Author Topic: [IC] Keykobo Verdigris - Pricing and GB date  (Read 37928 times)
Offline Zetina
  • Big bird
    • Instagram
« on: Sat, 08 June 2024, 19:55:21 »
KeyKobo Verdigris
A Keycap set inspired by the Verdigris pigment developed by copper statues through oxidation.
GB DATE
9 of September - 9 of October
GB POST
Kits
Renders
Haus by Hand Engineering
Kaze by NRD Designs
910 by TGR
Phidias by Brunosan
Ryu Ergo by Geon
F1-8X 722 by Geon
Deskmat
900mm x 400mm x 4mm size, Rough surface, rubber bottom
By Roksow
Color sample
Samples for the accents will be requested in the following days
Vendors
US: Clickclack
CA: Unikeys
EU: Keygem
UK: Prototypist
SEA: iLumkb
KR: Geon
OCE: Switchkeys
TW: PNKeyboard
VT: MOKB
TH: Aiglaston
CN: Zfrontier
Pricing
  • Base kit: $93
  • Add-on: $25
  • Numpad: $19
  • Novelties: $55
  • Deskmat: $25
This pricing is only for the US region and during the GB period, other regions can vary
Special thanks to:
  • Stelladoscope for the amazing work on the novelties.
  • To all the guys on the KatanaKaji discord :-*.
  • Roksow for the amazing deskmat
If you are interested in being a vendor or doing a collab for the set you can reach out to me on discord as zetina.kb
You can also follow me on Instagram for more updates or join the Room 181 discord
If you want to support this project, consider adding the signature below to your profile:
Code: [Select]
[url=https://geekhack.org/index.php?topic=123110.0][img width=304 height=120]https://i.imgur.com/UTLJJKz.jpg[/img][/url]
« Last Edit: Tue, 10 September 2024, 22:08:49 by Zetina »
Instagram: @zetina.kb
Offline Zetina
  • Big bird
    • Instagram
Re: [IC] Keykobo Verdigris
« Reply #1 on: Sat, 08 June 2024, 19:59:30 »
Reserved  :cool:
Offline paperassgasket
« Reply #2 on: Sat, 08 June 2024, 20:08:06 »
I love copper but I don't feel the urge to own this.
Maybe it's the modifier color, idk. I haven't put much thought into it beyond "this is just inverted GMK Pulse"
Offline zhol
  • zhol
« Reply #3 on: Sun, 09 June 2024, 00:38:27 »
oh my god I see the vision
i'm zhol
Offline Fraaaan
« Reply #4 on: Sun, 09 June 2024, 04:07:23 »
The UK ISO numbers from base should be alpha colored, and you can move R1 PgDn and R1 End from base kit to numpad kit since they're for 1800 layout support.
Also your scroll lock legend in base says "Scroll" while the windowed version from the extension kit says "Scroll Lock." Not sure if this is on purpose or not, but it would make sense to me that the legend stays the same.
GLWIC!
Offline Zetina
  • Big bird
    • Instagram
« Reply #5 on: Sun, 09 June 2024, 10:04:19 »
Thanks for pointing it out, End and PgDn keys have been moved to the numpad kit and the Scroll lock legend was a rendering mistake, should all be fixed now.
Also added Alice support to base  ;D
GLWIC!
Offline HugoChowsky
« Reply #6 on: Sun, 09 June 2024, 12:18:12 »
Suggesting Rebult Keyboards as vendor for Malaysia
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #7 on: Sun, 09 June 2024, 13:00:24 »
You have my attention for sure with this CW!
Offline tactilesbad
« Reply #8 on: Wed, 12 June 2024, 05:23:49 »
stop separating numpads from basekits
Offline Zetina
  • Big bird
    • Instagram
Re: [IC] Keykobo Verdigris - New accents added
« Reply #9 on: Tue, 25 June 2024, 17:42:42 »
Quick and first update, macro keys have been added to the novelties kit and accents have been added both to the base and novelties per popular demand
p.d: a pair of extra novelties is in the works at the moment
Offline Zetina
  • Big bird
    • Instagram
Re: [IC] Keykobo Verdigris - New deskmat!
« Reply #10 on: Wed, 03 July 2024, 15:33:47 »
Added the deskmat for the set
Offline keepoto
  • HHKB top for TKL pls
« Reply #11 on: Wed, 03 July 2024, 15:52:18 »
Roksow classy as always glwic
Offline Zetina
  • Big bird
    • Instagram
Re: [IC] Keykobo Verdigris - Vendors announced
« Reply #12 on: Wed, 10 July 2024, 14:46:54 »
Vendors added
Offline Zetina
  • Big bird
    • Instagram
Re: [IC] Keykobo Verdigris - GB and deskmat sample picture added
« Reply #13 on: Thu, 08 August 2024, 18:08:30 »
We finally have a date for the GB! thanks to everyone for their support on the project  :thumb:
Also added a photo of the deskmat sample (which turned out great)
Offline caghuama
Re: [IC] Keykobo Verdigris - Pricing and GB date
« Reply #14 on: Thu, 22 August 2024, 18:09:37 »
N
Offline dvorcol
  • Discord: dvorcol_5071
« Reply #15 on: Sun, 08 September 2024, 20:35:10 »
