Author Topic: [IC] JCS Arabic - GB from Jan 3rd to Jan 31st 2024  (Read 26352 times)
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
« on: Mon, 18 September 2023, 23:27:32 »
JCS(JC Studio) Arabic
yes im hoping this abbreviation will catch on
العربيّة
GB THREAD LIVE NOW!
302773-0
STORY
Hi, I'm Masje, a leekbros enjoyer. This is a keycap set I designed in collaboration with TheBloodyez, a good friend and talented keyboard designer. Check out QFRL
We hope to make an affordable, classic Arabic keycap set inspired by Cherry G80 sublegends, so, naturally we chose to go with dyesub PBT with JC Studio(aka Leekbros)
At the same time, we hope to create an inclusive base set that will cover most layouts. Please refer to our specs for detailed kitting information!
We will be looking into different-colored sublegends, so do please fill out the IC form to let us know!
IC FORM   DISCORD(masje)   DISCORD(thebloodyez)
TARGET PRICE
Aiming for $28-$35 @ 200 MOQ
This will depend on region.
TIMELINE
Lead time is between 1-2 months (from the manufacturer)
SPECS
- Text+icon mods
- F13 & WKL support
- Numpad, w/ split +=-, 1u 0, 1u 00
- UK ISO support
- Alice support w/ extra B, 2u, 2.25u, 2.75u, 3u spacebars (There will be an extra 3u spacebar)
- Split left/right shift options
- HHKB support w/ 1u pipe, 1u backspace, 1.5u backspace, 1.75 control
- 1.5u ESC
VENDORS
MENA / Sandkeys
EU / Keygem
UK / Proto[Typist]
US / Otakeebs
CA / Deskhero
OCE / Cafege
SEA / Mecha Store
TW / PlayKeyboard
ROW / Leekbros(Taobao)
GALLERY
302733-1
Wolf King by TheBloodyez
302735-2
45O-CHKB by TheBloodyez
302737-3
F1-8x by Geon
BONUS INFO
We will be able to provide the sublegends in different colors, as illustrated below. Pick your favorite colors in the GB!
302739-4
SPECIAL THANKS
Thanks to baul for his input and help
Thanks to CoolPenguin1 for input on kitting, jampot for the ISO tips  ;D
Thanks to our discord members for the support
SIGNATURE
Code: [Select]
[url=https://geekhack.org/index.php?topic=121431][img width=213 height=120]http://i.imgur.com/QrvFaPp.png[/img][/url]
« Last Edit: Thu, 14 December 2023, 23:30:15 by masje »
Offline nostr
Re: [IC]JCS Arabic
« Reply #1 on: Mon, 18 September 2023, 23:35:17 »
I am a fan, in for a few at that price point to be honest. Has this manu released other sets before or is this the first set run
Offline Moods
Re: [IC]JCS Arabic
« Reply #2 on: Mon, 18 September 2023, 23:59:49 »
i like JCS, i like beige, i like Arabic sublegends, i like you
Offline Rhienfo
  • Why is everything I want here so expensive :(
Re: [IC]JCS Arabic
« Reply #3 on: Tue, 19 September 2023, 01:15:25 »
Leek brothers have been doing some great stuff for the price and this is another example.
Hopefully this would reach 200MOQ cause that price is very nice (+ quick timelines are always a good thing)
GLWIC
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline CoolPenguin1
Re: [IC]JCS Arabic
« Reply #4 on: Tue, 19 September 2023, 11:56:04 »
They have a bunch of sets on taobao and some vendors stock them.
Offline mr_foggy
  • neue = nope
Re: [IC] JCS Arabic
« Reply #5 on: Fri, 22 September 2023, 12:23:33 »
in for all subs color  :thumb:
Offline Thebloodyez
  • Just a random keyboard builder.
Re: [IC] JCS Arabic
« Reply #6 on: Fri, 22 September 2023, 14:00:06 »
Lets go
Online Rob27shred
  • Insane in the Membrane! 👻
Re: [IC]JCS Arabic
« Reply #7 on: Fri, 22 September 2023, 14:32:03 »
GLWIC
I just got their JC Studios Desko black set & am definitely pleased with it, especially at the price!
Offline ELE.WORKS
Re: [IC] JCS Arabic
« Reply #8 on: Fri, 22 September 2023, 15:17:11 »
it's looks so nice
Offline aicyborg
Re: [IC] JCS Arabic
« Reply #9 on: Fri, 22 September 2023, 18:04:29 »
I'm in because UK keys in base.
Any option of a pink sublegends option? Pink is objectively the cutest and friendliest colour.
Offline mr_foggy
  • neue = nope
Re: [IC] JCS Arabic
« Reply #10 on: Sat, 23 September 2023, 05:30:33 »
I swear I saw text only mods in yesterday's render. honestly I wouldn't mind if you kept them text only, there's plenty of other icon+text sets around to mix and match, this would have been a nice variation.
Offline masje
    • masjewerke
Re: [IC] JCS Arabic
« Reply #11 on: Sat, 23 September 2023, 06:19:32 »
yeahhhhh hahahaha, we changed them due to popular demand  :thumb:
but of course we will still be considering...
Offline ashendarien
Re: [IC] JCS Arabic
« Reply #12 on: Mon, 25 September 2023, 04:34:35 »
Same. Aesthetically I strongly prefer -just- text or all icons, but the mix never feels as crisp.
Offline mr_foggy
  • neue = nope
Re: [IC] JCS Arabic
« Reply #13 on: Mon, 25 September 2023, 10:11:39 »
maybe an add-on mod kit with text only legends ;)
Offline mini_ninja_64
Re: [IC] JCS Arabic
« Reply #14 on: Fri, 29 September 2023, 17:39:30 »
Relly nice, looking forward to buying!!!!
Offline herfalerf
Re: [IC] JCS Arabic
« Reply #15 on: Mon, 02 October 2023, 10:26:47 »
This is good.  Cheap pbt is good.
Offline HubertThemad
  • * St. Jude Supporter
Re: [IC] JCS Arabic
« Reply #16 on: Sat, 25 November 2023, 00:09:22 »
Cast my vote for purple sublegends 💜
Offline masje
    • masjewerke
Re: [IC] JCS Arabic
« Reply #17 on: Mon, 04 December 2023, 06:13:52 »
Hi Hugh!!!
We will provide all the colors for the GB ;)
Offline masje
    • masjewerke
Re: [IC] JCS Arabic - VENDORS ANNOUNCED, GB SOON
« Reply #18 on: Mon, 04 December 2023, 06:15:01 »
Vendors announced! Samples are in progress, GB should be soon! (Late this year or early next year!)
Please let me know if there are other regions I should cover  :thumb:
Offline Rhienfo
« Reply #19 on: Mon, 04 December 2023, 21:30:45 »
Will there be an oce vendor for this project?
| hhkb bt
| m0115
| praxis
| camo filco
| ibm model f at
| baebae tkl
Offline masje
    • masjewerke
« Reply #20 on: Tue, 05 December 2023, 09:37:29 »
Yes!
Online Rob27shred
Re: [IC] JCS Arabic - GB from Jan 3rd to Jan 31st 2024
« Reply #21 on: Thu, 04 January 2024, 09:02:26 »
What's up with the US vendor Otakeebs? They still have yet to put this set up on their site. Don't want to miss out on this GB. :-\
