Author Topic: [IC] GMK CYL OG Extensions | GB July 15 - Aug 12  (Read 38525 times)
Offline busytimmy
« on: Fri, 29 March 2024, 23:02:54 »
GB CONFIRMED - July 15 to August 12
This is my first IC, please use lube.
Looking to gauge interest and obtain feedback on kitting.
Why?
My goal with these kits is to extend the usefulness of GMK sets like Hineybeige and Dolch R5 for keyboard layouts where you might prefer a less aggressive bottom row profile, particularly those with winkeys.
If you love beige and dolch sets (like me) but prefer a R4 bottom row for non-TKL layouts like 60, 65, 1800, etc., then this is the extension kit for you.
Also taking the opportunity to offer 1.5 super and 1u alt keys, for HHKB enjoyers.
R4 Kit
Macros Kit
Colours
Beige Kits:
GMK U9/L9 / CR
Dolch Kits:
GMK N9/CC / CP
WoB Kits:
GMK CR / WS1
Note: Windows and Menu keys will be manufactured in UV-print
Pricing & Vendors
Pricing:
R4 kit ~$45 USD
Macro kit ~$30 USD
Vendors:
Daily Clack - OCE
NovelKeys - NA
Oblotzky Industries - EU
Prototypist - UK
zFrontier - CN/SEA
Sandkeys - Middle East
Board Renders
Daal by Ankit
Cypher by Cable Car Designs
Seis Cero by Daji
Oku by NRD
Fossil by Carolina Mech
Big Thanks
Pensa (renders and general good looks)
Ankit, V, RadarNois (guidance and general good looks)
« Last Edit: Thu, 11 July 2024, 20:00:13 by busytimmy »
Offline busytimmy
Re: [IC] GMK CYL R4 OG
« Reply #1 on: Fri, 29 March 2024, 23:03:28 »
Change Log
April 2nd, 2024
•   Addition of WoB kit
•   Replacement of one 1.5u and one 1.25u alt key for alt gr keys
May 9th, 2024
•   Removal of WoB kit (see faq and lower in the thread)
•   Updated renders to include 1.5u Hangul control & alt
June 5th, 2024
•   Vendors added
June 9th, 2024
•   Topic renamed from 'GMK CYL R4 OG' to 'GMK CYL OG Extensions'
•   WoB Kit added back in
•   Macros Kit added
July 12th, 2024
•   GB dates confirmed and indicative pricing added
FAQ
1.   Will you consider this amazing set in WoB as well?
Yes! Enough people have requested this to make it viable. See change log.
2.   ne alt gr avail?
3.   Can we replace OG Windows and Menu keys with something else (sys, super, FN etc.)?
No, that would defeat the point of the set which is to have these 'OG' keys.
« Last Edit: Thu, 11 July 2024, 18:04:30 by busytimmy »
Offline caap
« Reply #2 on: Fri, 29 March 2024, 23:20:32 »
 :thumb:
Offline MoarCoffeePlzzz
  • Formerly Deeptek
« Reply #3 on: Fri, 29 March 2024, 23:25:00 »
In for a beige set.  :thumb:
Offline extrapriusplease
    • All my links
« Reply #4 on: Fri, 29 March 2024, 23:26:07 »
timmy you son of a gun i am in so freaking hard  :p
Offline RadarNois
« Reply #5 on: Fri, 29 March 2024, 23:29:07 »
Ayo making me break my GH post cherry
deffo in for multiple sets  ;)
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #6 on: Fri, 29 March 2024, 23:57:00 »
In for one of each, probably. Love the old school win keys.
Offline iamtragic
« Reply #7 on: Fri, 29 March 2024, 23:57:59 »
Glorious. Any chance of including numpad text + icon enter?
Offline mcmcmc
« Reply #8 on: Sat, 30 March 2024, 00:29:52 »
i'd like text fn but that's fine. cool!  :thumb:
Offline Bunn3y
« Reply #9 on: Sat, 30 March 2024, 00:38:39 »
I see Dolch I buy  :thumb:
Collection: Ivery Praxis || HHKB Pro 2 || JTD.Works Ovinnik || Realforce R1 87u || Switchplate iiA Sanction
Offline vinnyy
« Reply #10 on: Sat, 30 March 2024, 00:54:12 »
 :thumb: Good luck on this timmy!! R4 Lovers rejoice!
collection:
   Daji Ocho Cuatro x3, Daji Ocho Cuatro 2XL, HHKB Pro 2, Filco 1
Offline whirlwind
« Reply #11 on: Sat, 30 March 2024, 01:49:06 »
In for a few kits, please consider WoB R4 kit too :thumb:
Offline offbrandbiscuit
« Reply #12 on: Sat, 30 March 2024, 02:32:54 »
Reserved simply because icon windows keys  :D
i like fire trucks and moster trucks
Offline Fraaaan
« Reply #13 on: Sat, 30 March 2024, 02:49:01 »
Great project, GLWIC  :thumb:
Offline JLC
« Reply #14 on: Sat, 30 March 2024, 04:06:51 »
This is great! I'd be in for at least 2 sets.
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #15 on: Sat, 30 March 2024, 04:45:03 »
This is really cool to see, would like to have alt gr as well. GLWIC
« Last Edit: Sat, 30 March 2024, 05:50:32 by Rhienfo »
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline CircuitHero
« Reply #16 on: Sat, 30 March 2024, 08:07:08 »
I was just thinking about how i'd like my Hineybeige set to be R4. In for multiple sets
Offline chigi22
« Reply #17 on: Sat, 30 March 2024, 09:15:36 »
OMG perfection. In for one of each. Glad I waited to pull the trigger on whole ass sets just to get beige and dolch R4.
Offline juaninamilli
[IC] GMK CYL R4 OG
« Reply #18 on: Sat, 30 March 2024, 09:28:04 »
In 100% for this. Thanks for making these an option for our special snowflake needs!
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #19 on: Sat, 30 March 2024, 09:35:41 »
I'd be in on this if not for the windows logo keys (and that sad fax). Consider System or Super or anything else, really.
Offline headshot
« Reply #20 on: Sat, 30 March 2024, 18:47:28 »
count me in, glwic
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #21 on: Sat, 30 March 2024, 20:37:22 »
What all these crappy r5 exclusive runs does to a mfer
Offline busytimmy
« Reply #22 on: Sun, 31 March 2024, 02:00:26 »
Stoked to have so much feedback already, thank you all!
Likely changes at this stage:
- Include a WoB kit
- Replace one 1.5 and 1.25 alt key with alt gr keys
Keep the responses coming  :thumb:
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #23 on: Sun, 31 March 2024, 06:46:01 »
GLWS
Like others said before me: No Alt Gr? Wouldnt that be more “OG”
« Last Edit: Sun, 31 March 2024, 06:47:49 by twitchytheinsideman »
Offline Fraaaan
« Reply #24 on: Sun, 31 March 2024, 08:21:07 »
GLWS
Read the comment above yours.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #25 on: Sun, 31 March 2024, 09:49:41 »
We've come full circle from R5 kits to R4 kits! :p Not really up my alley since I prefer R5 personally, but I do see the demand for this as there has been a good bit of GMK sets sold recently that had just R5 bottom rows. GLWIC! :thumb:
Offline tom0
« Reply #26 on: Sun, 31 March 2024, 12:58:40 »
I love the windows key but having another option would be nice too
Offline busytimmy
« Reply #27 on: Mon, 01 April 2024, 17:49:46 »
Change Log and FAQ sections added (post #2)  :thumb:
Edit: WoB Kit added and IC form updated
« Last Edit: Tue, 02 April 2024, 02:43:54 by busytimmy »
Offline azhdar
  • Praise the AZERTY god
  • 65% Enlightened
« Reply #28 on: Tue, 02 April 2024, 22:39:38 »
Watching this
Azerty Propagandiste
Offline Zestrion
« Reply #29 on: Tue, 02 April 2024, 23:02:33 »
og winkeys and alt gr, so based
Offline syntezrx
« Reply #30 on: Wed, 03 April 2024, 14:01:14 »
in for 1 of each, ****ing A job
Offline stomaha
« Reply #31 on: Wed, 03 April 2024, 17:52:45 »
in for 2 of each.
Offline Delecomp
  • Pure Color Addiction.
« Reply #32 on: Wed, 03 April 2024, 18:32:31 »
In for 2 of each, really good job!
Villanelle
Offline mr_foggy
  • neue = nope
« Reply #33 on: Fri, 05 April 2024, 04:38:23 »
R5 enjoyer but this is a good project. glwic
Offline lampmk
  • wk 60 > wkl
« Reply #34 on: Mon, 08 April 2024, 00:03:39 »
please xbox backspace PLEASEEEEE
My collection -
Ovinnik - Kaze - Dodici - Spyder - Duck Eagle v3 - TGR Dolice - HHKB Pro2 Type S - Heavy Grail GOCF - Matrix Falcon
    • Twitchy Homepage
« Reply #35 on: Mon, 08 April 2024, 02:21:41 »
that's r2
though i would like to own xbox backspace too
Offline mr_foggy
  • neue = nope
« Reply #36 on: Mon, 08 April 2024, 08:20:00 »
unsure how that would affect cost but it would be based af
Offline save_me
« Reply #37 on: Wed, 10 April 2024, 20:16:40 »
perfect, interested in multiple sets.
Offline s3cr3tmyth
« Reply #38 on: Wed, 17 April 2024, 20:02:05 »
In for one of each gl! :thumb:
Offline dyrdevil
« Reply #39 on: Thu, 18 April 2024, 00:00:42 »
definitely interested in dolch, might go for beige too
Offline crowcrowcrow
« Reply #40 on: Tue, 30 April 2024, 16:51:48 »
PLEASE add the cool split backspace from gmk 9009 r1 into this it would really fit the theme of og PLEASE
« Reply #41 on: Sun, 05 May 2024, 18:21:10 »
Love the classic windows logo and menu keys, in for a WoB.
Offline busytimmy
« Reply #42 on: Wed, 08 May 2024, 19:18:07 »
Happy to share this project looks to be moving forward  :thumb:
Some kitting updates based on further community feedback and discussion with vendors (FAQ updated):
- WoB kit won't be included unfortunately; we're going back to the original plan of beige and dolch kits only.
- Hangul control and alt keys will likely be included in 1.5u (beige and dolch). Loads of people asked for this. Awaiting updated quote from GMK.
Offline iamtragic
« Reply #43 on: Wed, 08 May 2024, 23:00:25 »
Big win for the hangul lovers - much appreciated.
Offline Rob27shred
« Reply #44 on: Mon, 13 May 2024, 09:24:55 »
You know what, I second this! A 1.5u R2 Xbox backspace key would have me grabbing a kit just for that!
    • Twitchy Homepage
« Reply #45 on: Tue, 14 May 2024, 07:16:19 »
add a separate full kit of icon mods while you are at it. ;D
both beige and dolch icon mod kits are super hard and expensive to acquire. for beige it is 9009 R1 (2016) and for dolch it is Dolch R1 (2014) and Burgundy R1 (2017) that last had icon mods (with xbox backspace)
imo icon mods are also part of OG history. so would definitely fit the theme of this set!
Offline Rob27shred
« Reply #46 on: Tue, 14 May 2024, 22:25:17 »
Probably asking a bit much from where this ideal started so I doubt it. Although this is also a great ideal, might even be something that could run on its own merit TBH.
Offline Lysol_
« Reply #47 on: Tue, 14 May 2024, 22:59:18 »
love only question i have is that are spacebars possible? like 6u/6.25u/7u?
Offline fwoggit
« Reply #48 on: Wed, 22 May 2024, 02:41:44 »
need
Offline mr_foggy
  • neue = nope
« Reply #49 on: Wed, 22 May 2024, 16:57:03 »
we definitely need something like this
