Author Topic: [GB] NESON DESIGN | The 810E Series Ver.3 keyboard · Group Buy in November15th ·  (Read 142095 times)
Offline Simen
Hello everyone, this is NESON DESIGN Studio.
Neson Design Discord:https://discord.com/invite/kTAtCrYfPM
Neson Design Instagram:https://www.instagram.com/neson.design/
303164-0303166-1
303168-2303170-3
303172-4303174-5
303176-6303178-7
Here is the link to the IC post for The 810E Series keyboard:https://geekhack.org/index.php?topic=120539.msg3164030#msg3164030
Let me briefly introduce the differences between Ver.3 and Ver.2:
1.We have added a design feature called "force break" to the keyboard casing. "Force break" is a "Mod" technique that has enjoyed widespread use among keyboard enthusiasts worldwide for an extended period. We've integrated the principles of this method and redesigned it in a way that better suits fulfills our needs and achieves optimizations.
Note: The force break principle fundamentally alters the transmission path of vibrations within the keyboard casing, influencing the damping along this path and thereby allowing for precise adjustments to the acoustic performance of the casing.
303180-8
2.We've implemented adjustments to the acrylic diffuser's dimensions at the rear end. Specifically, we've expanded the width on both the left and right sides by 0.8mm, resulting in an improved overall visual aesthetic.
3.We've added a 2mm plate light-blocking sticker to address the minor light leakage issue from the front.
303182-9
Specifications and price
Layout: (F-row-less 1800 with isolated spacebar)
Mounting Style: Gasket mount with Leaf Spring plate
Typing Angle: 9° (Front Height 17.9 mm, EKH 22.7 mm)
PCB: 1.6mm non-flex cut, separate RGB USB-C daughterboard (supports QMK, VIA, VIAL, supports soldered or hotswap [designed and manufactured by Astro])
Layout Options: WK / HHKB
GB Price: 480 USD
GB Date: November 15th, group buying period for two weeks
Shipping Date: 2024Q2
Exploded View
303184-10
Includes
·Keyboard Kit(Aluminum top case, aluminum mid-frame, aluminum bottom case, Electroplated stainless steel mirror badge, diffuser plate, aluminum internal and external weight) × 1
·Light-blocking Cover × 1
·Aluminum plate × 1
·1.6MM Hotswap / Soldered PCB (choose one) and separate RGB USB-C daughterboard × 1
·Spacebar support foam (PORON) × 1
·Diffuser plates for the light strip (internal and external acrylic) × 1
·30 degree hardness C-shaped Gaskets × 8
·3.5MM PORON foam × 1
·1MM case foam × 1
·6-pin connecting cable × 1
·Bumpons × 2
·User manual × 1
Layout
Soldered:
303186-11
Hotswap:
Because of the reduced front height in the structure, incorporating multiple compatible layouts in the spacebar row is not feasible. Consequently, the ultimate decision is to adopt the following fixed layout, which is compatible with both HHKB and WK configurations.
303188-12
Badge options
(Choose one from the two, no additional purchases are allowed)
303190-13
Option A: The diffuser is relatively luminous, and when observed from a seated position, it presents noticeable brightness in both side and top views.
Option B: The diffuser is relatively subdued because the illumination emanates from the sides. Consequently, when viewed from a top-down angle, the lighting might seem dim, but it imparts a more pronounced ambiance.
Internal weight color option
Black or Silver
303192-14
External weight upgrade option
Standard black aluminum external weight (Default)
303194-15
Upgrade to Black Electroplated Stainless Steel Brushed Weight: +45$
Upgrade to Black Electroplated Stainless Steel Mirror Weight: +80$
Add-ons option
303196-16
ANSI / ISO Aluminum plate  +30$
ANSI / ISO FR4 plate +30$
ANSI / ISO PC plate +30$
Hotswap/Soldered PCB (3.5MM PORON foam, 0.5MM PORON case foam,does not include RGB DB)  +65$
Colorway
(The mid-frame and bottom case of the 810E are available exclusively in anodized black, with no other color options. The standard aluminum external weight is also fixed in black color.)
Black(Anodized Black Top、Anodized Black Mid、Anodized Black Bottom)
303198-17
Gray(Anodized Gray Top、Anodized Black Mid、Anodized Black Bottom)
303200-18
Silver(Anodized Silver Top、Anodized Black Mid、Anodized Black Bottom)
303202-19
Green(Anodized Green Top、Anodized Black Mid、Anodized Black Bottom)
303204-20
Blue(Anodized Blue Top、Anodized Black Mid、Anodized Black Bottom)
303206-21
Champange(Anodized Champange Top、Anodized Black Mid、Anodized Black Bottom)
303214-22
Cream(E-Cream Top、Anodized Black Mid、Anodized Black Bottom)
303216-23
(The colors depicted in the above rendering are provided for reference purposes and may not accurately represent the final product.)
Vendor:
Click Clack (Global shipping)      【Group Buy Link】: https://clickclack.io/products/neson-studio-810e
Novelkeys (North America)         【Group Buy Link】: https://novelkeys.com/products/neson-810e-keyboard
iLumkb(Southeast Asia)          【Group Buy Link】:https://ilumkb.com/collections/live/products/neson-studio-810e
Candykeys(Europe)                 【Group Buy Link】:https://candykeys.com/product/neson-studio-810e-mechanical-keyboard-kit
Swagkeys(Korea)                    【Group Buy Link】:https://www.swagkey.kr/38/?idx=676
Kukey Stduio(Indonesia)          【Group Buy Link】:https://kukey.studio/products/neson-studio-810e-mechanical-keyboard-kit-group-buy
NTCH Keys(Thailand)                【Group Buy Link】:https://ntchkeys.com/สินค้า
Jaekeyed(Philippines)               【Group Buy Link】: https://jaekeyed.com/products/gb-neson-design-810e-mechanical-keyboard-kit
JaePrototypist(UK)                    【Group Buy Link】:https://prototypist.net/collections/live-group-buys/products/group-buy-neson-studio-810e
The 810E Ver.2 submission list includes the following streamer/youtubers:
Name:                        Keyboard Color:                          Time:
Alexotos                       Gary 810E WK
https://www.youtube.com/watch?v=NJuMxQtsNtw&t=1s
Dbokey                         Black 810E WK
https://www.youtube.com/watch?v=fkpSxQJYnH4
Febust Channe              Black 810E HHKB
https://www.instagram.com/p/CzYQwFCv38y/
Edward Tanujaya           Blue 810E WK
https://www.instagram.com/p/Cy8GBUlvmTt/
Clackbait                      Cream 810E HHKB              (November 15th)
Heikey                         Champange 810E HHKB
https://www.youtube.com/shorts/uAI4NgTuV3E
Tristan Green                Green 810E HHKB
2024.1.31 Updates on The 810E Series Group Buy:
« Last Edit: Wed, 31 January 2024, 05:53:47 by Simen »
Approved :thumb:
PSA to prospective buyers:
Group Buys are inherently risky endeavors. There is an element of risk involved with collecting payment before the item has been produced and resulting uncertainty during manufacturing / subsequent operations. We urge all GB organizers to consider (and document) these risks, and want to make it clear to all who consider purchasing that these risks are present.
If you are unfamiliar with the Group Buy model, please read this primer - Group Buy FAQ / Buying Guidelines
This PSA is new and will become standard on all Group Buys moving forward. It is not posted on this GB in isolation and is not singling this organizer out in particular as someone to be wary of.
Offline Yehuo.
Unique split spacebar, cool design elements, and comes with a layout I need to use on a daily basis, I need it in my life, take my money
Offline Rob27shred
  • Insane in the Membrane! 👻
I think I might need one of these :eek:
Offline IBMweMissU
Any reason the solder PCB does not allow a split + key?
Offline Anorexus
  • Designer
    • Anorexus Web
Very unique design, good luck with the GB!
Offline Spockismyhomeboy
This very honestly might be my exit in the hobby in the best way possible :). A while back I sketched up my perfect board which is a resign/recreation of the old TRS-80 MODEL 3 board (basically.HHKB with a numpad) and this just checks every single box. Worth waiting for :)
Offline Tseg
I'm looking forward to getting my The 810E in 2Q24.
Offline Morbii
Got mine today and already built it.  Fantastic board.
Will it be possible to get additional light blockers to support multiple builds?additional gaskets would also be great, but less necessary than the light blockers.
