Author Topic: [IC] Caerdroia by AKB (Price and GB date announced!)  (Read 20154 times)
Offline Alchemist Keyboards
    • Alchemist Keyboards
« on: Tue, 18 June 2024, 09:34:56 »
GB THREAD LIVE
Among the roots of the trees you awaken,
Birds leer rapturously upon your disoriented visage,
The redstart solemnizes your parturition with angelic aria,
You recall the year was at its twilight, yet now birthed anew, blossoming with verdant,
All of your consciousness, connected with the weald like hyphae,
Abstracting your past life beyond all fragile recall,
This caerdroia is sacred, you know that you are home now.
The trees willed it, again.
When finding inspiration for designing new boards, sometimes I look back to vintage keyboards and computers, but other times I find inspiration in things that are much more abstract.
With Caerdroia, I wanted to finally design a TKL that I would be proud to put my name on but with so many of them out there already it was tough to come up with something entirely unique. It felt like everything had been done already and I think the reason why it took me over 3 years to finally start designing a TKL for AKB was because I was a little jaded by this, especially given that the majority of TKLs (to me) seemed to copy elements from their contemporaries, or other designs that have truly stood the test of time. I wanted to try and design my TKL so it was truly unique from every angle, and to do that I had to go down the abstract route for inspiration.
I learned about what a Caerdroia was late one evening while deep down a wiki hole - it is essentially a maze in a forest in Wales formed in a labyrinthine shape. While it has no truly historic significance, it has been adopted by various spiritual groups in the area and is hailed as a place of mystical enlightenment. I started with this idea and over time it blossomed into more of a fictional narrative about a sentient forest that would "adopt" unfortunate souls who happened to wander within it, and they would dutifully remain forever - bending to the forest's will. We take inspiration wherever we can find it right?
In March 2024 I worked with CannonKeys to do an in-stock sale of this board, limited to just 50 units. That was fixed to WKL only, and only came in one exclusive colourway. Now I'd like to expand the options, make subtle improvements and offer it to the wider community.
Links:
AKB Website
AKB Discord
See Caerdroia at CannonKeys
Key specs:
Additional specs:
  • Top-mounted 4.5mm MX plate (only)
  • EC kits and Alps kits to be available as add-ons
  • The revised USB hub has 2x USB Type-A ports with USB 3.0 support (supports USB 2.0 fallback if the connected device doesn't support 3.0 spec)
  • Manufactured by Hongtu
Confirmed colorways:
As soon as I posted the update with a colour poll, I realised I probably shouldn't have done that. My goal with this keyboard was to provide a curated
experience rather than throw every option at the wall to try and satisfy absolutely everyone, so that is what I have done with the colourways too.
Dolch
Previously with the in-stock round, I chose to run the board exclusively in the Dolch colourway as that was how I had always imagined it throughout
the design process; I personally can't really see this board any other way. I did also say previously that Dolch would be exclusive to the in-stock round,
but those boards didn't quite come out as intended - they were still very nice, but they weren't Dolch. Given that this board will be physically
colour-matched to an OGR (as was is0GR and Petrichor) it should come out as intended as a close approximation to the original.
Given that the OGR, is0GR and Petrichor have all had Dolch colourways now, it only feels natural to continue this trend and adopt this as kind of an
unofficial trademark of AKB moving forward with most projects.
E-Beige
Given that the most recent prototype was shown in this colourway, it just made sense to keep this as part of the lineup. Looks tasty too.
Verdant
When looking at the results of the colour poll from the IC form, all of the colours had virtually the same number of votes. This is my favourite colourway
after Dolch and it also ties in thematically with the story of this board that I want to tell. There is a small tweak now though - now the bottom case
shares the same warm, earth-toned grey with Dolch, as I think it is a much more complementary colour than the cold dark grey that was used before.
Earth tones all the way baby  :thumb:
Alta Rubedo
As with Verdant, I've altered the colourway slightly to use the Dolch bottom colour, fit the vision more closely and share an overall warmer tone. There is an
additional plus to this, as cutting down the number of unique colours used across the lineup has allowed me to keep the costs down to within expected margins,
as selling this board for $450+ was never considered as an option.
V1 Prototype Photos:
V2 Prototype Photos:
Note: The first top case part was missing an engraving so when a replacement was shipped out it had a slightly different shade, hence the slight two-tone look.
Additional renders:
Changes from the in-stock version:
  • Added EC support, based on Cipulot's EC TKL X PCB
  • Adjusted case screw position on the front to allow room for EC stabiliser wire
  • Adjusted internal AKB logo engraving
  • Expanded thicc plate compatibility
  • Adjusted the geometry around right shift on the thicc plate as some stabs didn't fully clear
  • Added force break gasket at the front-middle of the board due to screw position adjustment for EC
  • Adjusted alignment post design
  • Adjusted weight geometry (internal) for ease of production
  • Fix Alps plate to now support full right shift
Some context regarding the change to USB 3.0.
Some minor adjustments have had to be made to the bottom case to house the shiny new 3.0 hub, and due to the many additional components
required the decision has been made to connect the two daughterboards together into one, to make use of the extra PCB real estate. The only
external change made to the board is the USB-C port has been lowered by 1mm.
Compatibility:
Default (thick) plate support,
Solder MX PCB,
Alps PCB:
Hotswap MX PCB
Alps Plate (MX stabs by default)
Plate files with OG stabilizer compatibility will be open sourced
EC PCB support (Prepare yourself...also keep in mind not all of these will be compatible with the plate in the kit.
GB plans/details:
  • GB will be launching on Friday, 11th April 2025.
  • Price will be starting from $420
  • Regional vendors to be announced over the next couple of weeks, but this project will be managed by myself through CannonKeys  :thumb:
« Last Edit: Mon, 31 March 2025, 07:15:05 by Alchemist Keyboards »
Offline jpro
Re: [IC] Caerdroia (TKL) by AKB
« Reply #1 on: Tue, 18 June 2024, 09:59:46 »
I snagged one of these during the in-stock drop and it is truly an exquisitely designed board. Glad more people are going to get a chance to try one of these beauties. Good look with the IC!
Offline LMarci
« Reply #2 on: Tue, 18 June 2024, 10:22:22 »
Phenomenal project, GLWIC :thumb:
Offline Bennettb
« Reply #3 on: Tue, 18 June 2024, 13:41:59 »
I love the USBs! Super cool project!
Offline DivinaPapaya
« Reply #4 on: Tue, 18 June 2024, 15:27:20 »
Looks amazing and damn the two usb ports are great, its the only thing I miss from the moment I stopped using normie mechanical boards. GLWIC
Offline HubertThemad
  • * St. Jude Supporter
« Reply #5 on: Tue, 18 June 2024, 22:20:41 »
Between Taiwanese James and UK James, I will be bankrupt. Great project!
Offline Rhienfo
  • Why is everything I want here so expensive :(
« Reply #6 on: Tue, 18 June 2024, 23:27:08 »
Beautiful design, alps support, usb ports Perfect  :thumb:
GLWIC, this is great.
« Last Edit: Wed, 19 June 2024, 01:30:53 by Rhienfo »
keyboard collection - fjell
cherry blacks - unlubed - filmed and springswapped with tx 55g mediums - alu Plate | pretty happy with this, the blacks were cherry picked so they weren't that scratchy to begin with, but currently breaking them in, may lube them with a dry lube like ro59 or ptfe powder.
| hhkb bt
lubed with tribosys 3203 | like topre a lot, prefer it lubed but did make less tactile but that might have been a skill issue. probably will get more tactile over time as the domes age.
| m0115
bad orange alps lol | definitely needs a restoration. planning on wax boiling them and maybe a replacement pcb because the board has only 2 key rollover apparently.
| praxis
gateron yellows - lubed with 205g0 - 62g tx mediums - pc plate | probably my favourite keyboard already, feels super nice and sounds pretty good, it's got a great layout as well. probably gonna build this with mx browns, I feel like it would suit the board more.
| camo filco
stock with silent reds | Pretty cool looking board, the silent reds are actually good, they are smooth and I don't mind the mushiness (it's not even that mushy as well). the layout is pretty weird, but is useable. will probably mod this in the future. maybe a pcb and plate swap, change the keycaps to something dolch like, and also spring swap the springs in the silent reds.
| ibm model f at
stock, needs a cleaning and probably replacement foam. Do plan to change layout so it has split bs and rs, as well as ansi enter.
| baebae tkl
Built with new nixies on pc half plate. Love this board already, probably the best looking board I own, those brass accents are so mint. Really like it as is, but I do want to try an alu build (probably with nixies as well) just to experiment with that.
collection in pixel art
Offline twitchytheinsideman
  • UWU UWU UWU UWU UWU UWU UWU UWU UWU UWU
    • Twitchy Homepage
« Reply #7 on: Wed, 19 June 2024, 06:51:56 »
GLWIC
Offline halfling_barista
« Reply #8 on: Wed, 19 June 2024, 10:43:17 »
This is one that has grown on me a ton. I initially wasn't big on the shape as a matter of personal preference, but looking at it further reveals a very cohesive design: the slightly flared bottom that travels down, the rounded profile from the top with a flat overhang, the maze weight counterbalancing the front foot, the plinth-like thick plate. Nice list of updates in the short time since the initial batch. I really like what James has come up with here.
Offline ylothar
  • Yo Ho Ho!
    • KEEB.it
« Reply #9 on: Wed, 19 June 2024, 16:02:29 »
it is truly a beautiful board, and the presence of a 2.0 hub makes it extremely convenient for a thousand uses.
It's just a shame that there is no ISO plate option. Will it be possible to have the file after GB? Or will there be vendors in Europe that will have the ISO plate as an option?
GLWIC
«How much wood could a woodchuck chuck if a woodchuck could chuck wood?»
Offline JQ27
« Reply #10 on: Thu, 20 June 2024, 03:25:56 »
GLWIC
From what I understand, the GB version of this has a universal thick plate instead of the fixed ANSI which was in the initial drop version.
Offline dmatx1
« Reply #11 on: Thu, 20 June 2024, 04:30:38 »
Yes, the thick plate will support ISO too in the group buy (it was ANSI-only in the in-stock drop).
Universal MX plate files for normal (1.5 mm thick) plates are already available, so you can cut plates from different materials than offered in the group buy.
Offline Cringelord
  • Crack Connoisseur
« Reply #12 on: Tue, 25 June 2024, 15:10:08 »
An actually weight that weighs alot, nice.
Re: [IC] Caerdroia by AKB (Now with added updates)
« Reply #13 on: Sat, 08 February 2025, 13:29:13 »
Big update time
  • Now targeting April 2025 for GB
  • Added changelog from the previous in-stock version to current
  • Updated board specs based on recent amendments
  • Cipulot has upgraded the USB hub from 2.0 to 3.0
  • Polling possible colorways in the IC form
  • Added EC compatibility image
  • Added a pretentious poem to help tell the lore of this board
  • Added photos showcasing the latest prototype (V2)
  • Decided to roll with a 4.5mm thick plate ONLY (for MX). It's part of the identity of this board now and I won't have it any other way.
« Last Edit: Sat, 08 February 2025, 13:37:20 by Alchemist Keyboards »
Offline TheManicGeek
  • The Manic Geek
    • Linktree
« Reply #14 on: Mon, 10 February 2025, 12:21:12 »
Looks like a board I could really get into, being in the PNW and all. GLWIC!
Offline snurrebassen
  • mechanical keyboard designer and enthusiast
    • Linktree
« Reply #15 on: Mon, 03 March 2025, 06:29:38 »
i cant wait to give you money :eek:
i've had severe case of fomo ever since i missed the first drop
« Reply #16 on: Tue, 04 March 2025, 06:20:51 »
Mini update time:
Still to come:
  • GB launch date (still on track for April '25)
  • Confirmed MSRP (it'll be sub-$450)
  • Final colour options, based on IC response (and some executive decisions from yours truly)
  • Regional vendor announcement
  • Content creator schedule
Offline Randomlosername
  • Gacha Done Got Me
    • IG
Re: [IC] Caerdroia by AKB (March 4th Update)
« Reply #17 on: Thu, 06 March 2025, 07:35:15 »
Man I wish I was more into TKL's bc the 2 USB 3.0 Passthrough ports are RAD.
« Reply #18 on: Mon, 10 March 2025, 13:22:38 »
Update time:
1) Confirmed GB details
Caerdroia will be launching on Friday, April 11th and the price will be starting at $420.
CannonKeys will be serving as the US vendor, and other regional vendors will be confirmed over the next couple of weeks.
Add-on costs will be confirmed soon, and posted when I launch the GB thread :thumb:
2) Colors have been decided.
Dolch
E-Beige
Verdant
Rubedo
If you're curious about seeing the prototype in action, check out this VOD from gymleadernathan's Stream.
Still to come:
  • Content creator schedule when possible
Offline ilikerustoo
Re: [IC] Caerdroia by AKB (Price and GB date announced!)
« Reply #19 on: Mon, 10 March 2025, 14:21:21 »
Cool
Offline pyrobunny
« Reply #20 on: Thu, 13 March 2025, 18:22:06 »
Beyond excited to see Verdant going through to group buy. One of the most exciting group buys this year for me!
Offline Petch
« Reply #21 on: Fri, 21 March 2025, 15:10:38 »
can anyone share more pictures of the Verdant colour please? I don't mind if it's from other layouts
« Reply #22 on: Wed, 26 March 2025, 09:21:05 »
The same colour was used on a Petrichor prototype shown here
