Author Topic: [IC] KKB Dolch Neo | R0, R5 in base, & big keys!  (Read 27133 times)
Offline masje
  • Your neighborhood keyboard designer.
    • masjewerke
Re: [IC] KKB Dolch Neo | R0, R5 in base, & big keys!
« Reply #50 on: Fri, 14 June 2024, 03:34:20 »
you should separate the tkl and num
**** no they should not.
please add windowed keys to the extension kit.
consider offering a hangul sub alpha kit. kkb has the molds from jindo. yes I missed the gmk child kit.
honestly, I think separating them is the way forward, you prevent the waste of a lot of keycaps.
The key is keeping the pricing low.
For example, if i could make TKL base 80 bucks, and a numpad kit 10 bucks, would people still complain? I think not.
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #51 on: Fri, 14 June 2024, 16:16:35 »
No question that minimizing waste plastic is good for the environment. I'm a numpad user, and I'm all for TKL+Numpad with your target prices ($80 TKL, $10 Numpad).
I recently looked at 17 previous KKB GBs and Numpad users did not fare as well. Average prices were Numpad $20, TKL $92, Full $96. So with split kits, Numpad users paid about 4 times what TKL users saved.
Offline masje
    • masjewerke
Offline HubertThemad
  • * St. Jude Supporter
« Reply #53 on: Tue, 22 April 2025, 15:09:14 »
 :( well, we appreciate all the work you put into it regardless. Onto Triumph Adler Neo I guess!
Offline mr_foggy
  • neue = nope
« Reply #54 on: Wed, 23 April 2025, 05:05:39 »
dead bc https://www.instagram.com/p/DH2-ZaLvXfP/?utm_source=ig_web_button_share_sheet&igsh=MzRlODBiNWFlZA==
thanks kkb.
does this mean kkb just decided out of the blue to run Dolch on their own while you were planning to do so for a year?
Offline Mikhail
« Reply #55 on: Thu, 24 April 2025, 04:23:48 »
This BAE have ISO Enter legends. Please make real historical correct legends, not like this, and not like GMK and SP made.
Offline EdgeOfInfinity
« Reply #56 on: Fri, 02 May 2025, 16:03:48 »
as i still don't own any KKB or Dolch sets, this would've been perfect for me. really like the "neo" stuff, shame we won't get this set now.
Online Rob27shred
  • Insane in the Membrane! 👻
« Reply #57 on: Sat, 03 May 2025, 18:54:12 »
Damn this set got canned.. :'( Shame cause I was really happy with my KKB Skidata Neo set & was really looking forward to this one. KKB has excellent quality IMO, just shy of GMK but definitely better than any double shot ABS sets beyond them. I will say the color matching was a bit off with Skidata Neo, I originally joined that GB for everything but the base kit hoping to use them with the GMK Skiidata base I have, but the the blacks were just off enough to make it noticeable so I ended up having to grab the KKB base. Although beyond that I have no complaints about any of the 3 KKB sets I got as of right now.
