Author Topic: 【IC】NESON DESIGN: The 810E Series Keyboard (Group Buy in November 15th)  (Read 14419 times)
Offline Simen
·Hi, I am Simen from Neson Design and glad to meet here again.
·I would like to introduce our new design – The 810E Series, which is a member of N-Series with FRL(F-Row-Less) 1800 layout with isolated spacebar.
[/size]
299777-0
299779-1299781-2
299783-3299785-4
·First of all, we are really appreciated for your warmly support for 700E and the unique isolated spacebar design.As the 700E shipping process is finally finished, we have received plenty of positive feedback from users. At the same time, we also see some quite similar designs with isolated spacebar showing up. We are glad that our design has inspired others, but there are also some bad plagiarisms, which make us feel sad. From a creative perspective, we feel a bit depressed, but nevertheless, it also inspired our motivation for a better design. This has always been our pursuit. For more details about 700E, please refer to IC LINK : https://geekhack.org/index.php?topic=116394.0]https://geekhack.org/index.php?topic=116394.0]https://geekhack.org/index.php?topic=116394.0
·As the last of this series, we will try our best to make 810E as a perfect ending. It will be not the end of our design. We hope that all players can continue to support us on new chapters.
The 810E IC Form:https://docs.google.com/forms/d/e/1FAIpQLSeNdDX_Sxx9aoOqrMFoabm_ulfBLceBUt2m8jjbd2I20RKMEA/viewform?usp=sf_link
Discord:https://discord.com/invite/kTAtCrYfPM
Instagram:https://www.instagram.com/neson.design/
Catalog:
1.Details
2.Design
3.Layout
4.Color
5.Updates
6.Phototype Pictures
7.Vendor
1.Details:
·Typing angle:9°
·Frontend height:17.9mm
·Mounting details: Gasket mount with leaf spring plate, hardness for silicone gaskets is 40
·PCB:1.6mm (NO Flex), Type-C with daughter board. PCB supports QMK and VIA , designed and manufactured by Astro.
·Price:The basic price is about 480-500 US dollars (adjusted according to the real-time exchange rate in GB)
2.Design:
299787-5
Appearance:The 810E is a continue of N series, features a rugged design with sleek lines, maintains its industrial aesthetic. There are some adjustments on the connection part between the bottom-rear part and RGB lighting, in order to  create a more layered effect between the lighting and the bottom case.
299789-6
Structure: optimized 3-layer structure, frontend height decreased to 17.9mm, and better typing feel with isolated spacebar.
PCB: after Nico 01 GB finished, we will not use 1.2mm pcb, either PCB Flex or less PCB Flex adoption.
Keyboard Exploded View:
299812-7
3.Layout:
299792-8
4.Color:
(Tentative color)Black 、 Silver 、Green
299795-9
299797-10
299807-11
5.Updates:
Ver.1: ·The new side design features a dotted pattern and linear side profile. There will be a angled curves in the rear-bottom.
           ·Widen middle USB port.
           ·Replace JST 4pin connector with Molex 4pin connector, improve the durability and ease of use
Ver.2: ·Rear-bottom was changed back as oblique angle
           ·Adjust the mid frame to fit the new Molex connector
           ·acrylic diffusers adjustment
           ·Modify the rweight design
6.Phototype pictures:
·Some proof pictures of Ver.1
299801-12
299803-13
299805-14
·Ver.2 is proofing
7.Vendor
TBD
« Last Edit: Tue, 17 October 2023, 22:50:35 by Simen »
Offline Simen
Re: 【IC】NESON DESIGN: The 810E Series Keyboard
« Reply #1 on: Sun, 11 June 2023, 02:59:05 »
Reserve
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« Reply #2 on: Sun, 11 June 2023, 03:10:37 »
Exploded space bar very interesting. GLWIC!
« Reply #3 on: Sun, 11 June 2023, 21:20:29 »
9 degrees?! My wrists do not approve.
Offline treeleaf64
    • treeleaf64
« Reply #4 on: Mon, 12 June 2023, 02:28:44 »
Simply a difference in skill  :cool:
I am a full size keyboard and This is the cat and pat
I like the renders !!
Everyone must pay the cat tax
Offline spikedsynapse
« Reply #5 on: Mon, 12 June 2023, 08:26:17 »
What size is the spacebar on this? 6.25?
Love the exploded spacebar.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #6 on: Mon, 12 June 2023, 11:29:26 »
Don't ever try a Duck board out then!
Offline Rhienfo
  • GOTHETIGES
« Reply #7 on: Mon, 12 June 2023, 17:54:15 »
I mean this layout is unique... especially that bottom row. I mean it looks cool at least, also what's moq for this, is it unlimited?
Offline Xury46
« Reply #8 on: Mon, 12 June 2023, 19:42:18 »
I love this layout, fun stuff with the exploded spacebar and arrows
Offline VXQN
« Reply #9 on: Tue, 13 June 2023, 02:34:44 »
Design is generally pretty nice but the "the 810e" engraving is kinda wack. Very rare to see brand/model names prefixed with "the".
