Author Topic: [IC] Etar87 previously named QFRL100  (Read 52127 times)
Offline Thebloodyez
  • Just a random keyboard builder.
« on: Sun, 02 July 2023, 15:23:07 »
Etar87
Inspiration
I’m excited to announce that QFRL100 will now be called Etar87. QFRL100 name was given by me to the project as a joke (or obviously I am bad at naming projects only :p.
So what does Etar mean?
Etar(إطار) means in Arabic: whatever covers the outside of a thing, similar to a "border", reflecting both the keyboard engraving design language and its cultural roots to the designer. The name pays homage to the beauty of Arabic architecture and calligraphy, much like the V1 Arch did.
For those familiar with my work, this theme isn’t new as I always try to add some details of things that impacted me.
Specifications
7.5 degree 100% FRL.
Front H: 17.98 mm (EFH 21.55 mm).
Top and bottom mount.
Brass through weight.
Plate to top case: 7.8 mm.
Plate materials (Aluminum, PC & PP).
Mounting pads + screws 20 M2×0.4 mm (PC or FR4).
QFRL100% PCB 1.6 mm soldered and hot-swap.
PCB layout support: 10U spacebar, Split backspace, ISO enter, 1.25U left shift and 1.75U right shift, 2U and 1U on numpad.
Firmware: QMK, VIA and Vial.
Support Mx and Alps.
Weight built: 2.351 KG.
Additional information:
Case W: 437.5 mm* L: 115.2 mm.
Case Back H: 34.466 mm.
Case Bezels: Top & Bottom (9.5 mm), Sides (4 mm).
PCB MCU: atmega32u4.
PCB designed by Thebloodyezkb
PCB Layout
Solder PCB
ANSI Hot Swap PCB
QFRL100 Structure
The bottom button attached bottom pads then uses 2XM2 screws for the mount. The plate then sets on bottom button.
Renders:
Dark Blue
Dark Gold
Emerald Green
Purple
Red
Prototype V1:
Prototype V2:
V1 USB Cutout
V2 USB Cutout
V2 vs V1 Corner
Note: The V1 prototype fillet more smooth comparing V2 prototype, I am considering amending the changes in the final prototype with V1 top case fillet with V2 corners.
Price:
~450 USD for 100 MOQ ~400 USD for 100 MOQ.
Notes: I am targeting a higher MOQ than 100 to reduce the overall price, but as for now the I am aiming below 420 450 USD, and price is subject to change. Also note that the price has increased due to the hardware's limited MOQ
Vendors:
1- Clickclack (US & International).
2- Typo! Works (Taiwan).
3- Cafege (OCE).
4- Keygem (EU).
5- JaePrototypist (UK).
6- Deskhero (CA).
7- ktechs.store (SG).
Case Colors
(Old grey, Green, Blue, Red & Purple).
Aluminum Plate Colors
(Silver).
What's included:
Aluminum top & bottom case.
Plate of choice (Aluminum, PC and PP).
2 Through brass weights.
Soldered or Hot-swap PCB of choice.
UDB (unified daughter board) + JST cable
Screws (extra included).
Mounting pads + bottom buttons.
Hard carrying case.
TX AP Clip-in Stabs of choice (Normal or Long Pole).
Content creator
HubertTheMad update review
Special Thanks to!
Special thanks to my supporters.
Album Dump:
« Last Edit: Mon, 18 August 2025, 02:42:57 by Thebloodyez »
Offline Thebloodyez
Re: [IC] QFRL100
« Reply #1 on: Sun, 02 July 2023, 17:27:59 »
Update logs:[/center]
- To do:
  (Add renders)
  (Change UDB placement to central)
  (PCB V2 Prototype)
- 07/03/2023: IC Form
- 07/03/2023: The button used in the proto V1 is temporary and require new mold, Testing different pads material (POM (the current pads for V1, require new more sturdy design), Aluminum (Original design still waiting for the new buttons mold), CEM (Pending to test)).
- 07/04/2023: Added my discord & updated the button for bottom mount.
- 07/05/2023: Updated the IC form with plate material section.
- 08/28/2023: Added Caps_lock & Num_lock LED indicators to newest PCB version.
- 10/28/2023: 3D bottom button mold V1 printed (Will opensource it after GB).
- 11/18/2023: Prototype case V2 ordered along with PC pads, There will be another version of pads that I want to test as well (Will post changes once I receive the new proto).
- 12/25/2023: I will offer a hotswap PCB as an option. First I will finish from solder pcb then I will start with hotswap version.
- 12/31/2023: Received prototype V2.
- 01/17/2024: Tested bottom pc pads and need a minor changes.
- 02/01/2024: Got some positive responses from vendors I will list them once everything is settled.
- 02/10/2024: Added renders of the keyboard with layouts. List of vendors is updated.
- 02/11/2023: TX AP clip-ins stabilizers of choice will be included in the kit!
- 02/13/2024: Pictures of V2 prototype.
- 06/03/2024: Updated IC form.
- 03/22/2024: Ordered PCB V2 prototype.
- 04/14/2024: Solder PCB V2 prototype reached!.
- 04/26/2024: I tested the Solder PCB V2 prototype and I need to add some cosmetics in the GB version.
- 04/27/2024: I placed QFRL100 Hot Swap V2 prototype order and waiting for manufacturer.
- 09/03/2024: Looking for more vendors.
- 09/17/2024: Added new renders along new colors and removed WK top case.
- 10/09/2024: Locked the vendors for now
- 10/30/2024: Updated Hotswap PCB support to include (Split Back space, Split L Shift & Split R Shift)
- 11/17/2024: Removed TX Stabilizers to reduce the overall cost of the base kit.
- 12/26/2024: Corrected QFRL100 built weight to 2.351 (HubertTheMad reference).
- 05/18/2025: Prototype Hotswap PCB with the latest support.
- 06/28/2025: Ordered final the prototypes that will be sent to content creator to be built and gather final thoughts.
« Last Edit: Sat, 28 June 2025, 11:52:32 by Thebloodyez »
Offline Rhienfo
  • GOTHETIGES
Re: [IC] QFRL100
« Reply #2 on: Mon, 03 July 2023, 01:13:59 »
Looks interesting, bottom mount and alps compatibility is so good to see (10u spacebar is awesome as well)
Good luck with the IC
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
Re: [IC] QFRL100
« Reply #3 on: Mon, 03 July 2023, 23:00:00 »
Very cool mount! Do you have a discord where we can join?
« Last Edit: Mon, 03 July 2023, 23:04:55 by masje »
Offline doctorboy
    • ClackX
Re: [IC] QFRL100
« Reply #4 on: Tue, 04 July 2023, 07:48:37 »
Very cool project. The bottom mount looks quite interesting, I believe it should provide some bounce, right? Do you also already have some colours in mind?
Two recommendations from my side:
- personally, I would prefer to have the USB port centralised;
- I would also like to see the adoption of the new Molex connector for the USB daughterboard, it would be better for future compatibility.
Good luck with the IC.
Offline Thebloodyez
Re: [IC] QFRL100
« Reply #5 on: Tue, 04 July 2023, 10:02:36 »
Greetings to the longest of all bois ;D.
Thank you for your interest in the project, I added my discord in the update section.
Feel free to join!.
Offline Thebloodyez
Re: [IC] QFRL100
« Reply #6 on: Tue, 04 July 2023, 10:10:00 »
- I am sending the proto V1 for testing to get a feedback but yes there is bounce.
- As for colors I added in the IC form so based on that I will have in mind but I can see people want Silver and Black so far.
- I am considering central usb also Molex connector.
Offline Theman2k
Re: [IC] QFRL100
« Reply #7 on: Tue, 04 July 2023, 13:05:59 »
Not feeling this at all right now.
USB placement and cutout, mounting placement, bottom screws placement doesn't seem as good as it could be.
There is alps support.. but is there a matching plate offering for it?
No word on keyboard weight and PCB indicator LED's either.
No option for a thinner PCB with flex cuts for anyone who would like it.
Design is subjective, but for me it just seems bland.
Price sounds fine and it comes with a hard case which is a plus from me.
I also like the layout support, 10u is great!
I really want to like this (I love big boards) but I feel it needs some more work.  :thumb:
Offline aa212121
Re: [IC] QFRL100
« Reply #8 on: Tue, 04 July 2023, 13:42:03 »
Hope u filled out the IC :)
I guess the USB db cutout will help reduce cost cuz then it is the same 3 brass weights not 2 same weights+1 weight with db cutout - thats why no center usb. my guess.
I didnt realise this up till now, it is bottom mount? i couldnt quite understand how the current structure works with btm mount but ive been wanting a seamed case with btm mount!
« Last Edit: Tue, 04 July 2023, 13:49:55 by aa212121 »
Offline paulgali
    • SKME
Re: [IC] QFRL100
« Reply #9 on: Wed, 05 July 2023, 00:15:07 »
Both top and bottom mount afaik, to be honest with the 4 point mount on alphas I really wanna see what bottom feels like. Should be good imo
Offline Thebloodyez
Re: [IC] QFRL100
« Reply #10 on: Fri, 17 November 2023, 17:13:53 »
Due to the demand of softer material plates I included a new mounting point to the case V2.
« Last Edit: Fri, 17 November 2023, 17:36:55 by Thebloodyez »
Offline VXQN
Re: [IC] QFRL100
« Reply #11 on: Mon, 20 November 2023, 04:17:41 »
When using bottom mount, what stops the plate from shifting laterally? I have TKL that uses an o-ring mount and it's possible for the pcb/plate to hit the case which results in annoying sounds...
Offline Thebloodyez
Re: [IC] QFRL100
« Reply #12 on: Mon, 20 November 2023, 05:09:42 »
The bottom button "Head" will stop the PCB from hitting the case and the "Leg" will seal the plate from shacking. A shaking & hard bottoming out test had been done already with V1. However due to softer plate materials I added another mounting point to the top to avoid PCP with PC\POM plates from flexing and bottoming out with the case.
Note that I am still testing and waiting for proto V2 so I could do the same tests as above ;D.
« Last Edit: Mon, 20 November 2023, 05:18:57 by Thebloodyez »
Offline krautcat
  • local the flammable man without identity
Re: [IC] QFRL100
« Reply #13 on: Wed, 29 November 2023, 02:27:11 »
NeXT ADB-esque layout is lit.  :thumb:
Offline Thebloodyez
Re: [IC] QFRL100
« Reply #14 on: Wed, 29 November 2023, 11:24:06 »
I might consider "End" blocker ;)
Offline Thebloodyez
Re: [IC] QFRL100
« Reply #15 on: Mon, 25 December 2023, 14:07:11 »
I am offering a Hotswap PCB as an option!.
please check out IC Form for more feedback.
« Last Edit: Mon, 25 December 2023, 14:08:46 by Thebloodyez »
Offline Thebloodyez
Re: [IC] QFRL100 (Added Renders!)
« Reply #16 on: Sat, 10 February 2024, 15:16:09 »
Renders Added :thumb:.
Offline masje
    • masjewerke
« Reply #17 on: Wed, 14 February 2024, 23:52:27 »
Renders looking hot brother!! Excited to see this :)
Offline Thebloodyez
« Reply #18 on: Thu, 15 February 2024, 03:14:52 »
Thanks brother. I am excited too.
Offline Handke
Re: [IC] QFRL100 - V2 Prototype Pictures
« Reply #19 on: Thu, 15 February 2024, 08:38:10 »
no function keys... you call it 100?
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #20 on: Thu, 15 February 2024, 20:27:31 »
NeXT layout based
Offline Thebloodyez
« Reply #21 on: Wed, 06 March 2024, 01:02:23 »
 Its a 100 FRL ;D.
Offline Thebloodyez
« Reply #22 on: Wed, 06 March 2024, 01:06:17 »
NeXT layout based
I really like the NeXT layout specially if u pair it with 10U spacebar.
Offline Necrolegion
« Reply #23 on: Wed, 06 March 2024, 14:06:37 »
Any chance to add a dirty South Paw version with the numpads on the left side?
Offline Thebloodyez
« Reply #24 on: Fri, 15 March 2024, 18:32:49 »
Unfortunately it wont be possible for this project :'(.
Offline Dmitri
« Reply #25 on: Sat, 16 March 2024, 09:49:36 »
Longboi
Offline Thebloodyez
« Reply #26 on: Sat, 27 April 2024, 04:36:08 »
Solder PCB Updated!
Offline Paul Turner
« Reply #27 on: Mon, 27 May 2024, 01:53:37 »
Keyboards usually come in different sizes and functions
Offline Thebloodyez
« Reply #28 on: Tue, 03 September 2024, 16:52:58 »
Updated the list of vendors. and yup it is still alive :p
Offline Thebloodyez
« Reply #29 on: Tue, 17 September 2024, 02:47:59 »
Updated the post with a new render and colors! :cool:
Offline KrisonB
Re: [IC] QFRL100 - New Render and Colors added!
« Reply #30 on: Tue, 17 September 2024, 03:40:27 »
Dark gold (brown) so good
Offline Thebloodyez
« Reply #31 on: Tue, 17 September 2024, 07:08:54 »
It is really looks like brown\bronze, I am just inserting color names based on the manufacture ;D.
« Last Edit: Thu, 19 September 2024, 02:18:02 by Thebloodyez »
Offline HubertThemad
  • * St. Jude Supporter
    • Podcast Links
« Reply #32 on: Wed, 25 December 2024, 13:12:40 »
An absolutely amazing looking board, great typing feel, and sounds great (although that's subjective of course).
If you can hit the $400 for 100 MOQ price point, I think this board will make many people happy!
I joined the prototype run for this board, and all of us agree that the board is fantastic. Makes data entry and work something to look forward to every day.
YouTube Video Review:
Sound Test Compilation 1:
Sound Test Compilation 2:
« Last Edit: Wed, 25 December 2024, 13:20:11 by HubertThemad »
Offline Ceyx
« Reply #33 on: Sun, 29 December 2024, 10:54:19 »
Another banger I'd like with BT. Happy for everyone who doesn't require it.
Offline Sinister Slim
  • Weeb Keeb Enthusiast...
« Reply #34 on: Tue, 10 June 2025, 20:24:36 »
Just curious, what's the idea/inspiration behind the engravings on the weight?
« Reply #35 on: Sun, 15 June 2025, 19:38:54 »
Do we have rough idea which month for the GB date?
Offline KOBO ISSHI
« Reply #36 on: Sun, 15 June 2025, 21:52:38 »
Love the mount, top work!
Offline Ape
« Reply #37 on: Thu, 19 June 2025, 10:37:35 »
OMG PLEASE tell me that yellow will be an option! That is one beautiful board!
Offline KOBO ISSHI
« Reply #38 on: Thu, 26 June 2025, 23:13:07 »
Actually think i'll get one. The yellow is very cool indeed.
Offline Thebloodyez
« Reply #39 on: Sat, 28 June 2025, 05:43:30 »
Hey the yellow was a 5 MOQ GB run and it was done with a different manu.
Unfortunately the yellow will not be available with the final GB...
Offline Thebloodyez
« Reply #40 on: Sat, 28 June 2025, 05:47:14 »
Hey the yellow was a 5 MOQ FNF GB and done with a different manu (our most beloved manu around) unfortunately the final GB will be with a different manu and that color option is not available.  :'(
Offline Ape
« Reply #41 on: Tue, 01 July 2025, 07:29:54 »
Oh well - the other colors look good as well!
Looking forward to the next updates!
Offline Thebloodyez
« Reply #42 on: Fri, 15 August 2025, 15:06:46 »
The next update is the keyboard name change! Also stay tuned for coming updates soon :))
Offline Saurov
Re: [IC] Etar87 previously named QFRL100
« Reply #43 on: Sat, 06 September 2025, 15:58:21 »
Love this layout and the design, can't wait for gb
Offline VXQN
« Reply #44 on: Mon, 08 September 2025, 02:20:08 »
Absolutely lovely design. Sadly too wide for me (but if the numpad was on the left...) so I won't be purchasing but GLWGB!
Offline CEGeek
« Reply #45 on: Thu, 11 September 2025, 01:39:21 »
I've never used a 10U spacebar before. I'm really curious and excited to see how it performs.
