reply #3 on: Tue, 23 May 2023, 14:29:08 »
Reconsider your EU vendor
Offline Rafa_n
  • stuffforrectangles.etsy.com
« Reply #4 on: Tue, 23 May 2023, 14:36:24 »
Please not mykeyboard.eu
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #5 on: Tue, 23 May 2023, 15:00:14 »
I strongly endorse this suggestion. (And I'm not even in the EU)
Offline Neely_12
« Reply #6 on: Tue, 23 May 2023, 15:06:02 »
Some suggestions:
Label Rows
Label cap sizes
add 2u shift (optional)
add 4 keys to the numrow for UK ISO
Make alternate f and j scooped or nippled
add alternate 5
add split plus/mius
add 1u zero
add R3 1u pipe to work with the <> for terminal iso
change 1.5u backspace legend (optional but please)
Make sys req on print screen green to match real hasro
use R5 bottom row to match real hasro
Use text only on numpad enter to match real hasro
Use different EU vendor
Offline chorb
« Reply #7 on: Tue, 23 May 2023, 15:08:38 »
Why name this "HASRO" when it has differences in sublegend font and placement and front prints compared to the keycap set from the Cherry ESA-3000-HASR0 keyboard?
- Sublegends on the pipe and tilde are located differently on the Cherry keyboard.
- Sublegend font on this set looks way thinner than the Cherry keyboard.
- The enter has front printed "Power" and all the front prints are red unlike on the Cherry keyboard.
If this is meant to be a replica of the Cherry dyesubed keycap set from the ESA-3000-HASR0 keyboard - you have quite a bit to change.
If it's not meant to be a replica of the OG Cherry set - why name is "HASRO"? "Keykobo red cyrillic" or something like that seems like way more fitting name.
Also, is this R4 or R5? I can't find that information in the IC.
GLWIC :thumb:
Offline hali
  • OHHHH MY GODDDDDD
  • please buy cat ears alice
    • hali.studio
« Reply #8 on: Tue, 23 May 2023, 15:39:00 »
just call it red cyrillic if you're going to do things like red front print and text + icon numpad enter
« Reply #9 on: Tue, 23 May 2023, 16:05:39 »
I will definitely heed your advice and send the corrected kit in a few days
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #10 on: Tue, 23 May 2023, 16:06:56 »
HASRO good
Offline Fnzzy
« Reply #11 on: Tue, 23 May 2023, 16:40:58 »
I would strongly advice looking for an EU vendor that is not lying to their customers, employees, and designers. May I suggest Oblo, Keygem, or Eloquent.
« Last Edit: Tue, 23 May 2023, 16:42:30 by Fnzzy »
Offline aicyborg
« Reply #12 on: Tue, 23 May 2023, 19:36:09 »
I'm hesitantly interested, but I'd like to see some samples of KKB's pad printing before I were to participate in this.
Could full ISO-UK be added to this? You'd just need three more keys in addition to what's already included. GMK HASRO/SAV could be used as an example.
Offline Nascent
« Reply #13 on: Wed, 24 May 2023, 02:37:26 »
Yes, please
Offline mr_foggy
  • neue = nope
« Reply #14 on: Wed, 24 May 2023, 02:41:07 »
reach out to a different EU vendor please. 100% buying this if you get a better EU vendor.
and yeah, +1 for R5 support as KKB should already have most molds in place (mint dolch kit in Gigachad)
« Last Edit: Wed, 24 May 2023, 06:11:33 by mr_foggy »
Online Rhienfo
  • GOTHETIGES
« Reply #15 on: Wed, 24 May 2023, 02:52:54 »
As much I heard good things about keybobo's double-shot (Compared to the price at least) but I can't recommend this unless I see the pad printing for myself so I feel a prototype is needed here. Also we would need to see the price of course.
+1 on changing the eu vendor, mykeyboard does not have the best track record.
Offline m0squit0
« Reply #16 on: Wed, 24 May 2023, 07:40:11 »
Is the name inaccurate?
HASRO uses pbt dye sublimation, HAV uses ABS Doubleshot.
299290-0299292-1
Offline Edric
« Reply #17 on: Thu, 25 May 2023, 01:12:51 »
Regarding this one, please check the GMK HASRO thread https://geekhack.org/index.php?topic=117328.0.
Basically, OG cherry had misplaced legends and a font that gives you permanent brain injury the moment you see it.
Sublegend placement and the font you have in the renders are perfect, please keep them this way.
Offline Fraaaan
« Reply #18 on: Thu, 25 May 2023, 06:31:15 »
ISO support is very weird, looks like you wanted to do UK ISO but gave up halfway through. IMO either commit to full UK ISO or do basic terminal ISO.
Also please consider swapping to a different EU vendor.
Offline Dmitri
« Reply #19 on: Thu, 25 May 2023, 14:36:08 »
Pls add latin alpha’s as a kit.
Offline CaesarAZealad
  • Racc
« Reply #20 on: Thu, 25 May 2023, 15:42:24 »
There's plenty of already existing beige sets that will fill that need.
One, Two, Three, Four, Five, Six, Seven, Eight, Nine, Ten, Eleven, Twelve, Thirteen, Fourteen, Fifteen, Sixteen, Seventeen, Eighteen, Nineteen, Twenty... Yeah that seems about right.
"Ask your mother how good I can use more than two fingers." - Caesar, 2023
« Reply #21 on: Thu, 25 May 2023, 16:08:42 »
plans to talk to other vendors in Europe, but unfortunately they do not write me back
« Reply #22 on: Thu, 25 May 2023, 16:09:43 »
look, i fixed the iso
« Reply #23 on: Thu, 25 May 2023, 16:10:22 »
Some suggestions:
Label Rows
Label cap sizes
add alternate 5
add split plus/mius
add 1u zero
what do you think now
what do you think about the new kitting
« Last Edit: Thu, 25 May 2023, 16:12:09 by J0hnojoheneczko »
« Reply #24 on: Thu, 25 May 2023, 16:11:00 »
I changed the name
Re: [IC] KEYKOBO RED CYRYLIC
« Reply #25 on: Thu, 25 May 2023, 16:12:56 »
I will order better quality renders but when you accept the kitting
Offline aicyborg
« Reply #26 on: Thu, 25 May 2023, 16:50:28 »
Thank you for fixing the ISO support, but still definitely want to see pad printing samples from KKB before this goes ahead. KKB's cool but very new and a lot of the community doesn't trust them yet. When I say samples I mean physical things in your hand with real photographs (not renders) to see how they'll look.
« Reply #27 on: Fri, 26 May 2023, 01:16:47 »
I ordered a few samples from kkb, unfortunately it's not the whole set but it's always something
« Reply #28 on: Fri, 26 May 2023, 01:22:25 »
I have one photo from kkb, but of course the pre-gb samples have to be in my hands
https://imgur.com/a/JmPhhZG
Offline Alva_Works
« Reply #29 on: Fri, 26 May 2023, 03:57:49 »
Dont run this with mykeyboard
Offline The0rigina1
  • fumoposting
« Reply #30 on: Fri, 26 May 2023, 05:24:14 »
The stepped caps lock looks weird, is that mold issue or render issue
Offline Dmitri
« Reply #31 on: Fri, 26 May 2023, 09:00:02 »
I have been thinking to learn russian so i might buy it, but would still like to see a latin alpha’s alt kit so I have the option to switch.
Does keykobo have done pad printing before?
I never had problems with mykeyboard, but i prefer candykeys because free shipping.
« Last Edit: Fri, 26 May 2023, 09:13:02 by Dmitri »
« Reply #32 on: Fri, 26 May 2023, 10:29:07 »
render issue, vendor to europe has been changed to EloquentClicks
« Reply #33 on: Fri, 26 May 2023, 11:09:33 »
I'm not going to do a latin alpha kit
Offline mr_foggy
  • neue = nope
« Reply #34 on: Fri, 26 May 2023, 15:44:03 »
10/10 can safely say I'm buying
Offline Dmitri
« Reply #35 on: Fri, 26 May 2023, 20:25:32 »
What is the eta of keyboko?
« Reply #36 on: Sat, 27 May 2023, 05:06:34 »
it says in the post about 3-4 months from gb keycaps should be at vendors
Offline mizuuuu
« Reply #37 on: Sat, 27 May 2023, 11:31:27 »
the samples look promising, keep loving beige :3 glwic!
Offline incrediblejr
« Reply #38 on: Sun, 28 May 2023, 06:46:26 »
Better quality in what way? According to whom? Does KKB have a recessed stem like GMK? (CRP and XMI do not, making them "sit higher.")
Thank you for changing the EU vendor.
I would be interested in a 6u spacebar, like the one in KKB Miami Dawn.
Also, 'Cyrillic' is spelled with two L's, unless there is an alternate spelling I've never come across before.
« Reply #39 on: Sun, 28 May 2023, 11:23:40 »
it has better qc than gmk so it can be considered better quality because they don't allow to sell **** and of course i can add 6u spacebar
Offline Neely_12
« Reply #40 on: Sun, 28 May 2023, 14:57:22 »
Some suggestions:
Label Rows
Label cap sizes
add alternate 5
add split plus/mius
add 1u zero
Good enough.
Offline Neely_12
« Reply #41 on: Sun, 28 May 2023, 15:01:45 »
There hasn’t been a large enough sample size to say that keykobo has “better QC.” What we do know is that GMK legends are slightly better, but it doesn’t really matter as long as the price is about what you’ve estimated since it’ll be cheaper than most GMK beige sets. I do wish the texture wasn’t as smooth but that’s a personal thing.
Offline ggggggg
  • schmeiß die forties durch den club
Re: [IC] KEYKOBO RED CYRYLLIC
« Reply #42 on: Mon, 29 May 2023, 02:00:32 »
Bummed to see 40s support go with the kitting revision.
Offline El Kinoflop
« Reply #43 on: Mon, 29 May 2023, 02:07:15 »
Yup, disappointing to lose 40s support.
Offline ankit
  • Formerly ankit-sachdeva
« Reply #44 on: Mon, 29 May 2023, 03:11:17 »
Can you fix the 1.5u backspace legend and add a second 1.5u super and 1u alt while you're at it
« Reply #45 on: Mon, 29 May 2023, 03:18:44 »
I second that
« Reply #46 on: Mon, 29 May 2023, 03:26:16 »
I believe that it is rarely used and only increases the production price, and we are trying to reduce the price as much as possible with vendors
« Reply #47 on: Mon, 29 May 2023, 03:27:02 »
I'll see what I can do
Offline iamtragic
« Reply #48 on: Mon, 29 May 2023, 06:43:04 »
Can confirm that KKB has a recessed stem - looks virtually indistinguishable to GMK from a height standpoint.
« Reply #49 on: Mon, 29 May 2023, 12:04:28 »
I will try to take photos to compare their quality
